- Currie 12 bolt does anyone have them?
- Taking out the axle???
- ? about aluminum drive shaft
- 8.5" 10 bolt how strong?
- Anyone running a Nitrous Ready driveshaft from Denny's with a 10 bolt rear?
- 4.30 gears in a stock 10 bolt
- DS Loop help??
- Can i put ABS/TC on a rear without it?
- For those running an 8.8....
- Moser 9" from spool to posi question
- Who has a 12 bolt?
- Torsen T2-R improves traction everywhere
- Are there GENUINE GM 12-bolt gears?
- Those that have purchased a Denny's driveshaft, how long did it take to build?
- those w/ 12 bolts and a4?
- Clunking sound in rear...
- 3.73 question
- What did you pay to have your R&P installed?
- where can i get?
- Need quick help I'm doing my 9"
- 9" and torque arms questions
- Rear-end noise
- Few installed 9" pics..
- Anyone Break a 10bolt with 4.10's and Stock Clutch?
- Getting vibration at 100mph
- install info for Moser 9"
- overdrive question A4 nu-b
- Backlash reading or contact pattern?
- Setting pinion bearing pre-load
- Wheel hop?!?!?
- 3-channel/4-channel? difference
- differences/opinions on moser vs. Billingsley 9"
- How hard to instal a rear-end?
- Will my spohn torque arm fit a 9 inch?
- Will 9" fit without floorpan mods etc..
- 323's to 3.73's w/Vig 3200
- UV joints?
- need help to find out what rear gear my cars has.
- Sounds coming from the axel?
- Mysterious clunk sound when slowing down and moving from a stop, need help
- Some fancy new 9" parts - pics
- Who offers the 8.8 setup?
- anyone have 3.90's in a F-body?
- Does someone build 9" rearends on this board?
- A4 3.23 to 3.72 how much gain?
- 3.73's VS 4.10's
- Rear end newbie, help me out.
- 2000 Formula
- cheapest place for 12 bolt housing/axles?
- BEWARE to those with 4.10's/10-bolt!
- anyone need a 10bolt housing and axles.
- Budget 12 bolt?
- rear diff ?
- TCS rear on Non TCS car
- Just what will it take to break my stock 10-bolt using F1 tires?
- 98 Rear end noises
- 9" or 12 bolt! Need help by 11am EST
- Help Noisy Moser!!!
- Which differential?
- Moser 12bolt/BMR torque arm problems
- 1350 driveshaft to stock rearend? HELP!
- Just installed Strange 12 bolt need help.
- What is breaking in the 12 Bolt rears? And Why?
- yeah or nay? Aluminum 9" Center Section?
- Full spool on the street now and then?
- Help me decide what rpm to...
- Sweet 9" (pics)
- Gear install
- I've got a few hours to decide on which gear ratio
- Why not a 9"
- Quick Strength Question
- stock to 3.73
- From 3.23 to 3.73?
- wich gear should i leave the car in on the dyno
- Leaking stock rear end
- anyone has experience with G9 Diamond Trac-III or DPI's Black Gold Diffs for 8.8"/9"?
- Axle Width
- 2.73 to 3.73 help!
- 4 channel 12 bolt into 3 channel car?
- drive shaft length different W/ford 9" ?
- Spohn Adj. People inside
- Any "dead quiet" 12 bolts out there?
- Yet more 12 bolt questions
- I put in 3.73s in place of 3.23, speedo ?
- FYI-Strange 12 bolt Super Strength Posi's
- SLP opitions?
- i need longer studs
- do I need traction control, and ABS?
- Recommendations for a driveshaft please.
- 12 bolt setup part 2
- Zexel Torsen(sp?) or Paddle style???
- What Size Axles?
- A4 and 4.11's
- et and mph gains going from 3.42's to 4.30's
- 3.73 gears?
- Paging people with 3.73's in an M6
- help me to know my rear gear ratio
- quick question on my new rear diff
- Help me find this part please!
- Ways the rear breaks ....
- aluminum drive shaft vs steel
- The 4.10
- Where To Get A Torsen T2-R
- any one ever tried
- 12 bolt setup tips ?
- LPE Alum shaft. or other Suggestions
- Tough Decision; Strange 12 Bolt For $2350.00 or 8.8 For $2180.00
- Gas milage with new gears, for anyone that wondered
- 3.90 Gears
- Going to make some good changes on my 00 WS6
- Fastest anybody has gone with a 10 bolt?
- 8.8 questions...
- Poor opinion of Moser??? read this....
- What rpm at 65mph with 4.11's in a M6?
- Help with gear choice 3.73 or 3.90 in a A4
- How much time saved of qt mile with 3.73 gears?
- So that's why it was making noise...
- whats the length of a 12-bolt housing
- traction and new gears
- M6 bellhousing!!!LOOK AT...
- How to tell which seriers carrier
- Which brand 3.73 gears for my 2000 ws6?
- who here uses a TA stud kit?
- Could it be my pinion angle????
- Today learn a lesson!!!Important...
- Please Help!!! humming noise
- Will I run out of motor?
- What gears are the All Bores and Super Strokers running?
- rearend fluid on 2000 WS6
- What is the fastest someone has gone on a totally stock 10 bolt??
- any ideas on what i broke?
- stock ds
- nitto and rear end question.
- Series 3 carrier
- What gears with a TCI4400?
- 4.10's how much of a drop in et?
- Billingsley Nine Inch (pics inside)
- Gear ratio affect dyno #'s??
- Danm,another Alum. DS was gone!!
- Any of you guys have narrowed rear ends?
- Driveshaft material question
- Detroit Locker Question
- Who runs 4.10's in their A4?
- Noisier Rear; Moser or Strange?
- whats the difference...
- Stock Rear ends..
- stock rear fluid change??
- Switch to aluminum???
- Rear End Girdles
- rear end noise (marbles in a box)
- Is 2 drive shaft saftey loops neccesary?
- Anyone ever drop a Truck HD rear in an F-body?
- Stock u-joints won't fit?!
- 4.11 vs 3.42 mph issues?
- Anyone know the spline angle on stock diffs?
- Any way to beef up the stock rear?
- Ordering Moser 9" have Question
- Changing Gears From 3.23 To 3.73
- Rearend decision
- Quick Q: Axles with TCS and no TCS.....
- I'm a dumb a$$
- grind when taking off :(
- Instructions on adding a reluctor ring to 12 bolt.
- How much hp does a 9in Ford eat up ?
- Do our stock 10 bolts use c-clips for the axles?
- Easiest Rear to Install?
- I put a front E locker in my truck
- Help me choose a gear 4.10s or 4.30s?
- 4.11's These possible?
- richmond 3.73's...are they good?
- Is this right??
- Ford 9 inch with no rear abs?
- What gears and are they worth it!
- how long will stock rearend last
- Zexel Torsen "Heavy Duty" (T-2?) vs T-2R
- Are All Aftermarket Rears Louder Than Stock?
- 4.10 gears????? what do you think....
- Paint for new rear & drive shaft ?
- Question for all you Z-71 owners
- steal drive shaft on sale??!!
- Installing used, used, used gears
- Angles for pinion and tailshaft
- Brand of gears
- rear end cover bolts where do they go
- Leaky pinion seal
- who has the good deal on a steel d/s ????
- stock aluminum d/s limitations??
- odd vibrations at low speed, need help quickly
- Installing ARP Wheel studs
- Need some new ring gear bolts
- What is Stock Rear End Width?
- 12 bolt on a stock Z ?
- spool for 10 bolt?
- options to a 12 bolt
- gear install help
- Anyone Familiar with G-bodies?
- what gears w/pt4400
- DS Loop W/Mufflex Y
- Cheap 10 bolt gear ??'s
- how do you set pinion angle???
- how much abuse can the stock outshaft take
- U-Joint for Alum DS for Moser 12-bolt
- ? for people with 2.5" wheel studs
- do you gain or lose hp when changing gears
- Drive shafts?
- zexel torsen/Auburn High Torque rear differential
- What carrier unit comes with Moser 12 Bolt rears?
- 3.90's
- I Am Going Crazy!!
- 4.11 in stock 10 bolt
- How long do you think my rear will hold?
- Shops in My Area Say Stock 10 Bolt Can Be Beefed
- please help driveshaft???
- moser 12 -bolt
- how much fluid to fill a 12 bolt?
- Do i need????
- bmr torque arm
- Ordering a Rearend from Strange. Need Help Quick!!!!
- Moser 12 bolt owners with TCS or ASR
- who balances Aluminum drive shafts?
- moser with stock d/s
- So what's better for drag, IRS or solid?
- diff cover WTF!
- which is better 9" or 12 bolt?
- Dana 60
- 12 bolt moser install and lower shock mount
- Does a 12 bolt require a new driveshaft
- 3.90 gears now available for the Strange 12 bolt
- sounds like i have a supercharger. but i don't
- What's the deal with 8.8 rearend?
- One tire spin in burnout?
- Stock Gearing
- 4:10 Install In Stock Rear End
- DS safety loop
- Help! I've got 2 noises, Clunking from rear end and a whirring noise
- Axle spline question
- Abs Light???
- moser 12 bolt shock fix????
- breaking it in?
- rear end first timmer.
- Will 4:10s work in my stock rear?
- Need to install gears
- Silly Question about Rear Diffs . . .
- MAC torque arm installation???
- stock gear question
- Motive 3.73's
- 3.73 or 4.10?
- Long wheel studs with street tires??
- Driveshaft help!!!!
- Gear experts inside please! I have a broken pinion
