View Full Version : Gears & Axles
  1. another 10 bolt story
  2. what gears are best for 6speed for street/strip
  3. hp loss with alum DS vs. steel DS?
  4. no rear abs
  5. Traction control ?
  6. Concerned
  7. Noise!
  8. Where did you buy your Ford 9"
  9. rubbing sound on left turns?
  10. Cunfusion sets in...need help...
  11. Help!
  12. Bad Vibrations????
  13. Strange vs. Moser vs. Ford 9"
  14. Stock Differential
  15. Moser 9" users (question)
  16. To 4:30's, or not to 4:30's, THAT is the question
  17. Rear only whines during a burnout
  18. Rear sounds like a washing machine.....
  19. Rear Differential Question
  20. Moser 12bolt
  21. How hard it to replace the 10 bolt posi unit?
  22. N E 1 using the LG Rear End Girdle?
  23. Does anyone have a walk through for a rear end install??
  24. Oil up under rearend
  25. Differential Gurus in here...
  26. rearend measurements...
  27. What Rearend/Gears for my setup?
  28. What is the stock T/A gearing?
  29. Motive Gears 4.11 9x37 Teeth
  30. 9 inch
  31. which gears should I buy?
  32. how much streetability w/ 4.30 gears
  33. Need input on what gears to go with
  34. Rear end building 101 (10 bolt / 8.8)
  35. Drive shaft ...BOOM!!
  36. 71' 12 bolt fit in a 99' camaro?????
  37. Practical rpm Limit for Driveshaft?
  38. broke my mosher 12-bolt
  39. how do i tell what gears i have?
  40. trying to take out broken axle, need help
  41. I will never buy another set
  42. 4.10 gears = 1753 RPM or 3.73 gears = 1595 RPM @60mph????
  43. Mild steel or chrome moly for a driveshaft?
  44. new gears or not??
  45. What usually happens when a Torsen rear blows?
  46. Broke Wheel Stud on Moser 9", any tips for replacement?
  47. 4.71s in a 10bolt??
  48. moser 9 inch took it like a champ!
  49. Rear end swap write up????
  50. uh oh
  51. Welding spider gears with Torsen?
  52. converter 2.73 to 3.42 any tips
  53. If you had to do it over...
  54. Will this work for my car?
  55. If I bought this, exactly what else would I need?
  56. Moser makes clunk noise, what is it?
  57. need some rear end help asap!
  58. The 10 Bolt Worries
  59. moser noise help
  60. Car only spins one tire on a right-hand turn?
  61. Use additive with Torsen?
  62. I want a 3.73....
  63. Need advice on rear carrier swap
  64. whine, whine , whine
  65. Moser 12 bolt install
  66. what gear would you go with ?
  67. Anyone running a spool Street and strip.
  68. Moser clunk noise
  69. Questions about my rear diff and stuff :)
  70. Ive got 3:73, how much whine?
  71. STRONGEST gear set for a 10-bolt????
  72. 95 10 Bolt how do you get the reluctor wheel on the new diff
  73. Anyone else got a leaky rear end?
  74. is there a good rear-end with a diff that can make turns
  75. estimated whp loss with moser 12 and 4.11 gears?
  76. filling diff
  77. Bent torque arm bracket???
  78. Who wants a 12 Bolt
  79. Which Rearend, MOSER 12, Strange12, Ford 9?
  80. Money well spent
  81. It is worse then i thought!!!!
  82. What gears should I do?
  83. Anybody burn up 12 bolt posi
  84. Rearend Torque Specs.
  85. Differences in spool brands for my 12-bolt?
  86. Top speed w/ 3.73s
  87. anyone running the 8.8 ford rear??
  88. 4.10 max mph downshift points?
  89. What type of fluid should I use for my 10 bolt?
  90. 26 soline or 28 spline ?
  91. Strange noises
  92. Gear question, please help...
  93. right fluid for rear end?
  94. Where can I get Gm 3.73 or 4.11 for good price?
  95. Rear End Guru's come inside
  96. DAMN Moser to HELL!!!!!
  97. Stupid Question
  98. Will this work?
  99. Drain plug in diff cover
  100. ?? for you 9" owners,where do you find rebuild kits ,,,
  101. moser 12 bolt whine
  102. How to get ahold of Moser?
  103. .85 mm Play in rearend
  104. Pinion Angle ??????
  105. 95 Z28 LT1 - 82 9 bolt rearend.. problems?
  106. Anyone swap 9" center sections for street/strip??
  107. 3.73's..that is the question
  108. Mosier website?
  109. How many miles did I gain?
  110. why should i go from 2.73 to 3.42?
  111. 3.73 Ring and Pinion for 4 series spool
  112. ET streets and stock rearend?
  113. Drive Shaft Length for a 9-inch/m6 combo?
  114. Nodular Case for a 9-inch???
  115. Ring and pinions... C5's & F-Bodies interchangable?
  116. what did yall use for clamps on the sway bar for Moser 12?
  117. Swapping Rear Ends, have a question.
  118. ATTN: 12 bolt customers--Reluctor Rings/Backing Plates
  119. Need Posi for 10 bolt ASAP!!
  120. need new gears for my 12 bolt help
  121. need write up on removing gears !!ASAP...Tahoe!!
  122. Rear gears and dynos?
  123. Carrier ???
  124. Torsen or Auburn? whats better for 10bolt?
  125. HP needed to "pull" 6th w/ 4.10s?
  126. posi or mini spool?
  127. moser 12 is in but not abs or asr?
  128. How many quarts for 12 bolt?
  129. HELP!!!
  130. Is the old stock rear worth anything?
  131. moser 12 bolt vs. strange
  132. Weight of Dennys NR DS?
  133. gears for a moser 12-bolt
  134. 9'' fitment from 00 car to 95 - any problems?
  135. .moser 12 brake bracket mounting?
  136. Posi came apart who's fault?
  137. PLEASE HELP QUICK...WHO CARRIES A U JOINT FOR MOSE 12 BOLT
  138. What Posi Is This?
  139. Change posi to a lockar??
  140. Moser vs. 9"
  141. What exaclty do 3.73 gears do?
  142. Advice Please Guys Help
  143. Gears 2.73 to a 3.42??????
  144. What exactly is backlash and could this the Loud 2-1 clunk
  145. 4.10's in a stock rear?
  146. 4.10s just installed!!!
  147. moser 12 install...Q for ya
  148. Just ordered Moser 12 w/ 3.90 gears. Should I go w/ 4.11?
  149. Replacing Posi-clutch pack?!
  150. Is my ABS located on the axle or on top of the pumpkin?
  151. 3.73 or 4.10
  152. did i get the wrong axles from Moser? heres what i got...
  153. Gear Whine
  154. Clunking, is my rear gone?
  155. Another Moser 12 bolt install question
  156. 12 bolt install I am stuck!
  157. Limited Slip Differential
  158. How do I convert a LT1 12 bolt to work on my 2001 SS?
  159. Changing pinion seal w/o removing carrier, how to pull yoke
  160. Gear changing Question???????
  161. Anything i need to do special to install Moser 12bolt?
  162. 10 Bolt swatp: Need Quick Answer
  163. alum. driveshaft
  164. Want to put 8.8 in my Formula..anyone had experience or....
  165. WTB 12bolt or 9"
  166. Changing differential oil
  167. Torsen T2R.. questions
  168. which rear??????
  169. breather for 12 bolt
  170. BAD CLUNKING!!! Please advise
  171. 3.90 gears...RPM through Traps???
  172. WS6 with stock 3:73?
  173. Can u put a 3 channel in a 4 channel setup
  174. question on the 4:10 setup
  175. posi trac
  176. Dumb questions about LCA &rear end swap..
  177. Best way to quiet whining gears?
  178. 4 channel to 3 channel rear?
  179. Advice on ordering Strange 12-Bolt
  180. 3.73 to 3.42s -- big difference?
  181. What do I need for 12 bolt install?
  182. How far into tranny should driveshaft go?
  183. GM Gears? Randy's Ring and Pinion and DTS.
  184. What series carrier does Moser use?
  185. Strange 12 bolt sale ending soon!
  186. Anyone using ET streets with stock rear end ,m6 ,F-BODY
  187. Mosert 12 bolt Fluid question
  188. Beware of Ratech install kits
  189. How hard to change gears? and install kit question
  190. Did I mess up my grease change?
  191. do the brake backing plates need machined for a 12bolt?
  192. How much stronger does a TA girdle make a rear?
  193. 1500rpm in 6th = 58mph?
  194. Rear end/driveshaft slop question...
  195. Where to go for gear install in Chicagoland area?
  196. Who's using LPE's 3.5" aluminum drive shaft?
  197. How strong is the stoc driveshaft?You ET's please
  198. Final gear in 1/4 mile using 4.11 and stock SS wheels
  199. Install another stock converter and do gears? or no gears
  200. Help educate the new girl.
  201. solid pinion spacer?
  202. finally got my strange to shut up!
  203. Best 60' on 2.73 gears?
  204. how long will my 10 bolt last with 4:10's and E/T streets?
  205. Fully built 10 bolt
  206. ABS problem after gear install
  207. Moser 12 bolt installed
  208. precision gears?
  209. help me find gears for my TA
  210. Stud kit worthwhile on 10-bolt?
  211. has a yone broken a torsen differential?
  212. pinion seal screw up !?!
  213. SOME 1 PLEASE HELP
  214. who makes the best/quitest gears for the 10 bolt?
  215. Is this normal gear whine after 4.10 install?
  216. Anyone running an A3 with 4.30 gears?
  217. gonna order a rear...what all do i need to ask for?
  218. sensor connection problem with my 12-bolt???
  219. broken torsen differential
  220. Question on changing axle bearing.
  221. whos lost ET by going from10bolt to 12
  222. Ford 9 and torque arm compatibility
  223. Anybody running 30 spline axles in 12bolt &Few other Qs
  224. How much top end will i lose...
  225. OK i have my Converter.....time for New Gear.
  226. help for gears t56
  227. Ford 9" owners - question
  228. 80 mph vibration: help troubleshoot
  229. 9" in 3 channel (non traction controle) car?
  230. Can someone tell me how much RPM difference between
  231. PST Driveshafts
  232. which gears are best for highway racing/speed?
  233. Whats wrong with my rear end.(long)
  234. What is my STOCK GEAR 98 Camaro LS1
  235. chromemoly drive shaft
  236. OMFG!!! Waited four weeks for the wrong axles.
  237. Diff. leaking....
  238. Should i get gears??
  239. What's the GM part # for the Rearend Cover Gasket?
  240. To seal rear end: use gasket? RTV/gasket maker? Or both??
  241. bent axles what are the symptoms????
  242. Will a 6spd rear fit a auto?
  243. Best place to get a stock replacement axle
  244. Moser vs. Strange
  245. Gear swap, ABS comes on when near stopped now
  246. Posi carrier swap to non posi rear?
  247. What would the RWHP loss be with a 12 bolt 3.73....??
  248. Strange 12-Bolt disassembly and axel removal???
  249. What rearend should I buy
  250. GM gears
