- Can this be done?
- 12bolt is in,,, did some comparisons while I had the chance..
- Deep Trans Pan?? worth it? help any?
- PAGING HONDA TRANS FLUID USERS...
- C5 rears
- Why does my Spec III make a chirp noise on engagement
- New Transmission Slipping
- best deals on ss3600
- Ordered my Moser, one more ? before it gets here
- SLP Driveshaft loop
- Shift kits in 2002 SS's
- 3.73 GEARS/7.75 CARRIER?
- wierd tranny noises
- 3.73 gears/carrier size problem?
- shifter rattle
- Ram users with 980 disk...
- To Drll or not to Drill
- 3.90's for our cars??
- Hey Guys, Please Help, Wierd trans shifting problems!
- What type tranny is this?
- Moser or Strange. 12 Bolt or 9"
- Whining noise, please help
- TC Install Time?
- Any gains going from a 3.42 to a 3.73?
- factory driveshaft Q's.......
- stock ws6 rim key? how to get one if you dont have one
- What is this?
- Bent shiftfork?
- Will this Master work ???
- RAM VDS Question, need suggestions
- Transmission Problems
- Custom rear end gurus which...rear ends will work?
- First impressions of TCI CS4200 2.85 STR...
- Rear end experts please help.
- Amzoil Power Shift Trans Fluid
- 4.10s in a stock 10 bolt?
- What became of the Ford 8.8 in the f-body discussion?
- Does $2300+ for a rearend sound too steep to you too?
- Ram Master??
- output shaft isnt bent, i think?
- ADJ Master clyd
- tranny rebuilt vs. overhaul!
- spec stage 3 ?
- Stock Master Cylinder issue, hard to shift.
- Why would my tranny hit the rev limiter at WOT?
- Lost my wheel lock key
- FORD RULES!!!!
- need some advice?
- drill mod????
- Moser 9" question
- Were to buy Master with drill mod????
- Gear Compatability
- Worn rear end bearings??
- Is there any reason I would need a 400 over a 350?
- Swapping Posi for Spool ?
- anyone broke a 10 bolt?
- Which material?
- tailshaft is broken :(...updated
- Devil's Advocate
- which upgraded hydraulics?
- High STR ?
- Strange 12 Bolt Price
- Kudo's to RAM-10.16 with a 1.42 60'
- Another shift kit question TCI guys
- Gears
- Gasket # for 12 bolt diff. cover?
- Won't downshift into 2nd
- tranny messed up again, 0psi in 3rd?
- drill mod question?
- 02 Master and slave In a 98 Z???
- Why do I have a nipple?
- 4.30s or 4.56s?
- Rear end fluid change. What kind of fluid(s) and a "how to" document would be helpful
- B&M tranny?
- ABS,ABS inop, Ebrake lights are on
- Tranny Problems 2nd to 3rd at WOT
- Speed Inc tranny craps out in 2000miles!!
- Informtion on 4L65E HD transmission..
- What is the difference between LS1 and LT1 trans crossmember?
- Change 273's to 373's??
- external
- Info needed on Currie 12 bolt
- RAM 980
- th 400 in truck come inside please
- 4L65E?
- Tranny with a warranty help please
- Timken alxe bearing part number for Moser?
- 12 Bolt weight difference.
- Lockup Questions (Gurus needed)
- driveshaft safety loop on lowered car???
- 2004 GTO Drivetrain Photos!
- Transmission Problem Question
- Anyone think of running the aussie 9-bolt rear end?
- Polyurethane tranny mounts for autos?
- picked up my strange- questions
- Has anyone wrapped heat shielding around master cyl line?
- Vaccum Modulated/Comp Controlled
- TCI Convertor Install
- 12 bolt TQ arm bolt size?
- Find the perfect rear gear ratio easily
- I have THE loudest Moser rear ever!
- How reliable are Race prepped trannies?
- genuine gm ring and pinion
- master setting
- lockup problems...
- stock 10 bolt question
- Stock Rear End Question
- Good torque arm for Moser 12 bolt
- Vibration with new torque arm?
- Spohn TA and Moser 12 bolt = Problems
- Stronger Flexpalte Available?
- what rear end are you running
- Iron disc melted? Help me get it to un-melt!
- WTF? Bent Pinion??
- Shift kit with TCI 3500?
- I WANT A SCATTER SHEILD!!!!!!!
- Car goes CLUNK before it goes VROOOM
- moser 12 bolt rear end.. or is it!!!????
- GM long whl studs part # ??
- Blown Tranny???
- Unbelieveable tranny service
- 2.73 to 3.73
- 16 & 17" M/T ET Streets!!
- TCI SS3500 for daily driver/what times to expect?
- TCI Stall wont fit?
- 3000 TC into daily driver..any issues?
- Wheels Studs and U joint for 12 bolt
- TIG vs MIG welds on a chromoly driveshaft
- Post up if you want a LOCKER for your 12 bolt!!
- Colonel... looking for TC slippage data
- LINE LOCK AND SHORT THROW SHIFTER
- Ford 9 inch question
- Transmission Yoke Engagement
- 3rd gear lockup questions
- Just canceled order on a TCI SS3800....
- Help me figure out drivetrain problem
- Help me spec out a 9"
- synthetic fluid with eaton posi traction 12 bolt
- 400 rwhp on an A4.. will just a TCI shit kit help it last?
- Why no lockers for the 12bolt?
- Pinion Yoke Change
- Just ordered TCI's SS3800...
- What size carrier?!?
- Looking for a TC with some more punch for my TH400..
- what just happened...?
- Gear change
- Did BMR Control arm relocation brackets move your wheels back farther?
- Guys running 4.10's.. What driveshaft do you have?
- Ford 8.8 in a F-body???
- Is this the sign of a failing posi?
- transmission rear seal?
- 8.8 rearends info
- Will I need to paint my new Moser 12bolt?
- In search of new tranny
- Please help with gear selection for a 12 bolt ???
- 12 bolt vs 9"
- Help, Stumped on Rear end prob??
- 6 speed stuck in 4th in ss camaro
- lock up
- Alumunum Driveshaft. What to get? Help!
- Final story on poly trans mounts??
- B&M Shift???
- At what point do I need a 12 bolt?
- 8.8 Rear?
- Driveshaft loop?
- What can the lack of shift stops on the stock shifter cause?
- search inconclusive: Dennys NR shaft ?'s
- Help w/ trans- Tq. manangement or dying trans
- 3.23 or 3.73
- asr question.
- Which spool ??
- one wheel wonder
- Need Hel[p, I need a good Trans Shop!
- Shift kits TransGo vs TCI
- ring gear and cap bolt tq specs
- Vibration in rear
- Making your own Adjustable Master
- Need help with Wheel Stud selection!!!
- Better mileage with 3.73s than 3.42s?
- TCI 4400/Phoenix Pro: How does the looseness compare with Yanks and Vigs?
- ?'s about shift kits
- So how bad is a spool for daily driving?
- TQ Management
- Tranny or rearend?
- Ls1 edit - torque managment?
- A-4 REAR GEAR RECOMENDATIONS
- Paging Patrick G
- tranny rebuild
- If you Removed master cylinder or done Drill Mod Please Help
- Disappointed with the RAM 910 Disk
- what is wrong?
- 2/3 series Torsen diffs: is the center block the same?
- Rebuilt 10 Bolt problems?
- What is takes to get an F-body to do a wheelie :)
- Performance Built Transmissions Coming Soon...
- Need help with HAL shocks and 12 bolt
- what is this hose?....
- need serious help....quick!
- anybody else ever here of this Nascar gear trick?
- Shimming down transmission brace to change pinion angle?
- PLZ HELP. whats wrong???
- Questions regarding SPEC Stage 3 Carbon that came in Today.
- Ford 9inch rear end
- Lou's short stick
- which rear is Heavier 12bolt or 9in rear
- How many miles to break in Precision 3.73's?
- What is the STR for the 3600 Vig?
- A question about pushrods.
- HELP! Dyno graph included... (56k friendly)
- Changing rear end fluid...
- strange 12 bolt and stock tq arm?
- CF driveshafts: PST or ACPT ?
- 4.30's and 4.56's for Stock Rear
- Aluminum Driveshaft Help and Opinions!
- ARP TC bolts. Anyone using them??
- drill mod help needed quick
- 3rd gear problem with 6 speed
- Do I need the Billet yoke on the Denny's Nitrous ready shaft?
- Drill Mod Help
- Stock rear end Question?
- Tranny shifts in and out of OD at 68+mph???
- Edelbrock torq arm and mosier 12 bolt?
- ever had an axle bearing go bad on ya?
- repair
- is the tci streetfighter a 3500 stall
- gear change/ help
- Clicking sound comeing from rear under car
- Burning Smell
- Which one? 12 bolt or 9in?
- Best TCS convertor for max ET...
- Differential
- Does Anyone own a Cadillac CTS 5-speed???
- Any news yet on an SFI flex plate for the LS1?
- Can this work for me????????
- 2002 TA axle
- RAM 402/610 setup is awesome Thanks FMS
- how much for a driveshaft
- Efficiency and top-end pull: Yank vs. TCS
- Getting a 12 Bolt, what LCA brackets will work on my current 10 and the 12?
- HOW LONG SHOULD MY SPEC 3 CHATTER???
- 4:10's experiences
- Strange Gears?
- Need Measurements
- Where to get strange gears
- Could this be a broken motor mount?
- Could this be a broken motot mount?
- stock tranny question
- Quality of TCI products
- what does STR mean when people are talking about stalls?
- Driveline Noise....Need help
