View Full Version : Gears & Axles
- Tell me all you know about the ford 8.8 rear
- 3.42 gear install in houston
- Anyone know of the web site?
- Attempted to launch at 5200RPMs (nitto DRs) then spray still in 1st ON STOCK 10 BOLT!
- Measurments for Dennys Shaft
- rear end install question?
- 2000 a4 z-28
- axle bearings
- From 10 bolt to 12 bolt?
- Broke stock TA and 12 bolt housing. Any suggestions?
- Need info on 3.42s HELP!
- Two part ? about spools
- Where to get Superior Gears?
- gear ratio
- 1999 camaro SS rear end makes a grinding noise during decelleration
- gear guru's
- Where can i get 3.42 gears?
- Nine Inch Install - Cruise Control?
- Using gear oil "for posi", additive still needed?
- 12 bolt locker?
- What's my stock 10-bolt worth?
- How hard is it to install wheel studs?
- How come everything i touch gets f*cked up!?HELP
- Rear end whine? New gears?
- Need a new rear end
- another rear end decision
- No more SLP Torsen?
- Where to buy moser axles?
- Where can I get the stuff to check the footprint?
- What up with these 8.8 rears on Ebay.
- Changing gear oil, Which kind and How much?
- Moser gears
- Help ASAP. Swapping rear end
- 8.8 rear
- Driveshaft Length for Th400 to Moser 9"
- Well I finally did it!
- Race vs. Street Spool??
- rearend help please
- Ls1 10-bolt to Lt1 10-bolt please help me guys
- banging under hard acceleration
- moser 12 bolt reluctor ring not lining up with ABS sensor
- 3.73 guys with autos--- need help
- Driveshaft loop question
- Rear Axle problem?
- can i put a TCS rear end in a non TCS car?
- Question on gear install........
- stock gears on 01 T/A?
- Does anyone have 4:10s in a ten bolt and had them last?
- moser 12 bolt to ls1 from lt1 backing plate issue
- Driveshaft question
- moser 12 bolt and BMR lowering springs
- Tired of being scared of the 7.5!!!
- Gear questions?
- Heres my setup. What rear end should I go for: ford 8.8 rebuild or the moser/strange?
- Wheel Hopping 2002 SS
- broke the 12 bolt
- Should I even attempt to install gears?
- Moser 12 w/ Eaton posi...synthetic or non?
- 9" Install - Nine Inch is IN!!
- 9" is in...broke in ... and all is well so far.
- 3.42's or 3.73's??? Can't Decide!!!
- Are all Nine inches the same?
- Serious problem with Strange 4.10 gears
- what weight gear lube
- any1 with cf driveshaft come in!
- newbe 3.73's or 4.10's
- How far can I push it before it will break?
- How to break in new gears...A "how-to"
- Nine Inch Install - Brake Mounting Module(?)
- 9" Install Help U-Joint Install
- Backing plates how to get axles out
- bearings grease b4 or after
- Uh Ohhh!!...ONE more question
- HELP diff fluid change ASAP
- What all is needed for a 12bolt or 9" swap?
- How hard is it to get reluctor
- Help! Old rear out of car
- New Rear Is Loud!!
- Driveshaft Question
- 8.8 ford rear end would fit into f-body
- 2.73's Vs. 3.42's or Bigger
- posi
- Nine Inch - 9" Brake Backing Plate Install
- Pictures of differential oil after 50k miles
- Tooth count for 3 channel ABS reluctor
- Auburn vs Eaton Vs Ford tractech ?
- Not the typical "can my 10-bolt be built?" thread
- abs and 12 bolt
- Aluminum Spool
- How loud is a locker?
- Torque converter question
- Royal Purple weight.......
- Up Grading Gear's
- broken torque arm bracket
- Necessary to purchase a complete gear installation pkg?
- How much rear end fluid?
- Billingsley Racing 9" Street Package
- rear out of 88 chevy truck??
- what are my options?
- Can you run a TCS rear end in a non TCS car?
- banging after rearend install
- loud noise like a singing coming from my rear end
- what gears?
- going to spool, i broke my Full Locker, how much more RWHP?
- 9" rear + lowered car = ????
- rear end clank
- speedo calibration
- Moser 9" Refill Rate - Guesstimates
- 98 Z28 diff fluid changed, makes noises
- Is there an actual fact for this one???
- People with M6 w/Detroit Lockers Inside Please
- Rear End Click PLEASE HELP!
- 9" Install Question - Lower Control Arms?
- 9" Install Issue - Backing plates flip-flopped
- Oil on bottom of rear - Should I be scared
- 12 Bolt Internals?
- Broke an axle today at the track
- Moser 9" questions
- Do I have the correct 3.73 Richmond Gear?
- What is the best rear?
- whats the next weekest link?
- Changing the gear oil in my 02 Z06
- Billingsley racing
- What oil and how much to use in my moser 12 bolt??
- moser 12 bolt questions
- how many splines stock
- what to look for in used rearend
- Fuel Economy with new gears (3.42 up)
- 30 spline with spool what gears?
- WHAT OIL for my M6 rearend???
- Moser 9" Install Problem - Torque Arm Mount Bolts
- I dont know what gears I have after a4tom6 swap.
- 10 bolt - TCS vs. Non-TCS
- Loud Rear end.
- TR Complete Gear Package
- Couple of 12 bolt ????
- 2:73 better top end
- Gear Install Guide?
- Lakewood DS Loop not fitting..??
- Moser 9" Install - Help & Questions
- Does a 9" Detroit Locker need additive???
- Where to find good gear install instructions
- Moser 12 bolt making odd noise?
- Is my rear going?
- Guys w/ strange 4:10s in 10 bolt need your help.
- broken rear studs ..
- what do yall pay for a gear install??
- Rear End Fluid change
- rearend flush??
- Whats needed for 12 bolt install?
- M6 guys with stock gear + 4.10/4.11, have questions
- 390's, 410's, or 430's
- 12 bolt spool or 9" spool?
- New camaro owner, but questions on rearend
- 12 bolt moser.
- What gears go best with stock setup
- weight difference 9 inch vs 12 bolt?
- T-2R vs Auburn (& which Auburn?)
- gears 373 or 410
- Rear whine slow turn when hot
- 3.42 or 3.73???
- Weird Vibration
- Which driveshafts are you guys running?
- 8.8 or 9"?
- Which rear?
- Moser 9" Installed - Initial thoughts....
- How the f\/ck does this happen?
- Moser 9" arrives next week, what else will I need for the install?
- Help with Eaton carrier identification!
- what brankd gears??
- What gains going to 4.10s in a4?
- I feel sooo lucky!!!!!!!!!!
- et. change with 4.10's?
- Where to find torque values?
- Moser Rearend whine
- how hard to change out gears??
- do 4.11's actually make a bolt-on car faster?
- Can 10 bolt drums be put on a strange 12 bolt?
- are all backing plates the same?
- What kind of gas milage with 4.10's?
- 4 Channel & TCS to 3 Channel & No TCS
- Brake Line mounting plate - moser 12 bolt
- Moser 12 bolt hex drive bolt
- anybody here with 4:10s and tr 224 cam??
- Are 3.90's really more loud?
- 9" + Locker = Fluid Type & How Much?
- Strange 12 bolt from LT1 into an LS1??
- I broke two wheel studs...
- Help with bearing removal/install on carrier
- Ected
- Gear Ratios
- Torque Settings on Moser Install
- i dont know much about rearends.
- Whats Stock in 00 Ws6
- Diffs for the Moser 12 bolt: how are they different?
- Moser Questions - U-Joint, parking brakes
- Weird parts in Moser 12 bolt box
- Newbie Gear Question
- what size tires with 4.10's
- what do we have?
- C Clip Eliminators
- Where to get a replacement axle for cheap?
- Oem take out torsen diff.
- What are stock gears on 2000 WS6?
- new 12 bolt on the way
- tq converter
- guys running a spool come in
- Lt1 A4, 3:73 Or 4:10 ?
- keep my 323s or go with 373
- Who has done without ABS and TC in their rears?
- Who's blown up a standard posi in a strange 12 bolt?
- 3.73's vs LT headers
- 8.8 owners & Moser 12 bolt owners come inside!!!
- Rolling Coke Can niose from back end of my TA and GM can't seem to fix it!
- Damnit!!!
- how many track passes on 4.10's
- 3.73's
- Thinking about 4.10's(A4)
- Rear end poping noise..
- Part Numbers for Stock DS to 1350 Conversion
- Pics of broken driveshaft
- Can we get a sticky?
- Any info on torque specs for rearend?
- Need help with gear install!
- Vibration in rear???
- 8.8" pics
- To Clarify - ALL '99+ V8 Firebird Models have a Torsen Differential
- C-clip eliminators ?
- New 9" and weld on Lca's
- Pinion Angle for Moser 9"?
- 9" Rear pricing?
- little help with tire size please????
- [B]Strange 3.73's Humming??[/B]
- How can i tell if i have a 3 or 4 series carrier in my Moser?
- Who has ran a 1.50 or better with a Torsen?
- VIG 2800 and 3:73's?
- Installing Moser 12 bolt
- steel driveshaft
- No Torque Arm Setup - With ET Streets
- Anyone ever have this problem?
- 25-bolt rear-end ever created?
- Have 2.73 now -- what should I get?
- Ford 9' question.
- 3.73 or 4.10???
- Is my rear end going out?
- Has anyone ever been excited about getting 3.42s in their M6?
- shutter/chatter from the rear at low rpm!
- stud kit worth it?
- how many quarts w t/a cover
- Rearend Install...Odd Problem
