View Full Version : Gears & Axles
  1. Moser 9" 3.73 Howling
  2. thumper?
  3. really bad shutter problem....help??
  4. Posi or not???
  5. Please Help!
  6. Calling BLU11SECTA.
  7. 12 Bolt break in period
  8. Moser 12 bolt 1350 yoke Spicer U-joint???
  9. Moser 12 bolt 4ch fitting??
  10. 1st impressions of RAM 402/6130
  11. lowered car now rear is too far fwd..wtf
  12. Which gears for TCI Super Street Fighter?
  13. 99 HOE tranny problems
  14. TC AND GEARS?
  15. Need an Opinion Please
  16. all 10 bolts suck
  17. Tranny noise between shifts
  18. Help with gear setup?
  19. speedo troubles!
  20. Drill Mod ????????
  21. Anyone have a stock TQ arm mount.......
  22. BEST REAR??? Opinions PLEASE, good and bad.
  23. Gas pedal problem HELP!!!!!
  24. TC install Problems!!
  25. How to make stock master cylinder - Adjustable?
  26. General Question
  27. If you go between 1st & 3rd...
  28. TC 's and speedo readings
  29. Strange 12 bolt help!
  30. 4:10 gear noise
  31. Gear Recommendation: 421rwhp/400tq N/A 540hp/590tq N2o
  32. Anyone using the 8.5 inch 10 bolt rear?????
  33. LM Performance is selling the Qwik Stick
  34. what driveshaft are you guys running
  35. Broke my 12-Bolt!!!!!
  36. Rear End
  37. 3.90 gears
  38. Anyone know where I can find the line from the master to the slave.???
  39. Just ordered PT4000 - have a question...
  40. 1/2" studs with stock 16s
  41. My Pro-Stars won't fit up front w/ my new AutoZone brakes, why?
  42. Swapping the Gears in a 3.42 C5 carrier
  43. Broken wheel stud im a dumbass!
  44. 3.5" vs. 3" driveshaft...
  45. How good/bad is the stock rear end?
  46. Genuine GM 3.73's
  47. Does descreened MAF cause TC chatter?
  48. poping out of 5th
  49. How to us Spohn torque arm with moser 12 bolt
  50. Shake, Rattle, and Roll
  51. ST4000 vs TP4000
  52. Need unbiased info on using 3.90/4.10 in C5 CORVETTE..is it safe?
  53. Another TP4400 question...
  54. Cheapest place to get a modified stock adj m/c?
  55. need help
  56. Anyone here with TP4400 and 3.23s?
  57. Shifters??? what kind?
  58. What rearend do I have
  59. Paging *stick only* (MIKE)
  60. Master Cylinder Question? Question
  61. Which master/slave cylinders? 2000 car
  62. Wheel Rim Screws
  63. Noises in the drivetrain, take you best shot!
  64. Another gear ?
  65. TC or Gears?
  66. How can I make a lockup switch?
  67. STR differances????
  68. Which Rear end do i have?
  69. Thanks RT CAMARO SS
  70. Strange 12 bolt owners w/i
  71. Q about quick change rearend
  72. Red Line?
  73. Stock Length Studs ok with 15x3.5 Pro Stars and 5/16 Spacer??
  74. b&m shift plus question
  75. Gears without programing?
  76. 12 bolt or 9 inch
  77. My stock rear end has 3.73
  78. Bleeding the slave?
  79. Dont know what to do, very urgent!!!
  80. Anyone have torque strap info? Pics?
  81. What gear/trap RPM's wth 4.10's
  82. Drill Out Mod
  83. Web site for info and prices on VIG TC ??
  84. Lowest cost alternative to stock 10 bolt
  85. new car, need help
  86. Who's pinion seal leaks and just lives w/ it
  87. ?'s concerning gears and rearend
  88. NEED HELP- rear sway bar hitting 12bolt girdle
  89. Auto redlines....
  90. Gear? What do I do????
  91. Vig 3200 STR???
  92. Vig 3200 STR???
  93. Opinions/Recommendations for a Drive Shaft Safety Loop....
  94. Transmission and Gear Fluids?
  95. Diagnose my rear problem???? please?
  96. Is it worth going to 3.73s if you already have 3.42s
  97. Driveshaft Safety Loop
  98. 3:42????
  99. Project 200-4r autotrans transplant into F-body
  100. Those Who Need to Change Pinion Seal Or Changed it And Is Still Leaking---->
  101. T/C question, (i ask alot of them)
  102. Locking Convereter on the Gun?????
  103. Rear sway bar resting on Strange 12 Bolt
  104. How do I get the c-clips off the axles!!
  105. Time for a new tranny!
  106. 6 speed problem
  107. U-Joint! What size?
  108. Pt. 3 of Getting Nowhere.(Long)
  109. Removing Check ball?
  110. backup lights and neutral safty switch wires?
  111. do all 12 bolts make a "slight" clunking sound when turn VERY sharply
  112. SLP AUBURN POSI UNIT
  113. PLEASE HELP
  114. Need Trans Pan Deepened
  115. Cryogenics. . . what do you guys think?
  116. do I need a 12 bolt or will the 10 be fine?
  117. does it matter which brand of gears to buy?
  118. GM Techs or experienced LS1 mechanics in here.....
  119. What is the best gears for a auto?
  120. Those who ground rear calipers to fit 15's HEEEELP
  121. Just got a Hughes 3500 for practically free, need some advice.
  122. 2:73 to 3:42 worth it or not?
  123. What is the weapon of choice when it comes to a Moser 12 bolt?
  124. shift kit question
  125. TCI Racing Tranny Fluid
  126. 9" or 12 bolt and why....
  127. One more question about adjusting my LCA's and Torque arm. I need a little help
  128. Let’s talk about aftermarket TC lifespan...(kind of a poll)
  129. What is involved in changing pinion seal?
  130. Strange clunking sound when turning
  131. moser axles
  132. Gearing Question??
  133. need some input on what oil to use with rear gear?
  134. New gears, what else do i need?
  135. Information needed on Jay Fishers Stealth Arm
  136. Rear Weights??
  137. 4 link it???????????
  138. Whats up with my 60ft?
  139. 30 or 33 spline?
  140. WARRANTY
  141. 3.73's what should my rev limit MPH be in 3rd?
  142. 3.73?
  143. Not happy with 1LE mount
  144. RAM VDS people did you use the shims?
  145. Tranny build-up
  146. help! how to make metco lca's work with moser 12 bolt?
  147. need to disable reverse lockout code...same resistor as !CAGS?
  148. Gear question
  149. Just got 1LE tranmission mount
  150. Gear ratio ?
  151. u joint & yolk question
  152. 99 and lower slave cyllinder problems?
  153. Fluid
  154. what rear springs?
  155. Moser pressed on bearings vs c clips
  156. Best 12-bolt and where to buy it at the cheapest price?
  157. built tranny question...Hows this option?
  158. Aluminum Driveshaft ??
  159. Hotchkis Subframe Connectors - Installed!
  160. Dr. Tranny Instant Shutter Fix
  161. Got the P0757 error again(2-3 shift noid error) and what's lowest rpm for TC lockup?
  162. Vibrations
  163. What size STR in VIG 3600
  164. Drag Race Setup! What to use?
  165. Radius of Stock Tires
  166. Question with a 3 channel abs car and a 9'' rear end??
  167. Had Pinion Seal Replaced... Now Rear is Clinking!
  168. Switching from Vig3200 to YTP4200 and have some questions.
  169. True dual x-pipe or h-pipe sytem and torque arms
  170. TC Install...Help
  171. clicking noise in back end
  172. Found a 9 inch
  173. ZO6 rims and Bumpstops
  174. Cheap way out of a 12-bolt...
  175. Rear end bottoming out
  176. Calling the Colonel
  177. any one happen to have the 4l70 coversion instructions?
  178. TH 400 conversion
  179. hey guys problems with 10 bolt
  180. are they genuine gm gears??
  181. 12 Bolt Moser Question
  182. Gas tank clearance with 12 bolt - WTF???
  183. 02 Rear in 96
  184. Anyonw want to trade TP 4000 for ST 3500...
  185. From 2.73 to 3.42, what kind of mileage losses?
  186. TC for A3, which ones are being used?
  187. What Next?
  188. Help adjusting the torque arm
  189. Tranny Fluid???
  190. Jason 99 TA...Phoenix Injector ?'s
  191. Denny's or Carbon fiber DS
  192. Lou's Short Stick?
  193. ABS
  194. HELP! NEED spohn new style torque arm! what's this flow tech ta?
  195. Anyone's DS loop hitting the weight on the driveshaft
  196. 9" with 2" taken off each side!
  197. 97 rear in an 02?
  198. 1LE Trans Mount People quick question
  199. Cheese with that gear whine?
  200. A quick rearend question...
  201. What do yall think..Will My rear end Hold??
  202. Does anyone have a?
  203. Need tranny help please
  204. Twin disk roll call......
  205. posi rebuild kit???
  206. Remaining Adj. Master threads...
  207. Who's running a YTP4200?
  208. Torque Management?
  209. Can you make a 4 channel ABS 12-bolt work with 3 channel?
  210. Denny's driveshaft questions
  211. Does the stock torque arm have a bow to it?
  212. SLP Bolt In Subframe connectors
  213. Installing A TC Rear End in a NON-TC Car
  214. 12 bolt options
  215. 12 bolt
  216. Odd whistle noise from the rear...
  217. CRACKED my Moser 12 bolt housing
  218. TR224 and 4.30's ?
  219. Who has a Thruster Pro 4000? Whatcha Think?
  220. Odd high pitched noise .....
  221. Torque management experts, is this TM?
  222. can i get a measurement please???
  223. 3 Leaky Pinion Seals in 42K..Anybody Else?
  224. Rear sway bar Question...Off or ON??
  225. OPINIONS WANTED: ABOUT TO BUY GEARS.. WHICH BRAND AND WHAT RATIO?
  226. How much torque does it take to take the slop out of the pinion yoke?
  227. How to fix a Moser 12bolt leak at the end of the axle tubes?
  228. Torsen, which end is up on the c-clip retainer block??
  229. ARRGGHH!! Are ring gear bolts Righthand thread???
  230. What kind of combo would you use a UY6000 on
  231. Won't Shift Into 3rd At WOT Help!!
  232. STUCK... Where do I find the special bolts to hold the axles onto the rear (8 bolts)
  233. Looking for Kevin Winstead
  234. Is this a good price for a 12 Bolt?
  235. HPP3 shift firmness????
  236. TA that will fit with true duals?
  237. Ram 6130 did its job!
  238. Speedometer
  239. HELP Where is trans servo?
  240. HELP Where is trans servo?
  241. V6 rear springs
  242. what grade rear end fluid should I use for my Strange 12 bolt?
  243. Shifting problems 2nd and 5th
  244. my moser only spins one tire!!!
  245. 410 Gears?
  246. Anyone seen any write-ups for replacing the Torsen diff?
  247. shift kit
  248. Cracks in rear end housing
  249. Maybee low fluid was my problem.
  250. 2001 Trans Am posi???????
