View Full Version : Gears & Axles
  1. What Tires and Rims?
  2. PCM pin # for TC lock up switch (2002)
  3. Creaking Noise when rolling out at a stop light
  4. RWHP loss from 3.42 to 3.73s
  5. Maximum HPP+ 1-2 shift....+6 or +12 ?
  6. What Drive Shaft Loop Will Work With Macs?
  7. How much do 4.10's usually give over 3.42 "E.T and MPH"
  8. Damn Converer!!! Xploded after 1 day!! (long story!!)
  9. want to change auburn fluid myself.....need help
  10. Mac girdle VS. TA girdle? (ratech solid collar also)
  11. dyno pull questions???
  12. 1st gear "slipping", TM issue?
  13. moser or strange
  14. gear question
  15. New Moser Rear - HELP!
  16. Guys with PY3400 or PY3600 come in
  17. Where to buy shims, outside of a rear rebuild kit
  18. Tranny Problems helpppppppp
  19. a new gear question
  20. Torque Arm for 1.4 60ft?
  21. Has anyone's BMR Torque arm done this.....pics
  22. Part # for Gm 4.10 gears that will fit stock 7.5 bolt, anyone have?
  23. What controls lock up?
  24. Will 288 Slave be ok?
  25. Stuck in 4th
  26. Rev-Lok II, how do you like it?
  27. stock u joint??
  28. Rearend Life Span?
  29. WTF are my pinion & tranny seals leaking so soon after replacement???
  30. How to tell when slave/master is going?
  31. Definition of Master and Slave Cylinder?
  32. Gear Problem
  33. 1st post for me, need help/advise please.
  34. Paging Fireball (Brian)
  35. What TC when going to A3?
  36. Bad slave/TO bearing experience?
  37. SY 3500 works great!!!
  38. Drill bit size for "drill out mod"?
  39. Anyone know anything about Empire driveline driveshafts?
  40. Whats the deal with this?
  41. posi vs spool? help
  42. Moser 9" and ABS "only"???
  43. Anyone having problems with Moser 12 bolt and torque arm bolts?
  44. A simple way to a quieter diff. ........
  45. Locker for Moser 12 bolt?
  46. Gear swap and HP loss on dyno??
  47. No lockup in 3rd gear or higher! HELP :(
  48. Size of bolts for backing plates
  49. Rear-End question?
  50. Yukon Gears from Randys Ring and Pinion any good?
  51. Torque Arm questions...Help!
  52. My F@#*in tranny is broke AGAIN
  53. 4L70-Lock up in first gear
  54. Will a center section from a 78 malibu work?
  55. 30 or 33 spline axles?
  56. A3 swap-What is needed?
  57. Car is surging in OD
  58. What carrier size in Moser 12bolt?
  59. TP 4600 okay with 100 shot?
  60. SHIFTING POINTS???
  61. Trans braked 400 questions--->
  62. Has anyone ever changed the pinion gear seal in their diff?
  63. Do any of you actually feel that D is faster around town than OD?
  64. Noisy driveline?...
  65. How much will power change my TP4400 shift ext?
  66. Posi additive
  67. 7th REBUILD on TRANNY!! Need HELP PLEASE
  68. Any experience with National Drivetrain's Eliminator gears?
  69. Can driveline components cause misfires?
  70. Diff Fluid leak
  71. Weird problem last night....Help!
  72. Will 3.73s help??
  73. Scattered the Rearend again...
  74. Help!!
  75. Homemade Mastercylinder
  76. Torque Arm ?'s
  77. Why not 9" for a little more $$??
  78. Ah crap, did I blow up my transmission or what?
  79. Vibrations and clunks, need help.
  80. Thunder Racing Line loc button
  81. EATON posi or spool?
  82. Update on rear tranny seal:
  83. Drag CAGS question...
  84. What is needed to go from 2.73 to 3.42
  85. How much TQ and HP will the 12 bolt and 9" hold?
  86. ?? for ones in the know
  87. 4.10 and topend pull
  88. college coeds who like it rough...
  89. Best TC from a roll
  90. Pros and Cons of RAM sintered iron disk vs. 6130?
  91. Going Stage 4 Spec...any special break in procedures?
  92. Stock torque arm with moser 12 bolt?
  93. ST4000 and 3.73s?
  94. Another 4:10 question
  95. How to make poly trans mount act like stock?
  96. need to pull rear axles out, how hard is that to do ???
  97. Gears worn out???
  98. Weird squeaking noise coming from rear end only when I turn?
  99. Will this TRANSMISSION JACK WORK??
  100. What are my chances of snapping this...?
  101. What's the difference between a spool and posi?
  102. Tranny fluid leaking from some place...experts step inside...
  103. Hesitation? Broken Tranny Mount?
  104. 9" drive shaft
  105. I'm just not ment to get my car done!!!
  106. What are the chances of breaking a Moser 12-bolt out of the hole on spray?
  107. GM posi lube...Whats in it?
  108. Creative gear heads and/or hurst white ball owners wanted
  109. ACPT shaft-->Worth anything???
  110. please if you had this problem, help me out!
  111. mods for rear to hook up
  112. Vibration & Clunking Noise
  113. Cam and gear question
  114. TB400 with GV overdrive
  115. GEAR SELECTION PLEASE HELP ME
  116. Worth the switch to go from a 3600vig to a 4400PT??
  117. 3 gear not shifting right.........
  118. Anyone rebuilt Hust billet plus shifter?
  119. Gears????
  120. SWAPING REAR!!
  121. 1-2 shift slipping
  122. Trany wan't shift into 3 on spray
  123. Tire Height question
  124. Spec Stage 3 or what other?
  125. Tryin to learn about TC's
  126. Do i have the 1st stage sign of a rear going???
  127. Rearend poppin like corn?
  128. Neutral safety switch/ help
  129. A Question for those who have upgraded to 4.10 gears
  130. Stock Rear End Swap / Need Help, Advise Please...
  131. Should my tranny be slipping already??!!
  132. Cheap speedo fix??
  133. Anyone with an opinion of Shifters?
  134. Question about torque management...
  135. Bad Vibrations?
  136. will someone @#! answer my question?
  137. Just broke my 3rd tranny.
  138. rearend noise
  139. 9" and 12 bolt?
  140. Lockup characteristics of PYE 4000
  141. SPEED INC'S TRANS
  142. I Need a Good Trans and Rear Shop In Chicago
  143. Well, I went ahead and did it!
  144. PT4400 is in...DAYUM!
  145. Efficiency with a TP4400?
  146. Big TCs + Big TQ = broken tailshaft housing!
  147. 4L70 Reverse pattern-What shifter?
  148. New Strange posi unit junk before 300 miles
  149. Do you think PY3400EXTREME cool for Blown 427?
  150. Getting a new rear. Want to retain ABS and traction control ...
  151. Anyone running a locker w/ a 6speed?
  152. Source for rear end bearing kits?
  153. Need advice on building a fast daily driver.
  154. What can I expect from 4.10's?
  155. reaar axles
  156. question on our 12bolts
  157. P0502 DTC after first run...
  158. I really need these 2 measurements from this Denny's Driveshafts diagram
  159. SLP linelock problem
  160. mph to rpm/
  161. how much diff. from a roll...
  162. LCA Angle?
  163. 3.42 vs 3.73
  164. Rear Axle
  165. Tranny shift firmness increased w/0 shift kit or hpp3?
  166. Need some Trans explanations
  167. Anyone have stock driveshaft dimensions handy?
  168. Strange noises coming from raer suspension
  169. Paging the guy with 4L70 tranny trouble
  170. Has anyone ever broken a Denny's HD Aluminum DS?
  171. is this tranny combo possible?
  172. Clunking noise??
  173. Speedo recalabration using HPP on 1999s
  174. Stuck in 2nd Gear after 400 swap, won't start
  175. sometimes 2nd bogs?
  176. People that run 28" X 10.5 slick need advice please.
  177. Broke my DS on the DYNO! Anyone have Denny's 'Nitrous ready' driveshaft measurements?
  178. what year did they stop putting the 7.5 rear in the f-bodys
  179. Custom driveshaft loop?
  180. Vig 2800: Best TC for daily driver?
  181. ATTENTION ALL PHOENIX MEMBERS!!!
  182. Drive shaft loop questions?
  183. Bad noise coming from tranny...
  184. Clicking/banging noise when turning! (MOSER)
  185. tranny not shifting?
  186. rear girdle starts leaking after 15k miles
  187. What A B!tch!!!!
  188. TC Slippage & MPH/RPM Q?
  189. tranny deasnīt shift at WOT, need help again!
  190. Best way to use Adj. PHR
  191. Went slower with TC???
  192. recommend driveshaft?
  193. Stock PCM and Lock Up Feature
  194. pics please of spohn torque arm
  195. Help me upgrade my drivetrain...
  196. RR airbag psi for street?
  197. after hals tire hits wheel well sometimes settings?
  198. Who has broken there 10 bolt?
  199. How Much HP Lost with 12 bolt and Chrome Moly Drive Shaft? How Bout None!
  200. Pinion angle?
  201. Upgrade rear swaybar but not the front OK?
  202. I Need New Gears - Opinions Needed
  203. 2.73 to 3.73
  204. BIG PROBLEMS WITH SUSPENSION GEOMETRY--->HELP!!!!
  205. Pic of launch with YTP4000
  206. Driveshaft
  207. Ultimate Rear End Cover???
  208. I NEED TO GET MY TRANNY BUILT
  209. What does a shift kit do?
  210. Part number for 1350 to stock DS?
  211. Will front/rear springs from a '96 Camaro fit my 2002?
  212. paid +$100 for moser to add 4chan abs>>>
  213. Quick lockup switch question
  214. wheel hop problem....need help
  215. carbon fiber driveshaft ?
  216. Tips / Tricks bleeding the master cylinder
  217. spool what oil?
  218. Chances of breaking a Moser 12-bolt....
  219. how much is my speedo off now ? 2.73's to 3.42's?
  220. best sway bar WITH mounts for moser 12 bolt?
  221. What's the best launch for a YTP4000?
  222. Anyone have a wire diagram for a LU switch???
  223. 12bolt with 1350 yoke + CF driveshaft = spicer 460X ujoint.
  224. ok to go without rear swaybar?
  225. Trans is out. Everything appears normal??
  226. Drive Shaft Question
  227. just use the gasket?
  228. Will and LT1 rearend fit in an LS1?
  229. GM posi additive or not?
  230. How do I remove my stock U joint
  231. Trans Problems need help
  232. HELP moser 12 bolt/eton posi need gm additive?
  233. ST3200 and 2.73s?
  234. Will 3rd Gen 9" housing fit in 4th Gen?
  235. Dyno'd HP loss 3.42 -> 4.10
  236. What U-Joint with stock driveshaft and Moser 9"
  237. wow . . . too many parts and no TV in the garage
  238. 85w140 rear end dope...........Opinions?
  239. Is the sy 4000 nitrous friendly?
  240. moser 12 bolt/use which u joint/which oil/how much
  241. TCI Streetfighter info...
  242. Knock Sensor and U-Joint??
  243. Paging Ragtop!
  244. Your gear of choice?
  245. Rear End Questions?
  246. Poll: Richmond vs Superior
  247. 9 inch vs 12 bolt pros & cons
  248. convince me to buy...
  249. tp-4400 vs. #7 pump showdown!
  250. Paging LS1Lover
