View Full Version : Gears & Axles
  1. Confused about 1LE part numbers, 1LE sway bar owners please read
  2. Adjustable LCA's Question
  3. Help! ABS InOP light won't go off after Dyno!
  4. Question about Eibach ProKit
  5. Squeaking noise
  6. 12 bolt question...
  7. Which DS Loop will fit?
  8. shifter b&m or hurst?
  9. TH-400 and the Gear Vendor's OD unit...
  10. NEED HELP with JFP dual adj Pan Hard Bar!!!!!
  11. how hard is it to warp your rotors?
  12. Vigilante 2800 TC -> LS1 flexplate mounting holes mismatch
  13. Tubular Front Suspension Arm Upgrade
  14. Experiences with a PI3600....Lucky #7??
  15. Why no Dana or Tera?
  16. 3rd gear syncro took a crap again I think
  17. Is this normal? (transmission)
  18. SFC's on
  19. tranny problems
  20. syncors? or what?
  21. rear spring question
  22. Ptrick G and the Colonel
  23. Does yours Moser 12 bolt posi chatter alot making turns?
  24. Transmission Fluid?????
  25. Paging Colonel... Transbrake ? inside
  26. HELP! I think my star stage III just bit the bullet!
  27. Anyone buy an HPM Strut tower brace? Mine doesnt fit
  28. Day 6 of no CAR :mad:
  29. Ok, Whats the perfect donor 8.5" rear?
  30. Brake questions
  31. Hal struts w/ stock springs installed!
  32. F-Body Rear Lower Control Arms
  33. Need help problem with shifting me or car?
  34. After 2 launches at the track.... I got louder whine on the 4.10's
  35. Brake Rotor Cryogenic Treatment
  36. Kevlar-Graphite Brake Pad
  37. Where can i get MOTUL 5.1 Brake fluid or better online?
  38. Weight of stock a-arms (lower)
  39. I need a good trans place in Chicago?
  40. Can I buy just rear end backing plates?
  41. moser 12 bolt order questions
  42. How much brake fluid does our cars hold??
  43. Wolfe Race Craft Sway Bar help needed.
  44. How important are Subframe connectors?
  45. SUBFRAME CONN. QUESTION!!!
  46. Car is riding rough after suspension mods, need some help..
  47. Star Stage III is in and ready for the track
  48. question for Patrick G.
  49. Hals vs front runners?
  50. Hitting rev!!!!!!!
  51. changing gears
  52. Crappy Stock Rotors
  53. Changing to 3.73s - What's needed?
  54. RPO code for high performance diff.
  55. How to tell if tranny is slipping?
  56. Shift extension differences
  57. Why do steeper gears sap power..???/
  58. ¿Warped Rotars?
  59. Anyone ever had an aftermarket Bilstein go bad??
  60. Granetelli SFC's?? Opinions??
  61. serious m-6 12 bolt guys inside
  62. What all could I have Broken???
  63. Too much gear or just enough?
  64. Anyone else ever have this trans. problem?
  65. What is the benefit of using V6 springs on an LS1?
  66. ABS INOP and LOW TRAC light on permanently? Help!
  67. OMG...These 4.71 gears are downright IGNORANT
  68. Tranny fluid questions
  69. what is torque management?
  70. I need your help guys...
  71. Loctite: yea or nay on drive shaft bolts?
  72. Best place to buy posi for 10bolt?
  73. Paging Colonel
  74. Rear Air bag?
  75. Jeg's Drive Shaft Loop!!!!!
  76. 3rd gen rear end swap??
  77. Is my posi gone?
  78. Ground effects with lowering springs?
  79. yea or na on posi lube???
  80. Street manners of Vig 2800
  81. "Softest" lowering spring???
  82. why me ?
  83. Rear gear sanity check
  84. Radio Shack Cheap Fix for Skip Shift?
  85. TCI conv.
  86. Brake gurus, please answer ???
  87. Competition Engineering
  88. Is it possible to get a complete ready to bolt in 12 bolt or 9"?
  89. Just did drill Mod have some questions...
  90. Ram feels like stock
  91. help please !!!! lowering car and do not know which way to go!!!!!!!!!!!!!!!!!!!!!!!!
  92. SUBFRAMES
  93. Front end alignment needed after front shock replacement?
  94. Noise in left rear when shifting
  95. tcs/abs need help
  96. 26x11.5x16 slicks too wide for a 16x8 rim??? Will it cup???
  97. Any write up's on tranny fluid & filter change??
  98. Posi unit and which fluid to use
  99. Hearing noises in my rear again..
  100. Best prices on ET streets?
  101. Gear Oil - What to use for noise!?
  102. Spherical Rod ENds
  103. 12 Bolt Setup. Is this the Cheapest i could do it?
  104. Stock driveshaft on a 2001 Z28??
  105. At what 60' do you start pulling a tire?
  106. Brakes are squeaky even when not applied?
  107. whats "better" about the new slave
  108. how much longer does my 10 bolt have?
  109. ok since no one on LS1.com will help me
  110. Synthetic transmission fluid?
  111. Will LCA's be enough????
  112. Ground Control Coil-Overs....
  113. Jeg's Drive shaft loop part #
  114. Rotors for the front, which ones?? mine are shaking like crazy
  115. Pics of RAm 402/6130
  116. How to get rid of wheel hop????
  117. 12 Bolt Is Dead, Opinions & Gearing Help Needed
  118. Upper Panhard Bar??
  119. rear end ?
  120. which setup would give my tranny less abuse?
  121. 3:73 or 4:10 Rear Gear???
  122. Help! Does a Camaro and a Formula have the same.....
  123. My Moser 12 bolt rocks!!!!
  124. Who has the best 60' on a stock style suspension?
  125. *SIGH* - Pinion Angle Question Again
  126. GU2 vs GU5..Need answer quick ..please
  127. what's the difference in the 288 and 145 slaves?
  128. Broke my driveshaft last night...
  129. Drill mod problem
  130. My car is hitting rev limiter, what could it be?
  131. ET Streets on lowered car?
  132. OK need Ram Part # numbers
  133. shake through driveline. HELP!!!!
  134. Which gears are the quietest in your opinion?
  135. Goin' with the 4:10's......
  136. Quick opinion
  137. Harlan and other RAM users
  138. Aftermarket wheels
  139. need opinions on B.F. Goodrich Comp TA ZR's
  140. Which torque arm should I go with??
  141. Driveshaft making a whining noise??
  142. Jumpy console on hard shifts...
  143. Anyone get a HAL shock rebuilt by QA1?
  144. Hey Damien..still have noise
  145. Dry Weight of a 10 bolt???
  146. Is it possible to put too much oil in your rear end?????
  147. anyone fab'ed custom sfc?
  148. How bad is the clearance?
  149. Hitting rev on N20!!!!!! HELP!!!!!!!!
  150. Shift kit with Fastchips tuning?
  151. Madman torque arm?
  152. driveshaft length?
  153. What would hook better, 275-40-17 F1's or 235-60-15 BFG Drags?
  154. Wheelhop!!!
  155. Long wheel bolt sizes?
  156. Need wheels to mount drag radials
  157. Bridgestone Potenza RE730s...whatta ya think?
  158. 9 Trannys not sure what to do. Help
  159. What are some signs that my posi is going out??
  160. tranny problems
  161. PLEASE HELP!!!! Dealership Tranny Dilemma.....please come in
  162. banging in rear end
  163. In simple terms what is LOOSE in a TC!!!!
  164. what size carrier
  165. ** Driveshaft Diameters **
  166. Tools needed for gear swap?
  167. Which gears with a PT4400?
  168. Valvoline or Royal Purple 12 bolt rear end fluid...narrowed it down...opinions??
  169. New BIG brakes ordered today.. :)
  170. How much HP gain with CF driveshaft?
  171. What to expect???
  172. Can you Recommend a Rear Gear Size
  173. Which shift kit should I buy for my 99 T/A
  174. tire height question
  175. While the trans is out...
  176. Syncro's question?
  177. Deep Transmission Pans
  178. 4:10's and the TA cover stud+girdle kit....
  179. any probs with TP4400 on daily driver
  180. 12bolt & 9 inch question
  181. 8.8 rear end swap
  182. If the differential is bad, would it...
  183. Gun drilling axles?
  184. Moser or Strange (long but worthwhile story)
  185. Problem with Relocation Brackets
  186. Subframe Connectors
  187. Anyone have info on Lightweight STREETABLE front brake kit?
  188. car wont hold load in any gear. please help
  189. car wont hold load in any gear. please look within
  190. Where can I find transaxle info?
  191. What?
  192. Everybody with a 12 bolt please read.
  193. Does lowering only 1" change suspension geometry?
  194. carrier bearing removal?
  195. Need Help Quick! BMR Adjustable Torque Arm
  196. What fluid and additive in the rear?
  197. Need a quick answer about brake caliper bracket bolts!
  198. what's the best aftermarket shifter for the 6 speeds
  199. What point do I monitor for line PSI on ATAP?
  200. what's the best aftermarket shifter for the 6 speeds
  201. Front LCA replacement??
  202. What kind of rotors should I get??
  203. Anyone using the Jegs Torque Arm?
  204. Good tranny info:
  205. 4.71s are here....most likely going in this weekend
  206. ok should I change gears or not? help me decide..
  207. 1310 yoke and spicer 5-625x u joint for Moser
  208. Moser 1350 yoke 12 bolt stock driveshaft.
  209. Torque Arm Location
  210. Will 285's fit on 17x9 ZR1's?
  211. stock maf ends
  212. *****ATTENTION Hal/QA1 shock owners******
  213. Nyone hear Pop this code?? (C0055) from Tech II..help!
  214. anybody have there input shaft bearing go bad on the 6 speed? help
  215. Help me with lowering car and drag racing
  216. stock gears???
  217. Master Cylinder help!
  218. Best TC for 98?
  219. poly trans mount vs wheelhop, results
  220. Trans Flush?
  221. TH-400 with G.V. overdrive?
  222. Suspension help!
  223. Anyone running 285s on the back and 275s on the front?
  224. Chassis twist...?
  225. Recommends on SFCs and STB
  226. SES Light
  227. Quick question on footbraking a TP4400
  228. Convince me to get rid of my 2.73's!
  229. Eichbach or Hotchkis Springs? Need advice
  230. going from 3.23's to 4.56's?!?!
  231. Welding SFC's
  232. HELP!!! I have no clue what rear end fluid to use!!!
  233. Why not use old rear with stock brackets?? Please advise..
  234. Hittin limiter, Why cant I manually shift???
  235. 4.10 gears
  236. Best first suspension mod?
  237. ARE Kmember VS PA Kmember any differance??
  238. What springs to get?
  239. *********Pageing PartickG***********
  240. PT2400 vs. PT2900
  241. ? about v6 springs
  242. Anyone know the best str???
  243. PICTURES - Chrome Lug Nuts - GM 12-Bolt Studs
  244. which gears? help!
  245. Pro's and Con's of welding the torque arm to the rear?
  246. My drivetrain saga of 2001
  247. Whats needed to get rid of ABS?
  248. bad pinion seal??
  249. Paging Chris ARE 360
  250. Will the drill out mod help 1st gear engagement?
