View Full Version : Suspension & Brakes
- Heard of "Sprint" springs?
- What do you guys think about these brakes?
- brakes fell mushy
- panhard bar, adjustable or non adjustable?
- SSBC Tripower Caliper and Rotor Kit
- Replacement upper control arms for street use
- Stock springs and shocks limit?
- Pre-Heat treating new rotors???
- Tokico HP Suspension Kit
- Sway Bar ???????
- Slits and crossdrilling DIY ??
- Roll Cage Issue
- Questions about replacing brake lines
- Sway bar question
- line loc. SJM vs Hurst
- Cracking rotors...
- Suspension Suggestions
- Trak Link is on! Pics inside...
- Spohn Sway bar kit. Bushings Don't Fit
- where to buy a Turn One PS pump?
- wheel hop ??
- John Ames Springs and Konis
- TT2's+Baer kit?
- general drum brake help?!
- What next
- Does this rear have backing plates?
- relocation brackets or hose mod?
- My stock suspension car walks to teh right when i get on it
- Lowering springs just for the front?
- Spohn bolt in adjustable ds loop
- Why does my rear want to kick to the side when shifting gears?
- Which Rotors?
- Cryogenicly treated rotors?
- Who has the lowest price on Baer rotors ??
- Diamond Slotted Cut Rotors?
- Torque arm bushing
- Are Hotchkiss products good?
- okay to use bilstein hd replacements for DCarbons
- Rubbing issues
- bmr k member and a arm questions
- A-arms with spherical ends or polyurethane bushings?
- I need Part # for front set of Koni's for 1" lowered TA
- New Shocks
- Bilstein Shock Part Number Help
- Noise when turning right at low speeds?
- Bleeding LS1 brakes
- anyone use rod end dust seals?
- SFC STS question
- Best Price Brake Upgrade?
- Installing new springs/shocks
- anyone have pics of NBM trans am w/ red calipers??
- just painted my calipers
- Brembo Big Brake Kit Problem.....
- LCAs are squeeking every time i take off(even slowly)
- qa1's- what a difference
- Discount Tire WTF!
- New Koni's on the Rear
- quick brake caliper question
- buying crossmember T/A, questions PLEASE
- loose rotors?
- for those familar with rod ends
- any pics with rear hose mod?
- Will this torue arm help me?
- New vibration thread
- HAL Spring rate? (or G2's?)
- Front air bag question...
- torque arm...
- need lift in the rear, help?
- Drag suspension guys come plz!
- Why so many more Koni/Bilstein than HALs?
- kyb agx or kyb gas-adjust
- Should I have gone Chassis Mount TQ arm?
- Eibach Pro Kit to Hal shocks?
- Bilstein Shocks
- How the hell do I get this nut off!!
- lowering vehicle
- Camaro to Magnasteer
- K-Member Sneak Peek Pictures Released!
- Who have K-member? Or know some info…ENTER
- Caliper Bracket Issues
- improving the 60
- Finally installed my Panhard rod, found Stocker was bent!
- How do you guys like the Spohn TA?
- need bolt size for torque arm to tranny mount
- What the hell is creaking?
- Squeeking Brakes Part2 - NEWBIE
- Aligment spec's
- Bad torque arm causing "clunk"?
- Which sponsers sell solo bleeders?
- Torque Arm, RCB, and PHB
- Bilstein, Hotchkis, and WS6, Oh my!
- Car shakes after 65 mph do I need an Alignment?
- Bendix Rotors
- at what point do i need a aftermarket torque arm?
- Will a torque arm with a relocation bracket fit w/ my custom true duals?
- Help me identify this
- Torque upper shock bolts?
- what shocks to go with g2 super springs?
- Wheel Hop
- steering
- Wilwood
- Handling Problem after Relocation Brackets install
- New Product Release- Torque Arm Relocation Kit
- sjm help?
- another line lock question..
- quick brake question
- Electronic Brake Control Module
- squeeking brakes
- Looking for good drag/street shocks/springs. Any ideas?
- I lost against my friends mom's Accord because of traction issues!!
- Wierd noises from SLP subframes or DS loop
- Upper A arm swap good idea? Adj non adj?
- Want to replace entire brake system
- Are there better Rod Ends out there for UMI LCAs?
- Cant kill wheel hop...help!!
- SUSPENSION SYSTEM SPECIAL RIDE & HANDLING
- steering wheel question
- trimming bump stops
- Painting brake calipers.
- Does Alignment affect gas mileage?
- Brake grease questions
- 4 Channel Brake Bleeding and DOT 4
- Picked up..
- LCA Installation...can I pull the wheels off?
- Does anyone know what size
- Symptoms Of Bad Shocks?
- New brake pads
- Rear springs loose?
- broken torque arm
- panhard rod and LCA bracket help needed
- Is it OK to drive without any sway bars?
- UMI tubular subframe connector...
- Problem with Kumho v710
- Lowered Cars & Drag racing
- what is better slotted drilled or both?
- Next mods...suspension. Where do I start??
- Dot 5 Fluid With Abs
- Koni's - where to start?
- What are the BEST non/crossdrilled, slotted rotor replacements?
- slotted and drilled rotors on ebay
- whats the difference and how does it work?
- DMS springs?
- Koni SA/DA and Install question
- QA1's & Eibach Sportline Help
- Drilled/Slotted Rotors/Hawk Pad Install. ?
- Need an answer to a stupid question
- Sway Bar Help
- Need help finding shocks/springs that can balance handling/strip
- Torque Arm and X pipe?
- Weight Distribution???
- c5 brakes on f body
- am i just paranoid?
- New UMI adj. torque arm installed
- Help with SFC install
- Aftermarket springs/spring cup question
- Best shocks for drag racing?
- What angle on pinion???
- FS:::BMR front lowering springs
- do i have to do anything before putting springs on?
- New Rotors; New Annoying Sounds
- Need help figuring out which front sway bar is on my car
- Hal shocks: F series vs. R series, differences?
- Lightweight Steering knuckles need to lighten the load
- Boxed or Tubular SFC's?
- Springs with Koni SA for Street/Strip
- Another rotor question
- Installing Bilsteins...need a little help
- LS1 to LT1 brakes
- Relocation brackets???
- Front hub removal
- any pic's of koni's sa or da?
- Spohn vs Hotchkis Sway Bars
- Does anyone have a pic of a moser 9" with a UMI TA?
- ahhh f#*&ing brakes
- abs and a line lock??
- Suspension gurus come in
- Adding poly swaybar bushings help anything?
- ws6 vs. zo6.. ride quality.
- Camaro/Trans Am stock springs?
- Camaro's only Let me see pictures of you camaro
- HELP geting Caster Bolt out for front LCA's
- TA"S ONLY!!!!! let me see pics of your cars with Eibach Prokits
- quick swaybar help
- abs inop and low trac light help!!!
- best subframe connectors? strongest?
- Which torque arm is best for me??
- Nice Brake Upgrade from Stock?
- Koni SA users: how's the ride like at full soft with the factory springs?
- LCA relo brackets???
- SFC help please.
- Bilstein HD'S
- Shocks for a Daily Driver
- Wolfe Travel limiters???
- caliper rebuild kit
- Budget Suspension Upgrade with Pics
- Great set up for fast street only car?
- Billet strut tower brace?
- Koni, Koni, Koni
- Drag Launch Springs or keep Stocks?
- What oil does Koni use in their shocks?
- What's Next?
- bmr sfc004 tubular questions
- Rotor & Pad Question
- Help me please (which kit)
- Camaro pics w/DMS springs, pls..
- Can get brake line to seal - SJM linelock kit
- SFC and TA with Lanes True Duals
- hose mod?
- Duralast rotors... what pads?
- 98-02 f-body rear calipers & 01-04 Z06 rears???
- i need 3 point's weld-in SFC's for my vert....
- Swaybar Question
- Torque Arm
- Springs
- Need the supplier for C-5 zo6 brake kits
- Did i F#$% up my ABS?
- Wolfe roll bars
- torque arm bolts keep commin lose
- 6 point cage and SFC's
- Post install spring/shock issues
- Rotors frozen on to axle
- this does not look right at all!!
- thrust angle
- Sportline kit just came in....now how do i do this???
- what size sway bar for a better ride???
- umi 3 point subframes & LT
- Tire clearance ?
- Need rotors (Blanks) Where can I buy from
- Poll: Hotchkis or DMS springs
- Alignement after lowering?
- QA1 settings?
- My car has a mind of its own!!
- Power Steering
- For the love of all things good, but subframe connectors on your cars
- Who has cut there springs ?
- Vehicle specifications?
- Lowering 1" and 38mm offset wheels
- help on lowering springs
- Baer GT+ fit with 10-Spoke SS wheels
- what paint for calipers??
- Air bags
- Aerodynamics - Front Spoiler
- Intrax Lowering Springs
- Why is my rear caliper leaking?
- Strut tower brace
- Tire Alignment spec question
- brakes squeal
- Couple of questions
- Eibach Sportline with Koni's
- post pics of Eibach prokit
