View Full Version : Suspension & Brakes
- Lower with FLP LTs?
- Question on LCA?
- Help choosing a torque arm w/ specific setup...
- those with sfc's, did they help stop any squeaks and rattles?
- Shock and swaybar packages
- what Big brake kit for street
- QA1's front and rear spring rates?
- Need to lift the rear, what spring???????
- UMI Torque Arm and 3 Point SFC....
- suspension hardware
- Spohn TA Thunking FIXED.
- Is welding required to install qa1 rear coilover
- somethings wrong
- any place I can order brembo blanks coated?
- Best shocks for Sportline Springs
- competition engineering 3-way drag shocks
- Someone please explain panhard bars or panhard relocations
- Road tracking problem
- torque arm questions
- ABS lights on and off?
- Took my Car to the Dealership
- Torque arm questions
- Banging/thumping sound from driver's side LCA
- damn Pistons wont go in what to do????
- What do I have to do to compete with a WRX?
- opps...master clyinder
- Line lock
- installing subframe connectors
- outgrown drag, sell transam for vette or mod transam?
- Brake Calipers??
- stock sway bar diameters?
- where can i get air bags for my rear springs???
- Shocks Are Gone... Which Ones To Get???
- QA1 springs settling?
- Question for lowered LS1's?
- What are my stock rotors worth?
- air ride
- best of 3 Torque arms
- Correct lift points for my '98 Trans Am?
- Questions on torque arms.
- X shape roll bar/brace??
- EBC green stuff brake pads?
- umi phr doesn't fit
- Wheel hop question?
- New Rear Shocks?
- How do you mount rod-ended shocks?
- Bad strut?
- Eibach Drag Launch Springs
- Strange Eng. Strut install HELP
- SOM Suspension Stances
- How to adjust umi TA
- brambo blanks rustin really bad
- 100+mph braking?
- Will rear springs from an 87 iroc work on my 2000 TA?
- Rotor ?
- Bolt-In subframes...
- brake flush, which answer is right?
- Opinions on this suspension set-up?
- edelbrock versus BMR torque arms??
- Installed Koni's, did lower perch/heater hose mod FRONT END SITS HIGHER THAN REAR!!!
- when to replace upper strut mount?
- How to improve traction without handling suffering
- Eibach pros
- Question about Bilsteins
- umi torque arms any good?
- Hard Braking = LOW TRAC?
- poly bushings
- grinding my calipors to fit weld prostarts?
- Get new pads or get new brakes?
- LG C5 Brake Kit Install Guide!!
- good torque arm for moser 12 bolt
- Where to buy stock springs
- 16" wheels--PBR or stock LS1 caliper?
- Rear Toe
- How hard is it to change out the K-member?
- Can't line up front shocks -- help!!
- kyb or slp bilstiens
- Best pads for my stock braking system
- sway bar bushings???
- Help with Koni SA on rear - Re 98 Camaro
- Rut follow
- What type of cage do I need?
- Looking for suspension parts to plant my rear tires
- 1LE or BMR swaybars?
- Brake System Upgrade Required?
- Wheel stud's on an LS1 - please help.
- How hard is it to break a shock?
- Severe Vibration!
- Tie Rod Boot Air Tight Seal Broken- Replace?
- Shock and Spring Install HELP
- Adjustable Torque Arm Install...help please
- do relocation brackets really help?
- tranny and torque arm bushing question
- SFC question
- UMI 3 point sfc's installed...pics!
- Anyone have pics of just slotted rotors?
- BMR vs. SPOHN LCA's???
- Just spent $1067.57 on suspension stuff...PHEW!
- Wheel Hop?
- Plain Rotors for Street Time on Big Brake Kit
- Need some advice & pics
- my plan for suspension, chassis and brakes, what do you think
- suspension question
- How much of a drop do these springs give me?
- First time doing brakes on a newer GM car. Quick help and question
- Any springs that offer a SMALLER drop than 1"?
- 1le
- (4) Koni SA's are on!!
- If you are planning larger brakes and have HP EVO's check this out.
- umi or bmr shocktower brace
- intermittent brake squeak
- Guys with their rear isolators removed- any probs down the road? Car is sagging!
- Toe setting - How, not how much question.
- Springs... Suggestions??
- What are the lowest springs?
- help set my qa1s!! 0,0 in front and 3,3 on back!!
- Anyone else having problems with IRotors front rotors
- Need shock advice
- Need shock advice
- Help with spring question???
- adjustable LCA's or not?? HELP!
- Anyone using the Granatelli SFCs?
- Bolt on relocation brackets
- Need new shocks, but which kind?
- Just got spohn 35mm solid cromoly swaybar
- BMR LCA Question
- Koni perch question... NOT THE ORDINARY QUESTION
- Just a Front Sway Bar
- rear brakes, fbody/c5 z06
- Koni shocks on rear only - 98 Z28?
- Need new springs
- ebay rotors?
- suspension setup okay going with 18" rims
- ANy aftermarket springs the same height or near the same height as stock springs?
- about to get new brakes
- UMI boxed weld-in SFC's installed today!!
- QA1 questions for the experts!!!
- What does it take?
- sub frame connectors
- BMR Tunnel Brace
- Sway bar help.
- Torque Arm nuts keep getting really loose
- What's a good track setup?
- what do ya think of these adjustable lower control arm??
- Quick question...BMR Adj Torque Arm...
- Is anyone running Global West?
- For those who want to see ride height after springs
- Building up the suspension?
- Clearance Issue.... BIG one
- Brake upgrade from a 1998 T/a to 1993
- Will Corvette Z06 rims fit on my 1999 Formula
- line lock
- Weld In Or Bolt In Relocation Brackets???
- dms springs and shock guru's any advise
- SFCs?
- spring question
- squealing noise from left rear wheel area
- Front drag shocks
- Anyone ever driven with the ebrake on?
- What are the best shocks and springs
- Lower Control Arms?
- Koni's are on in the front!
- UMI 2pt. Bolt SFC
- C6 ZO6 calipers??
- LCAs & Panhard
- Kyb Agx Shocks
- i dont see how this could hurt?
- What springs should I use with Bilstein Hd's (not-revalved)
- Warped PowerSlot?
- Susp. Newbie here.
- Impression on Utethane Motor Mounts
- Post Pics Of Your Sportlines On Your F Bod!
- I'm on a mission.....(knowlegeable people, please look)
- Were to mount bushings/brackets on sway bar?
- New Bolts for BMR Adjustable T/A??
- wheel hopping.....
- Does anyone have any pics of their LG c5 brake kit?
- Koni DA or Koni SA
- Vibrate or clunking when turning the wheels
- H&R springs?
- need traction
- Where's Frank?
- subframes
- Wilwood Brake Setup
- Tokico's w/ GC coilovers?
- rotors
- Terrible Traction problems
- Does anyone autocross their F-body
- For those with the Spohn TA that experience the WTFISMYCARABOUTTOBLOWUP sound...
- Car Drifting, Less Grip ?
- Does anyone have a picture of their rear brakes with the rotor OFF? Could ya post it?
- Confused about Koni lower perch lowering mod...
- smooth
- Bleeding Brakes, Haynes Manual wrong?
- cleaning rotors???
- Finally some pics of the coil-overs installed..
- Spohn torque arm is making my butt sore.
- Lowering rear only, but need traction! Opinions please...
- Relocation Bracket question
- well.....
- Tough Q: emergency brakes
- Lower control arms?
- break in on new pads+ rotors
- Weird rear end feeling while exiting corners...
- Daily Driven suspension ? for drag racing
- Anyone Get Whinning Sound In Rear After Installing TA?
- best 1" lowering springs???
- Front suspension noise
- tubular kmember
- LCA settings? need some input
- Jegster Torque Arm Install Finished
- broken bolt please help
- .14gs?
- major squeaking in front right brake
- Rack and pinion or tie rod
- Drag setup suspension questions...
- Problems with rear suspension geometry???
- QA1 Shocks
- weld on or bolt on?
- total suspension upgrade
- Does you rear squeak? Fix inside!
- [HELP]Need TQ/procedure for Front ball joints nuts
- can't finish brakes
- kyb agx and pro kit...
- K-Member or LS1 Original CrossMember
- Suspension Advice
- what options are out there? shocks and springs?
- Best Drag Suspension
- Can't find stock spring specs
- what to doooo?
- torque arm bushing help?
- Alignment: Rear Thrust angle out of spec
- Any good pads at a local store?
- KONI SA Settings
- is it okay to....
- shocks
- questions with QA1 shocks (for STS kit clearance)
- Handle help
- need traction advice
- BMR track pack tq arm breaks (street driving) takes rest of drivetrain with it (Pics)
- abs inop, asr off question
- has anyone frozen rotors?
- Poly bushings....where to get them?? Look...
- simple question, which rotors will give me better performance
- Benefits of poly torque arm bushing?
- full suspension
- Rotor question...
- which subframe connectors should i get for my convertible
- Jegster torque arm for F-bodys??
- stock sway bar size?
