View Full Version : Suspension & Brakes
  1. Got owned by the Curb
  2. hal adjustable shocks
  3. Fabricating brake lines?
  4. Best Suspension Combo
  5. LCA rod ends, which QA1?
  6. Who likes their iRotors?
  7. SS w/ SLP Suspension question
  8. Air Shocks - Install Pix
  9. Recommended Suspension Mods
  10. Newly Installed Adjustable QA1 Struts/Shocks
  11. Which SFC's...Kenny Brown or SLP?
  12. Wolfe Anti Roll bar welding question
  13. kyp agx shocks anyone try them like or dislike?
  14. E-brake assembly at brake plate. Please help!!
  15. brake fitting size
  16. Wheel spacers...
  17. To buy or not to buy...
  18. Swaybars Installed. Thanks for advice
  19. 1.25 drop
  20. Whats a good company to buy Abody Suspension Parts??
  21. Looking for stiffer rear lowering springs.....
  22. madman LCA's and PHR?
  23. Difference betw. C5 and LS1 front brakes
  24. suspension parts question
  25. Need Info on suspension
  26. Are there any numbers on a WS6 spring to identify them?
  27. Please post pics of Hotchkis drop w/WS6 wheels please...about to buy springs...
  28. KBDD users quick question
  29. Independent Rear Suspension into F-body
  30. Making use of my new welder
  31. what would help me more
  32. LS1 Brakes?? Brake Light not going off?
  33. Do I still "need" SFC's if I install an 8 point cage?
  34. Which lowering springs would work best in this situation?
  35. Hyperfirm Brake Line Kit. Rear Center line upgrade kit for Traction Control Cars
  36. abs inop
  37. pinion angle on a th400
  38. camber specs....need quick...
  39. Which TQ ARM is better Spohn or BMR?
  40. Kyb Adjustable Struts
  41. Kenny Brown lowering springs?
  42. guess what i got today??
  43. progressive vs fixed rate springs
  44. Where can I find....??? Help!!????
  45. #1 thing to help with cornering?
  46. anyone have kenny brown double diamond sfcs?
  47. Whats the point of adjustable control arms?
  48. Good shocks?
  49. aftermarket torque arm and brake dive...
  50. New Rims call for a drop
  51. post pics of your Camaro w/ BMR or Hotchkis springs plz
  52. Need Help!!!! Brake Problem.
  53. need question answered fast about dms.
  54. What Lowering springs and shocks?
  55. Anyone have these
  56. Just installed G2 LCAs & Brackets
  57. Question for those with lowered cars.....
  58. Anyone installed a BMR Drive shaft loop??
  59. Question about installing the Pro kit?
  60. Powersteering pump making loud noise only on startup.
  61. if your car is lowered, i need your help
  62. BMR SFC's loose LCA bolt
  63. H&R springs
  64. Zo6 Calipers
  65. chassis and handling ?'s
  66. Stock control arms?
  67. alignment range with stock suspension
  68. bolt or weld in cage?
  69. Torque Arm & Poly Trans Mount Installed
  70. Adjustable LCAs, do I need them?
  71. Good goop for sway bar bushings
  72. Difference between SLP Bilstein and Bilstein HDs?
  73. torque arm install
  74. Anyone have SLP level 1 shocks with Prokit?
  75. Lowering spring question
  76. Will line lock keep me from warping my rotors?
  77. Slotted Rotors
  78. What aftermarket brakes are you guys using?
  79. Is this possible?
  80. subframe connector question, help!!!!
  81. Alignment or something else?
  82. please help
  83. SLP Level 1 & SFCs
  84. Any tips for removing the power steering rack?
  85. Will the Spohn Tranny Mount TQ Arm fit with duals.
  86. 90/10 front shocks/struts
  87. Swaybars??
  88. Can I re-use factory bolts for new lca?
  89. Few questions
  90. Opinion on road noise for dual rod end LCA's?
  91. Are adjusable lower control arms needed?
  92. New improved A arms from PA/Pro Fab!
  93. What springs to use with HALs
  94. Question about shocks....
  95. K-member ride height???????
  96. SFC question
  97. Need opinions on some parts
  98. Guys w/ dms and prokits pls post pictures.
  99. Elderbrock poly bushing
  100. will bilsteins for ls1 fit on a v6 firebird
  101. corvette calipers fit fbody
  102. Need lowering springs opinions.
  103. Control Arm Colors...Which colors would you buy??
  104. ABS INOP light came on last night...
  105. Problem With Elderbrock Torque Arm Install
  106. traction control?
  107. Edelbrock suspension parts.
  108. what mod first
  109. BMR rubber lca
  110. 1LE Sway Bars
  111. anyone with LCA relocation brackets
  112. Build your own SFCs?
  113. Tq arm Question
  114. dont want to see the SFC's....
  115. HELP need install cost quotes
  116. best sub frame connectors for lowered SS?
  117. how does 15x10 rears and skinnies affect handling?
  118. New SLP LCAs
  119. suspension questions..
  120. Pinion angle question
  121. Jam nut size on LG Tubular LCAs?
  122. hotchkis springs progressive?
  123. Bilstein ultra suspension package questions
  124. Brakes
  125. I'm having trouble with my line lock...
  126. Parking break adjustment
  127. Where to get SFC's installed?
  128. Spohn torque arem fit w/ true duals?
  129. Need recommendation for high performance street pads.
  130. Is it too difficult install Torque arm for DIY'er
  131. How much of a difference if any from a 1" to 1 5/16" rear swaybar?
  132. strano performance
  133. Global west double bearing LCA's?
  134. Rear shock lower mounting nut size/pitch?
  135. Which rollcage best suits me?
  136. need some advice about the way my car handles.
  137. Tunnel braces?
  138. Hawk pads and rotors
  139. who bought SFC's from Ebay???
  140. Grease for poly/rubber LCAs
  141. any one with gc coilovers set up with KYB's
  142. any pics of cars with 1LE or SLP springs?
  143. stock sway bar size?
  144. Caliper is rubbing on my rotor, im about to start grinding!
  145. any stiffer springs with same height as stock springs?
  146. Problem!!!
  147. K-member selection????
  148. ***Spohn Torque Arm Help!***
  149. LG Motorsports Speed World Challenge car in the making (pics)
  150. Need Torque Arm Advice
  151. LCA install
  152. TR224 Cam car with 100rwhp shot. Suggestions for improving braking performance?
  153. Relocation Brackets on stock height car - great.
  154. Spohn or G2 Swaybars
  155. 1LE Swaybars
  156. Front Brakes Sticking
  157. Pro's and Con's of Tubular Front Suspension?
  158. CG height
  159. New brakes
  160. Random Tech.
  161. Tire pressure
  162. What would a dead shock sound like? Bad Noise under car
  163. Convertible subframe install... remove stock SFC?
  164. What front springs to run with HAL shocks?
  165. Potentially stupid question.
  166. Alston Torqure Arm
  167. Dms Products?
  168. Alston Torque Arm
  169. what dsl with lowered car?
  170. Does anyone have adjustable schocks?
  171. Steering wheel cocked right, wobbly wheel..help!
  172. ABS INOP light coming on .......
  173. Gotta fix my car but found out I OWE money on my tax return...suggestions plz
  174. Grade 8 bolts good enough for LCA relocation bracket?
  175. Will 98-02 k-member fit on 97s?
  176. rear thumping noise
  177. Line Lock?
  178. Air Shocks- Call me Crazy!
  179. Can I still turn my stock rear rotors?
  180. Lowering 2inches any problems?
  181. Anyone having issues with their tq-arm w/
  182. Sure Stop Rotor Specail
  183. panhard bar.....good idea?
  184. new CHEAP SFC company!!!
  185. Ok, I was out cleaning the car and noticed this *pics*
  186. creaking sound coming from the passenger side rear
  187. Has anyone hear cracked their windshield because of too much torque?
  188. street strip shocks tech
  189. any difference between poly/rod vs polypoly suspension
  190. Brake Pads
  191. Sway Bar or Adj. PHB??
  192. What shocks w/ BMR 1" lowering springs
  193. Opinions on Jegster Bolt On SFC's please
  194. drag racing susp.
  195. Which Springs to use w/Hotchkis SwayBars?
  196. Minimal Brake Dust. Which pad?
  197. Airbag suspension
  198. Need reloc. brackets for LCA... FAST !!!
  199. How bad would it scrape???
  200. Pictures of installed SFCs please
  201. headers dragging
  202. another shock Q muahaha . search? wahts that
  203. Sam Strano, revalve price?
  204. Help! Stuck while installing front strut!!!
  205. Installed Moser 9" what Swaybar to get?
  206. Which replacement shock for daily driver?
  207. How to decrease F-Body weight?
  208. Torque Arm...help
  209. Spohn torque arm
  210. Experts comment on my setup
  211. Is the very 1st setting (all the way to the left) considered 1 or 0?
  212. Tie Rod Replacement
  213. Convertible rear shocks - access?
  214. PA K-Member even lower
  215. Spring/shock swap - Front strut pieces?
  216. I need traction !!!!!!!!!!!!
  217. Help, what is this?
  218. suspension newbie needs spring recommendations (yes, i tried the search)...
  219. Crossbrace, TQ Arm, and true duals...who's got it
  220. Eibach/Sway bars
  221. Jack up car with BMR boxed SFC's
  222. Who's having a sale?
  223. Creaky noises normal with poly bushings?
  224. SLP Sub Frame Connectors...
  225. if you have DMS and BILSTEIN HD NON-REVALVED please come in
  226. need alignment help
  227. Cures for crooked launches?
  228. Installed Bilsteins.....Car now sits up higher on the DRIVER's side...
  229. Sub frames
  230. Baer Brake systems
  231. which springs go good w/HD Billsteins?
  232. 1LE or BMR....Please read....
  233. People with Hotchkis springs....
  234. need some very average shock/spring advice
  235. what else do i need??
  236. BMR or PA
  237. 17's or 18's Help???
  238. Swaybars
  239. PA K-Member Special
  240. Installing Bilstein HD's and BMR springs help?
  241. LCA Help
  242. riding high in the back?????
  243. Addco 35mm Front Hollow Bar !!!
  244. Anybody notice raised height w/ Bilstein HD shocks?
  245. What DSL with FLP's
  246. just got my car lowered........
  247. Explanation needed regarding swaybar balance.
  248. Hal f and r series
  249. Installing LCA relocation brackets, what height/holes?
  250. Will I have to roll the fender lips with this combo?
