View Full Version : Suspension & Brakes
  1. Best Shock/Spring combo for a 1" drop?
  2. spring installation question
  3. Good poly trans mount? Which
  4. Eibach Pro Kit
  5. Intrax Springs w/LT's?
  6. Hub bearing noise?
  7. Best Sub-Frame Connectors?
  8. Sway bars on WS6
  9. solid end lca advantage????
  10. sway bar size on 99ss????
  11. STB at the track
  12. Pinion angle?
  13. Factory installed STB
  14. Those with Hals, what are you setting the ride height to?
  15. Custom SFC's
  16. sprint springs?
  17. Panhard bar clunking
  18. Installed LCA reloc. brackets, LCA's, and PHB today.
  19. ABS noisey and violent??!!
  20. anyone using the new coilovers for the rear?
  21. Steering rack clunk
  22. Getting rotors turned
  23. Brake Problem
  24. wheel spin fix
  25. Body Twist?
  26. Rear springs rubbing in an odd place - help
  27. New Guy Mods
  28. Installin Bilstein HD's/1LE rear sway bar/Performance align....
  29. Dms or pro kit springs?
  30. Installation/maintenance questions?
  31. are KBDDs necessary?
  32. what setup???
  33. Strut Tower Brace
  34. What shocks should I get?
  35. Will LS1 STB fit LT1?
  36. Stock Slalom Speed and modified
  37. kyb's and ground control
  38. How are rod LCA's and PHB suposed to feal?
  39. need help finding k-member and a-arms
  40. Anyone have experience w/ cutting off old SFC's?
  41. Tips on removing stock a-arm ball joint?
  42. Need help installing the front R series Hals.
  43. Suspension help-recommendations
  44. I-Rotors!!
  45. Any Prospeed Porsche brake kits left?
  46. Tell me about lowering
  47. benifits of a panhard bar
  48. springs & shocks?
  49. Need help installing rear Hals.
  50. Do I need an aftermarket torque arm?
  51. Alignment help needed.
  52. Need websites that explain spring/shock install.
  53. whATs a good shock and struts for dms spring
  54. Ugh another spring thread.
  55. Wheel hop HELL! HELP!
  56. How much to cut the rear bump stops for Eibach Pro-Kit springs?
  57. SSBC Force 10 Tri-Power Braking System??
  58. Competition Engineering Sub-Frame Connectors
  59. Susp. experts lets talk
  60. 2.0 60' All Day. Need Help!
  61. Help Me Hook Guys!
  62. Need help selecting springs and shocks.
  63. 99 SS suspension upgrade-- Any Advice?
  64. 2pt.stb's who's got them.
  65. Has anyone tried these SFCs?
  66. Illustration of where the rear bump stops and rubber spring isolators are?
  67. Any opinions?
  68. Sb 350 in a 99 z28?
  69. Installed Koni Shocks and SFC's today! Some ?'s
  70. Is this normal?
  71. How much better will my 60' be with a good TQ arm?
  72. Optional Bilstein Vs. Bilstein HD
  73. Bump steer?
  74. porsche brakes
  75. spring rates
  76. Anyone running this rear swaybar?
  77. Switching Brakes ?????
  78. Front end problem. Need help please.
  79. Size of tunnel brace bolts
  80. alternatives to the TA
  81. Removing welded SFC's
  82. Anybody running a 21mm 1LE rear swaybar?
  83. Installing Front Shocks
  84. ABS on the Side or Top of Pumpkin?
  85. Has anyone found a Driveshaft Loop that fits
  86. Best SFC's?
  87. Poly front upper and lower a arm bushings??
  88. Hal questions.
  89. ASR or TCS whatever I nned help
  90. Do any of the aftermarket swaybars (front, rear, or both) have any affect on drag use
  91. bmr sfc tubular ?
  92. Difficulty steering. Please help.
  93. I Need a shop in So Cal for SFC install.
  94. what SPRINGS for front and back....
  95. swaybar or not?
  96. Jegster torque arm
  97. ST swaybars
  98. traling arms
  99. How are the HAL QA1's on the street?
  100. sliding and fishtailing
  101. Tourque settings for the following?
  102. droping the car! few questions!
  103. Torque arm with true dual exhaust, Trans or Crossmember Mounted?
  104. need some shock advice
  105. Manual brakes and steering on street?
  106. BRAKE and ABS INOP light came on last night, any ideas?
  107. How many miles did your rear rotors last?
  108. need new tires.....
  109. painting brakes
  110. slp subframe connectors
  111. What Swaybars for this set up?
  112. STB - noticeable difference??
  113. Line Lock Install question
  114. K-member, BMR vs. PA?
  115. about mac springs
  116. Steering thunks...
  117. IF you had to build your suspention one piece at a time...
  118. Traction>subframe,panrod,controlarm, what?
  119. Stupid to not get subframe connectors?
  120. $25.00 drop
  121. Should I change Master Cylinder?
  122. Bad News..or Good...depends?
  123. Replacement Front Rotors
  124. major wheel hop question.
  125. Spring Thread, what to gow tih for a 1" drop?
  126. My thoughts on POLY bushings
  127. Useful life of stock suspension?
  128. Help! Rear alignment issues
  129. ABS Standard on all LS1's?
  130. Amazing handling WS6!
  131. Alignment now or after?
  132. Line Lock
  133. Loud Noise when Nailing it!
  134. Need Torque Specs for BMR LCA's....
  135. Lube for Heim joints?
  136. need help with earls stainless brake lines
  137. swaybar sizes
  138. Why???
  139. looking for rotors
  140. Noise and aftermarket LCAs
  141. Ground Control setup
  142. G2 front lower control arms -- wow
  143. Will LCA's help traction on a drag car w/ no wheelhop?
  144. 'Camaro' caliper decals???
  145. Winter Suspension Upgrade project..please help
  146. what can i do with my brake lines?
  147. rear springs for moser height increase
  148. Just installed adj phb for anyone who needs info
  149. What Front Brakes do you suggest
  150. Are bump steer tie rod ends necessary for lowered cars?
  151. C5 Rotors...?
  152. Got my BMR LCA's, Question about the Grease Nipples
  153. TQ Arm Angle ???
  154. Grinding noise.
  155. K member
  156. just lowered my car i have some questions
  157. Relocation brackets even when changing rear ends
  158. Rear coil conversion?
  159. Alignment issues
  160. Stuck on front rotor swap...
  161. Suspention with 9 inch rear
  162. Paging 1LE guys (kinda long)
  163. HAL's springs sag can I use an Afco spring
  164. weird prob w/ brakes/steering...please help!!!!!
  165. Best place to get Hypercoils
  166. Corvette C4 or C5 Calipers which to run?
  167. V6 spring owners step inside
  168. Slot Car Racing control arms?
  169. Help with wheel hop.
  170. Pictures of modified spring perches on HAL shocks??
  171. Cutting Springs????
  172. Anyone else have this problem with BMR k-member??
  173. k members?
  174. Control Arms and Strut Braces
  175. Question - Progressive Spring Install Orientation
  176. buying a spohn T/A which is best?
  177. Info on how to not have warped rotors
  178. iROTORS? or what...
  179. Has anyone installed Budzter coil spring height adjusters
  180. Has anyone installed budzter coil spring height adjusters
  181. Stupid question
  182. rear end squeaking??
  183. Questions About A Setup
  184. Checkout my new gear!
  185. No rice or flames, but best way to RAISE rear for "Camaro rake"?
  186. Need some good alignment specs....
  187. Best "race" springs?
  188. Passenger side rear sits lower than right side
  189. How did I bleed my brakes without bleeding em?
  190. drag suspension questions... help!
  191. eradispeed 2 piece rotors
  192. Right Lower Control Arm Bad Already???
  193. Rear Coil Spring Airbags?
  194. Help me pick a Torque arm please??
  195. Question on BMR relocation brackets
  196. Best HAL Settings for MAX 60ft?
  197. Bottoming out???
  198. Koni shocks! any downside at all?
  199. New QA1 "R" shocks vs. older version
  200. brakes locking up
  201. Reybestos Quiet stops/Brute Stops/Wagner
  202. SLP Optional Progressive Package?
  203. Steering wheel noise
  204. First Mod... Lower the Z28
  205. EBrake handle loose......?
  206. BMR adjust PHB- need info please
  207. What shock for both drag and autocross
  208. Lugnuts, torque settings, and wheel studs, Oh my!
  209. Help with Shocks
  210. Z06 calipers...
  211. Looking to stiffen up the ride
  212. Received Hals the other day, I have a couple of questions.
  213. BMR Drive Shaft Loop Installation Problem
  214. What is the difference between these Bilstein shocks?
  215. Eibach Drag Springs...
  216. Please help
  217. Shock Mount Part Number?
  218. Installed New Spohn Adjustable TA (LONG)
  219. Relocator brackets help
  220. Which is more important LCA or PHB
  221. KVR Rotors Warped/ Warped Hubs?
  222. so what destroys brakes...
  223. driveshaft loop for dual exhaust?
  224. Resurface drilled rotors?
  225. edelbrock TA hits floor board...
  226. I got my Spohn TA in...now I have some questions. Please Help
  227. Thoughts on Mov It brakes
  228. New SS Vert owner needs help improving handling
  229. Wheel Hop with Nitto Drs
  230. Need info on the new R series Hals and Hals in general.
  231. Eibach too low?
  232. rears warp?
  233. double caliper
  234. Rear suspension hitting real hard!!!
  235. SLP SFC or BMR SFC
  236. 35/21 swaybars
  237. Squeaking from passenger rear
  238. Irotors
  239. How to and how not to lift the front wheels?
  240. I need c5 brake torque specs. Know where I can get them?
  241. Lca Relocation Brackets On Stock
  242. Bump Steer & Alignment when Lowering
  243. Any comments on Granatelli Lowering Springs?
  244. shocks for cut springs?
  245. Relocation brackets needed or not?
  246. Anyone use the new Hal QA1-R front shocks (drag version)?
  247. Rlb
  248. Eibach Pro-Kit owners in here (or others with a small drop)
  249. Where are the Sub Frame Connecters?
  250. Did the 99 Camaro SS come with BIlstein shocks
