View Full Version : Suspension & Brakes
- Hal/ QA1 users, whats a good starting point?
- Wilwood brake packages on sale!
- Removed Traction Control... Now Problems
- When lowering a car can you use a non-adjustable panhard bar?
- Thumping Noise While hard braking
- I dont want to be lowered anymore!
- Is anyone lowered with SLP headers?
- c5 brakes on f body
- Any Pictures of Car with LG's G2 Springs?
- what could this be?? something leaking mabye?
- Sway Bar
- Which shocks with DMS springs?
- Need pic's of where to mount line lock switch.
- DMS Springs, Need pics of the numbers on the spring itself.....
- LG C5 brake upgrade kit
- Relocation questions???
- sway bar bushing and endlink?
- Are my shocks shot?
- Bolt in roll bar- Improve unibody integrity?
- Torque arm? is there that much difference between the two
- Need a guide for a shock and strut replacement for an 02 Formula
- Koni warranty?
- wat are stock ss spring rates
- stearing wheel vibration
- Poly Bushings
- spohn driveshaft loop
- noise from new subframe connectors?
- Wheels broke my panhard rod(?)
- pics of slp subframe connectors
- Suspension "squeak" ???
- Tubular A-Arm install
- G2 Spring sale for the 4th of july...
- Quick Help Needed!!! Should I replace?
- DMS Lowering Springs GP
- after h/c swap cant break
- what do you guys think of these SFC?
- edelbrock torque arm
- 1/2 On: Koni SAs, Thoughts (Koni, Sam Strano)
- What exactly is this called?
- Lowering the car, need advice
- Alignment specs ?
- Possible Broken Ball Joint (Pics)
- Help Brakes!!!
- master cylinder rubber gasket
- New vibration after sfc and tranny mount
- installing torque arm and trans brace, whats the best way to do it?
- Proper brake break-in??
- Creeking Sound after Spring Install
- Saved by an A-arm
- Ball joint replacement?
- going to be road racing
- DMS Springs
- OUT IN THE GARAGE>>> CALIPERS
- springs
- no brake pressure after engine swap
- Which shocks are better??
- Brembo Calipers On the car for Fitment, just need Rotors! lol
- is it ok to use different pads for the front and rear?
- New torque arm, new problem... Trackbird help!
- slp bolt in subframes
- canuck??
- torque arm with diamond style sfc
- Removed rear isolator
- turning rear rotors
- Rear Sway Bar Bushings
- Suspension FAQ?
- need stiffer springs!
- SFCs on - holy #@&%
- Is poly motor mount worth it??
- KYB AGX Adj shocks...drag racing.
- What size wheel studs?????
- Weird problem
- Would Shocks help wheel hop ?
- Broke My Spohn Tq Arm *PICS*
- Eibach Springs opinions/help please
- Play in steering response.
- best line lock kit?
- Shocks and Springs...
- stripped shock bolt (need more help than before)
- Need advice on Eibach
- I Need Pics of Brake Ducts
- damaged ball joint boot (trackbird!)...help please
- Anyone here made their own BOXED LCA's?
- ABS INOP codes
- Tunnel Brace Bolt size?
- Car Leaning in Rear...
- Piece on top of Panhard Rod
- 4-point cage. Hard 2 install yourself??
- Just installed QA1 R-series front shocks
- New swaybars or replace bushings
- rear swaybar endlinks?
- brake pedal goes to floor at idol
- Hardend Brake line part#?
- how do u know if you have bad shocks
- TBYRNE Motorsports' Baer Brakes Group Purchase!
- Light metallic clatter from front end
- Speedbump Rattle
- Trans am front springs>Camaro rear springs
- How much does it cost to have a 6 point rollcage installed?
- Edelbrock parts any good???
- Koni Adjustable shocks
- Rear allignment
- cheapest rear brake pads?
- Subframes DO make a difference
- new brake pad install.. expensive? machining rotors?
- Should I, have you?
- Any way to improve handling of a G-body?
- lower control arms/bump stops
- Trans Am brake ducts install....
- what is causing this metal scraping sound???
- C5 brake conversion, buying asap :)
- Whats the best brake setup for 16" wheels?
- cheapest/most reliable rotors???
- drag suspension?
- Creeking sound from rear
- Brake Caliper loose, makes noise when I hit it with my hand...
- g2 springs for drag?
- Bumper Support Bracket!
- what heads and cam you guys run for autox?
- Can you revalve Decarbon shocks??
- help rough ride
- Panhard Rod Question
- Speed Bumps
- Hotchkis and DMS pics please....
- spring and shock suggestions
- Dropped brake pads on ground, still safe to use?
- trans mounts
- problem adjusting my panhard rod ?(HELP)
- removing rear caliper bracket blots...im stuck
- struts and shocks.....
- ABS Delete / Line Lock Install
- How to switch from 3 chann to 4 chann ABS.
- LCA and panhard bolts
- LCA relocation brackets on stock height car?
- painting calipers question
- Spohn or BMR TA
- Question about STB...
- can't tell that much diff wit SFC
- I need a new Torque arm. few things
- LS1/rx7 pulls 1.13g's on the skidpad!!!!!
- Cant hook up should I get traction bars?
- ABS Part #
- Which weld-in subframes are the BEST?
- ABS kicking in?
- Creeking Panhard Bar
- Front only QA1s w/ stock springs??
- ABS INOP light?
- 1le springs worth the ugrade?
- Anyone using the BMR TA Relocation Kit???
- Someone Please Help Me With My Suspension Problems!!!!!!!!!
- Please Help Me With MY SUSPENSION PROBLEMS!!!!!!!
- E-Brake skips.......
- Info on Competition Engineering 3 way adj. shocks...
- scraping noise?
- Drag racing w/ Koni SA?
- Convertiable Subframe Connectors
- Noises from front
- Is it time for new brakes?
- lakewood adj. panhard bar?
- Front hals R series
- Anyone sell Brembo blanks in Houston?
- Pedal feel....new pads and lines
- front end squeeks
- Help with A-Arm Removal!!
- Rear qa1 coilover kit for f-body.
- Rear brakes only?
- installed Konis on my ride from Strano, with existing DMS springs
- suspension mods
- ? about torque arm install`
- Master Cylinder
- Coming up next...
- Panhard opinion
- Lower Control Arms
- What stops lean?
- Lowering my car
- Car sounds like a dump truck
- Hurst Line Lock installed!!
- BMR sfc owners or those who've made their own
- what do you think about Monroe shock??
- Decisions, decisions...
- Brake hardline fitting size
- Question for BMR customers
- 2 point strut tower brace
- Cheap Lowering, Cutting Springs...
- car leans a little bit...
- BMR LCA mis-alignment on passengers side
- Caliper Guide Pin
- Spohn Torque Arm alignment problem...
- Switch from ProKit to DMS or Hotchkis?
- Putting WS6 springs on a non-WS6 car???
- Would this be a rediculous way to lower a car?
- Non-Adjustable Torque-Arm??????
- Weight difference?
- G2 SuperSprings in stock @ LGM
- Iron Blocks, nose weight and handeling issues?
- What Rotors are best for the money?
- GripForce F1 Rotors?
- Sway Bar
- What makes the biggest difference??
- clearance with c5 conversion
- Replacing the front struts/springs
- UMI STB Emergency!
- Question for tubular k and a-arm guys???
- Abs?
- Chromoly versus Steel
- brake pads
- Brake Pads
- How Hard...
- Brakes fitting new axles?
- Global west coil over. front waaay too high!!
- New Car new Brakes trying to bleed lines!
- Rear feels a little bouncy?
- replacing factory springs
- BMR Front Shock Spacers, Safe and OK?
- Ughhh... I'm tired.
- bleeding abs brakes
- Advanced Auto pads...
- corvette & f-body e-brake
- New y-pipe scrapes. Options?
- 1LE Springs
- coil-over, Ground control
- New Product- SFC's for the 3rd Generation- If theres any in here
- set pinion angle, now cluncking!! help
- WS6 Hood is out of place
- Caliper Rebuild Kit NEED HELP!!!!
- Squeeky brakes are driving me nut!!!
- After Subframe Connectors I get noise from rear
- Drag racers with a RR air bag
- Koni SA shocks and Hotchkis springs?
- LCAs: Non-Adj, Adj, or Dbl-Adj.
- Do your Wholesale Direct rotors look like this? (pic)
- handling/lowering
- Subframe install ?'s
- Any recommended C5 Pads?
- How much tire diffrence can we have w/out the abs light comming on?
- Problem with SFC's
- Front and rear control arms + a arms
- Eibach Drag Launch Kit
- baer gt+ vs c5 brake upgrade?
- After 50 miles STB stilll wont go on
- Putting on 17" wheels, need lowering advice
- bendix rotors? what do you think?
- Are the mounts for the C5 rear brakes the same for Fbody rears??????
- Suspension is unloading under heavy launch.
- Koni SA picture - of the shock
- SLP Bilsteins with Hotchkis springs?
- Air ride in f-body
- new shocks. springs too?
