View Full Version : Suspension & Brakes
- LG Brackets and C5 rotors
- how do you know when your shocks go bad?
- What LCA's should I buy??
- suspension set up...
- Still Having Brake Issues HELP!!!!!!!!
- Koni SA or Bilstein HD?
- ride height
- 1LE Parts upgrade ?'s
- diff in spohn,madman, and sw tq arms ?
- My suspension future
- about to put on Eradispeeds
- spohn ta ???
- help with inner tie rod change
- LCA Relocation brackets needed?
- LT1 -> LS1 brake upgrade - how do LS1 brakes work?
- Can you re-install SFCs?
- Caliper rebuild kit, how to?
- e-brake handle removal
- Best rear shock choice - Bilstein HD or KYB AGX Adjustable?
- what can i do?
- Left my line-lock on for a week - will it hurt anything?
- Driving with a cage, will it change how the car daily drives?
- Poly bushings - Recommendations?
- $1500 for Suspension--Recommendations?
- Suspension Mods for 450HP?
- Custom Hurst line lock install pics!!
- TCI linelock
- Is This A Good Price For??
- 98 ss prokit? Ok for a vert?
- Looking into Wilwood kit
- Braking Problem!!
- OEM vs Durostop brake pads
- ? about master cylinder, please help
- Which Bolt-on SFC?
- Need good alignment shop in Chicago area
- Rotors breaking in
- Brake question
- Pic Request: Line Lock
- "street" car...any lightweight brakes worth it?
- Good springs for drag racing?
- Toe settings
- Sphoon, BMR, UMI?
- looking for imput on UMI performance parts.
- loud bang after SubF connector install
- Sway Bars? How big is TOO big?
- Best Alignment specs for 2000 Corvette
- which is a better buy.
- YAW RATE Sensor.....
- Recommend a caster setting, please.
- Z06 rotors and calipers
- K-member installed not happy
- DMS or MAC springs
- Wierd noise after shock/spring install
- Pro kit and Bilsteins
- My new panhard bar.
- Caster/Camber Plates
- problem with front lower control arm, help quick!!
- Massive Wheelhop Post-LCA Install
- Best adj. shock for my dd
- handling with Bilstein shocks only
- Help!
- G2s, BMR, or Hotchkis springs?
- Do I need adjustable lower control arms?
- Spring??
- What mod to plant rear better on takeoff and around corners?
- best deal on brakes
- Brake Problems Help!
- Which Line Lock??
- who sells a 3 point strut brace?
- Anyone ever used Varishocks.
- What Pads To Go With?
- need a place to get mov it or stoptech kits.
- Did a search but still have a question on rotors?
- Need help w/ swaybar decision
- Road Manners with LCA relocation brackets?
- Need shock and strut suggestion
- 1LE Suspension ???
- pic of air bag?
- brake lines off master? help with routing!
- lowering car
- need help with 9 sec car suspension
- Baer GT+ Deal, customer cancelled.
- Dropping it!!
- Brembo Rotors for Corvette on a TransAm
- C5/ZO6 brakes on an early 4th gen?
- Upgrade to SLP sport package?
- how to turn off abs inop and brake lights after abs delete?
- guys with caliper decals, question?
- Rollcage pictures let see them
- Weight comparison Strange vs Aerospace
- Weird front end noise?
- Quick Question
- Questions about shock install.
- Brake Upgrade for Z06
- STB Install Question
- Quick SFC install question. Please.
- Pinion Angle Question. Please answer ASAP
- subframes welded in....no difference???
- this is my setup where to next???
- HAL R Shocks and HAL QA1s...
- Sfc
- Best single suspension upgrade?
- Best Pads for Daily Driver/Autox
- Bad wheel hop issues
- LS1 Brake Upgrade
- Front tires wanting to follow the road...
- DMS spring cars come on in!
- B&G lowering springs
- Z51 Cross Drilled Rotors on 2002 TransAm
- eibach drag launch?
- SS Springs Stock??
- GC weight jackers/perch question
- Taking out welded subframes ??? Help please
- Spohn TA Question
- Wierd Noise! any help?
- brake pads
- Q1A question
- Adjustable or non adjustable?
- stock suspension specs of 1999 camaro SS's
- Need new shocks to soften up ride with sportlines
- Upgrading Brakes on Z06
- does a Panhard rod help??
- Torque arm clearance issue...
- Torque arm or tires?
- I have a non-adjustable torque arm. Do I need it?
- New LCA's rear end not centered??
- paging trackbird!
- Been gone awhile, need suspension suggestions
- Caliper Bracket Bolt specs
- Which A-arms????
- NEED Help!! Swaybar removale
- Opinions/Thoughts on BMR Torque Arm (non-adjustable) Please...
- consid. LCA's or pan hard?
- BMR brace
- ABS in the front but not in back?
- Earl's hyper firm brake lines
- Just installed both Sway Bars.
- what is the best spring for a QA1/Hals
- torque arm bracket/mount??
- K Member ???
- Bent torque arm mount!
- What's a GOOD brake fluid???
- adjustable torque arm....pinion angle?
- Need rear shock help... QUICK?!
- Opinions please.....QA1's on a near-stock car?
- from stock z28 to C5 wil it make a differnce??
- Street shocks/springs that don't lower the car?
- Sure Stop rotors from Speed Inc?
- Suspension For My Needs
- 3rd or 4th gen bilstein HDs?
- Where can I get a grease gun?
- C5 pads on my T/A
- Just got my sub-frame connectors installed- NOT HAPPY!
- Eibach Coilover kit
- Matching Shocks to Springs
- Hurst Line Lock and Soft Pedal
- Q1A's and Eibach drag springs...
- noob ?
- Your opinion on BMR Lower control arms....help!
- wheel hop prob please come in
- Thunder Racing Line Lock / Roll Control installed Pics ?
- Thread pitch on brake MC
- Any problems with cross drilled rotors?
- Traction Control
- Which SFC's??
- My car rides like crap. I need some suggestions.
- running true duals...which SFC???
- Going with Strange brakes...any mods needed to brake lines?
- QA1/HAL question...
- Weight swap on parts?
- Which of these ebay rotors look better to you?
- 01 Z28 remove/install PHR and LCA's?
- does a lowered car hurt performance?
- Why?!?!?!?
- Torque arm owned
- Looking to buy a new Torque Arm??
- adjustable or non adjustable?
- Wheel hop theory... what do you think?
- K member install page?
- Dual purpose suspension question
- People with Hotchkis STB come in
- changing aftermarket rotors.
- Bleeding Brakes... Strange Noise After Pumping The Brake Pedal
- HELP! 32mm F.swaybar bushings????
- Installing SLP bolt on SFC?
- Rear Thrust Angle Question?
- What are good lightwieght brakes for the rear? drag/street
- Brake pads that don't squeek...
- Switched from Pro Kit to Hotchkis Lowering Spring pics inside--->
- Car feels twitchy and is loose
- New Rotors... Should I change the pads as well?
- Will LCAs be enough?
- SFC's (SLP DD vs. BMR Tubular) STB (Hotchkis)
- v6 ratio vs. z28
- leaking hal/qa1 shocks
- G2 or BMR????
- Settling after spring/shock install
- Can lower ball joint be removed?
- Am I correct?? Street/Strip
- Bumpstops?
- sway bar mount broke. wtf?
- Looking for good blank rotors
- Power Steering Cooler
- brake bleed
- C5 rotors on my T/A
- need pics of Reloc brackets on car
- need help and part asap
- Reloc brackets welded now rear end sets back?
- Steel braided brake line kit?
- Any info on KYB adjustables?
- What drag-springs to run w/ QA1s?
- K member ??
- About to install LCA's question
- Pro Fab K vs Stock
- New brakes came in
- Stainless steel brake lines? Pics? are they direct fit?
- Brake help, adding couplers/jointer to lines? is it bad???
- who makes the biggest rotor
- Part number
- Rack and Pinion P/N?
- part #s for HALs????
- Question about QA1 Gen F front/rear kit
- Brake Swapping
- Rotor Break in
- BAD Z Lower control arms????
- Any of guys using Eibach Sportline's???
- Weight of SFC
- Suspension and Torque Arm Question
- Edelbrock Torque arm ???
- Some Brake Help for a New Guy please!
- where to buy raybestos quiet-stops?
- slp bolt on sfc's
- Abs
- Puzzled
- GC rear perches for Moser 12bolt
- DMS or BMR spring pics? POST EM!!!!! Reviews also.
- tunnel brace question
- Warped rotors?
- Craked Rotors
- anyone running a manual rack?
- Problems with front brakes
- Stealth TQ Arm?
- Abs Inop
- Horrid Brake Squeal when cornering under accel??
- SLP line lock ?'s
- rear swaybar endlinks??
- Spohn TA hitting floorboard while adj. pinion angle.
- Need some input about a suspension package
- Will these rotors fit my Camaro??
- LCA Question
