View Full Version : Suspension & Brakes
- LG Motorsports 20% off Christmass sale on G2 parts
- Lets talk about an AirRide Suspension Fbody
- Random Tech Torque Arm
- Best Semi-Aggressive Street Alignment, Swaybar Questions
- Help
- Coilover Question
- suspension questions
- How does a torque arm operate? range of motion?
- anyone have a PA k member and or front control arms?
- front sway bar end link
- LCA relocation
- what lowering springs stil give you a good ride?
- Brakes/weight reduction?
- Edelbrock lowering springs
- qa1 help
- Daily Driver!! Suspension?
- C5 Calipers
- New Shock Tower Brace!
- Replacing metal brake line pipes
- Spring Isolaters?
- Anyone used a Pneumatic liquid/fluid extractor to bleed brakes?
- Should I get my car realigned? *Piggyback off old thread*
- Goldline Springs?
- Which brakes?
- What are good drag launch springs?
- Please help with SLP STB install.
- LCA and suspension question
- LCA question(and more)
- back brakes
- how do you install a rack and pinon on a Z28?
- wheel hop
- What tire pressure do you run?
- Brakes Question
- Need Advice
- Sway Bar Delete
- global west springs
- Ok why is my car wheel hopping
- Torque Arm ?'s
- BMR SFCs on the car.. some questions..
- What are your caster/camber numbers?
- Torque arm with x pipe.
- Rear shock bushing tightening.
- is this a brake problem
- hotchkis tvs kit
- do i have 1LE susp and need help w/swaybar install......
- drilled and slotted rotors
- G2 Super Springs........
- Shocks
- good sway bars?
- car pulling to the side
- Pro Series or Sport Series?
- QA1 Shock Settings
- H&R Springs?Search Didnt Help
- New brakes
- Spohn adjutable TA
- Dropping a motor out the bottom, need info on ABS lines...
- Does an 01 SS suspension use 1LE bushings?
- clunking sound...help
- Spohn Rod End LCA
- Question about wilwood 6 piston brake set up.
- Bumpstop rubbing?
- cam is in and tuned, now its time for some suspension
- How long to aftermarket rotors last.
- anyone running welds w/ GC kit
- Enlinks in the rear
- Cutting springs no/yes?
- how to change rotors and pads
- Time to upgrade....few questions..
- HAWK HPS Brake Pads on sale!
- Matching shocks to spring rates
- Which SFC's?
- why is my steering wheel stuck upside down?
- changed rear rotors
- full suspension.. and still wheelhop!!
- A few Questions on Front A-Arms?
- Questions Z06 Calipers on a Fbody
- Spohn Extreme Drag Rear Sway Bar HELP!!
- tube chasis ??
- Now THIS is how you work the cones *video*
- Need Suggestions on new Suspension
- Hal shocks on the street
- new motor, need suspension upgrades
- bump steer
- Air Ride system questions
- Best rear springs for...
- What are brake calipers made out of?
- help with steering
- Bob Bishop Brakets
- BMR extreme torque arm, will it hit speed pumps?
- Real bad squeeking noise coming from front
- Axle hop after BMR relocation brackets
- ES Trans Mount
- For those of you looking for rear shock bolts
- pro fab k member problem
- Rear spring issues.
- Car rides like a bucket of $h!t...
- weld in roll cage
- Shimming A Motor...
- subframe connectors
- big brakes and skinnies...
- Help Please!!!!
- Aphr...
- Rear tires angle problems
- How much did you pay to install arp studs?
- Rod v/s Poly LCA
- how low are u guys riding?
- my car started popping after a grease job
- Do you MIG or TIG your subframes SFC on?
- Broke Sway Bar Bolt -- Okay to drive?
- squeaky rear suspension
- Installing Heater Hose on Rear Spring?
- Dust Boot Problem on Koni Front Shock.
- Broken Shock
- Hal Springs Vs Stock Springs
- should i get the slpbilsteinsor regular bilsteins (i have pro kit)
- brake lines
- Dash Mounted Break Light Always On.
- Question about different size tires...
- Clearance on lowering car 1.5 inch
- wolfe rear anti roll bar
- DIFFRENCE between regular bilsteins/slp bilsteins/revalved bilsteins
- which crossmember
- Help with shocks.
- Cutting springs w/o removing off the shock
- 400HP daily driver
- HELP! broke brake sensor on back of spindle!
- Do I need LCA Brackets?
- Subframe Connectors...
- UMI SFC's
- Right Rear Shock (?) Scrape...
- suspension help. what should i buy.
- noob need help! (98 z28 to handle on road corse)
- pro kit what shock to go with?
- QA1 v. Strange v. Afco
- Help! front end alinement
- Slotted brakes
- tower brace
- anyone have the edelbrock tq. arm? anyone know if it is worth the $$$???
- 98 suspension
- Spohn vs. LGM (G2)
- Memebers W/ BMR STB pls Help
- Better Ride (Currently Semi-Drag Setup)
- Rotor/Pad Install
- Rear V6 springs on a V8???
- Warped rear rotors?
- GM rear brake pads ?
- loud squeek whenever i break
- tokico or kyb gr2?
- pro-kit+bilstein shock/strut pics?
- Installed front brake calipers,rotors,brakes
- tokico struts and shock with eibach please help
- Handling and Lowering
- Thanksgiving Sale 4-cross Drilled Slotted Rotors W/axxis Pads And Fluid 299 Free S&h
- I need advice on how to get stiff
- Need to resurface rotors with new pads?
- Lower control relocation brackets ???
- eibach and stock shocks
- Getting out of drag racing,want a good ride again?
- SFC's
- ok, im looking at my shocks and springs and i cannot figure out....
- How to remove spring seats from DeCarbon shocks?
- anyone have pics of spring/shock install?
- looking for part #...
- Answer me this ???
- rotor woes
- Help, low trac light?!?!
- How hard is it to install a BMR K-member
- springs
- QA1 weight diff
- 100MPH shake rattle and roll
- Question Regarding Shocks and Springs
- Removing ABS & TCS
- Hal Rs on the front...what on the rear
- Installed my bolt-on SLP SFC's today!!!
- EBC redstuff pads
- Newbie question(s)...help please
- A Arms, PA vs. BMR WTB
- Newest Product! Single Adjustable Lower Control Arms- Pics!
- C5 bracket package
- need new brakes, stick with OEM pads or hawks
- How durable and streetable is k-member and a-arms?
- *i want my car to stop faster* for cheap~!
- KYB or Bilstein?
- Adjust Koni SA height on car ?
- Parking brake light?
- What shocks/springs to buy
- Looking for feed back on the Wholsale direct brakes & rotors package.
- What is available for braided brake lines?
- BMR vs KBDD
- Need Some Input On Springs/Shocks
- About to order SLP Weld-in SFC, any reason not to?
- Is there a wrong way to install a STB??
- Bolt on BMR Reloc Brackets clearance
- have a hurst line lock , is it worth buying an install kit ?
- DIY guys, SFC easiest to weld, no lift
- are there different versions of 'Bilsteins'?
- have you heard of these springs?
- Sway bar questions..
- Setting pinion angel-How to
- Will LCA relocation brackets help ?
- What to put my QA1 at?
- Banging from rear when braking.....
- extending end link spacer
- quick help while the spring is off, how to bring up right rear
- Spohn LT1 Torque Arm for Ls1 true dual car?
- Hotchkis Sport Springs
- What to buy?
- Where can I buy rear f-body Wilwood Rotors??
- power brakes don't work after new motor
- springs
- Have GC coil overs which headers
- Competition Engineering Shocks???
- am confused ?? and i need help !!
- Rattling?
- just lowered the car some, now im getting a knocking??
- Broke a wheel stud..need some help!
- Are LT1 and LS1 struts the same?
- removing swaybar
- 450 rwhp
- LG Hypercoils
- no power steering
- wholesale direct rotors?
- Edelbrock Torque arm for F-body-anyone running it?
- No Front Sway Bar
- Loud thump from rear, blown shock????????
- What springs are these/opinions??
- what to use to cut spring?
- car sat for two weeks and now brakes squeek like crazy
- Finally lowered the Z
- how much to drop my tA
- Do BMR Spherical Race/Street LCA make noise driving down the road, or should I with..
- Rotors, what to buy
- Hurst Line Lock question
- $@&*(! bleeder bolt!
- Tubular K-Member?
- Street / Strip shocks
- $1000 to spend on suspension, please help...
- QA1 Hals R series--what Spring??/
- Do i need Relocation Brackets to make LCA's function properly?
- what sus part will help get traction?
- What do you think about my choices?
- Lowering springs?
- How long will it take me?
- Help...Bolt on strut towers are rusted.
- Moser 12 bolt and sway bar
- torque specs for 3 vertical k member bolts????
- Bob Bishop 13" front brake conversion kit
- Spohn Adj. Torque Arm...need help/input!
- Shocks & Springs
- C5 brakes in the rear?
