View Full Version : Suspension & Brakes
- Brake pads & rotors you been through?
- how much is a full drag suspension on a stock car worth in et?
- camber correction kit for ls1 f-body???
- revalved bilsteins, and blistein HD's??
- Need help with brakes...getting upset!!!
- LCA's and Launching
- Free Installation
- Wholesale Direct or IRotors?
- Torque Arms and LT's
- Strange vibration
- Will 97-04 Corvette rotors fit 02 F-body?
- Air ride technology
- 80Z28 torque specs, pinion angle and...
- Which drag springs? Suspension help etc.
- lowering spring decision. help!
- Why would adjustable control arms be better than non-adjustable control arms?
- question on noises from Spohn Adj. TA
- wheel and suspension questions inside...
- Needing pictures of SFC's on car..
- aftermarket K-member advantages/disadvantages?
- need suspension help
- I got new shocks!!!
- 1/4 mile spring and shock set up also daily driver
- Replacing Ball Joints, Aftermarket suggestions?
- Need help with my situation?
- Spring Rates: HAL vs Stock and others
- Slotted rotor question
- what should i expect with the Spohn adj. TA?
- what are all the advantages of a tubular k member?
- LCA problem
- why dont firehawks come with adj panhards and lca reloc brackets
- best spring for use with bilsteins
- Fellow Spohn TA users?
- Need rotors that resist warping
- Questions about this crazy cage
- 98 rotor and caliper swap?
- SLP STB w/ FRC's on LS1???
- SPOHN products
- Koni SA 3rd Gen Bil setup
- Tracking down a clunk in the rear suspension.
- DIY alignment?
- ¼ panel dimples - from brake/axle hop, or lack of subframe connectors?
- spring ride height question
- Springs & Shocks 4 Daily Driver
- Grinded calipers to make my rims fit, just 1 question?
- Hal's or Strange's drag shocks with BMR springs?????????
- Where do I get Bilsteins revalved?
- Bolts loosen up on TQ arm w/ moser 12 bolt.
- Slp Springs what's what?
- Dust protector won't go in QA1 spring?
- rear suspension upgrade for 98 t/a
- question about rear suspension for ls1
- ls1 rear suspension upgrade. any suggestions??
- Need HELP, car sounds like it's gona fall apart
- MAC lowering springs - where to buy?
- for those that have cut their springs...
- excessive bunny hop when accellerating out of a turn
- Why am I hearing squeeks coming from my rear suspension?
- Suspension to get me by
- global rear height adjust kit
- Tightening swaybar endlinks ?
- How to make my car comfortable AND handle?
- quick Camber question>>
- LT1 traction help
- Torque Arm Strength?
- Is K-member and Lowers engough for -2.5 camber?
- Shocks?? Newbie
- LMPerformance Pkg???
- Converting 94Z brakes to 98-02 Questions
- worth it to upgrade to 1le front springs?
- Full Suspension setup 700 - 800 rwhp?
- GC coilovers question...
- suspension
- rear shakes back and forth while driving????
- aftermarket spindle???
- stock rotors suck!!!
- Bilstein Shocks
- What would you guys a reccomend for a could Street/Corner carving setup?
- looking for info on WS6 Springs
- Rotational Squeaking is Freaking Me Out
- eibach to stock spring= worse handeling
- Please help me choose between these 2 mods.
- pics of a my parts i got waiting to be installed!!
- SLP linelock wiring
- wilwood w tcs and abs?
- BMR Relocation Brackets
- Brakes shaking bad!
- mitchntx / trackbird / anyone > Need help on wheels
- ABS Activating When Wheels not slipping
- building subframes...need specs
- Thinking about converting to Manual steering?
- Qa1 springs yay or nay
- Swaybar Bushings.. Do they make a difference..
- two questions
- Need suspension advice....
- will BMR trak pak increase chance of 10 bolt breaking?
- Brake Kit
- best torque arm (have space limitations)
- tightening the sway bar...
- Question on Manual Rack & Pinion
- Shocks absolutly needed for lowering?
- 2000 ws/6
- Best shocks money can buy for '01 WS6??
- Gabriel ultra shocks for front???? Any good???
- DIY SFC Install
- Stud on shock twists off!!!!! HELP!!!!!
- Intalling SLP SFCs
- Which SFCs ?
- Car don't turn?
- edlebrock torque arm
- Goin for 10's (maybe 9's) in a vert - what suspension upgrades will I need?
- banging noise under hard acceleration
- Subframe connectors: Bolt-on or welded?
- Vibration over 65
- Need Help!!! Front Noise
- what are relocation brakets for?
- install price?
- Bilstein HDs with Hotchkis springs?
- So many different ways...whats the most accurate way to measure & set pinion angle?
- UMI Performance Sale 10% off all our Suspension Products!
- Having cage installed... do I need SFCs now?
- Should I feel a Difference
- Best sway bar combo for Track Days/Road Racing??
- BMR Vrs Spohn Vrs UMI
- !Front Swaybar, How much time reduction?
- k-member time!!!!
- LG Motorsports G2 Torque Arms on sale to LS1 Tech members
- Brake fluid looks like coffee
- Fixed Banging BadZ PHR...
- Hotckis TVS suspension?
- Suspension Technique springs…
- Rear Brakes
- pics of bmr boxed installed!!!
- Torque Arm Problem
- 3" true duals + aftermarket torque arm?
- Front Swaybar Install
- What struts do ya recommend?
- Adding Tq Arm + Panhard rod. Benefits?
- Squeeking chassis
- car vibrates!
- Coilovers on all 4 corners??
- lowering kits
- Help with Line Lock
- What Exactly Will I Feel With A New Torque Arm?
- Suspension help. what shocks to run with G2 Super Springs
- qa1/hal springs which ones
- Brake/ABS Help
- Going 12 bolt rearend...what else do I need to order for hooking up on the strip?
- brake fluid that won't break down???
- Will someone please answer my questions......
- buying 2 rotors?
- lower control arm question
- Braking problem (suspect front rotors) but read..
- going to a th400 and shooting for 9s...what to upgrade?
- Problem with new Brembo Blanks--FYI
- Are KYB G2 shock/struts for the f-body any good??
- newbie to suspension needs a hand
- HAL QA1 + Bilstein question...
- custom roll-bar first impressions
- The "UPPER" Panhard brace....Is it really needed?
- Lowering Springs vs. Performance springs
- Z06 Brake converstion
- Best compromise pinion angle?
- What exactly does a PHR do?
- is a 24mm rear sway bar worth getting?
- looking for STB and SFC and Torque Arm
- Alston Tq-arm users step inside
- Which Shocks for a lowered TA?
- Could someone post a pic of a Powerslot rotor on car?
- Drag Spring for f-body question
- Are there light weight rotors
- Getting hals for the front need spring advice
- where to buy a pinion angle finder
- Broke Torque Arm Today......pics
- Torque Arm Selection
- Little prob with the brakes
- Are these defective rotors? (need a quick answer)
- Witch K member
- Experience with UMI products?
- i need help, iam having a hard time installing energy suspension torque arm bushing?
- strange problem with power steering cooler
- Need Advice
- Trackbird's adjustable PHR & LCA's
- best shock for a smooth ride?
- front brake clunk/stick
- Anyone have info on Edelbrock adj. arm?
- Are M6 and A4 stock torque arms the same?
- Alignment experts take a look.
- Can't get the caliper back on
- Swapping HAL shocks for type R question
- good handling F-body
- Drag Racing on ET Streets is going to put me in the wall...
- Lowering, what exactly changes??
- caliper question
- what tower brace to get?
- Quick SFC question
- Complete Rotor Install and Brake pad Replace...
- Need adivce
- ideas for ideal lowering job??
- C5 Bump Steer Tierod set on an F-body??
- BMR tubular SFC question
- brake flush
- PA Kmember and Aarm problem help!
- Best suspesion combination for 500rwh???
- Lowering springs - what spring rates are they?
- y2ks and brakes
- installling BMR adj Tq arm, how i set pinion angle
- CTS-V brakes on a F-body.
- QA-1 "R" series vs. Strange Silver series
- Question for the lowered Guys
- Sticking brakes and Vibration above 50 and when braking????
- Here are a few pics...
- BMR Torque Arm questions
- Rear brakes make a clicking noise
- Eibach race springs "John Ames"
- 98+ z28 braking distance
- Brakes get Soft after Hard Turn
- Front drives like its on rails but...Tail wag - why?
- 2 problems, need help
- brake probs
- tubular or boxed lca?
- Adjustable BMR torque arm tunnel clearance
- gonna buy a BMR Tq arm used, he said it needs a rubber mount?
- Where to buy Suspension Technique springs?
- New Pads and rotors, now they feel warped???
- Adjustable Panhard install
- noob help with suspension!
- Bilstein HD vs. Ultra ??
- Need Part# for Panhard Rod Bolts
- help with brake install
- Changing brake pads.....
- New pads/rotors/ss lines/ and brake fluid, pedal is mush, what happened?
- BMR LCA poly/rubber Up or Down?
- help with swaybar creaking
- Thrust angle excessive ? and adjustable panhard bar
- 60 ft times with stock torque arm
- Finally my SFCs are in
- C5 Front upgrade, bad issues>>
- bumpstops
- Help!!! Wholesale Direct C5 front rotors, which direction they go??
- any way to increase steering response time?
- Getting a clicking, clunking noise in front end
- BMR non-adj. TQ arm???
- Help finding rear spring isolators
- Stock ride height and anybody elese think their nose is higher than the rear ?
- BMR TRACK PACK T/A broke!!!!
- What are the tell-tale signs of a bad brake booster?
- anyone with true duals....
