View Full Version : Suspension & Brakes
- exhaust rubbing on rearend
- 1LE Suspension, How Would I Know?
- why does my car do this?
- spring question
- adjustable panhard bar????
- How much brake fluid for a complete flush?
- Brake Dilemma!!!
- what pads to get?
- do i really need a STB, sway bar and torque arm?
- G2 Coil over Kit...
- Question on BMR TA install
- Got my Metco LCAs installed....
- How is the rear of the Hotchkis SFC designed?
- Got my Sphon LCA's on the car!
- Airbag pressure on passenger side
- Worth it to go from poly/rod to rod/rod?
- Alignment with pro-kit (the drive home)
- is the motor t-arm and tranny mount from thunder good
- what kind of socket fo a 2000 camaro calipers?
- Through Floor Subframes.
- Need help getting BMR a-arm off
- Installed Wilwood Kit Today!!
- Front sway noise-HELP
- anyone pull the carpet back for KBDD install?
- BMR Xtreme Duty Rear Drag Sway Bar
- Front Sway Bar...
- Side to Side motion..
- laugh if you want, but...
- Setting up Adj. Panhard Rod
- relocation brackets need to be in car w/o being lowered?
- wheel hop HELP! already changed LCA's
- Y an adj. panhard?
- LCA's ????
- Baer Brake Packages
- Madman torque arm
- What size bolts for LCAs & PHB?
- Are all revalved Blisteins equal?
- any good web sites
- adjustable drag shocks?
- Well I got the ball joints seperated...
- spohn torque arm users
- SFC Pictures....
- Front Sway Bar ???? Are They Different???
- H&R Guys Inside:
- What size bolts for lca & phr?
- Opinions On G2 Springs
- What to do for autox?
- Eibach Pro Kit trick for rear?
- Lowering PHR attachment on axle side...
- Tricks to seperate ball joint?
- kbdd and bmr weight diff
- Decided to go with a BMR k-member, what company should I go w/on the a-arms?
- Edelbrock Torque Arm??
- Brake Squeak?
- Quick-Best way to change LCA's
- Spacers for springs???
- Porsche Brake Rotors?
- Parking Brake Messed Up
- where to start on suspension mods???
- Torque Arm??
- Problem with new Pro Kit ride height
- perfect stance...
- Lowered with DMS springs, time for new shocks
- Aerospace #
- high pitch noise from rear suspension
- weird noises from rear brakes
- alignment?
- I want my SS to lose some weight, k member, a arms, weight mods?
- SLP sfc fit
- Just got Gstop brake upgrade...can someone give me break in tips?
- why do my rotors keep warping?
- Adjusting parking brake
- How much can you adjust BMR LCA's?
- noise after new brakes installed
- sfc rust
- Ride Height
- need help choosing PHB
- Anyone use DMS lowering sprins AND HAL QA1 "R" front shocks? problems?
- Do I need to turn my new iRotors ?
- need new rotors
- BMR LCA Relocation brackets........
- Help RE battery relocation
- BMR LCAs?????
- Braking hard, can our cars handle it?
- Hotchkis vs. BMR
- Upper and lower A-Arm ?'s
- Vette Brakes!!
- Scraping noise while braking after shifter/susp. upgrades
- brake problems need help
- What is needed after new spring & shock install?
- Wheel Hop.. GONE! (Thanks UMI)
- poll: what sfc's to get
- Brakes have constant squeak during driving and when pressing the pedal?
- TA q's
- What material are the Hawk HPS Pads?
- Your Thoughts/Experiences with Spohn Products Please
- Hotchkis Read End Package??
- Slot Car Racing LCA's
- Best rotors?
- Homemade SCF's
- Do I need a Torque Arm?
- What to use to grind calipers.
- Torque Arms
- What makes your car launch hard...???
- swaybar ?s
- Whats a good autox setup?
- brakes and SFC's
- Who uses Bilstein HD's?
- rubbing noise when driving?
- Who's lowered their car w/o new shocks??
- BMR boxed or Spoohn Tublar LCA's
- Aerospace Brake install???
- bolt in relocation brackets?
- Any need to replace the Power Steering Fluid?
- What's the diameter of a Bilstein HD shock shaft?
- 1LE 21mm rear sway bar??
- Brakes squeal when in reverse
- dont know jack about brakes. need rotor, pads.. what else?
- Performance Alignment
- Ultimate suspension setup, your choices?
- Front BMR sawybar
- Budget Suspension Package
- Corvette Magnetic shocks
- Front drag springs??
- Cheapest Place for KYB Shocks
- Bad Wheelhop Problem
- Stuff req. w/drop springs
- lowering question.
- Newbie Suspension Questions
- Swaybars
- replacing stock torque arm bushing?
- need a drop but need advice!!!
- Please post your Hal settings for the street and the strip here.
- Loss of Ground clearance with Hotchkis SFC's?
- Not pleased with quality of Spohn SFC's!
- Do I run any risk removing the front sway bar and does it help at the strip?
- Brake pad input needed
- Which relo. bracket, spohn or bmr?
- What shocks to use?
- G2 LGMotorsports sfc
- Stock struts with full BMR frontal?
- BADZ's LCA's/Panhard rod!!!!!
- brake vibration
- What do you think of the stock handling for Z28
- Metco LCAs
- Sophn Torque Arm Clicking
- which sfc to get?
- KennyBrown SubFrame COnnectors?
- JC Whitney Rotors: Long Term Test Results
- How easy is it to install a LL?
- 4 point STB?
- Which k-member manufacturer and need help with options.
- Going with powerslot rotors and hawk pads this weekend. any tips or suggestions?
- with BMR K-member what are motor mount options?
- BMR Trac-Pak
- Chatter Clip Question
- Aftermarket K, OK for totaled car? 3rd Gen LS1 swap
- LGMotorsports street-race Panhard rod HELP!
- What rotors what calipers
- Got owned by the Curb
- hal adjustable shocks
- Fabricating brake lines?
- Best Suspension Combo
- LCA rod ends, which QA1?
- Who likes their iRotors?
- SS w/ SLP Suspension question
- Air Shocks - Install Pix
- Recommended Suspension Mods
- Newly Installed Adjustable QA1 Struts/Shocks
- Which SFC's...Kenny Brown or SLP?
- Wolfe Anti Roll bar welding question
- kyp agx shocks anyone try them like or dislike?
- E-brake assembly at brake plate. Please help!!
- brake fitting size
- Wheel spacers...
- To buy or not to buy...
- Swaybars Installed. Thanks for advice
- 1.25 drop
- Whats a good company to buy Abody Suspension Parts??
- Looking for stiffer rear lowering springs.....
- madman LCA's and PHR?
- Difference betw. C5 and LS1 front brakes
- suspension parts question
- Need Info on suspension
- Are there any numbers on a WS6 spring to identify them?
- Please post pics of Hotchkis drop w/WS6 wheels please...about to buy springs...
- KBDD users quick question
- Independent Rear Suspension into F-body
- Making use of my new welder
- what would help me more
- LS1 Brakes?? Brake Light not going off?
- Do I still "need" SFC's if I install an 8 point cage?
- Which lowering springs would work best in this situation?
- Hyperfirm Brake Line Kit. Rear Center line upgrade kit for Traction Control Cars
- abs inop
- pinion angle on a th400
- camber specs....need quick...
- Which TQ ARM is better Spohn or BMR?
- Kyb Adjustable Struts
- Kenny Brown lowering springs?
- guess what i got today??
- progressive vs fixed rate springs
- Where can I find....??? Help!!????
- #1 thing to help with cornering?
- anyone have kenny brown double diamond sfcs?
- Whats the point of adjustable control arms?
- Good shocks?
- aftermarket torque arm and brake dive...
- New Rims call for a drop
- post pics of your Camaro w/ BMR or Hotchkis springs plz
- Need Help!!!! Brake Problem.
- need question answered fast about dms.
- What Lowering springs and shocks?
- Anyone have these
- Just installed G2 LCAs & Brackets
- Question for those with lowered cars.....
- Anyone installed a BMR Drive shaft loop??
- Question about installing the Pro kit?
- Powersteering pump making loud noise only on startup.
- if your car is lowered, i need your help
- BMR SFC's loose LCA bolt
- H&R springs
- Zo6 Calipers
- chassis and handling ?'s
- Stock control arms?
- alignment range with stock suspension
- bolt or weld in cage?
- Torque Arm & Poly Trans Mount Installed
- Adjustable LCAs, do I need them?
- Good goop for sway bar bushings
- Difference between SLP Bilstein and Bilstein HDs?
- torque arm install
- Anyone have SLP level 1 shocks with Prokit?
- Lowering spring question
- Will line lock keep me from warping my rotors?
- Slotted Rotors
- What aftermarket brakes are you guys using?
- Is this possible?
- subframe connector question, help!!!!
- Alignment or something else?
- please help
- SLP Level 1 & SFCs
- Any tips for removing the power steering rack?
- Will the Spohn Tranny Mount TQ Arm fit with duals.
- 90/10 front shocks/struts
- Swaybars??
- Can I re-use factory bolts for new lca?
- Few questions
- Opinion on road noise for dual rod end LCA's?
