View Full Version : Suspension & Brakes
- Rotos turned/new pads--still squeal?
- Who makes the lightest boxed SFCs?
- Weird noise from new brakes
- 90/10 front strut options?
- shocks for GW coil overs > >
- muffler shop weld SFCs ?
- More info on the clunking that I can't isolate yet
- STB and tire wear
- 1.25" ST Fbody rear sway bar needed.
- tire rubbing - update 5/24
- RK Sport sway bars????
- Line Locks?
- Global West Traclink system question...
- Anybody used traction action lift bars......
- 1le sway bar
- Silicone grease for poly. bushings a must?
- Lighter Steering
- ? about stb
- Manual brakes? Can it be done?
- Tell me what to do guys *update*
- Wilwood Superlite 6 Big Brake Kit
- Suspension binding problem with BMR K-member setup
- Best source for Z28 suspension parts?
- Rattles, squeaks, knocks...
- Couple of Questions
- BMR or Hotchkis 1" drop peformance springs?
- Who sells Herb Adams PHB's?
- LCA questions?
- Autozone Rotors
- Any experience with the Baer 2 caliper setup?
- Which sponsor, besides tirerack sell Goodridge?
- trouble lining up rear with lca + relocation brack
- Need some advice, 1st time autocross Sunday
- Help needed leaning prob
- my brakes feel wierd at high speeds
- How to get more responsive steering?
- PHB questions?
- How much power does it take to bend tubular SFCs?
- Lowering questions?
- pics of LS1 with hals with stock rear springs?
- Installing SLP line lock....a question
- Dropped Spindles?
- "tires rubbing"... roll the fenders??
- LGM hypercoil springs???
- HAL Shock Question
- Anyone using MAC subframes?
- Best Brakes.....
- any pics of tubular sfc on your car?
- Couple general suspension questions
- Need some suspension pics!
- Lower Control Arms...What Kind to get?
- Are HAL's 12way shocks good for cornering?
- BMR 1" lowering springs. What's the ride like?
- HOW TO GET ALL 500HP TO THE GROUND???? HELP!!!!!!
- Removing rear brake calipers for drag racing, help
- ground clearance w/ Spohn TA
- SLP Eibachs and BIlstein shocks
- What pads for eradispeed rotors ?
- look for part number for threaded sleeve
- stock front springs with hal coilovers
- QA1 front shock adjusting
- strange or areospaces brakes
- BMR tubular a-arms: advantages/disadvantages?
- handeling difference
- 2000 SS rear sway bar size???
- my lca's didn't help much....
- Pedal is soft after SLP line lock install???+more?
- Think i found the culprit!
- My car sways like it has no sway bars...
- how do i get my z to handle better in the twistys
- Earl's or Goodridge SS Brake Lines?
- New brakes and rotors rubbing?
- Rototech Rotors any Good?
- Suburban Wandering and Pulling
- Raybesto Ceramic Pads?
- Installed new passenger and driver wheel bearings.
- Camaro Weight ?
- Need opinions on spongy brake line replacements
- Car is pulling left at highway speeds ?
- QA1 Setting Questions
- 1LE swaybar
- Pics of Eradispeeds please?
- BMR Subframe Connectors only for hardtop cars????
- Just installed the newer version BMR adj panhard.
- Ceramic Brakes
- Hal 12-way Adjustables
- Where to get the bolt that goes in the brake line?
- Bilstein HD vs. HAL for the rear
- Road course and autoX setups
- Rear sway bar install?
- Baer Claw Etched Rotors?
- Anyone ever remove they're EBCM or replace it?
- Anyone's stock rear sway bar endlinks clunk?
- Unplugged hose from brake master cylinder...
- What size rear sway bar bushings do I need???
- SLP Roll Control-Ideas on where to mount toggle
- Need help with suspension
- Old pads ok to use with new rotors
- BRAKE EXPERTS...Please help quick with caliper ?
- Anybody get roll cage from GP yet? TBYRNE?
- True Duals with SFC's
- bolt in or weld relecation brackets
- is there a cure for throttle-off oversteer?
- Tubular or boxed?
- ? Regarding Caliper clip and caliper pins...
- will stock shocks work with lowering springs?
- drag launch spring
- Spring Substitute
- Need some quick help, ASAP!
- Threaded Sleeve on the caliper is stuck...
- Where do I get replacement wheel bearings?
- Do our front wheels have Wheel Bearings?
- Suspension Setup
- ABS problem...?
- Eradispeeds- Brake upgrade or just Eye candy?
- Hows this setup? everyones opinion needed inside.
- Lowering package with the least amount of lowering
- Powder coating brake rotors
- Lowering the front... what gets affected?
- What combo w/ LGM Hypercoil springs?
- Wheels not sitting evenly in wells in the rear
- Switching from drum rear to disc rear
- Brake bleeding question...
- Would this spring position (current mounting)clunk
- Front drivers side caliper wont go in straight! he
- 4th Gen BBK
- Need alignment specs
- my brakes r actin weird
- My rear is higher on one side vs. the other...
- SS suspension
- Good pads with least brake dust?
- my car is jacked up on 1 side......pics inside
- Lowering package (Rookie here, so help)
- Trick Springs???????
- eibach spring question
- ground clearance
- Need suggestion on brake pads.
- Can I put grease fittings on my BMR A arms?
- Lowering Collector Edition
- SLP Bilstein Suspension Package! Lowers the car??
- Issues swapping between HPS and HP+ on same rotors
- r u guys running tublar or boxed
- installing BMR boxed SFC??
- hal front spring
- Replacing brakes. Hawks or OEM AC Delcos?
- Coilovers??
- How much is this T/A Lowered??
- How long are stock LCAs, center-to-center?
- Lower Cost Alternative to BMR
- Wheel hop & tire pressure?
- spring question come inside please
- steering wheel 90 deg crooked, alignment is ok
- DMS Springs
- LOWER pricing for T BYRNE suspension components!
- Convertible Rear Springs??
- New brakes but crazy sound....
- Front Hals and the "snubber" that is non-existent
- Rear coil spring insulator
- What Set of rotors, and Where to get them??
- I think my Hal's adjustability is non-existant
- What size Torx bit is the driver's side struttower
- So I got me an adjustable PHB, now what?
- Anybody have sportlines come inside
- Anybody running sportlines come inside
- Please help my new suspension went crazy!!
- What companies make Tubular K-Member's?
- loud boom heard
- Tire Rub
- lowerings springs not so low...
- Cost of brake backing plates
- TEST forum 6
- Please help me pick shocks ...
- Inside of calipers are rusty looking, questions...
- Brake install questions.... fluid and SS lines
- That damn Torx bolt under the master cylinder... HELP~!
- Front End Alignment Specs??
- Anyone have pics of SS with pro-kit
- traction how-to?
- BMR K Member Install, anything I need to know before I start?
- Front Swaybar??
- Need help with caliper and to anyone who has had their calipers powdercoated.
- Will ZO6 calipers fit on a 2000 SS?
- Just got new tires
- Where can I get red factory replacement calipers for a 2000 SS?
- high speed vibration, expected or too much
- Help with Eibach Springs?
- I cant hook at ALL Nitto 555 vs 555r
- DMS springs installed... Very pleased
- Autozone Rotors?
- sfc and oil fill tube
- SLP Level 1 Suspension GP
- lowered car, now does hook
- Brake line question
- suspension squeaking and banging?
- help with pinion angle
- K member torque specs?
- Hows this tire?
- How to tighten Castle nut that holds spindle onto lower A-Arm?
- Who makes a good subframe connector??
- hotchkis torque arm mount
- Help: LS1 brakes on an LT1
- Which torque arm?
- BMR K-member defective?!?
- aftermarket brake rotor question
- Just got my DMS springs...
- What is the differences / Advantages between these two LCA's
- KVR cross-drilled rotors - cracks after 1 year
- Changed front brake pads, should calipers..
- traction control system
- Is an LS1 master cyl and brake booster better than one from an LT1?
- kyb's and bmr's??
- Will I have problems with SLP Weld On SFC and QTP or FLP headers?
- how 2 adjust BMR LCA's?
- 21mm rear sway bar vs 22mm
- Where is the rubber thing you remove by the rear springs to lower your car?
- Caliper and bleeding questions?
- What pads for eradispeeds?
- Any con to using a lightweight K-member?
- noise re- abs
- C'mon Monday!
- Need Victoracers ASAP
- Sure Stop Rotors?
- Dimensions of Boxed LCAs
- Wilwood 6 piston fronts
- just got my spohn torque arm?
- New rotors and pads...
- Which Fuse to pull to disable ABS?
- What brand powersteerin cooler?
- HP Brake lines for traction control car
- How about this brake kit?
- Power steering fluid for 01 LS1 car
- Longer LCA bolt with sub-frames?
- 1LE question
- Can someone explain poly/poly and rod/rod,heim joints to me?
- Which relocation brackets
- Anyone using kyb agx shocks?
- Thunder Racing Brake package
- Subframes: Should the weld points be on the frame?
- A4 No Stall Can I run Slicks on a 10 Bolt?
- front brake upgrade info
- have questions on Poly bushings...
- Any make their own subs?
- Life expectancy of stock shocks?
- SFC`s- weld in vs. bolt in
- Rod ends & loc-tite?
- suspension set up for autox
- HAL FRONT SHOCKS W/COILOVER'S W/IRON BLOCK???????
- Anyone help? I've got squeeling brakes...
- 275 or 285 for 9.5" rim. BFG KD any good or Nittos all around?
- Advise/ Pics of Edelbrock 3pt STB???
