View Full Version : Suspension & Brakes
- Rod ends & loc-tite?
- suspension set up for autox
- HAL FRONT SHOCKS W/COILOVER'S W/IRON BLOCK???????
- Anyone help? I've got squeeling brakes...
- 275 or 285 for 9.5" rim. BFG KD any good or Nittos all around?
- Advise/ Pics of Edelbrock 3pt STB???
- better brakes
- What shocks?
- Broken brakes....need part number
- C5 Caliper swap questions
- Front end alignment specs
- on the brakes the steering wheel shakes
- Anyone tried monroe sense a trac with the pro-kit
- Debating between Springs
- Vibration at 80mph
- Can someone help me out with my rotor swap?
- BMR Lower A-arms and Hals popping!
- Edelbrock performer IAS shocks and struts?
- 35mm or 32mm Front Sway Bar??
- Sway bar questions for the pros.......
- NEXT MOD HELP: Torque Converter or Brake Upgrade
- setting up for road racing?
- V6 Rear Coil Springs
- suspension combo ?
- Eradispeed rotors are loud.. normal?
- ABS operation w/ different tire diameters??
- Best wheels and tire combo?
- sway bar spacer kit for a moser 12bolt
- Shock stuck in upper mount
- Broken Stud off Hub
- Trans Am Vs. Formula
- E-bach pro-kit hows the ride
- Slp bolt on subs???
- ADJ. PHR really necesary with hotchis springs
- Rear stud length? With 15x10 Draglites!
- ARP wheel studs
- Abs and brk light on ???????
- Difference between Spherical and Reg. Panhards
- Shocks for lowered car?
- LCA bolt torque specs.
- Caliper bolt sleeve froze in place?
- bump steer kit
- 28's and y2y suspension?'s
- Hal's?
- Hal ride height for best traction?
- 98 C5 wheels fit LS1 TA??
- breaks shake car
- DO ceramic pads perform as well as non cerm.?
- those with hotchkis springs come inside
- WHY O' WHY does this happen ?????
- leaking abs be the man and throw some info
- BMR tubular LCA's
- Opinions wanted; Best 17" drag radial (traction)
- Which spring compressor??
- Questions about mods
- whats needed when lowering car
- Easiest way to install BMR Kmember? .. already have motor out...
- Thunder Racing Lowering Pkg
- K member and A arm install questions
- please tell me nitto tires come in 18!
- Need new rod/rod LCAs. Which?
- Are poly motor mounts?
- Breaking in new rotors and pads
- QA1?????
- want your ideas for autox suspension
- Anyone running 10s or 11s on lowering springs?
- Torque Arm Question...
- Anyone running these shocks
- need camber info please going ---
- The age old tire question
- a must read
- NEED TRACTION ON TAKE-OFF
- Question about uninstalling sub-frame connectors?
- What size wheels and skinnies to go with?
- Need help diagnosing this "rubbing" feeling
- LT1 AND LS1 SUBFRAME CONNECTORS
- Are shocks a must when lowering with Eibachs?
- Ever heard of EMC rotors?
- need someone with suspension experience inside...
- How much heavier are Powerslots and Autozone Rotors than stock?
- Ball Joint Greasing, Any Tricks?
- Edlebrock shocks on a Pro-Kit? (HP TV)
- Bleeding brakes....
- Will relocation brackets lower your car?
- Vibration when lowered car?
- any easy way to raise/lower hals?
- Suspension torque specs
- 18x9.5 verse 18x10.5
- Does your adjustable BMR Panhard Rod look like this? (pics)
- People with Ground Control Coilovers please come in...
- Metcos vs. BMR tubular - weight comparison?
- Those with DMS springs....
- Damn parking brake! :(
- LCA relocation brackets on non-lowered car?
- Shorter Turning Radius, Is It Possible?
- Looking For Better Steering Pump & Rack
- sphoon TQ arm and 9'' and QTPs
- Just picked up my Autozone rear rotors...
- Help with power steering problem.
- anyone using hawk hps pads
- GM & Warped Rotors!!! Please come in!
- Revalving Bilsteins when lowering...
- ASAP: EBC drilled & slotted rotors warp/crack YES/NO?
- Is it any good?
- Bringing downt the front end of the Bilstein susp.???
- how much camber adjustment is in the stock suspension??
- What are the BEST parts for a 1/4 mile care?
- Anyone Who has G2 Sway Bars?
- Will Hal's fit on the Prokit?
- Track WEIGHT
- Help removing A arms
- Best All Purpose Tire on Stock Rims: 99 Z28
- getting traction without drag radials
- 98 TA shocks for the street only
- Problem with BFG Drag radials
- boxing Control arms, Panhard bar? worth it?
- Will I get good Traction with these?
- What lower control arms??
- Revalved Bilstiens still on backorder?
- Pictures of installed SLP SFC´s?
- best rotors and pads
- Can someone post pics of an LS1 with the DMS springs?
- convertible - free parts!
- People who have wolfe roll cages come in
- Correct way to weld in subframe conn.?????
- People running 15x3.5 or 4 on the street please come in
- Tires for $113 a piece , Hankook
- Stock caliper piston sizes?
- How offten do rod ends need to be replaced
- -- BEWARE -- striker754 LCAs for sale
- Which Springs
- Roll cage / sub frame cont. question
- Goodyear $50 Cash Card...
- how long to change rearend and fr, shocks?
- Different rear tires
- paging 2001camaroguy
- Rattling from rear sway bar endlinks!
- light weight rotors?
- questions about HAL shocks
- Got 4.10s, want a better bite
- Sway Bar Removal Help Please...I'm stumped
- some info on lowering Please Help i am ready to buy everything but what?
- dms springs?
- Anyone tried AC-Delco Road Response shocks?
- Need Alignment Help (G2 Springs, 17x9, 275/40/17)
- camber/caster?
- suspension parts
- suspension parts
- Removing calipers
- Wast of money or good to have????
- Importance of lower unsprung weight?
- torque arm ??
- Help buying BMR K-member....
- Problem woth HAL front kit
- Pics of G2 coilovers
- Does anybody have pictures of the MadMan Subframe Connectors?
- What subframe connectors go W/FLPs
- Tip For Fixing The Goodridge Brakeline Kit
- koni / bilsten combo ? please help
- Need New Tires...want better traction
- alignment??
- Thinking about Porsche Brake system, any input?
- ThunderRacing LS1 Braking Package Reviews?
- whats wrong with my car?whatdo I need?
- Does your aftermarket drop change all the time?
- Will Hooker LT's fit with KBDD SFC's?
- Lowering with Sportlines... need anything?
- Pics of SS with BMR springs!
- Wearever rotors, pads?
- RR and autox shocks?? Edelbrock IAS??
- Bilstien HD or revalved bilstiens?
- Earl's Hyperfirm Brake lines?
- shock therapy???
- shock therapy???
- Will 4.10's in a stock rear break racing from a roll?
- Pics of 335/35/18s on the rear within
- c5 front calipers on the back of a C5?
- Anyone else noticed this with lowering springs?
- Does this sound like a good clutch set-up to you guys?
- Pics of my TA w/ 11s and 315s on all 4 corners
- susp. questions
- Thuder Racing Lowering kit?
- Brake Pad metal clips
- Anyone actually seen a broken windshield w/ 3pt STB
- is this normal?
- 15x8 pro stars/ what size street tire?
- prothane bushings
- Need shock help ASAP!
- Easiest Order To Install????
- help on slick sizes
- bear brake systems.... ADVICE
- 1998 camaro max rim size
- Trailing arms
- calling all handling experts
- Need some help with part #s
- FS: G2 Poly/Rod Lower Control Arms in Black
- Why won't my piston go back in the caliper?
- need new tires.... :( blowout on way to SBN.
- Right rear is 1/4 higher than left!?!?!?!
- Do springs go bad? 60k miles?
- lowering and exhaust
- KYB AGX'S + DMS springs?
- torque arm question
- Magnetic shocks
- 315/35/17s on 17x11 GS ZR1 wheels ... on ALL 4 CORNERS
- Pics of BMR Springs on Camaro's
- what c5 wheels/ offsets fit my 98 z28
- quick question about a brake job
- Will these rotors work?
- Nitto 555 variants - What's the difference?
- Am I driving a bus?!!!
- Shock/Spring ?? inside:
- Clank over Speed Bumps??
- coil overs
- Stock skid pad #'s?
- GM driveshaft recall?
- step by step instructions on shaving calipers???
- Who can understad the numbers on a tire, I have a problem.
- tell me what you guys think ?
- Problem with line lock during burnouts...
- What first for handling? Shocks/Springs or Sway Bars?
- PSI for 245/50/16 nittos.....
- Spohn Torque Arm?
- Auto zone extreme rotors??
- What do you guys think about the DMS Signature Series Suspension Package?
- Pickin the brains of suspension experts!
- How to delete ABS
- Handling difference between 18" and 17" setups?
- WS6 Suspension adequate for 440 Rwhp???
- QA1 ?
- How Much Would My Front Raise?
- Brake kit opinions...
- KBDD SFC
- Pro-kit install, bad news but fixed
- Where to buy Grand Sport rims??
- Question about AZ Vette rotors on F-body...
- KBDD and Mac Header +Y-pipe question
- BFGoodrich drag radials
- hotchkis torque arm mount
- Full Rt or Lft turn from stop > Front wheels jump and skid
- Full Rt/Lft wheel turn from stop > Front wheels jump & skip
- picked up 60ft.
- Turn Eradispeed Rotors
- g- force tires
- Installing a few things soon
- 9.5" Rim (Front) - What's the smallest tire?
- What don't I know?
- Who runs 315 Nitto 555R's?
