View Full Version : Suspension & Brakes
  1. Are these spring rates and drop height good.
  2. Need spring advice. Confused from all the info.
  3. Slp or hd bilsteins
  4. UMI 4th of July Sale- 10% Off and Flat Rate Shipping!
  5. BMR 4th of July Sale 10% - OFF Most BMR Suspension Products
  6. Up To 40% Off - Spohn Performance Independence Celebration Sale
  7. advantages of using flaming River Power Rack
  8. Single or doubles
  9. Swapped rotors now brakes are a little bit spongy
  10. Rear shock help
  11. Negative camber wear
  12. seeking suspension advice
  13. Lowering Front Only (I have already used search)
  14. 4 link?
  15. Hawk HPS vs. Wagner Severe Duty pads?
  16. Strano Performance Parts SP141 Lowering springs update
  17. trying to bleed abs block and.one solenoid is stuck.
  18. Paging bmr
  19. Torrington bearing plates for coilover adjustments?
  20. Noob question: Installing UMI PHB poly/roto joint
  21. Jegster 8 point roll bar
  22. more c5 brake upgrade ???s
  23. Car shaking! alot.
  24. Synthetic grease for polyurethane lca's?
  25. HELP! brakes locking up and abs not pulsing after sitting
  26. Torqure Arm for 3.5" H-pipe
  27. sfc install ?s
  28. LS Camaro parking brake dust shield question
  29. Eibach Lowering Springs
  30. Probably a stupid wuestion, but........
  31. Energy suspension question
  32. Just installed BMR springs, not happy with rear *pics*
  33. Loud Front Suspension Pop
  34. T/A adj. or non adj.?
  35. Money well spent..
  36. rear suspension travel
  37. Brembo OE front rotors for $25
  38. C5 rotors Durastop/NAPA/AZ/ebay?
  39. Help! Mushy Brake Pedal After Replacing Everything
  40. help removing front LCAs
  41. Suspension advise getting a 9 inch
  42. Air ride vs full suspension
  43. pinion angle?
  44. steering wheel shaking while over 45mph
  45. Suspension adds for "body float"
  46. Will a Founders Perf. STB clear Fuel Rail Covers?
  47. Missing bolts, need help to replace!
  48. Brake proportion valve question?
  49. Founders Performance: Would you recommend them?
  50. BMR lowering springs
  51. severely lowered guys
  52. How often, grease UMI lca's ??
  53. Strano Performance Parts Customers, present or future, please read:
  54. Thinkin about ground control?
  55. metal ring on rotor
  56. adjustable vs non-adjustable. Advantages?
  57. Sfc ???
  58. alignment question
  59. Koni SA settings on your cars?
  60. Tubular A-Arms Install Questions
  61. Pending price change on Koni Shocks, effective 8/1
  62. Hose Mod
  63. watts link 97 f-body
  64. Rotor Won't Come Off WTF!?
  65. Break Lines
  66. Keep my boxed BMR SFCs, or get the UMI 3-point?
  67. Recommend me a good shock/strut
  68. Typical problem with E-brake not working
  69. A-Arms
  70. service manual says preferred camber +0.4 ???
  71. Brake Rotor and Brake Pad Suggestions Please??!!!
  72. Replacing Steering Gear?
  73. questions insisde. brakes and ride height help.
  74. Upper Shock Mount --- Where to buy?
  75. SLP Bilstein's in stock... Still $384.99/set
  76. Ebrake and Brake Line Bracket Help
  77. moving right along: finally lowered!
  78. Sagging
  79. vibration at the steering wheel above 45MPH
  80. control arms...
  81. Bilsteins or KYB AGX on 02 WS6?
  82. can someone make me a list of everything i need to do a suspention overall
  83. cut stock springs need new shcoks
  84. Rebuilding Steering Rack....
  85. C5 z06 brake fitment
  86. Car going back in forth between gears
  87. Suspension problems- strut/shock mount
  88. Clunking from rear when going over dips not bumps
  89. deleted ABS, brakes sticking
  90. How to adjust tq arm?
  91. left rear squatting (help)
  92. Can't install sway bar links on A/M a arms.
  93. Front driver side rotor grinded to shit! What's causing it?
  94. Front end help. Retaining/Jam nut size?
  95. Difference Between V8 & V6 K Member?
  96. UMI adj. tq arm & relo bracket
  97. BMR Launches New Product - 2010+ Camaro Rear Lower Control Arms (TCA028)
  98. Thinking of putting UMI stage 4 front kit on my car, thoughts?
  99. front hub width
  100. Another clunk thread
  101. Setting car up for street races: dig to 50ish
  102. BMR 1" lowering A Arms, Stranos, and Konis. PICS
  103. lug nut torque observation
  104. Instant Center: Experts Only
  105. Need suggestions on rear suspension setup.
  106. Rotors Moving/Clunking
  107. ABS lights on
  108. UMI solid mounts with UMI k member
  109. will 2010 stock 14" rotors fit on 04 gto?
  110. front wheel alignment issues, wheel to far back.
  111. My alignment
  112. Need help asap!!
  113. new tie rods?
  114. Cost to weld sub frame connectors?
  115. general brake question
  116. upper shock mount hardware
  117. Need advice
  118. Koni/Strano or custom susp from UE
  119. jam nuts wont loosen on BMR phb
  120. Brake issues... No peddle pressure?!?!?!?!?!
  121. Strano Spring update: 6/14/11
  122. Eibach Pro Kit
  123. best brakes for a 17" Rim for the price?
  124. BMR or Strano Lowering Springs?
  125. Bump Stops
  126. set up help
  127. tubular k with upper and lower control arms
  128. Removed brake booster now pedal is hard?
  129. I saved a dogs life, but killed a wheel
  130. suspension settings for an m6 on drs
  131. Difference with chrome moly LCAs
  132. Burkhart TQ Arm question
  133. torque arm/ driveshaft question
  134. What's the difference in AC Delco rotors?
  135. Solid UMI mounts installed.
  136. HELP. My front brakes don't work
  137. Looking for Rotors
  138. Cleaning up brake calipers
  139. Posssible reasons?
  140. Question on Springs
  141. picked up some used koni shocks, quick question.
  142. mini tubs
  143. new brakes, grinding noise from the rear
  144. ABS INOP Light Came on...
  145. Roll Bar Install
  146. F-Body front hubs
  147. Experiencing some wheel hop, suggestions?
  148. Remote Torque arm mount?
  149. Torque spec for torque arm to torque arm bracket bolts?
  150. Spohn double del sphere panhard bar length
  151. Removing the Rear Control Arm Bushing Sleeve
  152. which lca to get ?
  153. Best place for rotors and pads
  154. QA1 Shocks
  155. Stock Suspension vs Coilover Suspension Question
  156. Is this normal
  157. High speed vibration and I checked EVERYTHING!
  158. Difference in FE4 and F41 lower control arms?
  159. '00 z28
  160. Looking for springs
  161. Quick question about suspension problem.
  162. Painted Calipers.
  163. Thanks for a great first HPDE!
  164. Turning warped rotors, w/o replacing pads?
  165. Sqeeky shocks HELP!
  166. Anyone recommend good LCA's for use with Watts link?
  167. Anyone know where to get custom brake lines for CTS-V calipers?
  168. Suspension or Tire Issue? Car getting slower
  169. Shocks and springs help please!!
  170. a STB that will fit??
  171. Need pics of Lt1s lowered....
  172. Better mod for the money: Shocks or Poly Bushings?
  173. ls1 f body master cylinder brake line size??
  174. Need Brake Upgrade in the WORST Way
  175. Two point or three point subframe connectors
  176. Umi and TSP
  177. what springs with rear strange shocks???
  178. AFCO install questions help
  179. Brake line from front to rear
  180. Brake bleeders, Firebird & Corvette
  181. s60 and bmr torque arm problem
  182. stock shocks shot
  183. Rear, off-set LCAs only available with rod ends?
  184. strut tower brace
  185. shocks & struts
  186. ground control with konis?
  187. Do rear springs just pull out?
  188. Any feedback on Koni STR's?
  189. Very Loud Grinding Noise Coming From The Rear Brakes
  190. Brake question
  191. Will these calipers fit?
  192. Squeaky new brakes. Please help!
  193. Big Brake Kit
  194. Master Cylinder Question
  195. Another Driveshaft Safety Loop thread
  196. Did home boy and me mount this upside down?
  197. Suggestions for Brakes?
  198. Any advice
  199. Brembo Blanks - Rear
  200. How to get low!
  201. alignment question
  202. Raising tq arm mounting point higher up in chassis ok on lowered car ?
  203. Master cylinder thread sizes? Urgent
  204. Torque arm bushing Mount problem
  205. Suspension recommendations
  206. no impact gun on rotors?
  207. question about spindles
  208. Drive shaft noise?
  209. do front adjustable shocks/struts lower the car
  210. Steering rack and shaft issue in here!!
  211. Strano springs and KYB agx shocks
  212. Will a Jegster nonadjustable torque arm fit a moser 9"
  213. Bent Spindle???
  214. Rear Springs
  215. ABS Block Brake Line Cross Threading
  216. Adjustable rear springs
  217. front shock install questions
  218. Brake Install Write-Up
  219. what shocks are you running with sportlines?
  220. zo6 brake conversion on my 02 z
  221. awful wheel hop
  222. Options to protect against removed bumpstops?
  223. help - vogtland springs too low
  224. Clunking and jerking from the rear end
  225. Serious Vibration ?
  226. Torn Transmission mount, replacement recommendations?
  227. Tower Braces
  228. Rear wiggles from bumps
  229. BMR rear control arms non-adustable
  230. What angles for engine/tranny and rear end for street/strip?
  231. rotors?
  232. lowering spring install, $500. is this accurate?
  233. Upper shock bolt will not budge
  234. Whats everyone doing for bumpstops?
  235. Complete suspension
  236. Brakes to the floor?
  237. Aftermarket TA/Exhaust and ground clearance ?'s
  238. rack and pinion swap
  239. New koni/h&r setup
  240. Help! Anyone running a Spohn DSL Crossmember (part#405) with Eibach Sportline Springs
  241. Ridin' on Strano/Koni!:nod:
  242. Crash
  243. front wheel tick noise
  244. Why would I want an aftermarket Panhard bar or LCA's?
  245. Squeaky Rear Suspension
  246. pulling the ABS
  247. Power Steering not working after shipping car
  248. Emergency brake lever access
  249. blew out my front right AGX shock
  250. Will C5 Calipers On F-Body Rotor Clear 15" Skinnies??
