View Full Version : Suspension & Brakes
- C5Z brakes on LT1
- aerospace brake quality?
- Swiss cheese the stock k member!!
- 2002 Camaro Z28 Strut Bar
- will 05-06 GTO brakes fit 4th gen?
- Just a little interesting teaser shot from the BMR Development room
- Koni STR.T's and HP 2.5 kits are in stock
- Power steering pump
- Question on the rear bump stop spacer
- Which Founders PHB?
- Softer suspension for 2002 Camaro SS SLP: New Shocks or Springs?
- Anyone Drag Race Koni SA's ??
- slp torque arm
- ASR INOP / ABS before car even moves.. weird problem
- Driver side sits higher
- When to replace shock mounts?
- MWC full front race kit, what specs should i use for alignment
- One thing leads to another!!!
- Car Slanted/Leaning to the Right
- Alignment in the AM....any words....
- I need Advice: Installing a rack and pinion
- Adjustable panhard bar and alignment
- My car is too low...
- Confused about brake lines
- Thoughts about these ebay brakes?
- Good first Suspension Upgrades
- Tunnel brace/ drive shaft safety loop
- Is this a moog k6178?
- What do you guys think of brake motive?
- MWC front/rear suspension questions
- Bmr lowering springs drops
- Bottoming out problems help
- Almost Ready for Alignment (pics)
- Koni/BMR Front Strut Question
- noise (creaking/clunking) frome suspension
- Looking for factory torque arm mounting pictures
- Will the heater hose mod effect anything?
- Suspension
- Does This Look Correct?
- Just Gotta Ask.....
- parts compatability
- Best suspension mods for street car?
- Driving with 1 broken front strut mount, how dangerous?
- Shock Tower Brace
- Fully eliminate wheel hop?
- 4 channel line lock on a 3 channel car?
- rear wheel sticking out
- Ground Clearance suggestions?
- Alignment recommendations
- wheel stud help
- Thanks UMI performance
- Factory SLP Bilstein Suspension VS BMR Springs
- Poly Bushing Question
- So much for German engineering
- Brake suggestions for lt1?
- wheel spin and convertibles
- K-members, control arms and some common misconceptions
- Rear shock - spacer?
- New Koni shock possibly bad?
- Painting Suspension
- Qa1 vs qa1 r differences and is it worth it.
- Groaning/straining squeaking noise when turning.
- time 4 new brakes-upgrades?
- profab k member
- bmr turbo k member
- need help with weak brakes
- Running brake lines after tubular k/upper/lower swap
- Weak brakes need help
- please help with suspension
- polyurethane bushing replacement help
- alignment after relocation brackets?
- Tubular K-Member and Manual Rack
- Koni front spring perch seat question
- how do i tighten e-brake cables
- rear isolator and heater hose together
- Hydratech dealers?
- whats your ride height
- Alignment Problems
- need front LCA bolt!
- First time replacing shocks. What else to replace while they're out?
- Sound of a broken Torque rem or transmission mount?
- What rear shocks for 4th gen fbody, turbo, 6 speed
- Budget, Susp options
- My brakes will not bleed
- Poly engine mounts aftermarket k
- Need help ASAP-Torque arm bushing install problem
- Labor Day Sale. Until Sep 4th!
- Labor Day Sale!
- Educate a noob on the advantages of lowering
- Break upper or lower ball joint in replacing front shocks/springs
- 1000hp turbo 6 speed afco vs strange front coilovers
- Anyone have a wiring diagram for the abs module?
- Anyone here rebuild and powder coat calipers?
- Are my CTS-v calipers now paperweights?
- Keeping ABS with Moser M9 ?
- 99 silverado 5.3 prerunner?
- Spohn torque arm WTF?!
- 4 channel/ 3 channel rear end
- Spring Ratings database for F-bodies
- Wheel hop from take off
- UMI Sub frame connecors hitting pinch welds
- Adjusting pinion angle process!
- rear end brake lines ?????????????help
- Viking coilovers--gas charged or not?
- Cruise control
- Going racing... shop will be open
- source for eradispeed friction rings?
- ONE tire is too far back...one tire is
- Z06 vs CTS V upgrade
- have 3000 to spend on suspension
- Shocks & Springs upgrade
- Pinion Angle... again
- 4th Gen WS6 suspension
- Does a Tow Hitch add any structural integrity?
- Suggested Drag Set Up
- Which lowering springs
- WTF??!? Brake piston won't compress!!
- Cutting strano springs... stupid idea?
- Steering shudder help
- BMR F-Body Rear Springs positive feedback
- 2001 Suburban - ABS Question
- WS6store Brake Package
- Anyone ever run Eibach Prokit springs on front and BMR/Strano on the rears??
- Moser 12 bolt... Need the right u joint
- Umi lcarb
- Do I need to compress springs to assemble front struts
- Help with trying to make car hook
- Strange question?
- Are subframe connectors worth it on a hard top Camaro?
- Koni Shock Value sale... ending, very soon
- Please help ASAP, I need to know the rear caliper bolt size
- Rear Lower coil spring Insulators
- Need help installing new BMR torque arm...
- Rear traction question after 3.90 gear install
- Reg C5 brake s or Z51?
- SLP long tubes.. problems with lowering
- Squating issues
- Stock torque arm? How much can it take at the track???
- BMR k-member bolts up, but looks off...
- Spohn swaybar rubbing shocks?
- Custom Braided brake line?
- BMR UMI QA1 SPOHN supsension, k frames, control arms etc!?!?
- Lakewood drag shocks for 93-02 f body
- Counterfeit Bremblos
- Brake Lines
- removing shock tower cap?
- What else should I replace when I put a new rack and pinion in?
- Best street LCAs
- Founders panhard bar
- Bleeding Brakes - No Air Bubbles but not a rock solid pedal
- cutting front springs on drag car
- Aftermarket torque arm DIY (Help)
- constant clunking sound
- ABS to no ABS
- Clunking when braking with intermediate pressure
- Brake lines
- Mityvac vs speed bleeders
- BMR's KM019 and violent shaking
- Relocating ABS. Can I extend communication wires
- No front sway bar street car. What to upgrade?
- What gets tightened with suspension loaded?
- UMI Releases New Product- Bolt In Rear Shock Relocation for the Camaro/Firebrid
- UMI Releases New Product- Bolt In Rear Coil Over Brackets for the Camaro/Firebrid
- ugh... updated 1le bushing info please...
- BMR Suspension Releases New Product - Tubular Lower Control Arms (TCA002)
- BMR Suspension Releases New Product - Motor Mount Solid Bushing Upgrade Kit (MM006)
- MWC suspension and rearend sets yet another record!
- AJE K-member questions
- Tick from front suspension...
- Brake system flush. rebuild as well? Dot4 or 5?
- Suspension refresh question
- Viking coilovers vs. Bilstein/BMR or Strano setup
- Help with Comp Cams Brake Vacuum Pump
- no break lights!
- can different size wheels (offset backspace) affect alignment ?
- Front K-member & suspension reccomendations
- Steering Backlash: '98 T/A
- How far along is the 98-02 transam handling compare to e46 bmw?
- hello
- Suspension Set up for Drag Radials
- Handbrake adjustment 2000 camaro ss
- Brakes. Rotors and pads! DD/weekend warrior!
- Driveshaft loop w/ tunnel brace torque arm?
- which torque arm?
- Airbar ride height issues
- Fays2 Watts Link help
- springs
- wheel jerking to the left or right after hitting a bump
- What lubricant/grease to use on caliper guide pins?
- ride height
- Torque Arm Rubbing
- 3rd gen bump stops (with or without spacer)
- UMI Torque Arm install Q's
- GTO IRS to SRA conversion... lil help?
- 9in relocation brackets
- steering/intermediate shaft bolt
- Straightening rear control arm mount..(pics)
- Strut tower brace won't fit/align
- how to make camaro's suspension STIFF
- vibration when full throttle 9in 4l80e
- new shocks.... so many choices
- Lowering springs and shocks?
- front brakes question
- Bushings/Ball Joints Replacement - Vendor(s)
- Back after a while with a 02 Z28
- Switched from 1in drop spring to 1.25in drop spring
- Ground clearance
- 18 inch wheels causing abs problems?
- afco coil over ?
- lakewood ds loop and umi tq arm/ 4l80e trans
- Something still wrong with the brakes....
- z28 adjustable suspension suggestions
- Drag spring questions on 02 ss
- WS6 Body Roll
- Lowering the front sway bar
- discontinued parts (need advice)
- popping noise when braking?
- 1998 ABS Module
- What to do with old QA1 HALs?
- MWC front suspension package on SALE!
- UMI Adjustable Uppers
- New shocks all around... What else? SPONSORS?
- can my motor and cam be causing no vacuum for brakes or something else?
- UMI LCA bolt sizes?
- lower steering column bearing - replacement?
- Do I have an adjustable LCA?
- Adjustable or non-adjustable LCA?
- R1 concepts & Baer rotors
- Car Handles Like Crap After Replacing , Pan Hard, LCA
- UMI 4th of July Sale- 10% off & Free Shipping!
- Best Lowering Springs 2001 ss
- UMI roto joints leaking grease
- C6 Z06 Brake Upgrade Question
- TA Girdle Clear Sway Bar
- Loose Rear Upper Shock Nut - Does not Tighten
- Strano Performance Springs are back in stock....
- Stock vs Bilstein shocks, which are better for drag
- Why Is my ride so harsh and jarring
- Wanting a ser of qa1's
- lca's or lca relocation bracket. Which is better for a budget drop?
- BMR Torque Arm Relo Crossmember Issue
- Switched from Eibach/QA1 HALs to Strano/SLP Bilsteins
- founders relo panhard .. too long ??? help
- Car not level after lower
- 06 gto creaking noise help! !!
- S5269 or S5271
- Aftermarket front sway bar + stock rear sway bar = ?
- adjustable panhard bar - needed when lowering car?
