View Full Version : Suspension & Brakes
- Sway bar question
- Koni shocks squeaking
- UMI front swaybar bracket braces...
- Question on noise ?
- Looking for some front and rear spring / shock suggestions
- Electronic Suspension
- Chirp with tire rotation after hitting curb
- C7 power on a LT1 (2nd gen)
- Heater Hose/‘99 Cobra Rear Spring Isolators
- Coil-overs vs static drop (4th Gen SS)
- GM brake pad cross reference help
- Need Advice/Input on Suspension Components
- 14 in. Wilwood rotor on 17" C5 ZO6 wheels?
- MWC K-Member Moved Wheels Forward
- Adjustable leaf spring shackle question
- Recommended bushings for 99 Camaro
- Clunking from front shock
- K member and Lower A arms
- 98 Camaro suspension upgrades/questions
- Help w/ Knee Assembly Info for 4th Gen Fbody (Trans Am WS6)
- How do wide wheels affect steering/suspension?
- Moog outer tie rod
- Brembos
- Sway Bar End Link Lengths
- upper ball joint lifespan
- Caster Adjustment Question
- mevotech lower control arm design issue
- Strano M/C Brace for 4th Gen....Unbelievable!!!
- rear control arms?
- Brake Line Routing AT vs M6
- Which coils? BMR or UMI? Or....???
- 98-02 F-Body rear parking brake mount/bracket
- Another option for big brakes on f-body cars
- What Viking Coil Over Spring ?
- Coilsprings
- Bushing list for 98-02 Camaro / Trans am?
- Throttle Position Controller Module
- Assistance on upgrades to help hook
- 4th gen shocks ?s
- 4th Gen Panhard Questions
- need help with brake pads for my daily
- Brake line kits
- BMR or Stock rear springs
- Popping noise from front suspension when driving
- '01 Firebird rear brakes locking up
- Suspension Check gen 4 fbody
- BMR torque arm bracket
- What's all needed for full suspension rebuild on a stock 01?
- Is there a difference in suspension on 2015-2019 Silverado's and Tahoe's?
- UMI subframe connectors problem on firebird 96 convertible
- 4th gen UMI adjustable LCA Install
- Super rough ride with all new suspension
- Wheel rub - Alignment Problem - Control arm upgrade
- BRAKE warning light
- Do These Rotors Exist?
- C5 Brake Setup - Low/Soft pedal when engine is running
- Shock Tower Brace
- Qa1 rear coilovers?
- teaser: Friday 4/1 is the day.... to save some money on "something"
- HELP, can’t find parking brake hardware
- ABS Sensor Interchangeability
- BMR torque arm DOMadjustable, Or relocation bracket?
- Mevotech control arms?
- Anyone driving with a Watts Link?
- Moog Upper Control Arm Bushings
- Wheel alignment question
- Only lower the rear?
- Bmr k-member without motor mount question
- Lower Front A Arm Bolts
- What Koni's did I buy.....4/4 or 4/3's???
- Prothane vs ES TQ Arm Bushing ‘00 Z28
- 1995 Camaro Z28 M6 Wheel Hop Help
- Manual brakes with stock calipers?
- Car swerving back and forth at highway speeds
- rear spring upper rubber insulator
- Strano Springs back in stock on 2/25/22
- Cut brake line?
- Koni sport and spring help
- Brake issues
- Springs ‘00 Z28
- Weld On SFC’s with Seat Brackets
- Umi road racing k memeber with on3 turbo kit
- J&M rear control arms
- Rear bump stops. They matter.
- MWC K Member near me to measure?
- Brake calipers "upgrades", number of pistons, and their sizes.
- Some No Prep and Street Drag Racing Breakdown with SRC Video
- How will a 9in affect my handling???
- Good video on Torque Arm drag Suspension
- can I do SRT.t and not new springs? don't want lower
- what do you guys recommend
- Tubular upper control arm question.
- Best Rack & pinion ???
- Wheel cylinder issue? 02 TA LS1 Ws6
- Aftermarket a arms for drag racing
- Leaf Springs for Drag Racing Part 2
- Stripped threads on brake line nut, any easy way out ?
- Abs inop
- Rear Brakes for 2000 SS (Drag)
- Moog balljoints leaking like a sieve
- C5 master cylinder fitting size?
- New Shocks & Bumpers
- Best power steering pump for hydroboost
- Help on launch
- CTSV Brakes & spare tire
- What springs, shocks combo for near stock ride height on SLP headers clearance
- Power Steering
- Front Sway Bar Broke
- Ridetech Price Increase coming.
- Does anyone know of the best bang for buck shocks and coilovers
- 2021 Black Friday wheel specials @ Strano Performance Parts
- 65 Chevelle Front Springs
- Hard Brake Line Replacement 01 Camaro?
- Strange s5070 Install/Review
- Adj rear or Drag bar w/ watts & 315s?
- WS6 Bump Stop confusion
- Afco Shocks stock springs?
- Hydroboost brake boosters anyone?
- Lowering/UMI treatment
- bolt in vs weld in subframe connectors
- Founders J&M 3 piece poly ball LCA assembly
- 4 channel vs 3 channel
- F body Brake Pads without ABS
- Who has a Turn One HP2 Power Steering pump?
- K-member ?
- Let brainstorm coilovers UMI VS Ground Control
- Coilover options for Ridetech bolt on rear 4 link
- Koni sport stuff, end of Sept 2021
- Sub frame connectors
- e brake cable routing
- Want to change to Koni's ..do I need springs too...?
- driveline vibration issues
- Bad springs causing bump stop to hit?
- BMR Turbo K-Member caster (rear) bolt hitting body
- 2021 camaro LT1 big brake upgrade
- How do you actually measure caster?
- 2000 ss camaro ls3 t56 s60
- Scraping noise/ Rear uneven
- Abs pump leaks. Can I swap to a non traction unit?
- Lowering springs + subframe connectors?
- No Prep Drag Racing Suspension Setup Part 2 | Back of the Track Front Suspension
- Where to buy Stock rear spring
- Any suggestions on rear caliper rebuild kits?
- Shocks need to be replaced, what other things should I replace?
- Anyone make a Bolt in cage for 98-02?
- Brake light, ABS and TCS lights on
- Advice for stripped Bilstein shock stud
- Hown many washers for a banjo fittings on the calipers
- abs fault but no light
- control arm
- My retarded rear end
- Did I damage my master cylinder?
- C6 spindle dimensions
- Issues with front suspension feeling "bouncy"
- LCA Bolts for MWC k-member
- Ridiculously Harsh Ride 99 Trans am
- Help finding name of this part and where to find one
- Strut replacement on a lowered car.
- What springs for rear Afco's
- Suspension set for sale. Should I get?
- Low pedal after cts brake swap
- Where to lift on engine for ps rack mounting bolt
- Bilstein install help, one quick question
- Strano SP141 springs back in stock
- Upgraded suspension constantly bottoming out
- CTSV 4 piston to rotor clearance question
- Line Lock/Roll Stop and Heat?
- Strut Tower Mounts Failing
- Brake line question for upgrade.
- Stock A arms on BMR Turbo K Member?
- 93 z28 K-member into V6
- ATTN Sponsors.....4th Jul sales ...
- ABS Delete Break Function.
- FOUND - Stock Fourth Gen LCA ABS Sensor Retainer
- Elongating lower a arm slots.
- Swaybar close to vikeing shock knob
- square tire setup question
- stock swaybar bushings
- 93-02 Wilwood brake idea
- Air Suspension?
- Pre made brake lines?
- 02 camaro suspension
- Correct rear spring clocking?
- Poly t/a bushing came out...now what?
- What to expect with these mods
- Line lock / roll control
- Torx bolt size
- Help with ABS Module Part Number
- shocks/struts with 19" wheels
- Fly n bye performance
- Bmr drag bar problem?
- Lower control arm bolt issues
- What is this?
- K-member bolt
- Front brakes dragging/ locking
- what best pads
- Do the CTS-V or Z06 6 piston front calipers bolt on
- Instant center issues?
- ATTN: UMI, BMR, Spohn, Strano and Founders Performance
- Vibration On Out of Corner Acceleration
- tie rods seem too short
- new suspension mod will they help??
- Brakes grinding when off pedal
- Cheap Rear Stock Sway Bar Kit
- suspension plus tires equals NVH?
- Help!! Pedal goes to the floor!!
- Adj Front LCA for lowered car alignments
- New tie rod replacement.. input appreciated
- UMI discount coupon
- 1995 Camaro Z28 M6 Lowered wrong, reuse stock springs?
- Question about rear DRAG ANTI ROLLBAR level
- Best brake line kit
- Rough ride
- Adj. Torque arm issues
- Question about ride height of my convertible 2002 ss
- Need new shocks and springs/base FB
- Need a EBCM.
- Bump Stop Relocation?
- Broken torque arm
- ATS Caliper Upgrade on 4th Gen and Wheel Fitment
- Need shocks and springs
- Installed rear lowering springs, got a 4x4
- Brake line/pipe size??
- What would be a good starting point....
- Rack and pinion question
- Recommended brake kit for 2002 Firebird
- Ls rear disc swap to 96 asr rear
- Best power steering pump for 99 Trans Am?
- Driveshaft rubbing safety loop - need advice
- How tall are gen 4 axil bumpstops?
- Suspension help
- Brake Master Cylinder bore size - 67 camaro
- Drag Racing Rear Suspension Upgrades with Penske Racing 7500 Double Adjustable Shocks
- Broken wire holder??
- Pinion Angle Confusion
- Front lower control arm bolt replacement.
- Shout out to FoundersPerformance
- “Brake” light after CTS brake swap
- 1999 FireBird ABS Light
- Torque Arm or Sway Bars
- Rough Rear suspension
- LT1 to 4 piston CTS-V brakes
- Koni STRT/Strano
- 8.8 guys
- Suspension help
- New approach to more angle? Daily /drift.
- Abs bleeding tool & securing brake lines
- Baer Extreme 6S front kit
- What to do for rear bump stops?
