View Full Version : Suspension & Brakes
- Odd creak and clunk from rear
- rear hub wiggles
- Koni shocks and Strano springs arrive in the morning...
- Suspension question
- Blank Rotors and Pads
- Torque Arm....tunnel brace mounted.....which has the best clearance......
- Manual Brakes (Stiff Pedal, no stopping power)
- sagging pretty hard on pass side
- question on lt1 power steering pump strong enough for ls1 rack
- Dust boot and bump stop?
- Bilstein Shocks and front spring seat .
- Two Piece Rotors- worth it?
- rattle after torque arm install
- Stabilizer end links - Poly vs. Rubber
- maximizing caster (pictures inside)
- Fikse FM5s in 17x9.5 and 11 brake upgrades
- Finally time to hook up! Lol
- Brakes spongy
- Coating LCAs & knuckles: Where NOT to powdercoat?
- Fedex man left me a box today...
- Hawk Quiet Slot Rotors?
- Spohn Tunnel Mount Torque Arm question.
- lower control arm and panhard bar question
- 60's with Strano springs -- what are yours?
- Terrible Brake Fade.. Suggestions on pads?
- c5 to stock brakes
- In (or on) car Video of the SCCA National Match Tour
- Solid pinion spacer.
- Compressing Stock Springs
- moser 9" torque arm bracket!?
- Strange SA rear Coil overs?
- Wheel Alignment specs
- Moog Upper Ball Joints
- KW Rebate Sale for orders through 7/31/13
- Stock V8 Springs for Drag Racing
- Tubbed 4th Gen
- camber with adjustable a arms
- Shocks and springs question
- mount mount torque arm?
- Need suggestions for new blank rotors
- Torque Arm for a Nitrous Car M6
- Want to launch harder
- wheel hop problem
- torque arm
- Need rear brake bracket bolt!
- Koni STR.T FINALLY available for 93-02 f-bodies?! (well, almost...)
- Front end help??
- need help deciding which brand to go with???
- Upper control arm support?
- lowering spring
- Jegs torque arm ?
- Brake fluid amount?
- front end higher on stock suspension?
- abs delete
- founders performance advise
- Offest axle issue
- C6 z06 CALIPERS on ls1 fbody?
- proper suspension setup?
- shock and spring package
- How do these rotors look?
- Gbody suspension
- Most Reliable/Recommended Spring Compressor?
- Help
- torque arm nut fell off
- LG Motorsports G2 Super Springs..can one collapse 1/2" instantly, but not the other..
- Some New MWC stuff for the LT guys
- Eric and Midwest Chassis!
- Strut mount question
- Bump stop question
- Adjustable Torque arm
- 95 ABS piping diagram needed
- Attention brake specialist!!!! "Sponsors"
- SFC causing larger wheel well gap?
- Car sits lower on one side.
- Help
- What shocks ?
- 18" Wheel Handling Negatives?
- Front sabilizer bar link, WS6
- Best way to line up lower control arms...
- quick QA1 rear shock question, sponsers step in.
- "thumping" sound coming from rear after install
- UMI Performance Sale 7-03 to 7-09- 10% off & $9.99 Shipping!
- bmr weld in subframe connectors
- Shorter spindle arm?
- BMR LCA's vs UMI LCA's
- Need help with suspension
- front strut bolts
- White brake hardline bracket?
- Verifying Spring Rates
- *Help** Popping sound coming from front left part of suspension
- ABS pump motor
- BMR SUSPENSION SALE @ coloradoSPEED
- Pictures of UMI's 2000 Trans Am- Full UMI Suspension & Viking Shocks
- Springs on Koni Lower Perch
- Questions about upgrading
- BMR Releases New Product - Turbo Low Mount K-member for 98-02 F-Body
- Adjusting ride height with QA1's or Vikings??
- Koni Sa Adjusters
- Torque specs for steering shaft?
- Stock WS6 front sway bar on Z28 worth doing?
- fbody braided brake line kit
- UMI Solid Motor mounts fit like crap with BMR k-member
- Baer Brakes Installed! Suspension Pics Inside!
- help me order SL6R rotors and pads
- Read this if you need to saw out your front lower arm bushing!
- 2002 ws6. Lower Control arms
- Car is unloading at the track
- Semi-soft pedal on GTO
- brake line/fitting sizes
- New shock/spring set up
- Replacement Rotors
- Is this ride height about average?
- Freeway vibration and ride harshness
- full braided stainless steel lines?
- 4 piston in the front 1 piston in the rear, is this an issue?
- Panhard bar end width?
- LCA relocation brackets...which hole?
- Rear brake problems
- What Spring for the added weight of an LQ9?
- Rear End Wobble?
- What would cause my right rear fender to be 1.5 inch lower than the right side....?
- Broken torque arm bolt
- lca relo bracket install help
- Strut sizes?
- quick questions on a highly modified car
- Koni Shock Value sale--EXTENDED!
- My flushed and stanced 00 TA on BBS'
- ABS Inop Intermittent
- Final Stance
- Steering slop?
- Springs/Lowering Question
- SLP SS shocks/springs on a Z28
- Any1 w. MWC torque arm for moser 9 in, come in
- ws6 brake upgrade an other stuff newbie here
- Stuck nut on coil over bolts
- 4 Piston Brembos Help.
- Steering Issues
- 4 Piston Brembos, ZO6 Rotors, and You.
- Lowering ride with UMI torque arm relocation
- guys with rear afcos
- 2001 camaro ss best stock spring
- Dumb question about disk brakes
- Aftermarket K member owners come in
- 60 foot times
- What brakes to use on my turbo 02 camaro?
- My Brakes Suck, Help!
- Ware to get longer brake lines
- coilovers
- I Thought Cutting Stock Springs Were Frowned Upon?
- LS1 Brake Conversion Problems ***UPDATE***
- Torque arm inadequate after cam/ UMI/MR LUOS PORN
- UMI torque arm relocation with poly transmission mount???
- Vibration...I'm lost
- UMI torque arm clunking - FIXED
- Eibach Sport Lowering Springs with 315's?
- How do you replace Brake lines?
- step on brake/ steering wheel vibrates
- stranos or next best things?
- just installed my founders rear suspension
- Raise front height?
- Brake Mock Up......Is this correct?
- UMI Boxed Front Lower Control Arms and Shock Hardware Size?
- Koni sale extended but don't wait!!!!
- Ride height and tires rubbing
- Watts Link
- Qa1 double adjustable settings.
- Installed travel limiters and lost 60ft help needed
- Heater Hose Mod + Rear Lowering Springs. Good or Bad? Help!
- steering wheel loose?
- FOunders panhard relocation kit
- Rear Spring + Sway Bar & Torque Arm
- anybody have these mevotech UCA's?
- Underneath Scraping
- 2000 camaro subframe connectors
- Brake pad contact less on one rotor?
- Steering making creaking noise....
- New bushings factory rear LCA = crooked?
- vibration getting worse
- Doing BMR & Koni's! Where does this go?!?!
- Spring and Shock combo
- afco installation help
- Lower A-arm removal question
- K member install and dropping oil pan
- Shock suggestions?
- Redundant but necessary shocks and springs question
- F-body suspension
- Homemade rear lca's, panhard bar, and torque arm
- Whats the best spring for bilstein shock
- LCA removal..
- My Founders Performance Review
- LT1 to LS1 Front Brake Upgrade
- pinion angle deflection advice
- still feels loose over rough surfaces (especially in turns)
- Lower ball joint out, removal question.
- big brakes on rear...hear me out
- how to adjust A arms and tie rods?
- spring and shock ride height question.
- Help BMR torque arm speedometer plug
- ls1 brakes on a 2nd gen f-body
- How do i tell these are stranos??
- RackDoctor manual rack ?'s
- manual brake question
- Correct endlink Length - Energy suspension
- Strut tower brace mounting
- ride height question
- 6LE C5 Brake upgrade issues
- Anyone able to get me a pic of assembled front coilover assembly?
- Drilling Jeep Bumpstops?
- Rack and Pinion replacement Question
- vibrations issues help needed.
- Eibach loweing springs comments and help
- just ordered my founders stuff
- Suspension question for a bolt on car.
- Lowering the Z
- brake fittings
- Car Sways Badly Under WOT - NEED HELP ASAP
- intructions on lg motorsport lg 3 point tsb
- LCA's install advice needed
- any idea how to install spohn rack/steering shaft
- single adjustable Poly/rod lost.
- Looking for a deal
- PA Racing Adjustable Lower A-Arm
- Best Price on Bilsteins???
- Drag Bag Question
- 275lb spring on street
- Vibration issue, read and give opinion!!!
- LCA Question
- Trans Am disc brake rear vs other options...
- It's called tramlining, right?
- BMR + Bilstein HD's
- Can a 4wd z71 be lowered? Odd question I know
- Spacers on front sway bar?
- Will Strano springs work w/ QA1 shocks?
- Spring rate recommendation
- UMI k member questions
- Bump steer tierods on Strano springs?
- Rack Dr. manual rack - A+
- Founders suspension?
- 4 Piston CTSV and 13" Rotor?
- Cutting my Shocks shaft to remove mounts. Will this work?
- Rock Auto parking brake cables for ls1 rear in LT car
- Wheel Hop Solutions???
- Brakes to clear 15" wheels
- Bmr tubualar K member welds breaking?
- Poly LCAs have got to go!!!
- Master cylinder install? Help.
- Please help cant turn left
- Quick disconnect swaybar link
- 2 pt. vs. 3 pt. subframe connectors
- bump stops hitting rims and tires..and saggy springs
