View Full Version : Suspension & Brakes
- ABS Light with video inside
- What all is needed to swap these shocks on?
- Are these the proper bumpstops?
- winter rebuild time
- Looking for LCA or PHB?
- LCA reloc bracket/stock LCA's?
- Decisions :/
- eibach drag launch vs. stock front springs
- fbody brakes; V6 versus V8 difference?
- Setting up suspention for certain 1/4 miles times... (F body)
- how many inches to lower????????????????????
- I would like to start building suspention components
- Suspension help please
- Can someone check my alignment? Issues...
- Can't get caliper back into place..
- 4130 Tube size comparison for suspension components
- wheel hop..TA or LCA bushings??
- how noticeable is 32mm sway bar
- 2011 brembos on a 98 z28
- Who makes the lightest tq arm?
- I'm torn...UMI or BMR???
- spindles for autox and toad racing application
- Time to lower 2001 SS
- sway bar and endlink question
- Tell me if I'm right. Math problem!
- Rotating poly bushings?
- Did you adjust your rear shocks after a heavy rear end install?
- Lowering Help
- Need some part number help
- Fbody rear coilovers stock location, you have em? pics?
- Putting together springs and shocks beforehand
- 99 SLP camaro front swaybar
- lowering and control arm position, suspension gurus chime in
- Time for some new shocks
- really bad axle hop issue
- Replacement ball joint for umi tubular a arms?
- advantages of converting to IRS over solid axle?
- I want to Lower my car, coilovers? springs? help?
- SJM ABS! Kit Install ?? Help
- What driveshaft safety loop for TSP duals?
- Need help finding bolts
- Braided lines question
- How does lowering affect suspension geometry and handling
- Question for stock suspension
- Advice on these parts?
- Relocation Brackets and LCA's
- Simple question about swapping rotors and pads..
- New LCA & Panhard Bar Questions
- 98 camaro hard brake pedal
- Sway Bar End Link Length for Lowered 4th Gen
- Help!! Just installed EIBACH PRO KIT, car sits lower on drivers side?? (pics)
- Lowering the Camaro
- LT1 vs LS1 4 channel rear wheel speed sensors?
- Stagg Shocks And Eibach Sportlings Review
- Shocks and Springs?
- Alignment with boxed LCA's?
- What Shocks To Use???
- SJM line lock help
- stiff steering - bad p/s pump?
- Why does my ABS/TCS light always come on?
- Spring Identification
- My UMI and BMR suspension build
- dependable drag suspension
- Looking to upgrade brakes
- Front upper spring mount/Upper A-Arm.
- mini tub questions
- Recommend me a Line Lock
- Real handling oriented Front lower control/A-arms!
- Coilover question
- suspension question
- has anyone ever made a 4 link for a f body
- auto cross
- Neat brake question. plug unhooked
- Anyone sell whole bushing/balljoint sets?
- wolfe roll cage compared to others? for 4th gen
- lcas
- Alignment with manual rack
- Need some ideas on shocks/springs F&R and Brakes.
- Anyone done an "A" body rear coil over?
- bagged f-body?
- Backing plates
- Bleeding brakes questions?
- Koni Sport Off Car Adj. (rears)
- Car pulls in rutts hard
- kyb Strut rebound question
- racing coil springs??
- Manual rack info
- brand of sway bar end links matter?
- Adj or Non - When upgrade to 8.8 or 12 bolt
- New sub frame connectors
- 5th gen brakes under 17s?
- Staggs shocks..?
- What should this cost me.
- subframe connector questions?
- Hub bearing assembly
- Suspension brand recommendations
- LS1 front caliper to spindle bolts?!?
- LCA and Panhard Bar?
- Shocks and struts
- Strano Lowering Springs or Eibach Drag Launch Springs?
- Anybody deal with Koni warranty?
- Vibration above 70
- BMR camber set up question...
- New brand I've never heard of?
- Pair of slotted rotors under 55 bucks...Anyone used these??
- 3 point SFCs or a Sway Bar kit?
- A arm help?
- Anyone ever have torque arm mount crack.
- eibach lowering springs
- in need of MM spacers for cts v
- BMR vs. Midwest
- UMI Performance New Product- Adjustable Boxed Lower A-arms
- My homemade torque arm relocation bracket. What yal think
- Up To 40% Off! Spohn Performance Holiday Sale
- UMI Thanksgiving Sale- 15% off and $9.99 Flat Rat Shipping!
- BMR Thanksgiving Sale - 15% OFF and $9.95 Shipping per Order
- 02 camaro, which stainless brake lines to get?
- Question about my slp springs on my 99 SS.
- Which mod next?
- Does anybody Know What size/thread flare fitting for brake lines for rear brakes
- Service vehicle, Brake and ABS light on after new battery??
- Strange sound after shock install, ideas please?
- Anyone make a wheel cylinder rebuild kit?
- Drag shocks and springs
- Alignment help!
- Installed my BrakeMotive Rotors and Pads
- Got some issues
- Best aftermarket drag brake set-up?
- Midwest Chassis manual rack?
- Stranos + KYB AGx anyone?
- Review on SLP Bilstein Shocks
- Front strut questions
- Suspension lowering combo question.
- off-set rack bushings ??? need??
- Suspension Gains?
- lakewood drag shocks
- what rear sway to match my 35 mm
- Car jack stands??
- DIY Subframe connectors ?? Who's done their own??
- Wheel alignment on a lowered car for better handling
- shocks , kyb- agx shocks ?
- any ideas on a roll cage ?
- Powdercoating my calipers
- Need help: ls1 suspension on lt1 car?
- Will any vendor sell front sportline springs only?
- what shock for a unique rear?
- spacer needed on camaro brembos like cts-v brembos??? need info asap!
- Who rebuilds shocks?
- Good price for C5 brake upgrade?
- Midwest Chassis Anti Roll Bar
- Sway bar question. What kind of difference will I notice going from 32/19 to 32/21?
- FYI - Upper Balljoint Replacements
- Eibach sway bar bushings/brackets?
- Suspension experts, I really need your help.
- Poly bushing install issues. NEED IDEAS
- Help with lower ball joint removal?install?
- Had some Spohn Solid Motor mounts put on..
- Opinion on shocks - Edelbrock or ??
- Quick Q: What brake pads do i get: HAWK
- Passenger Rear clunking=bad hub?
- pa racing k member any good?
- How much will the stock TA take in an M6
- Sping Replacement
- Bad to leave front suspension unloaded?
- BMR Launches New Product - Xtreme Anti-roll Bar (XSB001, XSB002)
- Need advice on COMPLETE Turn Key braking upgrade for 99 TA?
- Who sells Red Calipers for LS1's?
- Abs ?
- heavier duty spring
- BMR Lower A arms
- Tokicos and Eibachs??
- Back Shocks Only?
- HELP!! Need Springs + Shocks
- Torque arm problem
- aftermarket upper control arms....???
- New Video footage: My old car, new owner... same results
- Front Strut Torque Specs
- Pics of cars with lowered front ends?
- Money Spending/Credit Card Limiting Time....
- BMR Track Pack - Crossmember Height
- Someone talk me in to Koni 4/4s and stranos...my bank account is going to be hurting
- Lowering my car with Stranos...which PHB to choose??
- Help me pick my suspension!!
- Mini tubs
- All Koni sets of 4 shocks are on sale....
- Installing shocks, few questions
- 02 WS6 TA stock height replacement springs
- 02 TA Koni SA`s with Spohn Delrin LCA`s ... Squeak?
- Strano Performance Parts phones are down (please read)
- High speeds without front sway bar.
- removing the front shocks (Brake booster in the way)
- Line lock switch opinions/help
- Front wheels not parallel after K member install
- need a little suspension help..
- Can't reuse bolts when swapping to aftermarket K member?
- 02 TA Koni Single Adjustable Shock install Bushin Question
- have bmr weld in LCA relocations, which hole do i use
- UMI Torque Arm pinion angle question?
- 02 TA Rear Coil over Kit Benefit?
- Anyone running KYB 741034 AGX struts?
- I'm beginning to hate this car.
- Tq arm/ rearend problem
- loss rearend
- COPO has returned!
- So there is no GM parts upgrade for the rear caliper yet?
- C5 upper arm dimensions
- What ds loop to use with tunnel mount tq arm
- BMR Suspension Customers Dominate LSX Rumble Class at LSX Shootout
- Simple rear shock swap
- need help diagnosing a rear susp problem
- K-Member Sale?
- 98 camaro pulls to the left on hard acceleration+
- Installed new shocks--clunks
- Alignment after struts?
- Brake pedal going soft it hits the floor
- 9inch hitting drive shaft tunnel
- Post Pics of Your BMR Lowering Springs!
- Lowering springs going on today.
- getting a kmember soon need advice
- rear springs for drag racing.
- Looking for a 13" Hat-Mount Rotor...
- BMR full lenght torque arm issue
- C5 rotor conversion bracket question
- Paging UMI, Motor Mount Question
- Rear sway bar problem.... (with pictures)
- Lowering springs only?
- Stock Brake Rotors
- 1" lowering springs - cheapest (suggestions)
- Brake fluid flush???
- Complete suspension overhaul - need a little help/advice
- Shocks bad?
- Which Torque Arm fits?? S60 rear and TSP TD's
- how low will it drop with 6.0 swap and bmr A-arm
- Which Bilsein shocks do I get?
- Any different? 98-02 Camaro SS vs 98-02 Camaro Z28 springs/coils?
- Suspension upgrades
- Power Steering Pulley
- eGay springs.
- Help me out fellas with my suspension ideas...
- RETURN OF THE 1LE! GM Concept Camaro
- C5 emergency brake
- Raisin' her back up...
- Weld in SFC vs. bolt in.......
- Baer Brakes installed....Finally!
- Do I need to install sway bar before alignment?
- Brake booster and ABS removal on my street car
- V6 springs on ls1
- CTS-V Caliper Rebuild Question.
- Lower front end
