View Full Version : Suspension & Brakes
  1. want to install F-body BAER brake system on c5 **please help**
  2. Anyone had their UMI T/A break?
  3. I have rear brakes but no fronts!
  4. coil-over coversion kits
  5. what works good to measure pinion angle with?
  6. Best place to get Front Brake Calipers
  7. Understeer - Z06 vs F-body
  8. Installed SFC....
  9. This IS a rotor problem!.. right?
  10. LCA's installed, but a couple questions?
  11. 98 ABS module
  12. Which Bilsteins??
  13. No front sway bar. My driving impressions.
  14. Corvette Calipers Questions
  15. finally an upgrade to crap factory bump stops!
  16. Rotor Fitment...
  17. Front strut ?
  18. Lowering Spring questions... BMR/Strano??
  19. New pads, rotors, caliper, and lines... still brake shuddering?! but random...
  20. Rear swaybar preload
  21. Anyone sell kits?
  22. Brutal Rear Vibration
  23. Does this look OK?
  24. BMR, is there any problem in how my weld in LCA brackets were done?
  25. Front end shaking
  26. ABS inop & asr off HELP!!!!!
  27. lowering springs on stock shocks come in
  28. CTS-v upgrade/cooling ducts (review and pics)
  29. From 440 lb. spring to 300 lb. spring with 50/50 shocks
  30. Koni and strano VS qa1 and eibach pro kit
  31. Can i install my shocks and springs?
  32. stock SS shocks and spring on a V6?
  33. clutch and brake fluid flushes?
  34. QA1 issue....
  35. UMI PHB shifts rear end to the right?
  36. UMI Sway Bars
  37. Installed UMI torque arm from WS6store.com
  38. Do I need new rotors?
  39. where to get lighter bumper supports for 94 transam?
  40. aftermarket Y-pipes and UMI torque arm relocation x-member? Problems?
  41. Putting a 6.0L Iron on a Camaro, what Front springs should I use ???
  42. Different ABS?
  43. low soft pedal
  44. BMR ? Taylor ? Summit .. what battery relocation ?
  45. Issue with spring install.
  46. UMI bolt-in LCA relocation brackets moved rear back 1/2" *pics*
  47. Which suspension should I get / would fit?
  48. My Bushings are failing
  49. Anyone try an elec. vaccuum pump 4 brakes?
  50. Just got SFC Installed Impressions?
  51. brake squealing and rocking!
  52. Stock F-body rotor dimensions
  53. rear end cover hitting panhard rod bar!
  54. squeaky noise
  55. spohn torque arm problems. need advice
  56. Need to swap rack n pinion... Is there a write-up on it?
  57. Subframe connectors and shocks
  58. Ladder Bars for 2000 camaro z28
  59. Panhard Bar Mount Destroyed. Ideas For Repair
  60. Anyone want to drop some up front high center weight?
  61. Spohn Suspension
  62. Rod end size on wolfe double adjustable LCA's
  63. could you post pictures of your 1.2" drops? thanks
  64. please explain lower perch
  65. What would it take to lower a LS1 Camaro 1"-2"?
  66. Need help on suspension!!
  67. Show me your brake cooling duct please.
  68. BMR k member issue
  69. A arm removal
  70. rear spring weight jacks for a moser 9"???
  71. New!- UMI Performance Sway Bars
  72. Shock tower braces?
  73. Coilovers: fighting ride height, about to give help
  74. BMR vs. UMI Torque Arm
  75. Got bored so i built a shock tower brace
  76. BMR Lca, BMR Panhard Bar?
  77. Please help - in Miami 1100 miles from home and problems
  78. New shock and spring and LCA kit any advice to install.
  79. Strano owners in here ....plz
  80. LCA Relo Brackets and Handling
  81. Wolfe Adjustable Upper Spring Mount
  82. Custom routed brake lines?
  83. best alternate to koni's????
  84. STS, lowering, and tire size
  85. Master cylinder wasted?... check my logic
  86. What to set the Wilwood prop valve at?
  87. Looking for the person who placed a Swaybar set order this weekend
  88. watts linkage from sam strano
  89. Grrrrr caint hook " need advice "
  90. How do Summit drop springs ride?
  91. One thread for my NEW BMR springs and Powerstop brakes!!!!
  92. Hotchkis hollow adjustable rear sway-bar?
  93. what damage if I forgot leave parking braking on while driving ?
  94. Brake fluid
  95. Wow :(
  96. Hard brake lines
  97. Rear shock dust boots
  98. Caliper sticker-CAMARO
  99. Ft Lt WSS Harness P/N / Connection P/N
  100. Pedal feel with performance pads/rotors
  101. How much smaller are ear drag brakes compared to LT1
  102. Want to upgrade my brakes, opinions needed
  103. Has anyone made a bubble flare using their double flare tool?
  104. 2002 Trans Am WS6 How to set pinion angle?
  105. ball Joint?
  106. '95 formula: UMI T/A vs. y-pipe
  107. where do you buy new 93-02 bump stops?
  108. aftermarket k-member help!
  109. strano sway bars??? car sitting up in the front??
  110. How do you lube Rod Ends?
  111. Brake Upgrade???
  112. Spohn k-member w/stock lower A arms??
  113. Spohn Torque Arm problems on stock RE
  114. Front Strut install question
  115. aftermarket adjustable torque arm question
  116. please help me with my shocks n coils
  117. WATTS link and a moser 9"???
  118. Uncooperative Main Torque Arm Bolt
  119. Different torque arm bushings??
  120. Moog Steering Rack Bushing
  121. how to make my 84 camaro handle drag/track
  122. some noises
  123. Axle Slap
  124. Koni / Strano
  125. corvette suspension conversion?
  126. My checklist-Probably a ton of them
  127. Different torque arm?
  128. GR-2 shocks worse than old oem???
  129. What parts are required for Koni's and Strano springs
  130. Front suspension clunk after shock replacement
  131. Any sponsor sell the C5 brake hardware for the Conversion?
  132. Powerstop slotted rotors, advice before install
  133. new stance
  134. please recommend me some bushings/shocks/suspension parts
  135. new shocks springs and bushings but still scrapin?
  136. strano springs w 18s questions
  137. can anyone vouch good for agx's?
  138. can i see pix of the SLP sfc installed to see how low they hang...
  139. Poly/poly lca question??
  140. Question on replacing an outer tie rod end
  141. Koni/Strano Install Video
  142. thinking about removing power steering...
  143. Heater Hose Mod Writeup
  144. BMR's front only
  145. Help H/C Car. What do I get First?
  146. Squeaking front suspension
  147. Strano spring ride height on TA?
  148. CTS-V Brake Install w/ Pics
  149. Rear SLP Bilsteins/Heater Hose mod done
  150. Rod end lube?
  151. Why are my rear wheels leaning in? Please Help!!
  152. Suspension?
  153. abs delete ?
  154. Squeak from the rear driver side
  155. Lowering: Will it bring my TA up?
  156. GM discontinued axle stopper bushing??
  157. Abs inop/trac light on--help??????
  158. BMR lower A-arms and AGX KYB shocks...what needs to be modified?
  159. Steering gear coupling shaft.
  160. What's the ABS module worth?
  161. Popping noise during cornering from rear suspension (Spohn Lower Control Arms?)
  162. Brake Problems
  163. what spanner wrench to buy
  164. Which setup is better?
  165. Can you weld in Sub Frame connectors on a regular lift?
  166. Bad Panhard bushings, opinions needed
  167. Ground Control Coil Over !! Link inside.
  168. Bad Breaks in an Impala 1970
  169. Bad front wheel bearings?
  170. Coilover ride height question
  171. Tire Rubbing
  172. Spohn Drive Shaft Safety Loop ?'s
  173. 3 point SFC's & Tunnel mount torque arm
  174. LG coilovers creaking on bumps?
  175. Are my tires causing my car to just go side to side on uneven roads??
  176. Which drag shock for me?
  177. Changing Brake pads... Brake calipers wont budge
  178. SLP subframe connectors and drive-shaft safety loop??
  179. What else should be modified after lowering the car? (Strano springs/Koni 4/4s)
  180. Panhard bar question
  181. weak brakes
  182. Koni DA, perch mod
  183. tryin to get the front lower
  184. LCA Bolts?
  185. Fitting 98 Z28 Brakes on 94 Trans am axle need info...
  186. Want to sell your 01-02 SS/Hawk SLP sway bars?
  187. Fron lower control arm bolts!! Help!
  188. 6Litereater Big Brake Upgrade
  189. QA1 what???
  190. Does this pic show a bushing problem?
  191. Going QA1
  192. AGX's out and Bilsteins in!!!
  193. What setup works better w/420 RWHP,then current Stock Torque Arm setup&poly bushings?
  194. Car swaying all over the road after moser 9" install
  195. Best street pad?
  196. Missing trq arm nut, what size is it?
  197. Question on LCA relocation brackets on a stock ride height car
  198. Rear lower than front with hotchkis springs
  199. How to tune Koni Adj shocks
  200. UMI adjustable control arms
  201. Shock question
  202. Flowmaster merge fits with UMI tunnel mount
  203. understeer q?
  204. Car bump steering a lot on 275s.
  205. Bilstein Strut Help!!!!!!!
  206. chrome moly LCAs worth it?
  207. Looking For A Brake Fitting...
  208. BMR not a sponsor anymore???
  209. Got my BMR 1.25 springs installed.
  210. ABS Thread Size???
  211. Tokico shocks...
  212. Do lower control arms wear out?
  213. Difference b/t base c6 and c5 z06 calipers?
  214. Help leveling car
  215. Ebay Panhard Bar...
  216. what should my konis be set to???
  217. Best handling setup
  218. Can you help identify these springs?
  219. Center The Car
  220. hal 275 springs question
  221. Good find?
  222. Aftermarket Rubber Bushing LCA's
  223. Q's about goin to a 1LE front sway bar
  224. cts-v upgrade??
  225. Clunking noise on deceleration after TA install
  226. What's your LCA Angle?
  227. stock torque arm with umi relocation crossmember
  228. Rod or Bushing End LCA's?
  229. g-body suspension into a-body
  230. Koni SA/Strano Springs at da track???
  231. Upper A arm Prob..Cant loosen ball joints
  232. Sway bar sizes stock/aftermarket
  233. Couldn't find much, SBC k-member?
  234. Adj panhard bar or not?
  235. Adjustable rear Strange shocks and sway bar too close for comfort
  236. Brakes shot, lil street upgrade?
  237. What plain blanks to mix with stock calipers?
  238. Help me figure out my suspension setup for street/strip
  239. brakes problem
  240. Strange clicking
  241. Upper shock mount replacment?
  242. Koni adj.
  243. What is best for drag setup. Stiff or soft??
  244. Wheel hop after springs?
  245. What pads can u buy at Advance/Autozone with LOWEST dust?
  246. broken torque arm mount - replaceable?
  247. What suspension next?
  248. QA1R Question?
  249. Parking brake is stuck! How do I fix?
  250. ?s About Shock Adjustment
