View Full Version : Suspension & Brakes
- Help me build a "Trans Am GT," if it can be done.
- Torque arm help
- Will evo 8 bembo calipers fit on my z28?
- suspension help
- 98-02 firebird brakes
- deal on fbody stock Brembo front rotors and hawk pads
- WACKY 3 channel/4 channel confusion, help needed
- Tubular front end?
- Need some suggestions please.
- Front suspension and steering rebuild
- Strano springs/SLP Bilsteins - initial impressions
- Lost bolt that goes thru Torque Arm 01 T/a??
- Wheel Rubbing!! Help Me Please!!
- E-brake bracket removal HELP
- Bilstein spring combo
- New UMI Adjustable TA
- Is This A Decent Setup?
- New rotors, now pads??
- adj or non adj torque arm
- Any street cars running Midwest front Kmember?
- Happy New Year!
- Back shocks leaking?
- Easy way to slighly lower front?
- Watts Link
- Need help with my brakes !!! Spongy pedal sometimes sinks lower!
- Lookin to lower, Best options?
- BMR Trak Pac Setup?
- What are my options????
- Will C5 brake conversion brackets fit C6 Z06 calipers? UMI
- Torque arm on last leg!!!!!
- Major suspension modifications coming soon !
- lt1 ls1 rack differences
- Parking Brake Problem
- Problems with urithane bushings...
- Is this how lowered camaros are supposed to ride?
- Is This Normal Braking Performance?
- Shock mounts
- Look what goodies came today!
- Good article on shocks
- what springs
- Torque arm relocation crossmember
- New parts.
- Brakes
- A bilstein Story!! epic fail :)
- BMR Suspension Handling Performance Packages
- where to get rear axle bump stops?
- Stock shocks, what springs?
- Removing backing plates....
- UMI Rear Sway Bar
- QA1/Spohn Rear Coilover Conversion Kit - Anyone have experience?
- Front Suspension Conversion
- Firehawk C6 Brake Upgrade
- Suspension for a Street Car
- bilstein rear shock bolt size
- Post Christmas/End of the Year Specials
- BMR manual rack and ZR1s
- suspension mods
- build your own suspension
- How necessary is a upgraded rear sway bar for a 1/4 mile set up.
- Best Suspension for Drag
- alignment for new suspension
- Downside to Coilovers?
- UMI adj control arms locked up
- Madman’s Annual End of the Year Sale
- Power Steering Issue
- Adding Grease Fittings to Stock Parts
- 2002 TA What wires to ground to get rid of abs light...
- ws6 springs/shocks
- No Brake Pressure?... WTF?
- BMR Christmas Sale 15% OFF MOST BMR SUSPENSION PRODUCTS
- Those with DA rod-ended LCA's...
- Bilstein SLP v. Bilstein HD?
- Will Lowering The Front Of The Car Change The Pinion Angle?
- BMR Suspension Lower Control Arms.
- A few price drops/changes
- Steering Wheel Play
- ws6 front struts vs. formula front struts
- Woohoo... SCCA T2 Approved handling pacakge!
- powersteering with an fittings
- Adj. LCA's - The ONLY way to center wheel?
- Rear brake pads not...using the full pad?
- Koni shock questions and pics. Come in!
- BMR customer services
- Power steering ?
- Looking to lower
- Strano Spring delivery status update: 12/20/2010--they're arriving.
- 4 Links or Ladder bar for 900-1000rwhp
- Lca Brackets
- Panhard Bar: Double Adjustable/???
- caliper piston woes
- drag springs???
- SLP Bilsteins with Strano Springs
- Questions?
- What lt1 camaro suspension parts make tha biggest difference?
- torque arm relocation with tsp rumbler x
- UMI poly/roto rear lca clunking
- What would it take to get an FBody to get a stopping distance, 60-0, of around 105'
- Checking Rear Rotor's?
- Has anyone used iRacing to help/learn how to drive
- best BMR price
- NEED HELP!! brakes not working while car is on
- Koni Shocks: My supply chain--the how and why of it all.... and a note about springs
- baer rotors
- Help with my pinion angle. UMI torque arm on s60. Pics :)
- Suspension "squeaking" all of the sudden?
- S & W Race Cars t/a and sfc kit question
- C6z51 brakes with 17" zr1s
- What are the biggest best brakes I can put under 17" FM5s
- CTSv Brakes, why?
- Oversized PHR bolt size; can't find original thread
- Can the FBodies be made to handle like the 2011 Mustang?
- Car wobbles under hard acceleration above 70
- Qa1/hal 12 way adjustable rebuild?
- Spring strut and shock whats right for me?? Help please's
- Spring/shock install
- Keep front abs with 9in rear?
- Picture of cut UMI T/A bracket for S60
- 1le or stock springs with blistein shocks
- Torque Arm Question 82-02 All the same??
- Am I Going To Be Happy With The Gain's?
- I need perspective on moving from 17" to 18" wheels - ride quality, handling, etc
- what should my pinion angle beeeeee
- Is this normal??!!!! (Spring Question)
- Spohn Torque Arm, time to let it go?
- Koni shocks!
- Different steering ratio racks?
- Car pulls to the left
- Struts / springs wont compress when in car - Urgent Help!
- help with hooking????
- Where to buy steel rear brake lines that run along rear end?
- POR-15 suggestions
- stock suspension
- Car gets wobbly and scary at 120+
- ABS inop light flashing?
- Suspension; Where to begin?
- Did welding in your sfcs do anything?
- 68 chevelle 60 ft issues
- 02 Z28 Front Suspension --> 94 Z28?
- chassis/alignment/suspension issues
- Qa1 owners,need to know what setting you have your shocks at...
- Sway bar brack upgrade (f-body)
- Rear End Centering HELP!!!
- Serious brake problem!!! Need help!!
- Question on F-Body E-Brake cable brackets
- Vibration while braking!... ???
- Upgrading only the front sway bar?
- koni rear shock adjustment
- Steering rack & Pinion
- SFC's and header clearance?
- Different way to adjust parking brake.
- Few questions on LCA bushings, end links, doublechecking pt numbers
- K member help!
- Need some advice on lowering my 99 T/A
- Bilstein shocks. springs?
- weld in sfc?
- are my ball joints bad?
- BMR Launches New Product - Sway Bar End Link Kit (ELK004)
- ls1 brake swap question
- SJM line lock kit
- Wheel spacer, GMHTP CTS V brake swap
- Spohn crossmember vs. headers/y pipe
- Bilstein HD or SLP shocks - what to expect?
- Replacing ABS module, is this a DIY?
- Torque arm relocation mount for adjusting pinion angle?
- Rack and pinion reseal kit
- looking for a rubber T. arm bushing...
- E Brake only works in Reverse?
- Spring Air bag?
- lca brackets
- Competition engineering drag shocks?
- Anybody have abs work with the abs inop light on?
- Ideas how to fix LCA rattle?
- help with suspension on my 1986 camaro...
- How would YOU approach making a road race T/A?
- suspension....HELP PLEASE
- bmr trak pak question
- serviced my rear brakes discovery
- dont like my stance need help!
- Drag struts for Fbody? What should I buy.
- Vibration after heater hose mod
- Are SS braided brake lines worth it?
- 23mm rear swaybar
- Aftermarket shock for aftermarket rear
- Frozen strut mount
- Looking for a rear spring that will NOT lower my car...
- Need help!! Experts with F body suspension..
- cant get rid of wheel hop!
- PA racing K members
- DAMN if I'm buying a new rack and pinioin...
- c5 brake job
- Another Bilstein question
- shock engineer for a race team, designing, building, and rebuilding shock pac
- Group Purchase request on Koni shocks!!!
- installed strano/koni 4x4
- Spindle Movement?
- Russell speed bleeders continue to bleed!!!
- No brake pressure with stainless steal lines!
- Jacked up my front suspension
- I need better 60's, what to buy next?
- Brake ?
- Wheel Hub Options
- Jaguar IRS in fbody ??
- Torque arm/ chromemoly vs. mild steel (lbs.)
- CTS-V vs. Wilwood/Baer brakes
- tube chassis
- UMI LCA and PHB???
- UMI lowering front lower A-arms
- UMI Performance Thanksgiving Sale- 15% Off!
- 98 trans am tcs proeblem
- BMR Thanksgiving Day Sale
- Sound under car
- LT1 with LS1 Rear Axle - Which Brake Rotors
- guys with BMR torque arms, need some quick help
- Random Technologies Torque Arm. Bushing??
- Rattles with Solid Motor Mounts
- Strano Performance Thanksgiving Weekend Specials (UMI products included).
- Need some advice.
- LCA relocation brackets.
- Tubular PHB worth it?
- BMR Launches New Product - Lowering A-arms (AA020)
- People with Bilstein and Strano Springs, please come in!
- suspension advice
- Shocks Replacement
- Competition Engineering Sub Frame Connectors
- Wolfe Sway Bar & Stock Tank?
- Tokico shocks vs Blisteins
- Eibach sway bars and springs
- UMI Performance Black Friday Specials??
- Bumpstop Pounding
- Fays 2 Watts Link - Another Stranoparts Satisfied Customer
- C0041 Wheel speed circuit, help finding replacement?
- 98 trans am lowering question
- Where should a slight bent rim go?
- F-body V6 vs. V8 rear springs...
- which torque arm
- softest 1 inch lowering spring
- Wtf i still have wheel hop
- Strano lowering springs installed.....pics inside
- School a newbie
- ls1 springs and shocks on a lt1?
- Break light came on
- BMR xtreme torque arm , tubular sfc's ?
- Lost my banjo bolts... where can I get em'?
- Strip suspension setup
- Lowering question
- PA Performance BROKE K member pics
- C5 Brakes - What pads are you running?
- Got an alignment...need opinions on the settings
- wanting to do some suspension need help??
- abs sensors
