View Full Version : Suspension & Brakes
- strange shocks 275 springs....passangerside looser than driver
- Need front K-member for Firebird 98' - which models k-members will fit?
- BMR old vs new springs
- Feedback on lowering car w/ a 12 bolt and longtubes!! What works and looks the best?
- Stopping distance between a few setups - if anyone cares to guesstimate...?
- Stock calipers, best pad/rotor reasonably priced better stoppign than stock stuff
- what should i pay?
- What is the best brake/rotor for the buck?
- DSL or Tunnel Brace with TSP Duals
- Low Trac Light on and off when on highway
- poly vrs rubber bushings?
- Rear shocks blown?
- BMR springs or stock springs?
- Brand new QA1's seem to be junk already...need help!
- adjustable lca's with mini-laddar bar?
- Suspension suggestions
- brake tech question
- Touching up suspension....things to do over winter?
- Bad Shake
- vibration in 6th gear
- i need opinions on suspension setup
- Death to deCarbons; or, New Suspension!
- Spohn Upper A-Arms Don't Fit
- spring bumping on passenger side?
- Rusted Stock Shock Nut - OPTIONS?
- UMI c5 brake upgrade kit?
- Clunking noise after Bilstein SLP Install
- BMR lowering springs. *Lots of pic's*
- wheel hop, but i have bolt ons...
- Those with the mini ladder bar setup?
- GMHTP's 6-piston CTS-V Setup
- Stock front sway bar experts.....
- Types of rear LCA
- Torque Arm Installation Help!
- lower balljoint greasing
- Massive Camber Issue (during turns) - Expert Help Needed - Pics included
- wow, pinion angle makes a huge difference!!!
- Bilsteins & Torque Wrench - WHICH?
- Brake pad replacement
- Eeeek! Rear Koni Shocks Didn't Come With Nut! Help Please!
- Rattle, clunk from front end...?'s
- best mods to hook on the track
- Your Ebrake Tension at the Spring (hook) on the Rotor??
- 1LE rear LCA bushing equivalent?
- russell speed bleeders
- relocation brackets
- Wilwood F&R T/A brakes
- Uncontrollable breaking?
- Is it right.
- Cannot Find Part! Stock Shock Threaded Sleeve
- Aftermarket Lower Control Arm Torque Specs
- SLP line lock busted..
- Suspension Bushing Grease?
- Which rear drag sway bar?
- LADDER BAR IN 4th GEN?
- SLP Bilstein Shocks vs. Bilstein HD Shocks?
- New Struts Question.
- which strut/shock to use
- stock pinion angle
- SJM ABS Delete
- Need some info
- Quick help! Rear LT1 Brakes vs LS1
- Anyone familiar with the brake pressure modulater valve??
- help with front end alignment and t-top rattle
- Anybody notice noise with Spohn adj. PHR w/ spherical ends?
- New stance
- Will I Have Rubbing Issues?
- umi tq arm bolt broke?
- suspention question looking for more traction with eibach prokit
- Abs inop!!
- Cutting stock springs
- Post pics of your aftermarket k-member installed please...
- 6-piston CTS-V Brembos - Full install with pictures on GMHTP.com
- Is this spacer thing necessary between upper CA/shock mount and body? Pics inside...
- Spindles!!!
- which torque arm
- Brake Calipers and Powder Coating???
- lowering kit? for c5 z06
- CTSV front and rear on f-body
- Brakes wont bleed right?
- Which torque arm ...
- Started ordering suspension... Couple Questions
- Manual rack questions
- Sway bar question
- budget shocks front and back for prokit?
- Suspension techniques pic wanted
- No front sway bar + skinnies on the street
- Thinking about buying Moser axles? Don't ...
- Need help identifying part....
- shock ?
- SLP Bilstein & OEM GM Parts needed for install
- Which brake pads should I purchase?
- Brake upgrade from LT1
- How long should a spring be for a rear strange rear DA coilover?
- Need to get my wheel streaght?
- NEC5 Autocross and Car Show Event (5th Gen Camaros)
- Ajustable torque arm
- Anyone have pics of Kenny Brown DD's SFC's installed?
- I'm sick of listening to it. Help me out-handle my Old Man's '08 (MX-5) Miata
- Springs: Linear vs. Progressive
- different springs or stock exhaust?
- Rack and Pinion Conversion
- MOSER 9 suspension questions
- Custom W-body LCAs
- Suspension problems?
- What tool do I need to release the springs so I don't rip my face off?
- Guys...measure your bars...
- LCA Brackets (UMI)
- QA1 Springs on AFCO Coilovers
- Nathan--are you out there???
- minimum thickness on baer rotors?
- Strano Peformance Parts Handling Packages--New prices, new items
- Back in Time Koni prices: Lower.... in stock, come take a look
- V6 Springs?
- Strano/SP141 springs: In stock
- Suggetions for Autocross Brake Redo this Winter.
- Drag Bar or Strano Adjustable? *street car*
- Possible Stripped Strut Mount Bolts
- Tires Rubbing on Frame In Tight Turns
- LG g-stop c5 conversion bracket owners... come in
- Shimmy-Shake when braking
- HP + Brake squeal...any solutuions
- Need Help! Swapped Diff without an e-brake cable bracket
- UMI & BMR in here please.......
- suspension suggestions?
- Eibach springs, now what?
- Question about compressing front springs
- Right Rear Tire Rubs LCA
- poly bushings = junk?
- Budget rotors?
- Stb
- LCA Relocation needed to improve corner handling?
- eibach springs vs. stock for rear
- carquest rotors?
- shocks/springs+struts= strippers are????
- Eibach Pro-Kit or BMR Front Springs?
- Which UMI TA do I need?
- Initial suspension setup??
- Where do I get this e-brake spring?
- Anyone ever tried making LCA relocation brakets
- OMG spring install help with pix plz help
- If you had your way, how would you improve this..
- I want to lower the front of my car a little bit more, how do I go about doing this?
- Best significant suspension mods for the money
- LT1 Prothane driver side motor mount
- Side to side shimmy under hard throttle after new LCA's
- braided brake line
- Installed offset bushings... any other options?
- Weird brake pedal... possible knock back
- SFC Weld vs Bolt on?
- best springs for ride quality (already have kyb agx shocks and rides BAD)
- Installing BMR springs/panhard tomorrow, Any Tips/ Advice/ Suggestions??
- Re Doing suspension, what to get??
- Rear brake calipers dragging on rotors when cornering?
- BMR 2010 Camaro Wins Speed Stop Challenge at LS Fest
- Drilled/Slotted
- mounting DA rear shocks.
- ABS/EBCM question
- Now have Konis and Stranos and I dont feel happy....
- Koni Sports: w/free shipping starting @ $890/set
- The worse feeling!!
- Bilstein HD's, where does this part go?
- SLP Bilstein $409.99--IN STOCK
- brake bleeder question
- i wonder if i need new brakes?
- install video for lowering springs??
- spring length for rear coilovers?
- Z51 Brake Setup F-Body
- Those with C5 Brakes conversion. What clips/boots do I need?
- C5 brakes on F body with TT2's????
- help with rear strange DA coilovers
- how to replace rear springs
- BMR Launches New Product - Rear Suspension Bushing Kit (BK021)
- Buying CTS-V- Need advice on rear shock!
- AGX rebuilds/reseals?
- Rear springs
- the car doesnt feel like one solid piece anymore,,where to start?
- bilstein replacement bushing (LS1 F-body)
- Upgrade path, looking for recommendations
- can worn motor or tranny mount cause handling issues?
- rear control arms and relocation brackets - ok to have play?
- Edmunds 2010 Chevrolet Camaro SS: Suspension Walkaround
- Removing caliper mounts
- Baer GT-Plus Kit
- tech 2 needed to flush system? car stops for crap.
- BMR,where's the front lower F-body drop A-arms? Please update us!
- Help! cant get strut apart
- 5.3 and umi k member
- People Who Have Had Issues With Pinion Angles Come In!!!!
- 1le LCA VS BMR Tubulars
- unbalanced engineering Bilstein race shocks (coilovers)
- caster camber and toe
- Iron block + turbo, front height?
- DA LCAs & DA PHB - Weird popping noise
- Strut Mounts
- Look at the friggin size of this STB..........
- Whats Torque Spec for nut on front strut assembly?
- Madman Hurricane Sale!
- Anybody running V6 coil springs on ls1 cars?
- BMR Launches New Product - Driveshaft Safety Loop for Automatics (DSL015)
- 01 ss with zr1's. can i drop my ss???
- Ordered some new shocks from BMR yesterday...
- koni's and visit to BMR
- Firehawk Big Brake Kit
- control arm question
- Nailed 2nd gear HARD yesterday and heard a 'CLUNK' from what felt like the rear end..
- Changing shocks. Pointers??
- Braking problem
- third gen rotor with 1/2" studs??
- Brake Bleeding question....
- OEM calipers?
- How to tighten up steering
- QA1's advice, and need the hook up!
- UMI adjustable torque arm broke!
- launch problem
- Need QA1 struts rebuilt. Where to go?
- Aftermarket bump stops for the rear?
- Energy Suspension Install
- Bilstein Used...Yes or No
- simple question
- which coilover is best for a DD
- non adj LCA = harsh ride?
- Trans Am
- Stock shock replacement
- Alignment after adjustable panhard?
- new front end ideas. What to use and what not to use.....
- frame and suspension
- Front end rebuild time, what parts?
- Need a front caliper bracket.
- Anyone running Bilstein HD with stock LT1 springs on LS1 car
- any one have lines that go the whole way back????
- Congratulations to Sam Strano!!
- Black z06 calipers?
- ABS delete - all them leftover abs wires!
- SLP Bilstein Lowering spring question
- What rear is in 2011 Camaro?
- cracked sway bar mount
- Rack & pinion issues
- WTB King Springs ??
- UMI New Product Release- Heavy Duty Billet Sway Bar Mounts
- is the 6litereater c5/6 brake kit worth a dang?
- C5 brakes on f-body with TT2's What spacer do I need
- Lets see your broken TQ arms!
- Intermediate won't reach!
- Quick Bilstein SLP question
- Anyone running 18" wheels/Stranos/Konis come in
- Can a snap-on diagnostic tool do an autobleed of the ABS pump?
- Eibach Sportline Lowering Spring owners
- What will lower my 60ft times, suspension kits ?
