View Full Version : Suspension & Brakes
- upper panhard support?
- A few questions!
- what else do i need to lower my car 1.5in?
- Who's running tubular front CA's and coilovers?
- spring rate idea qa1
- Thanks Sam!
- H&R Springs-Owners?
- Parking brake tappat needed
- CTS-v pad choice?
- Best place to buy brake lines?
- In the market for a street car torque arm... so confused?
- Qa1 ?s Please Read if you have them!
- CTSV rear calipers on a 2000 WS6???
- Where to place bearings on Strange drag shock?
- need help with brake lines Whats the Difference
- Help!
- C5 brakes on my WS6-quick question
- Need to re-do my suspension w/ rear mount
- Help! Caliper mount bolts snapped!
- Front strut/sping hardware
- Strano Performance Parts will be closed 3/10 to 3/15
- street strip setup?
- 2010 Camaro rotor dimensions?
- newbie hearing a weird clunk, help?
- LCA Relocation bracket Question!?
- roto-joints are on!
- Wanted to post about how happy I am with my Strano Springs (with crappy pictures now)
- help with brakes!!!
- Panhard bolts. What Size?
- Need to raise the car up a little bit
- Seting up you qa1 suspension helppp.
- banging noise after subframe con. install?
- need help with pad/rotor swap asap!
- Hate to ask?
- power steering problems.
- Front Spring Rate?? Help
- Any sponsors sell master cylinders?
- Post some pics of your LineLock installs
- steering shaft bolt
- steering wheel "play"?
- Motive power bleeder problem
- Ok what happens if the rear end is already not centered due to worn out parts?
- Chrome moly suspension parts
- kyb/ strano
- non adj vs adj a arms?
- Torque Arm Mount?
- All brakes dragging?
- Non adj worth replacing??
- BMR sway bar noise
- Ordered G-Force Ladder Bar Conversion kit. Any one have experience with it?
- do stock springs need to be replaced ever?
- torque arm - tunnel vs cross member
- LT1 rear calipers
- car darts to the right under hard acceleration
- what shocks to use?
- Rear Bump Stops
- Wilwood rotors
- Painting disc brake rotors...?
- Hawk or EBC pads?
- Tokico hp shocks springtech springs
- Car Sits Lower On One Side?
- QA1 settings on the street....
- Positive camber issues
- Drag suspension guru's come on in.
- springs/swaybars?
- cam only 60ft times
- Replacement pads and rotors...
- SLP 1" lowering springs
- Stiffest Springs help.
- How to bleed brakes with Tech II?
- Mater cylinder?
- Alignment specs inside, suggestions for dd?
- Is there an ABS delete write up? :(
- fitment questions
- What calipers/rotor combo will clear prostars?
- package deal
- What springs do I have??
- sh- load of suspension mods, whatcha think
- What should I do next?
- Alignment question regarding caster
- Rotors Questions
- Front coilover / rate reccomendation
- Weight savings with UMI chromoly A-Arms?
- Raising rear of lowered car
- Edelbrock subframe connectors
- heavier rate springs needed!
- Broken Rear Sway Bar
- Quick ? about greasing
- shocks and springs help needed!!!
- Guys running new design BMR Lowering Springs and SLP Bilstein Shocks come in.
- Does anyone have these??
- Common fitment question about lowering springs...
- Parking brake ruber boot ?
- Brake booster
- LS1 Master Cylinder
- qa1 shocks
- Getting ready to replace a-arm bushings and tie rods ends, few ?s
- How important is this piece?
- Steering shaft bolt?
- Rear brake line problem
- Alignment necessary after shock install?
- Loud Howling while turning
- Asking for advice
- Street Shocks/Struts and Springs for 408 Needed!
- Purple springs on an 02 WS6?
- Anyone running drag bags on their factory spring?
- Anybody have pics of the UMI tunnel brace/safety loop #2025 installed with 3"ORY?
- how to fix wheel hop on 04gto
- Help!! Lowering a weight deleted car.
- Advice for bunch of parts installation by mysefl...
- Need to be a bit lower without affecting anything else
- Stock fender to ground measurement
- Pulsating with new rotors and pads
- One problem with adj. shocks!
- School me on LCA's
- HELP!!!! PS Rack and Brake Problems
- How do i pull out the steering shaft on a 96Z? Pics?
- Bent Panhard?
- Need help with coilover shocks
- anybody want to trade their prokits for sportlines?
- C5 Z06 Brake kit fit 18'' ADR M-Sports?
- shake above 60, ideas?
- QA1's?
- Need a quality alignment in Indiana
- stock rearend lengh on fbody 4th gen???
- Alignment after shopping at Strano's
- Eibach Camaro SS test: better performance and 13% better MPG [Video]
- Adjusting the ADJ PHB... Nut&String only way?
- Question??
- Double adj control arms with relocation brakets?
- OK ! Read 1000 post
- Parking Brake Adjustment?
- HELP with UMI T/A relocation crossmember PLEASE!
- Check valve with an AN fitting?
- Anyone running Eibach Pro Kit with Koni's?
- Energy Suspension Master Bushing Kit Install
- Rear drag springs
- torque arm sugestions please
- Rack and pinion make clicking noise when going out?
- lpp headers dont work with my new umi K-member
- Lt1 to ls1 front brakes?
- my car does wheelys from a roll. fix it.
- back brakes scraping
- Should I change my springs?
- Steering feel of an 03 WRX, in a 98-02 fbody?
- New shocks with lower springs?
- upgrades
- looking into auto-x
- C5 Caliper Conversion vs Stainless, Fluid and Great Pads
- kyb acx shocks? or better?
- panhard bars?
- Strano's top brake kit, or Baer GTs?
- Ford roadster P/U chassis question.
- C5 Brakes with TTM Wheels?
- '00 WS6...Newbie STARTING THE BUILD!!!
- Rack seal sucking in air?
- shock install help!!
- Suspension Mods
- Wilwood brakes... locked up. help
- QA1 springs
- need stiffer suspension??? please help with tire fitment
- Is there a front brake upgrade that still fits inside Prostars?
- Adjustable pushrod for brake master cylinder, from booster
- New Koni 4/4 install
- Where to start.
- Scary to drive my Z28
- Different Steering Racks
- suspension advice
- TBSS brakes
- Question with my Kyb's
- new idea for my shock upgrade married to Strano springs...?
- Car sat 2 months, now vibrates horribly!
- difference in shocks
- Best LCA's for Detroit Locker Street/Drag Car ?
- SFC's neccesary for stalled a4?
- where are people getting intrax springs??
- Ford 9 inch C5 Disc brakes???
- lca relocation brackets for QP 9" rear end?
- tubular or boxed SFCs
- ABS Delete questions
- UMI 15% off sale 2/15-2/21
- BMR Fabrication - President’s Day Sale (25% OFF Most 4th Gen Items)
- What Torque arms are better?
- Bent Front Spindle?
- eibach pro kit..what shocks?
- How would this set up be?
- sa QA1's
- what is too low
- Question about Drag Race Suspension
- can I use 93-97 sportlines on 98-02 F-bodies
- Rotors
- Suspension problems, need help!
- QA1 stocker stars..
- I need to lower my car
- CUSTOMIZED Strut Tower Braces for 1993-2002 F-Bodies
- Help question...
- rear sway bar ???
- What rear shocks for the street/strip?
- c5 fbody caliper adapters, who all sells them?
- Trouble bleeding brake system
- Anyone put coilovers in the back?
- LTx front brakes to C5 rotor/bracket or LSx rotor?
- Driveshaft loop fitment help
- Torque arm question.
- what shock rate should i go with HAl's
- Basic help - will buy from vendors
- quick ? kyb qal drag coils???
- 85 iroc-z camaro suspension?
- Anyone make their own adj. panhard bar?
- Chevy Nova Overseas vs USA Tubular Control arms
- questions for sam, about sam
- Looking for a anti roll bar
- Strano's Good For Drag Racing?
- Suspension For ME!
- Rear Caliper Rebuild Kit Part ????
- Which aftermarket k member?
- Need HELP with sub frame connecters
- Rebuilding Calipers...How To or Whats Involved?
- Impala 1970 - Drum to disc brake conversion kit - need help
- New pads???
- KYB Struts and shocks?
- C6 Z06 brakes on 99 camaro?
- shock/struts
- UMI any plans on offering a CM Kmember option??
- SLP Bilstein $409.99 shipped
- Need advice on suspension TLC
- What is missing? Build thread of my 4-link.
- Power steering issue
- Who has the best prices on UMI ?
- Steering Wheel and Shaft is off
- rear axle width?
- Best Torque Arm for Moser 12 Bolt
- Popping noise when turning
- Longer wheel stud ?
- New takeoff stock springs
- Wiggling Steering Shaft
- 02 SS procharged what shocks??
- 25% off Koni's at Tire Rack...
- Strano springs siting crooked?
- STB + Solid Mount clearance
- QA1 Axle Housing Bolts???
- corvette calipers????
- What suspension pieces should I add?
- suspension problem after install, please help!
- Play in the steering wheel
- help taking off front spring/shock
- Subframe Connector Hardware?
- Advice on how to build a strut tower brace
- Another C5 brake upgrade
