View Full Version : Suspension & Brakes
- Control Arm Relocation Bracket Set up?
- brembo big brake kit down sizing questions
- Wheel Bearing??
- whats the best line lock
- lowering kit questions..
- EdleBrock IAS adjustable shocks/struts
- Got my Strano springs on today (before/after pics)
- Koni Shock sale through 6/30/09
- Stupid Question # 42...:)
- Manual steering conversion ?
- Lauching
- Polished My DeCarbons
- Where to get different brake lines ?
- C6 Z06 Brakes
- Suspension upgrades help w/true duals
- Sway bars or not?
- Specs on alignment for DD
- What torque arm should i buy for a 9''?
- Strange shocks.........which springs
- LSx to LTx Rear Brake Swap
- ABS Delete
- Complete Suspention Shopping list ?
- pics of camaros with 1 1/2 '' drop
- Broken torque arm, what else could be tweaked?
- Does adj phb cause any binding?
- Brake fade and vibration at high speed
- knock after shock install, also a squeek
- Does anyone know the wall thickness of the STOCK front swaybars?
- broken spring perch maybe??
- Can anyone tell me how adj spring spacers work for rear?
- Poly mount problems?!?!
- spring compressors wont fit stock springs?
- need to hook whats next?? help!!
- Spring rate and drop with DMS front springs?
- WTF.. Rear brake pad has no wear?
- Torque Arm adjuster stuck
- spohn solid motor mounts
- So who thinks i need adjustable LCA's!
- FLP LT's and SLP 3 pt SFC's
- Strano's Springs or Front Solid Sway Bar
- Need suspension upgrade
- non adj. lca & 9" guys come in
- setting adjustable front a-arms
- who has Eibach sportlines??
- I am getting sooo fed up
- Koni shock/Strano spring BEST SETUP
- need traction
- springs
- Back to Stock Height!
- torque arm delete?
- Rotora Big Brake kit
- Adjusting Strange Double-adjustables for Street/Strip
- New suspension Underway. Tell me what you think.
- What size tubing to get to bleed brakes?
- Bolt on relocation brackets
- DIY front coilovers
- Which BMR rear anti roll bar?
- Need help getting a new suspension....
- Help me find brake fitting.
- Stop Tech
- BMR Pre-Spring Lowering Spring Sale!!!!
- Constant Squealing noise after Brake/Wheel bearing install..Help please
- bolt on doouble diamond sfc's
- SWAY BAR ?s
- Parking Break
- Replacement Poly Mount BMR Torque Arm
- pinion angle issue, rear twisted?
- F***ed up suspension!
- Pull the wheels!!!!!
- Suspension Tuning Tips (quick read)
- Anyone recommend suspension parts and shop?
- wheel hop by changing tires
- Strano springs are on(review) (before/after pics)
- BMR Launches New Product - G8 Trailing Arms (TCA026)
- Manual steering rack?
- right rear lower then left???
- Aligning a lowered car???
- Will Stock LCA's and T/A rob hp &tq on a Dyno Pull ???
- are lt1 shocks differnt upfront then ls1?
- Improve my ride quality
- Koni SA Shock install
- going to be trading my bilstein/DMS setup for....
- UMI LCA and relocation brackets question
- Front Caliper Keep SHEARING!!
- shocks and springs... now what?
- Removing TCS but keeping ABS and CC?
- whats the diff?
- 3rd gen r. swaybar fit 4thgen ?
- Need help for suspension set-up
- Which SFC's should i buy and why. POLL!!
- need help can't find my brake system
- Stock SS suspension question
- Aluminum LCA ?'s
- Sphon Rollcage
- Roll Cage and Subframe Connectors.
- front sway bar question once again
- Possible koni problem?
- 95-99 Neon spring sleeve instead of heater hose
- Are the C5 calipers 1 or 2 piston?
- will this work?
- Wheel hop! Need help ASAP
- Help me plant this sucker..
- C5 Brake Measurement
- Coasting problem
- I think I screwed up.
- SLP/Bilstien Install
- Group Buy - Cross Drilled & Slotted Rotors w/Hawk ceramic pads
- hopping when braking
- What causes this?
- Make your own PHB & LCA
- going to do my springs on my own
- Finally changing out stock suspension.. suggestions?
- Fitting C6 Zo6 Brakes on 98-02 need info...
- 17 or 18 inch wheels?
- Heater Hose Mod - Size Hose
- CTS-V Brakes???
- Difference in LT1 vs LS1 front springs?
- Suspension Damage Ran over unmarked Island
- help chosing shocks
- Bilstein Struts?
- umi tunnel mount vs umi relocated torque arm
- BMR Springs
- New to suspension. What would you recommend?
- front shock help.
- Need help with cars handling
- Car has been lowered...
- Show me your lowered 93-02 Camaro
- Will this ruin rear shocks?
- What do you do to get that kinda ride? Picture in
- Post Pics of your Rotors pics (installed)...
- NONSTOP bottoming
- torque arm..
- James?????
- Why does my rear kick out to the left?
- Wilwood SL 6 piston VS Brembo CTS-V 4piston
- Ground Control to help lower my 4x4 camaro back to stock, but for dragging?
- Could I do this without messing up anything?
- Wheel hop????
- 1993 stock springs vs. ws6 springs
- Best Stock F-Body Endurance & Road Course Brakes?
- Squeak/Grinding noise coming from the rear
- E.t. gains from bushings?
- camber adjustment
- QA1 R series questions
- Brake master cylinder went dry.
- Installed TA and PHB
- Adjustable Shocks
- Shocks
- ? on my S60 rear sway bars end links!
- manual brake master cylinder ?
- Front struts leaking, what about springs?
- NEW UMI SFC's and LCA's Installed!!
- boxed vs tubular subframe connectors
- Need help hooking up
- Initial Impressions Strano Springs/Koni 4/4s -- Long
- Koni Installation Help!!!
- Strano lowering springs are on the T/A
- I dont want to go lower...
- Front Shocks only
- SJM ABS delete kicking my ass
- will bilstein shocks help traction?
- Sway bar and motor mount torque specs... asap
- Broken Konis?????
- Lateral Sway?
- Doing ABS delete right now in garage
- do i cut bump stops isolators???
- a question about koni's
- Kudo's to SJM
- Car Feels Loose at Speed
- Just replaced front shocks, do I need an alignment?
- Opinions driving the street with big drag rear sway bars..
- Lowering my car?
- UMI torque Arm Hitting Tunnel
- QA-1 or KYB AGX
- does a bent rim feel like a warped rotor?
- Stock 98 Z28 suspension had red springs?
- Any experience with Brembo rotors?
- Loud pop when launching resulted in poor traction, think I found it.
- Caliper advice needed!
- Did some work today. Pics inside.
- what springs are the best for street and strip?
- Which torque arm relocation crossmember
- bear sport touring front pads
- pics of eibach drags springs
- Lca relocation bracket install question
- BMR Launches New Product - G8 Strut Tower Brace
- Koni SA Front Installation Questions
- This SFC does not look right to me (pics)
- Should I get new pads?
- Calling SJM ABS delete users
- Removing stock LCA bushings
- Wheel-hop
- torque arm
- Do drilled and slotted rotors help stopping power?
- has anyone had their rearend lock up temporarily?
- Play in front brakes
- None lsx brake help
- New Setup :)
- Modifying stock controll arms
- Problems installing Spohn ds loop
- Tips for Springs/Shocks
- Thoughts/Pics: SLP Springs & Bilstein Shocks
- Adjusting LCAs and PHB
- 94-97 vs 98-02 rear spring?
- K-Member Swap help?? best way?
- Biggest Brake Kit for 17's?
- C5 Brake Conversion Abutment Question
- Little confused after new suspension
- Steering Shaft Bushing
- My Strano Springs Installed
- Trans mounted torque arm problem.
- Question on UMI Panhard Relocation
- Strano springs with Koni 4/4
- Grinding noise???
- strange shocks-- 300 lb springs WAY TOO LOW
- Upper A arm question (different one)
- Definition of riding the bump stops?
- Strano Spring question
- Looking for chassis shop suggestions
- Getting My Ride To Hook!!!!!
- Please help guys....
- All finished
- Needing advice
- Adjustable lca's ?
- how much will springs help
- what 60ft should i expect
- Springs
- looking for input on suspension tuning
- Just ordered ABS delete kit. Any advice?
- Spring?
- LCA, are rod ends too harsh?
- Corolla - Frozen Rear Suspension in Cold Weather?
- Which LCA relocation brackets are these and how do I install them?
- help with drag setup
- Err.. Think I found my suspension problem?
- BMR Launches New Product - G8 SubFrame Connectors
- Bought fromnt Konis, now need rear...
- Okay to use stock motor mounts?
- KYB AGX Knobs Point Inwards?
- non adjustable tq arm
- C5 Brake conversion, install pics
- Springs
- C4 Rearend?
- Drop from Strano/Konis
- 4-Wheel Big Brake Kit Interest?
- I hit something.
- anyone make their own SFCs?
- Rear Brake upgrades?
- Strange Double Adjustable Question
- question about a 9"
