- Hawk Difference in Quality
- Front brakes
- NEED ADVISE on Suspension?
- C6Z06 brakes & suspention on C5. possible?
- School me...
- Watts link rear suspension pics
- strange question
- Struts/shocks. how often should they be changed?
- installing lcas and brackets
- what spring for the front or rear
- double drilled?
- Weird braking when braking (2001 C5 Corvette), need help asap!
- Installing a tubular K-member on an LT1 Camaro
- 1" drop not looking right...Help
- Christmas Presents Finally came! UMI
- Advice needed
- BMR Subframe hardware
- shock question, street and strip use...
- Help Adjusting Koni/Strano, almost gave a gf a concussion!
- Guess whats wrong with this picture?
- drag bags with stock springs???
- Rear Brake Line Question??
- Newbie at UMI Performance
- Are these koni's worth it?
- Pic request: rear brakes
- Strut Nut Rusted, Replacement Needed
- Please help!!!!!!!
- back half Q
- Before and After pics: Eibach Prokit
- What are you doing to hook on the street?
- How do I recenter the rear axle??
- 01 Camaro Frozen Caliper?
- Hawks HP plus pads break in?
- New torque arm install now have a vibration!
- Upper a-arms questions
- So what should I do??
- I Don't Think my car has bumpstops!
- I have clunking issues
- ABS woes
- Were Tubular SFCs the right choice?
- new stance
- What spring rate for track/street
- help with brake pad install
- LT1 to LS1 brakes... Good!!!!
- stranos with kyb agx shocks?
- Brake pad/rotor sale?
- can someone look at their rack and pinion for me?
- 97 WS6 FORMULA with lots of miles...
- brakes for 15 inch front wheels...
- Which Spohn Adjustable Torque Arm?
- UMI LCAs
- De Carbons are absolute Sh#t!!! Koni's on the other hand...
- Are my hubs on correct? 56K make a quilt
- J&m lca
- alignment/tire wear issue
- Strut Brace question
- What rear brakes are 93-02 F-body using ?
- No rear sway bar.. Good or bad..????
- an afco ?
- Just ordered Sams Springs and the Koni adj!
- E-Brake dust cover
- what you think about this set up?
- Please help! No rear brakes 93 Z28
- Cheapest place for Wheel Hubs ?
- Need QA1 adj. rebuild kit. anyone know where i can get it
- Rotor Dia.?
- Caliper paint and decals
- Tie Rod End Replace
- k member conversion
- ABS inop and ETS off
- New K-member.. what busings/bearings/things to replace?
- Sway Bar End Links
- 2" drop too much for my setup
- afco?
- 1" lowering springs
- Bilstein 199001 + 19902?
- Aftermarket Stock Spring Height?
- Just got my new DKT LCA's!
- Rear sway bar killing bushings
- Hawk HP+ pads (initial review)
- Brace that goes under the driveshaft
- quiet pleeeease.
- What shocks to get
- Thninking about replacing the hardline in the rear brakes....
- Some advice on LCA's please!
- caliper help
- caliper question
- Another clunking thread...
- wilwood drag brakes
- Strange shocks/qa1 springs help
- Best Drag shock and question on lowering springs
- i need some advise
- UMI lower a-arms ball joint question
- my car feels sloppy
- Suspension mods
- C0035 Fr LH WSS CKT Malfunction
- grinded down calipers + powerslots not fit?
- Penske shocks??
- Need help with Torque Arm
- Front Caliper Brackets
- sqeeky brakes issue please help
- stock bleed screw part numbers
- pads not making full contact
- Spring cups for Strange??
- need opinions on my suspension
- Umi 3 point installed
- looking for suspenion set up to handle 450 to 500 rwhp
- Need Rotors - Any advise?
- What suspension set up?!
- Koni rear shock problem
- Torque arm or shocks?
- HELP: I'm sooo confused with my custom front suspension!
- Adjusting the PHB
- where to find poly bushings
- Best shocks?
- Happy New Year from UMI Performance!
- Torque Specs
- Happy New Year
- Front Coilover install
- Which ball joints to use?
- Panhard!??
- Question about painting Calipers
- LCA Question
- 1982-2002 F-Body LCA's and Panhard Rods...
- eibach drag launch springs
- Satisfied GranSport 6 pads... yey or neigh?
- Installed Torque Arm But Feels The Same
- wondering how long it would take to install lock line
- Front Struts, Who has some for Sale?
- strut tower bar
- Complete Drag Race Powertrain/Suspension ETC. Setup For All 93 & Up F-Body
- 2" drop in back of my 02 z !!
- Project ugly brakes (pics)
- Which PHB?
- Why No Rubber Bushing LCAs?
- brake bleeder fitting
- Just purchased '02 SS w/130K miles. what shocks?
- what short torque arm to use with true duals
- How to bleed front brake fluid on 01 Camaro SS.
- Question about panhard bar
- brembo brakes on LT1?
- when on jack stands one side sits lower(rear)
- Vibration at high speeds
- Dash Break Light Comes on
- why does my new brakes do this?
- strut tower bar
- C5 Rotor Conversion Package for 1993-2002 F-Bodies!!!
- sticking back brakes?
- which shocks would you recommend?
- any pics of weld in frame connectors
- Anyone tried the DOT5 Sylicon brake fluid?
- Major brake problem. Hard pedal and wont stop well.
- Best spring for daily driver on pretty much crap NC roads
- Sportline's with kyb agx shocks...???'s
- Rate my suspension choice
- rear sway bar is inch enough
- Drilled rotors cracked all to Hell. Can this cause the brake to drag?
- finding quality brake pads
- lca torque questions + help with rear suspension please!
- subframe connectors or shocks?
- what a-arms to go with
- quick question
- One day only!!! Don't miss out!!
- hotchkis STB install
- What Sway Bar?
- Poly/Poly LCA - Bind?
- quick question about lca's
- SFC for a vert
- Merry Christmas from UMI Performance
- Bleeding bone dry 95 camaro brakes w/ ABS
- Converting LS1 to LT1 Brakes
- PICS- of Front cut springs and Rear hose mod only??
- Happy Holidays
- Motor Mounts
- lowered car with spare on - bad scraping!
- stock ride height
- How does this brake combination sound??
- Heater hose mod. What size heater hose??
- Lost ABS What could it be?
- Rear end sliding out....
- competition engineering
- Worked all day on the rear suspension. Have some questions (all one thread)
- Hollow frt sway bars.
- BMR questions.
- Sway Bar Removal?
- Rod end bearing for stock control arm
- Springs/Shocks
- Rack and Pinion Help
- Upper and Lower A ARMS
- LCA Relocation Brackets - Yes or No?
- 2" Drop Spindles
- Christmas Sale from BMR Fabrication on 3rd Gen Suspension Parts
- Christmas Sale from BMR Fabrication on 4th Gen Suspension Parts
- Lesson Learned: Brake install
- non adjustable panhard on lowered car...
- Line Lock Activation
- Drastic lack of traction
- Panhard Bar question
- Duh......No wonder she had the stopping distance of a Mack truck
- what k-member are you running?
- LS1 parking brake on 3rd gen?
- What is the size of the bolt that connects the brake bracket to the spindle?
- calipers?
- KYB shocks
- people with UMI k member come in
- BMR Strut Tower on 99 V6?? can it be done?
- Anybody with QA1 rear coil over experience?
- relocation brackets improperly installed?? please help
- What do you guys think of these?
- Difference Between QA1 "F" and "R" Struts
- do i need shocks???
- Thinking about putting some money into suspension -- a little clueless.
- Took my car to midas and now i need a whole new brake system???
- silicone brake fluid abs issue?
- BMR Chevelle at the SC Suspension & Handling Challenge 2008
- TA relocation crossmember adjustability question
- Torque Arm Question
- need help picking lca
- LS1 into a 55 EFFIE?
- SLP Bolt in subframe connectors
- SFC Questions
- SLP Torque Arm?
- Who knows about aerospace components calipers?
- Mother F-ing tq arm mount!!!
- Installing stock torque arm
- torque arm?
- Need some info on ls1/C5 brake calipers...
- How to bleed ABS module???
- Bad alignment
- Anyone have a C4 rear brake caliper bolt?
- Which shocks?
- Question about lg springs
- ladder bar question?????
- Steering Rack Q's
- suspension issue
- UMI SFC VS Stock Y Pipe
- So who makes a DS loop for a TD x-pipe
- Supension Qs
- 6LE Lower Control Arms... All rod ended and at a GREAT price!
- UMI 3pt SFC's
- LCA Relocation brackets
- help!
- Sfc
- brake feel
- squeak problem... not sure what it is..
- Strange Front Coilover Install. Questions on settings for drag racing??
- For dragracing
- front sway
- Swapping lt1 brakes to ls1 brakes
