View Full Version : Suspension & Brakes
- Brake Help.
- 02 SS front sus
- Rear suspension questions
- Strano Performance Sway Bars & Handling Kits
- What is the single best rear suspension upgrade? (For Drag)
- Which Torque Arm for 4l80e Setup?
- Will my setup be ok?
- BMR Fabrication Congratulates Troy Pirez
- lowering
- suspension question
- New parts
- Suspension Setup (man im confused)
- alot of Suspension Questions
- just installed rear comp shocks
- Where do i buy the front hubs from?
- Bent UMI TA Diff bracket
- Coil Over Owners Chime In
- Hotchkis strut tower brace: Is the LT1 model same as LS1??
- Help me build up my rear suspension!
- LCA Relocation brackets: Must Have?
- Fully Independent Rear Suspension 4th gens
- Car Sit 1 inch Difference from Side to side?? Need Help?
- QA1 275lb springs question
- Aftermarket LCA's?
- Wolfe Tublar SFC?
- help please
- Koni pricing information
- BMR Stb and Spohn Adj STB... Help
- Transmission bushing install
- sway bar question
- Popping noise after front QA1 install
- MPGs went down after drilled slotted brake job...
- to soft?
- question on subframes
- How to wire a line lock correctly
- I want to revoke a comment
- rear koni install help!!
- UMI strut bar
- Props to SJM
- need help
- Convince me to buy adjustable suspension components
- drag racing QA1 question please
- where to get some brake parts
- Best fo Both Worlds!?!?!?!
- ABS and DRLs?
- Replaced Lower A Arm
- Best wheel width for handling?
- Satisfied with SLP Bilsteins?
- cut stock springs for the strip?
- Strano Springs
- Torque Specs for spring swap
- mustang front struts
- Corvette Rotors
- brake questions areospace front brake kit
- Does this look good?
- TA - tunnel or X-mount for HANDLING?
- Another brakes question.
- need new brakes and rotors
- Where can I find rod end bushings?
- CTS-V Brakes on a 4th Gen.
- WANTED pics with the eibach pro kit
- 18" Rims with Eibach Sportlines: Pictures Wanted!!
- sprotline spring ....wanna swich to prokit
- CN 1.6 springs??????
- kyb agx's and a few ?'s
- Question about LT1 to LS1 brake upgrade
- Which next suspension component for me? 97 TA
- which suspension package for moser 9"?
- centering the rear
- A big thanks to everyone at strano parts
- Identifying 3 Vs. 4 channel ABS
- shock/spring options giving me a headache
- im going to order the comp shocks
- Will these springs fit?
- time to hook! need advice
- wich motor mounts ?
- New struts no there's a funny noise...
- best overall street/track set up ??
- bts kit
- Vibration~
- are these shocks any good
- Painted Brake Calipers and Eibach Pro Kit
- Street suspension on a budget
- (pics inside) what kind of shocks are these ?
- 8-point roll bars
- Heavy rotors
- adjustable lca's
- best set up for drag racing
- Wise to ADj. my rears Koni's??
- Cheapest place for slotted/drilled Front Rotors?
- I want my SS to handle better?
- shocks for lowered car that does drag racing.
- bear brakes?
- Setup
- Sloppy Rearend
- What would you recommend???
- Modifying cast spindles
- guys with kyb agx shocks come in
- which hawks pads?
- Quetion about pinion angle
- koni 4/3 rear setting
- Aerospace Pro Street kit fitment questions.
- Best shocks?
- Where can I get this bracket? (pic)
- UMI Boxed vs. 3 point subframe connectors!
- best place to get drag breaks for 2000 ta
- How much torque I need on a spohn rear swaybar?
- what helps lower 60 ft times
- Rear driver side brake pad getting eaten up.
- UMI products
- What is needed for more caster - lower A-arms?
- Pro-kit vs. factory ss suspension.
- v8 eibach on v6?
- Need pics of cars lowered with Strano springs
- Problem?
- SFC's or Torque Arm?
- yet another.....
- 15" wheels any other caliper options w/o grinding
- Weld sfcs entire length???
- Idea to swap shock/springs between seasons
- binding rear suspension
- Where to get....?
- cheap way to kill my wheel hop..
- question
- SFC's for a hardtop
- Strano order
- SJM ABS delete/linelock question
- UMI kmember pic request
- Suspension Time
- Handbrake won't work if car is moving forwards
- just ordered bmr stuff
- PHB & LCA's
- wobble
- rear brake rotors
- Upper A-Arms for my application?
- Adjustable torque arm
- torque arm bushing and trans bushing replacement
- Christmas present to myself!!
- brakes/rotors
- any diffrence in front brake calipers? 02ws6.. 00 ta?
- ABS inop question
- K-member kits
- hey yall just lowered my car what yall think
- Looking to Lower, Suggestions Please
- 2002 Impala 3.4 liter Broken Spring
- ABS failure?
- T-tops Leaking
- Wolfe SFC's?
- UPS man brought me stuff today.
- LCA's tubluar vs. boxed
- Foreign junk and bad roads
- Strano settings works for GT4
- Help: Relcation Brackets messing up my tranny
- How To Air Bag Your 4th Gen for $600
- I love AutoX and drag racing...What to do?
- installed bunch of umi parts: big thumbs up
- Blistein BTS
- those of you with eibach pro-kits
- 94 rear brakes vs WTF??
- installing hub..?
- strut tower brace ?
- Brakes
- bout to go leave 2 lower my car
- Is this wheel hop?
- Wilwood Bg Brake Kit Squeeking
- c5 z06 Brakes
- Grinding Noise
- Have Intrax Springs, what shocks to use?
- Lowered car and suspension travel
- Strano springs, suspension and tires?
- do i need to readjust panhard bar??
- Hopefully Obvious...
- Alignment needed after shocks?
- Rear Coil-over Shocks
- Check out my $237 Hoosier 315's!!!! PICS!!!
- 16 Position QA1???
- Need to hook my Z
- Need Help on Something
- LCA relocation setting ?
- need lowering advice
- Help with bleeding brakes through the Motive Powerbleeder
- So I just lowered my 00 SS and took it for alignment
- Good Lower Control Arm For Drag Racing
- Hex bolt?
- Adding spring spacer to sportline front springs?
- is a wheel hub/wheel bearing press fix??? car is apart please help
- WTF? My Tower brace doesn't fit
- Rearend Position.
- bmr trq arm=pain in the ass!
- rear end lifted
- Alignment
- what springs/shocks for drag car w/ tons of weight reduction
- which torque arm????
- adj upper and lower a arms
- Burkhart specials on brakes, shocks, and suspension items
- !Truck Springs
- WS6store slotted or Autozone blanks?
- for those with a jegster torque arm
- LS1 -> LT1 rear brake swap
- Possible Break Upgrade?
- Strano rear sway bar vs stock
- Front brake upgrade, Mustang II
- blew power steering line )=
- please help before i waste $$$ wheel hub/bearing???
- What the hell???
- Strut Tower Brace's
- strut tower brace and sub frame connectors
- C5 brakes on 69 camaro ready to go help
- Anybody used EBC Ultimax Rotors?
- getting LCA relocation brackets w/ rear out.
- need some help
- Rear is too low after springs...
- wheel is hitting?
- qa1 spring ? thoses of you with qa1s chime in
- what shocks do you reccomend
- anybody runnin lt's and a body mount torque arm?
- BMR trac bar = Driveshaft contact?
- Noisey suspension, need help.
- 99 front suspension on a 97?
- kyb gas adjust
- qa1's and true duals...questions!
- anyone else running bmr springs?
- c3 Corvette Suspension site
- Koni/Strano set is installed
- bump stops
- BMR or UMI or Yank Torque Arm Relocation K member question
- settting up lca's
- Tubular vs. Boxed LCA's
- Which headers have the best clearance?
- Panhard Rod/Rear Suspension Problems
- need a drop/suspension opinions for new wheels.
- brake won't even hold my car stalling to 1,800rpm???
- Problems with poly LCA and TB bushings
- brake booster?
- Wheel shakes violently under 50 mph
- Pre-Autozone Rotors Install?
- Abs Inop, Brake Light, Trac Off
- Replace shocks
- Panhard Bar
- 98-02 F-body vs 04 GTO brakes
- my brakes stuck on
- dirty master cylinder
- Are all torque arms the same?
- ball joints and tie rods
- Lake wood traction bars
- Are adjustable LCAs overkill?
- Need help, please come in.
- Any suspension ideas for this particular set-up?
