View Full Version : Suspension & Brakes
- Shocks?
- Prokit with TSP True Duals???
- Adjustable or not? (Torque Arm)
- Hydraulic Plumbing (as in lowriders)
- Shaving off sides of Spohn Drag bar?
- New suspension in. Sam Strano is the man
- what needs 2 be done 2 get C5 ZO6 brakes to fit TT2s
- Brake fade
- UMI F-Body Tunnel Brace Mounted Torque Arm
- 17x11 or 17x10 Front Wheels
- QA1 question
- TCS OFF and ABS INOP won't turn off
- Stock Steering Rack Question
- 4link weld in suspension for streetcar
- Torque arm CLAMSHELL
- Wilwood Rear Brakes
- bmr LCA rattles (poss fix ?)
- is my rear suspension setup bad?
- help with suspension ??
- UMI K-member Installed
- Which Lower Control Arms???
- Sub Frame Connectors
- Which Sponsor would be best??????
- Spohn LCA's & PHB installed! WHOLY SHAT!
- BMR K Member???
- backhalf, ladder bars, frame rails, i need answers please
- What LCA's have the best rod ends?
- LGM or Eibach
- *PICS* Before and after Strano springs, Konis
- Hydraulic Coilover Thread
- QA1 springs 275 or 300lb for the front??
- QA1 question
- new springs ...
- G-body suspension
- Difference between sportline and prokit
- New set up
- torque arm relocation
- C6Z Calipers and Wheels
- 1le part numbers
- Not lowered - 315s in front - F-body?
- Serious Matter
- Hotchkis Suspension
- Whats the advantage to a tunnelbrace torque arm?
- Problems with new rotors and pads
- abs light has been on since i bought the car.
- Will 82-92 shocks fit a 93-up???
- Rotors..
- LCA relos/LCA/subframe discussion
- Zo6 Calipers on a Trans Am?
- Need shocks
- Torque Arm
- which springs with bilstein shocks
- My car feels like the rearend sways?
- new brakes..breaking in?
- Sam if money is a issue what other cars do you suggest
- Top of strut rusted fast, what do I do?
- Torque arm w/ dsl?
- Which Pads And Rotors???
- Help swapping front springs
- crooked front end
- Koni SA's and Strano Springs on a Vert
- Brake Problems
- Brake problems still??????
- At the end of the track.......
- Is aftermarket TA needed?
- lower control arm bushings
- Heater Hose Mod
- Steering wheel play
- Where to buy some rotors?
- Baer Eradispeed Problem
- low trac light on at stop?
- Painting my Calipers... Need Opinions
- alignment?
- car shakes back and forth after sportline install
- For those of you with lowered rides and wide rear tires?
- What is the best for suspension mod for THIS setup???
- Make my ride SMOOTHER!!!
- Installing Adjustable Panhard Bar.....is it tough?
- Ajustable shock questions
- What adj. shock setting is same as stock shocks?
- Those who run Competition Engineering's drag shocks
- sway bar end links
- Suspension & Brake TECH & FAQ
- getting some sportlines. Shock q's
- Koni Install HELP
- what springs + shocks ?
- Rack and pinion?
- panhard rod...need some help!!
- 2 or 3 point SFC's?????
- Steering?
- Hows this list look
- Rod Ended LCA's On The Street
- Which shocks for stock springs?
- Do you really need the line lock with the abs delete?
- pass rear sits higher after lowring.. need advice please
- Roll Cage install
- brembo blanks?
- Hey Sam...Ohinls for The Fbody's?
- 05/06 GTO calipers...
- QA1 Shocks make a difference in my launch??
- need help reassembling strut!!! ASAP please!
- Steering racks interchangeable?
- K Member Install
- Just got the car lowered
- Warped rotors cause a woh woh woh sound while going down the road?
- what shocks on lowered car
- what's the second set of holes for on the rear of a aftermarket T/A?
- Lowering with TSP catted Y
- How loud are your rear LCAs?
- UMI PHB and LCA Install
- WS6 Store vs. UMI C5 brakes
- Lets talk grease.
- HAL Generation "F" Series Shocks Front & Rear Shock + BMR lowering springs???
- Smushy Brakes
- Question about alignment
- Crappy Springs/Shocks - need help!
- > Best monotube shock for BMR lowering springs?
- Rear brakes grabbing, making clunking sounds in reverse.
- Brake Question
- ABS Inop Light On
- Question about my Eibach Sportlines.
- What causes the passenger side to sit lower than the dirver's side in the rear?
- Tubular A Arms
- Hawk Pads Ceramic or No (street car)
- 02 springs fit a 95????
- Bigger Rotors w/C6 ZO6 Calipers possible??
- How do SFC’s really work?
- QA-1 and Spohn Q's
- rubber that stops from bottoming out
- ProKit install - Master Cyl question.
- Need help with ladder bars on Chevelle
- Rear suspension Set-ups POST !!
- caliper rebuild kit?
- where to buy rod ends?
- DMS Springs?
- Car Drifts To The Right...alginment?help
- Sub-Frame connector's from GM
- LGM springs or Eibach sportline lowering springs
- Shocks or LCA and PHB
- STB anyone ever fab their own??
- stock swaybar size for 98-02 ws6
- Anyone Worked With Hydraulics? (as in lowriders)
- quick relocation bracket ?
- Will ABS work with 28'' Tires
- brakes are sticking! need help!
- Alignment settings for Strano springs and Koni DA?
- driver side rear tire wears out faster
- Koni 4/4 and Strano...help setting them up
- Good Struts for Street/strip
- BMR XTREME Rear Anti-Roll Bar worth it?
- Pics of 12 bolts in 4th gens????
- 1979 12 Bolt on 1996 Camaro
- E Brake adjustments
- Accidents SUCK!!!
- have to hold brake firmly????
- Suspension or Rearend?????Help Needed!!
- Alignment specs for lowered vehicle
- Newly installed Line Lock leaks :(
- Build Your Own Bullet Camera Package!
- who makes low budget drag shock???
- Bolt in LCA Relocation Bracket Problem
- Should I upgrade my calipers etc.?
- Used springs, bad idea?
- How well does a aftermarket tq arm help on the street???
- Stock Ride Height Handling Package.
- E-brake lever part number? (Search didnt reveal much)
- looking at hals but got some quetions
- Sway bar help steering response…?
- Question about stability~opinions?
- adjustable trq arm question...
- Strano Kit - Goodby 60'?
- people with rear prokit sag,what do you do?
- Strano sway bar owners inside! (Or Sam himself)
- Pinion Angle
- torque arm ???
- Best mods for Z28 for racing and handling?
- Koni Install and settings, SUCCESS, whole new ride!!!
- Differance between 94-97 and 98-2002 Eibach Springs??
- my car grinds on sharp turns
- swapping stock swaybar question
- How do you know WHEN to change out rotors and pads?
- EBC yellow stuff. any one using?
- what type???
- shocks
- Sportlines or Intrax on a Ws6.....Pics please!
- hose mod
- intrax lowering Springs thumbs up or thumbs down?
- newbie lowering question.
- Help with front end rattle!
- Baer Eradispeed Rotors.
- Best DD Shock/Spring Combo
- WS6's w/ Strano Springs POST PICS!!!
- Just installed the New susupension setup!!!
- SJM LCAs
- replacing the rear brakes on 98 z28
- More issues with BMR Torque Arm Bracket (Build Quality)
- Which LCA's??????
- difference in calipers
- Eibach and Bilstein Question
- hooking on the street..
- ground control coilovers
- master cylinder
- STB make a difference?
- Have questions/issues for 9" and BMR TA install...
- Questions on installing BMR TA Relocation Bracket **PICS**
- UMI Questions.
- Short Torque Arm + Road Racing = ?
- dms springs, and ? shocks
- Line lock question?
- EBC brake pads...
- BMR Extreme T/A w/ Eibach pro kit?
- bmr adj crossmember
- Whats the point of coilovers?
- Changing brake lines with ABS?!?
- Summit springs?
- "02 Z28 Vert" Can I use 00SS Coil Springs
- LCA Relocation Brackets?
- Greasing Global West Control Arms
- Clunking in front
- Set me up for F-Stock
- WILWOOD brakes
- hals/qa1's
- Will an alignment raise my car? Strano springs, UMI tub cntrl arms
- Need Info, 1994 Firebird Formula
- Steering Wheel Swap?
- Still have whell hop after UMI LCA. (HELP)
- Have serious problems hooking, need ideas!
- best k- member
- Paging UMI !
- Just had ATE rotors + HAWK HPS pads installed
- will an eibach prokit work for a 00 V6 car?
- Lowering 00 t/a
- i want to get bolt on sfc's so what brand
- Air bags?
- pinion angle W/ adjustable torque arm?
- Brake Help!!!
- Does your MytiVac suk too?
- best shock for the money
- Symptoms of worn torque arm?
- C5 Brake upgrade finished
- Nasty wheel hop!
- Too much play in steering! HELP! Please!
- Strano spring results before after SLP pro-rate
- Wolfe CM Double Adjustable Panhard rod..
- Qa1/Hal shocks. Are they noisy?
- Sway bar hitting shock...
- Long torque arm VS Short
- brakes sticking
- lca relocation brackets change pinion angle?
- Brake squeal
