View Full Version : Carbureted LSX Forum
Pages : 1 2 3 4 5 6 7 8 9 10
11]
12 13 14 15 16
- 1ST Timer
- 1ST Timer
- What intake gaskets should I use
- head change how much pickup
- headman hustler s10 long tubes
- Ram air set-ups
- Nitrous Stand Alone Fuel Systems with Race Gas
- manual water temp gauge
- L92 Victor Jr users...step inside please
- Anybody using an EFI fuel pump??
- first time at the track this year
- 2 wire alternator, what goes where ?
- 5.3 paper build - any advice appreciated
- Hooking up the 6ls 6010?
- Lq9 swap with Carb need help with pump
- main cap's torque?
- I'm back!!! thanks to 3pedals i'm super motivated about this LY6 swap and a carb
- lq9 on alcohol
- Backfire Issue
- Making the drive to test 1/4 today.
- 5.3 1/8th mile testing
- 6.0 Build critique
- Holley setup advise please.
- Holley, Barry Grant , Quick Fuel??? Which would U Buy??
- Carbed or efi? Seeking input
- MSD Box that comes with the Victor Jr. kit
- A different fuel pump question
- My 5.3 retro fit
- Input on my ideas...Carbed Lq4
- Performer intake and nitrous?
- is their an adapter plate to mount carb sideways
- 4.8 carb advice
- electric fuel pump question
- Aero vs trap speed
- Help picking a carb
- Another oil leak thread (sigh)
- going carb on my 98 ls1 transam, sick of my tuner
- help me reach my goal
- cam sensor for MSD 6012
- carb maybe....
- Selling my 1975 C3 Corvette with ls1
- LSX G Body Run Video
- What kind of numbers?
- 50cc acc pump
- engine advice
- cpl last things and its ready! few ?s
- too big of cam?
- Another PCV question thread
- New eps cam specs!!!
- Hooked up my lock up torque converter
- How do I know exact compression ratio?
- Quick Ignition
- alternator question
- Someone please help!!!!
- Ls1 Ms4 Cam Jetting/Metering Questions
- Trex
- e85 carbs
- Adjust timing to get traction??
- High alternator mount and power steering.
- Engine run video/help!
- New best in Mustang
- 91 S10 LQ4 Build
- Thinking about going carbureted.
- Timing on 370ci LQ4
- new best ss 6.2 stang
- riddle me this...
- 4.8 or 5.3?
- LSX 454 dyno
- lq4 on nitrous sputtering at 7000
- New needing help on a 5.3 build.
- CARBED PCV routing!
- anyone use EFI intake w/pix??
- Hood Clearance on a 69 Camaro
- Fun with Cam Timing........
- gm performance intake
- Blown head gasket..results.
- Where's your......
- testing carb spacer
- will it fit ?
- 1952 Chev Truck Retrofit
- R4 compressor on 5.3 truck engine
- fuel pump, regulator and return line
- 1-2 shift misfire need ideas
- 650 speed demon
- Anyone have a 4th Gen F body with Carb?
- ebay headers
- Carbed 6.0 and T56
- Msd 6010
- 6.0 piston to valve clearance
- cast iron 6.0
- Combo for 79 Trans am
- 70 camaro lq4
- Experienced advice requested ref carb selection
- LS1 Engine with Edelbrock Timing Module
- Pics of 6.0 LY6 into tube chassis 1963 Plymouth Valiant
- Carbed PCV ideas
- Header Gasket ?? RTV, MLS, ??
- Death of the Carb'd V8?
- How much power?
- new PB 7.01 1/8 93 mustang coupe lq4
- Quick 700r4 to ls question
- new best
- 6.0 to the 86 TA
- I think I just found a carb problem I have been chasing.....
- new track times
- Show me your Pcv set ups
- 'bout freakin' time....
- Msd mounting issue...
- Best intake manifold for setup??
- Just one more 6.0 Mustang
- how to identify
- Steam port Crossover?
- New exhaust carb 6.0
- Stock LS2 intake/carb suggestions
- Help me with PTVC
- LS engine block choice
- Help me dial in!!!
- runs like a turd!!
- Eric at HKE, help!
- Moved back to east coast - new best runs for the Camaro
- cant post pics?
- Vic Jr Intake Leak....
- Beaudacious S10 Resurrected!!!
- Dirty heads
- 04 5.3L wont stay running Help!
- Stevecritt LQ9 L92 Build Thread.
- What should Target AFR be?
- wideband
- will 6010 work with boost?
- Knock sensors?
- drivin issues.
- Rich idle....where to go from here?
- Professional products
- Carbed 08 5.3/4l60e Using Rossler Black Box
- My 67 Chevelle build.
- new best et from my cam only 6.2 and my turbo 400 fti setup
- NemeSS's 1968 C10
- new personal best
- Buying 6010...what does it come with?
- engine cutting out at 6000rpms on nitrous
- Any blow through setups?
- LSX 5.3 in a boat
- 408 lsx heads and cam?
- What fuel pressure regulator is the best?
- Valve Spring..Advice
- Need a carb asap!!
- Where on engine can I get a vacum reading
- to ms3 and stock heads or mill heads and get smaller cam?
- burnin the tires
- Help me figure out my C4 swap
- 99 carb'd camaro
- Start of LS s-10 Blazer
- Relocated coils, what plug wires?
- Signs of a bad 6010?
- More changes
- 6.0 heads/cam carb??
- Which wheels for my 91 RS
- Finally got to make some test hits on the Mustang.
- MSD red wire
- Msd 6012?
- quick fuel carbs..whats your opinions?
- Best place to put O2 sensors?
- Carbing a 5.3 and need some help.
- GMPP L92 Dual Plane VS Victor Jr L92 Height (pics included)
- Deliver Me From Temptation - N2O
- Rear pump squirters leakin while shut off (hot)
- Stock lq6 carb dyno
- King Demon RS for 408
- tach on a 6010 problems
- carbed lq4 with 6010 issues.(very hard to start)
- Anybody tried Summit Racing carbs?
- Alternator wiring differances?
- 86 Z28 5.3 swap
- Help! 6.0 with 823 head, carburetor, nitrous, cam selection?
- msd 6ls question
- Adjustable timing pointer
- Want a good deal on a new Edelbrock Intake?
- Air cleaner housing - Is bigger better? No real space constraints...
- Anyone install their Performer RPM manifold "backwards"?
- 5.3 cam choices
- Tools defined
- GM ASA Hot cam - complete specs? Cam doctor?
- having problems
- Dual plane
- my new build,,,oh no another mustang
- Which transmission for Fox?
- carbed ls1 cam question
- msd 6010 question
- Hard to start when hot
- swap help
- Fuel Pump Problem Fixed
- dyno day
- carbed lsXtra 68 firebird 400,newbie
- valley covers
- what hp will a holley red support
- what stall to use?
- Got EPS Cam specs today for my build
- Open or Closed exhaust??
- Anyone using Weber IDF/IDA or Dellorto DRLA Carbs?
- which carb jets should i start with
- Anybody running an LS6 cam?
- First outing to the track...not so good day.
- Any carb guys looking to go f.i. ?
- Questions on a 6.0 foxbody swap
- Air cleaner
- Alternator wiring made easy.. Save yourself a headache!
- Which valley cover and coolant crossover pipes for carb'd LS1?
- Help me finish my conversion
- Cam specs and different manufacturers???
- Nitrous carb guys and 6010 box
- Rr 1.7/1.8?
- 364/440 crate engine. Just got it
- distributor conversion with truck accessories?
- Single plane LS3 carb intake manifold height?
- Carb Sizing on 408 LSx
- Not Enough Carb for H/C/I LQ9???
- What weight oil are you running?
- Too hot to wrench or race.
- Throttle cable for a four barrel throttle body?
- The replacement (91 B4C RS 4.8 swap)
- car wont stay running HELP
- Fox Body, Dynatech, Plug Wire problem
- stumble at wot, 6.0l, l92, holley 750
- ANOTHER 6 LTR MUSTANG GLORY STORY with track times
- l92 valley port? where do i hook it to?
- Speedtigger goes to Graceland... well Summit.
- Cant deside on cam?
- 4.8 build
- Fuel Line size ?
- Lq4 carb wiring
- Whos using F body accessories with alt and water pump only
- what plugs and gap?
- MSD 6010 upload
- jet sizes
- I'm at a loss..
- LQ9 carb build! lots of questions. Fuel system?
- Another Single Wire Corvette Alternator question
- Car skipping @5,000RPM ??
- Gauge install help!!
- Semi built lq4..carb or F.I is the question!
- MAP timing table with MSD 6010
- MSD 6010 Software
- Victor Jr. or Performer RPM?
- LQ4 Build
- Anyone have a msd box go bad?
- Wha size are the bolts for the Performer RPM Intake?
- Need Foxbody Mustang wiring help neutral safety switch..pic inside
- Got her fired up!!!!!
- Out with LT1, in with LQ9
- Odd misfire
