View Full Version : Carbureted LSX forum
Pages : 1 2 [3] 4 5 6 7 8
  1. Pics of 6.0 LY6 into tube chassis 1963 Plymouth Valiant
  2. Carbed PCV ideas
  3. Header Gasket ?? RTV, MLS, ??
  4. Death of the Carb'd V8?
  5. How much power?
  6. new PB 7.01 1/8 93 mustang coupe lq4
  7. Quick 700r4 to ls question
  8. new best
  9. 6.0 to the 86 TA
  10. I think I just found a carb problem I have been chasing.....
  11. new track times
  12. Show me your Pcv set ups
  13. 'bout freakin' time....
  14. Msd mounting issue...
  15. Best intake manifold for setup??
  16. Just one more 6.0 Mustang
  17. how to identify
  18. Steam port Crossover?
  19. New exhaust carb 6.0
  20. Stock LS2 intake/carb suggestions
  21. Help me with PTVC
  22. LS engine block choice
  23. Help me dial in!!!
  24. runs like a turd!!
  25. Eric at HKE, help!
  26. Moved back to east coast - new best runs for the Camaro
  27. cant post pics?
  28. Vic Jr Intake Leak....
  29. Beaudacious S10 Resurrected!!!
  30. Dirty heads
  31. 04 5.3L wont stay running Help!
  32. Stevecritt LQ9 L92 Build Thread.
  33. What should Target AFR be?
  34. wideband
  35. will 6010 work with boost?
  36. Knock sensors?
  37. drivin issues.
  38. Rich idle....where to go from here?
  39. Professional products
  40. Carbed 08 5.3/4l60e Using Rossler Black Box
  41. My 67 Chevelle build.
  42. new best et from my cam only 6.2 and my turbo 400 fti setup
  43. NemeSS's 1968 C10
  44. new personal best
  45. Buying 6010...what does it come with?
  46. engine cutting out at 6000rpms on nitrous
  47. Total timing
  48. Any blow through setups?
  49. LSX 5.3 in a boat
  50. 408 lsx heads and cam?
  51. What fuel pressure regulator is the best?
  52. Valve Spring..Advice
  53. Need a carb asap!!
  54. Where on engine can I get a vacum reading
  55. to ms3 and stock heads or mill heads and get smaller cam?
  56. burnin the tires
  57. Help me figure out my C4 swap
  58. 99 carb'd camaro
  59. Start of LS s-10 Blazer
  60. Relocated coils, what plug wires?
  61. Signs of a bad 6010?
  62. More changes
  63. 6.0 heads/cam carb??
  64. Which wheels for my 91 RS
  65. Finally got to make some test hits on the Mustang.
  66. MSD red wire
  67. Msd 6012?
  68. quick fuel carbs..whats your opinions?
  69. Best place to put O2 sensors?
  70. Carbing a 5.3 and need some help.
  71. GMPP L92 Dual Plane VS Victor Jr L92 Height (pics included)
  72. Deliver Me From Temptation - N2O
  73. Rear pump squirters leakin while shut off (hot)
  74. Stock lq6 carb dyno
  75. King Demon RS for 408
  76. tach on a 6010 problems
  77. carbed lq4 with 6010 issues.(very hard to start)
  78. Anybody tried Summit Racing carbs?
  79. Alternator wiring differances?
  80. 86 Z28 5.3 swap
  81. Help! 6.0 with 823 head, carburetor, nitrous, cam selection?
  82. msd 6ls question
  83. Adjustable timing pointer
  84. Want a good deal on a new Edelbrock Intake?
  85. Air cleaner housing - Is bigger better? No real space constraints...
  86. Anyone install their Performer RPM manifold "backwards"?
  87. 5.3 cam choices
  88. Tools defined
  89. GM ASA Hot cam - complete specs? Cam doctor?
  90. having problems
  91. Dual plane
  92. my new build,,,oh no another mustang
  93. Which transmission for Fox?
  94. carbed ls1 cam question
  95. msd 6010 question
  96. Hard to start when hot
  97. swap help
  98. Fuel Pump Problem Fixed
  99. dyno day
  100. carbed lsXtra 68 firebird 400,newbie
  101. valley covers
  102. what hp will a holley red support
  103. what stall to use?
  104. Got EPS Cam specs today for my build
  105. Open or Closed exhaust??
  106. Anyone using Weber IDF/IDA or Dellorto DRLA Carbs?
  107. which carb jets should i start with
  108. Anybody running an LS6 cam?
  109. First outing to the track...not so good day.
  110. Any carb guys looking to go f.i. ?
  111. Questions on a 6.0 foxbody swap
  112. Air cleaner
  113. Alternator wiring made easy.. Save yourself a headache!
  114. Which valley cover and coolant crossover pipes for carb'd LS1?
  115. Help me finish my conversion
  116. Cam specs and different manufacturers???
  117. Nitrous carb guys and 6010 box
  118. Rr 1.7/1.8?
  119. 364/440 crate engine. Just got it
  120. distributor conversion with truck accessories?
  121. Single plane LS3 carb intake manifold height?
  122. Carb Sizing on 408 LSx
  123. Not Enough Carb for H/C/I LQ9???
  124. What weight oil are you running?
  125. Too hot to wrench or race.
  126. Throttle cable for a four barrel throttle body?
  127. The replacement (91 B4C RS 4.8 swap)
  128. car wont stay running HELP
  129. Fox Body, Dynatech, Plug Wire problem
  130. stumble at wot, 6.0l, l92, holley 750
  131. ANOTHER 6 LTR MUSTANG GLORY STORY with track times
  132. l92 valley port? where do i hook it to?
  133. Speedtigger goes to Graceland... well Summit.
  134. Cant deside on cam?
  135. 4.8 build
  136. Fuel Line size ?
  137. Lq4 carb wiring
  138. Whos using F body accessories with alt and water pump only
  139. what plugs and gap?
  140. MSD 6010 upload
  141. jet sizes
  142. I'm at a loss..
  143. LQ9 carb build! lots of questions. Fuel system?
  144. Another Single Wire Corvette Alternator question
  145. Car skipping @5,000RPM ??
  146. Gauge install help!!
  147. Semi built lq4..carb or F.I is the question!
  148. MAP timing table with MSD 6010
  149. MSD 6010 Software
  150. Victor Jr. or Performer RPM?
  151. LQ4 Build
  152. Anyone have a msd box go bad?
  153. Wha size are the bolts for the Performer RPM Intake?
  154. Need Foxbody Mustang wiring help neutral safety switch..pic inside
  155. Got her fired up!!!!!
  156. Out with LT1, in with LQ9
  157. Odd misfire
  158. Heat soak
  159. Testing New Combo today
  160. best carb for a stock ls1 ?
  161. Best tranny controller for carbed LS2/4L70E?
  162. Can't get outta the hole... Carb help needed
  163. carb/ cam only ls2 guys...
  164. Check my math please ?
  165. I'm Running a Q-jet on my 5.3 and Love it
  166. LQ4 Information Pleaes
  167. Pro Systems Carbs
  168. Valley Plate?
  169. Will a stock LS1 cam pull too much vacuum at idle? Swap cam for carb application?
  170. Does this look right?
  171. Could this pinched O-ring on the oil pump pick up have caused a spun rod bearing?
  172. 6.2 cam only 250 shot on a fogger**time slip added**
  173. Fuel pump location?
  174. 6.0 Blow Through
  175. LQ4 carb size
  176. 2001 mustang saleen need custom harness!
  177. 5.3 carb or fuel injection
  178. Can't get my LS2 to idle!
  179. fuel pressure issues
  180. 6010 - Battery disconnect
  181. Streetknight's Fox Build
  182. help with nitrous tuning
  183. Good news and bad news......
  184. Ls & lsx?
  185. Sealer needed on intake bolt threads?
  186. can a Super Victor work on LS3 heads?
  187. wtb carb'd intake and msd boxs for 5.3
  188. DMMizell LSx copy's
  189. Fuel Line Question
  190. Stock flexplate or SFI
  191. Cam sensor extension harness sucks
  192. ARP rod bolts & resizing the rods.
  193. holley dual carb intake
  194. Is my 2002 ls-1 1st design or second design?
  195. Yay, nay?: MSD controller for LS efi...
  196. LQ4 Questions
  197. Push Lock Hose
  198. i thought you carb guys might like this!
  199. Super Vic + Carb + hat under stock SS Hood?
  200. fuel pump issues
  201. ultra hp tuning
  202. Base Dyno Pull - Results
  203. On my way.........
  204. approx. Hp Tq
  205. New 408 tuning
  206. S-K Speed.....
  207. MSD question....
  208. Who has the Holley Modular Hi Ram?
  209. any gain switching to carb
  210. Is .030 alot to turn off the crank?
  211. MSD 6010 MAP setup?
  212. LQx with a carb look but EFI
  213. What engine assembly manual
  214. ls1 850 or 950
  215. wiring my f body alternator carb ls1
  216. who make summitracing carbs?
  217. Intake manifold help
  218. Stock LS6 dyno numbers....
  219. Damaged the RS today
  220. What caused a spun rod bearing?
  221. 98 camaro racer
  222. help with msd cable lol
  223. Air cleaner assembly help....
  224. Fuel pressure drop ??
  225. on the fence about going carb on my LQ4
  226. MSD 6010 wont rev passed 2200rpm
  227. 5500 car falls flat on face
  228. Wiring - EFI to Carb
  229. Question for guys running a 750 holley
  230. Custom Cam for Carb Setup
  231. Project 427 bagged daily driver
  232. ***************FOR SALE*************** (Carbed applications)
  233. msd 7531 and coil per cyl?
  234. Super Victor fuel distribution issues
  235. LS Carb for sale section??
  236. MSD 6010 No start...help.
  237. quick question bout 6010 and wiring with NO progressive for tach output
  238. Oil pressure sending unit adapter
  239. Carbed L33 jet size question
  240. Test drive
  241. A/C with a carbed LS setup
  242. its alive again!
  243. Mustang Coupe LY6 swap BRP mounts
  244. What size carb for stock LM7?
  245. 91 s10
  246. msd to computer cord
  247. going to wheel dyno tomorrow any guesses???
  248. Why are people putting their Carb on backwards?
  249. 1rst track results for the junkyard dog
  250. THIS close to driving...small prob with TV cable bracket?
