View Full Version : Carbureted LSX forum
Pages : 1 2 3 4 [5] 6 7 8
  1. LS1 Coil Harness help
  2. Quick help on drivers side breather...what size??
  3. LSx Carb'd Swap Q's
  4. The difference between a Holley 950HP vs a 750HP
  5. 6.0 carb help (need cam setup)
  6. gmpp carb intake
  7. What would you do?
  8. Happy holidays to my carb forum friends.
  9. sheet metel carbed ls1 intake
  10. who uses wideband o2 setup on their carb motor?
  11. L-92 Dual plane intakes
  12. Damper options with dist cover>?
  13. Carb'd 5.3 with issues...
  14. Carbed 6.0 cam question for a full size 4x4 toy...
  15. Seeking opinions between a LQ4 and 502 bbc
  16. Roots blower?
  17. how much gain from
  18. Top 10 reasons I ditched EFI
  19. 6LS for 24x reluctor...hook up to any coil pack?
  20. anyone????? TRIED IT YET
  21. Project EFI to Carb in my 2007 Silverado
  22. Vic Jr. or Performer for budget 5.3 w/ 4.8 pistons. 11.5:1+ comp
  23. GMPP L92 vs GMPP cath port intake height
  24. Can my 65 make it to the 6s/10s on the motor?
  25. In tank fuel pump
  26. carbed ls3 problem,.help
  27. Water pump issues.. Broken water neck
  28. map sensor find
  29. 5.3 cam help
  30. Figured I'd post this here...
  31. hood clearance
  32. 6.0 carb conversion help!
  33. Carbing a 09 5.3, What tranny?
  34. 89 mustang 6.0 10.63 on motor VIDEO
  35. ls1 s10
  36. milling 243s
  37. new best time
  38. HELP coil harness problems.
  39. ported iron 6.0 heads a good choice???
  40. Timing !!
  41. 241s or 243s
  42. Anybody know anything about Demon carbs
  43. Gutting out my Tahoe for my El Camino
  44. MSD 6LS mounted inside???
  45. Porting heads on a budget motor
  46. Cam for a carbed 5.3...light car
  47. Hood clearance...SBC vs LS
  48. Edelbrock to msd
  49. 408 lq4,l92,build for 92 corvette.
  50. What is the real cost & performance gain of stroking an ls-1?
  51. e-bay rotating assembly
  52. Carb baseline setting help
  53. new school72 walk around vid !
  54. is this about right
  55. carb advice
  56. pics coming tomorrow
  57. LQ4 plan....
  58. Goal: 6.50's 1/8 with carb...what do I need.
  59. some thoughts
  60. happy thanksgiving
  61. Intake needed
  62. Will I be better off with LS1 or LQ4?
  63. l92 vs 317's
  64. Extremely rich on a cruise. Tuning help please.
  65. stock 2002 throttle cable to 4150 carb
  66. LY6 & LQ4...will same intake work?
  67. cam companies...
  68. E85 anybody use it?
  69. LSX recommended clearances
  70. Idle timing
  71. carb 347 n2o options
  72. new to LS...is carb the way to go on conversion drag car?
  73. What should I expect hp f.I to carb 6spd to th400
  74. need cam ideas...ls2 w/carb
  75. LS3 foxbody video
  76. Got a new carb for the TA
  77. Carbed lq4 intake/cam question
  78. Carbed 2008 4.8, 6010 msd box
  79. my ly6 on 150 shot
  80. New best
  81. My carbed L92 headed 6.0 "video"
  82. Using 6.0 in our Port City circle track car
  83. 5.3 carb setup for ski boat...
  84. Drag racing only need 600+ hp.
  85. stock lq4 best chip 6010
  86. Carbed LQ4 Smoke at Idle-Carb Issue?
  87. Stock rods w/ arp bolts or forged on a 418 w/ nos
  88. Carb for LQ4/317, then LQ4/L92 Combo??
  89. Best carb choice for LY6 (6.0 w/ L92 heads) stock cam
  90. E-85 questions
  91. Gm intakes
  92. anyone need a new msd 6010 cable?
  93. Building temp carb motor, need input relating to cam/intake choice
  94. G6X3 cam or something else?
  95. Fuel bowl plug question.
  96. Looking for input on proven carb'd LY6 combinations
  97. Data logging a carb'd LS motor
  98. shakedown runs - got some questions.
  99. Bad lifter cause backfire through carb?
  100. First Passes 383 Carb & Dist.
  101. New Mallorey FireStorm ignition?
  102. Nightstalker 90 chevy 1500 5.3 carbed
  103. LS3/L92/243 heads and intake ?s
  104. Part throttle misfire? help!
  105. Carb setup on ls1... Help
  106. In need of advice
  107. Motor mount ??
  108. Electric Fuel Pump/ Electric Water Pump ???
  109. Just ordered a new custom carb cam.
  110. got a new toy
  111. carbd lq9 with 799s compression fear?
  112. first time out with lq4 powered mustang
  113. Finally done chasing lean tip in problem!
  114. 64 GTO Road Race Car with LS3 416 Carb Motor
  115. Custom coil cover for carbed Ls1
  116. convert carb to fuel injected?
  117. Winter Muscle Up
  118. Carb question but not for my LS1
  119. What Spark Plug 6.0 carbed
  120. Custom grind cam for my carb'd 5.3 arrived
  121. Anyone using the msd6ls two step feature?
  122. 4th gen throttle cable problems
  123. lq4/ls3 heads g6x3 cam.holley 750dp hp good enough??
  124. How To Check Coils Packs
  125. Bracket to mount tps sensor to carb.
  126. what cam to use?
  127. Cam Suggestions
  128. Anyone regret going carb?
  129. Stupid question in Regards to the 6010 box.
  130. Traction
  131. Crank case Evac kit and Valley cover?
  132. 1-wire alternators
  133. Need some help with the conversion
  134. 6.0 mustang upgrade time
  135. Coleman Roddy
  136. What cam to use on a carbed ls1
  137. "Speedo gear housing" help!
  138. Alternator wire voltage?
  139. 6010 startup
  140. help with 5.3
  141. Intake manifold
  142. head bolt?
  143. Carbed LS in a GMC Sierra
  144. Tried getting my engine/trans in today...no dice. Suggestions?
  145. MSD ignition, LS1 carb swap question
  146. timming
  147. Need some help!
  148. Fuel pump and regulator questions
  149. 5.3 built for demolition derby
  150. fuel pressure regulator help
  151. New Best ET & MPH Last Night.
  152. How are your 60' going?
  153. Ran the quarter mile tonight
  154. Any 98+ ws6 carbed guys in here ??
  155. Sway Bar
  156. Carb for 6.0
  157. Carbed 454 LSX
  158. Cool Practice Tree app for Droid.
  159. E85 Carbed LSX?
  160. CR and PTV?
  161. Sexy valve covers??
  162. Fuel Economy Thread: Post your's here
  163. best time ever 6.2 10.54 128 mph 100 shot
  164. So now I have a N20 system:)
  165. Low profile air cleaner setup?
  166. What is required to do an l92/ls3 carb setup
  167. Took the stang out for a few passes
  168. oil cooler delete
  169. Went racing
  170. lq4 with ls3/l92 heads ptv clearance
  171. Anybody wanna help a New guy from Ga with some ?'s
  172. Edebrock / MSD box?
  173. Jet sizes
  174. How much timing with MSD 6LS and boost??
  175. Carb size help??
  176. Lowest profile carbed intake???
  177. Coil question???
  178. EPS cam stage 3 l92 mast intake
  179. MSD 6ls and WINTER -40C
  180. gasket for victor jr
  181. Stripped Carburetor Discharge Nozzle Threads
  182. Any idea what is causing the car to act like this? (Drag video)
  183. Finally got my carb'd LS project on the street
  184. Carb guys- help needed lsx454
  185. Carb & spray...Help
  186. Pt number please
  187. i got a ls carb intake for sale.
  188. edelbrock ls1 controller
  189. steam hole block off
  190. Ok guys tune help with no2 msd 6010
  191. Gather Parts. Step 1
  192. Carbed 454LSX
  193. Proform built mech sec carb
  194. Electric Fuel Pump Recomendation
  195. LS1 5.7L MSD 6010 ignition curve?
  196. Lunati Carbureted LS Cams
  197. Tuned the carb
  198. Carbed LS3 foxbody
  199. Cutting out on top end
  200. timmig cover with distributor
  201. Painless Wiring fan controller dies for a 2nd time.
  202. need some suggestions
  203. Could this mean a Victor Jr. VS. Performer RPM track test?
  204. 5.3 vs 5.7 vs 6.0
  205. i need a cam for carb 6.2
  206. The price for intake in Québec Canada!!
  207. Fuel tank
  208. LS1 cam specs
  209. bbc water pump on ls
  210. Radiatior over flowing?? after long trip?
  211. Nitrous questions with a carb 5.3....6010 tune help
  212. Pace Coil Covers on
  213. 5.3 + Carb Questions
  214. gen IV whith carb.
  215. guys with t rex's
  216. pace performance ls2 89018191 engine package
  217. 11s are slow...........
  218. Has anyone got a blower on there LS?
  219. Carb problems - Idle AFR? - My car thinks fat is phat!
  220. What size pushrods????
  221. 86 Trans am 5.3 power, REPAINTED
  222. 6.0 Monza lives
  223. Spacer Rama - The dual plane spacer test
  224. 1970camaroRS burnout
  225. won't rev over 5,900-6,000
  226. another 6.0 question
  227. 6.0 ?
  228. Wtb: Msd 6010
  229. Carburetor question
  230. painted!
  231. Carb'd LS1 for my 71 Camaro
  232. LS1 HP750 Holley tuning issues
  233. *** Important info for those going to run a Super Victor carb intake P/N 28097 ***
  234. Rpm freeze
  235. Compiling Parts List
  236. Intake choice
  237. Going to the Drag Strip - video & time slips added.
  238. 6012 tunning tips (help)
  239. Quick Fuel 1050?
  240. map curve
  241. Belt squeak from hell -With a brand new belt!
  242. NASCAR Spec engine
  243. Building headers for LSX into Chassis car
  244. Need some carb tuning advice
  245. Carbed GEN4
  246. 1986 s10
  247. 500 hp LS6 carb set up
  248. Wide band Purchase
  249. What intake and cam would you advise??
  250. 94 GMC 1500 4.8 swap
