View Full Version : Stereo & Electronics
  1. Front Door Speakers
  2. Lighter socket doesn't work, not the fuse.
  3. SRS Codes?
  4. head lights chattering?
  5. Good speakers for LT & cammed car?
  6. will a 3rd gen camaro sub box fit a 4th gen
  7. Headlight facts???
  8. HU Harness question. Trying to avoid splicing.
  9. amplified mtx thunderform?
  10. SECURITY/ Alarm going off, after new battery install....
  11. Kicker 12" l7 wiring??
  12. HD Radio
  13. Monsoon Amp Bypass Question
  14. Front vent position on heat switch not working.
  15. Air/Fuel Gauge Problem
  16. 8k HIDs all around
  17. Lets turn my foglights into turn signals.
  18. Just bought beltronics vector 995 radar detector. Anybody have one?
  19. 10" stealth box fit with BOSE?
  20. Help me pick a head unit
  21. Where can i get my JBL Amps Repaired?
  22. Looking to buy old school RF amps!
  23. Anyone have these yet? R8 Projector Headlights
  24. Is the radio harness all I need?
  25. Any one have blown camaro sail panel speakers?
  26. Pioneer AVIC Z-110BT installed in custom DD bezel
  27. 98 Z28 Monsoon Indash CD 'AUX' Button...
  28. LED guages
  29. Cd player won't play
  30. Where can I get this custom switch?
  31. Cheap electrical components (ex relays)
  32. Mounting the BMR battery tray
  33. Remote start and factory security
  34. 98 Camaro V6 dash into a 95 Z28 LT1
  35. Anyone use the ebay "stealth" box?
  36. Radio gets no fm reception
  37. im shooting fuses..
  38. Is vats causing this? Car takes a bit to turn on.
  39. Aftermarket radio doents turn on and trunk release button just clicks?
  40. amp to sail panel speaker help?
  41. Light up Camaro stereo bezel
  42. Fitting a double din?
  43. DIY touch screen
  44. speaker pods/custom door panels
  45. monsoon build dated 2000
  46. HU mounts and mounting Sat antenna
  47. Is iTunes CD quality?
  48. Which speakers to use for fill, rear sail panels
  49. OBD Readout on Double Din
  50. Stereo Question--MP3 Player/Ipod capable?
  51. Quick HID question
  52. WTB Headlight Setep
  53. Which sail speaker Trans AM
  54. Budget Stereo?
  55. Which remote starter do you prefer?
  56. Weird Delco display and strange black box? WITH PICTURES
  57. ??? about alpine type R's subs
  58. 98 Camaro (shift light install) SIGNAL WIRE?
  59. Worth upgrading from Alpine Type-R to Type-X for my 10"???
  60. JBL 6.5" Sail Panel Install
  61. anyone have remote start?
  62. CDT or Alpine?
  63. Spray home insulation as extra sound deadening?
  64. mosoon 24 pin /12 pin wiring
  65. Converting Coaxial Speaker to Component for Monsoon
  66. Can't program swi-jack to version 1
  67. Alpine type r 10inch subs
  68. What sound deadner do you recommend and how much do I order?
  69. Hardwire Sirius
  70. What wiring do I need? (sub/amp install)
  71. How to remove the coathanger hook...?
  72. Passenger drl / turnsignal light not flashing
  73. Trans Am door panel light
  74. radio qiut working(help)
  75. Happy 9th Birthday!!
  76. need a hard to find distribution block
  77. Monsoon options
  78. Wanna sell your stock monsoon
  79. using stock amp and aftermarket amp for sub
  80. Din 1.5 Head Units
  81. Capacitor
  82. Alpine type r vs type s.....general system help
  83. new system?
  84. help with stereo installation please?
  85. Pioneer DEH-P6900UB
  86. Let's see your setups and SPL scores
  87. Any difference between the old (black) thunderform and new (silver)???
  88. humount still open???
  89. C5 Vette, Amp and Sub Install Questions
  90. If I replace my head unit.....?
  91. keyless and power window conversion
  92. using the stock amp
  93. My new system
  94. Sirius satellite radio guys....
  95. Headlights flickering
  96. alarm on car doesnt go off!
  97. What do I need to run HID lows in my TA?
  98. 1979 corvette body control module
  99. Getting rid of amps and subwoofer... Questions
  100. Kicker L7 trunk box
  101. Black Friday Discount: Now until Sunday, up to 15% off!!!
  102. are these good speakers?
  103. '94 firebird formula speaker specs
  104. any tips on in dash screen plz!!
  105. Question about CDT Speakrs
  106. Anyone have the Kenwood KVT-696 flip-up headunit?
  107. How do I disable VATS with EFILive???
  108. Stock speakers blown and suck, Looking for cheap factory speaker replacements....
  109. **Interior Lights and Locks do not work.**
  110. Installing sound deadening (edead 80)
  111. new head unit?
  112. Radio Stays on when car is off.
  113. Stereo System Help.
  114. Xmas Lights
  115. Amp and Sub on stock head unit
  116. Corvette intercompatibility
  117. Ipod without a headunit?
  118. 02 TA Custom System
  119. CDT component speakers for doors
  120. 2 12inch memphis subs vs 99 TA
  121. Short antenna for 8mm?
  122. can i use my fog light switch and ACR for something else?
  123. Coil wiring harness...
  124. Security Light On; NO START
  125. Best budget 12 inch sub to pair with 340W x1 (RMS) @ 4ohm
  126. turn bass all the way down
  127. monsoon vs pre-monsoon 10 speaker
  128. Tapping into stock stereo, aftermarket amp.
  129. Whats this mean?
  130. Turn signals don't work when headlights on!!!!
  131. Monsoon amp wattage/power output
  132. Sub encloures
  133. Alpine CDE-102, also cd player portion question.
  134. Speakers not playing
  135. Need help on my 96Z28
  136. Alarm issues (read faq)
  137. Delco display quick fix...
  138. Need Monsoon Speaker Advice and Wiring Info
  139. Seat Back install
  140. Pioneer DEH-2200UB?
  141. Help! Rewire underdash for fast xfi
  142. Who needs 4th gen camaro speaker grills
  143. Factory Bose head unit - display flickering, volume level reacting to headlights ect?
  144. Raptor Shift Lights??
  145. Install new power antenna and extra wire?
  146. Autometer Tach and Speedo questions..
  147. What goes in the passenger side rear wheel well? Big connector missing black box
  148. messed up BCM
  149. Cdt 10 inch sub with a Phoenix gold m50 amp
  150. LT1 Firebird speaker advice & opinions!
  151. Aftermarket head unit, stock 95 5 speaker bose, blown door speaker - what to replace?
  152. Removing Dynamat
  153. Monsoon radio sucks?
  154. Theft of F-Bodies.... What to do?
  155. Aftermarket stereo issue
  156. ACCY terminal empty
  157. HOW to wire in DDM 55W lows and 35W fogs with harnesses TOTALLY LOST!
  158. Is this the stock antenna wire?
  159. Firebird LT1 HID?
  160. Voltage Question
  161. Double DIN or Carputer?
  162. 2 trans ams have flickering radio display
  163. wtf is wrong with my cluster?
  164. Short in my sail panels?
  165. question about keyless entry
  166. Power seat
  167. question about 6 disc changer
  168. Advice on removing aftermarket stereo to go back to stock
  169. Need something better.
  170. Door Chime Scratchy Sound
  171. stereo/cap problems
  172. advise please on speakers
  173. Ian at KeeAudio is the man!!!
  174. Sub installs?
  175. Autometer issue
  176. Monsoon Amp
  177. Does it hurt to keep Monsoon in car?
  178. Stock wire harness good for amp?
  179. Help with Stereo setup.
  180. ac delco unlock code?
  181. Relocating head unit?
  182. Radio overheating
  183. the best head unit
  184. trunk randomly opens?
  185. When replacing the front speakers with aftermarket do I use crossover?
  186. Anyone add Seat Heaters to their F-Body?
  187. Lighted "Trans Am" above radio?
  188. How do you connect Amp Power wire from Battery
  189. Amp Power Wire Fuse?
  190. Tuff Stuff AD244 Alternator
  191. Quick Monsoon Sub Question - Please Help!
  192. People with aftermarket two way alarms please post your opinions on what you have.
  193. Think my old Loctronics alarm is messing up
  194. Took car apart for paint... now interior lights wont go off
  195. Power antenna with after market HU
  196. Guys with light weight batterys in daily drivers please post
  197. Throw up some pics of your radios
  198. speaker noise
  199. wiring harness questions
  200. Got some new speakers, should I get a new amp?
  201. Possible starter problem
  202. Finally got the box wrapped up.
  203. Battery relocation
  204. Polyfill Ratio? Subthump Stealth + Alpine SWS-1043D?
  205. Taking the monsoon radio apart in the Camaro.
  206. Headlight!!
  207. Question/help with line output converter...
  208. Hands free door popper with push button start!
  209. Ported VS Non-Ported
  210. altenator upgrade with new stereo system??
  211. Quick help!! Replacing camaro mid with TA Mids ?
  212. 5 speaker Bose system issues???
  213. JVC nx5000 anyone?
  214. Speaker cutting out intermittently
  215. How does replacing Head Unit affect Alarm?
  216. who builds the amp cover boxes that goes on the flat spot above the gas tank with..
  217. dimmer switch
  218. replacing factory speakers
  219. fbody speakers
  220. Big 3 Cable Lengths
  221. 2001 Corvette horn went out...
  222. Speaker Replacement
  223. Problem w/ seq tail lights
  224. Weird Problem with Audio
  225. Problems with push button release of trunk??
  226. Double Din Bezels for Firebirds for sale!!!
  227. new alternator and wiring ordered
  228. Stock radio, no lights.
  229. Sudden whine in stereo
  230. Another steering wheel light
  231. Radio Doesn't Turn On
  232. Firebird Headlight Option
  233. With a monsoon system.. anyone mounted the rear speakers on top of the dash?
  234. Stealth box question
  235. No power to tail lamps fuse
  236. 94 Firebird TA wont start and how do i program new keyfob
  237. DO I have key less entry?
  238. best 10'' sub?
  239. Driver Window Just fell apart, lol...
  240. Autotrix Passenger Window Fix
  241. Pulled head unit, now car won't start!
  242. my sub stopped working now I'm sad. Help!
  243. Speaker sizes
  244. Car wont start!...No its not VATS(bypassed)
  245. steering wheel controls dont work?
  246. MTX Thunderform?
  247. Stealth or T-Top Box?
  248. <<<security light issue>>> help
  249. Security Light
  250. Convertible monsoon question
