View Full Version : Stereo & Electronics
  1. Steering Wheel Controls!
  2. Question about a bad Shock Sensor
  3. Advice for my custom stereo build plan in my vert..
  4. rear hatch doesn't open like its supposed to.. help
  5. Double Din Install, cutting the bracket help *PICS*
  6. Help Finding a Connector
  7. bixenon help please
  8. LT1 Radiator Fan
  9. Monsoon Sail Panel Speakers
  10. Odd antenna question
  11. 6x9?
  12. Went over railroad tracks, car goes insane!!
  13. Installing Pioneer double din with amp and keeping power antenna
  14. Info on Batteries
  15. Dissconnected wires hanging under kick panel. Please Help!
  16. Kenwood 2013 Double Din Multimedia and Nav Radios!
  17. Bypass Modules??
  18. Stereo shuts off randomly. Hvac lights shit off if i flik it?!?
  19. Double Din Qs
  20. Aftermarket headunit in my 99 FRC
  21. Replacement Tweeter(s) for Alpine SPX-17REF Setup
  22. PLEASE HELP!! Viper Installation, Remote Start Does Not Work!!
  23. Water coming into passenger firewall grommet
  24. Dead gauges and electrical gremlins on 99 Camaro
  25. January Ride of the Month! Sign Up! Win an Alpha Nav Double Din Headunit! New Voting!
  26. CDT Package from Kee Audio
  27. Factory Bose sub box
  28. LS1 stock monsoon and alarm question
  29. Doors Unlock But do not Lock...Need Help!!!!
  30. Dementia's Stereo Build
  31. Kee Audio Speaker Help
  32. Steering wheel controls semi-color change write up
  33. Another blinker problem
  34. HVAC wont light up. Unpluged wire?
  35. Traction control panel broke, what are my options?
  36. 98 trans am monsoon volume button going crazy
  37. my 94 birds lombar adjustments dont work
  38. Need help ASAP please!!!
  39. Help! No Tail lights, gauge, console or fog lights!
  40. Clockspring help
  41. question on trans am speakers
  42. Installing a hu with no internal amp to stock monsoon amp
  43. random alarm?
  44. audio issues
  45. Tweeter Location
  46. Stock HU/Amp Pioneer 10" sub/amp/speakers
  47. Weird Lights Issue
  48. Installed new Head unit, alarm and lights/dash issue
  49. question about aftermarket head unit...
  50. SS spoiler on to 98 Z
  51. Keeaudio lvl 1 package- 289$ comparison
  52. Odd window motor issue
  53. Headlight not staying up
  54. Whats a good shiftlight?
  55. Christmas Specials???????
  56. Touchscreen in 02 Z
  57. Black Lites for 3rd Brake Lite Old '60s Look
  58. Alarm Troubleshooting ( HELP! )
  59. body harness maybe
  60. '01 Trans Am Running lights / turn signals repaired
  61. * 01 firebird* Need Help choosing sounds- speakers and head unit (monsoon)
  62. I'm replacing my driver window motor
  63. Central Texas Alarm Shop
  64. Cannot unlock doors w/o horn blasting
  65. Windows and radio shut off when I operate windows
  66. Alpine W535 wont fit
  67. Monsoon Amp with High end componets
  68. Does anyone know...
  69. Shaved antenna and Relocation
  70. Back to the Stock Headunit
  71. No Sound After Removal and Install of Amp
  72. Have a problem with my car after a radio install???
  73. Another double DIN
  74. Adding a splitter to stock head unit to allow mp3 input
  75. What is this?!?!
  76. 1999 Camaro Left Front Indicator Bulb Problem?
  77. Should I use a crossover for my front door speakers?
  78. 98 Trans Am Gauge Cluster Removal
  79. steering wheel control adapters..is one preferred over another?
  80. To much for a stealthbox?
  81. Help, headlights won't come on!
  82. December Ride Of The Month Prize! Sign Up Today!
  83. subs and speakers
  84. Racetronix fuel pump and now the fuel gauge doesn't read right.
  85. 2000 Camaro SS Audio System Build
  86. HAY Double D !
  87. Critique this audio setup
  88. wiring Plug Identification
  89. Battery Relocation Pics needed
  90. Input On Speaker Selection?
  91. RAAMmat BXT2, anyone use it?
  92. Revamping My stereo and deleting the Monsoon
  93. 4 - 2- 1
  94. replacing headlights 1994 firebird
  95. Sound cuts out for 1 second, repeats
  96. Kee Audio Cyber Monday Specials on the gear you want!!
  97. Empty/fake/display battery
  98. Sail panel speaker problems
  99. cam codes with inop tach, calling mr whitebird00
  100. 1999 Camaro Z28 Speakers
  101. Speakers powered by headunit, should I switch them back to monsoon amp
  102. How are you mounting your double din?
  103. Replaced head unit poor sound
  104. AEM gauges sensors?
  105. alarm question
  106. Double D Mods Black Friday Sale!
  107. Kenwood releases some info on new radios for 2013! Can you Say WiFi!
  108. Starter/Battery issues
  109. lingenfelter two-step mounting location
  110. Needing help with speaker wiring.
  111. aeroforce gauge not working
  112. Double din help
  113. Monsoon Amp - Convertible
  114. How do I check if my TA ever had DRL?
  115. Brake Lights
  116. Making the wires for big 3
  117. Funky Factory Monsoon setup???
  118. Light..
  119. Door Speaker upgrade on 2002 Camaro SS w/Monsoon amp...
  120. Check engine light
  121. Kee Audio Speakers Packages Shipping Daily!!!
  122. kenwood dnx7190hd
  123. Double D Mods Speaker Upgrade Packages!
  124. Good, cheap Iphone friendly Head Unit
  125. Rebuilding Stereo....way too many options, need some help.
  126. What are these two light holes in the dashboard????
  127. Bazooka subs
  128. LS1 Wiring Harness
  129. Front door speakers not working, all others OK
  130. That little bulb above the p/w controls?
  131. Will a stock Trans am ws6 amp fit an SS??
  132. Pioneer Head Unit
  133. HID Kits
  134. Stereo install questions
  135. Gauge Cluster replace
  136. Stock HU issues
  137. Neat Radio bezels
  138. November Ride of the Month! Enter to Win!
  139. Firebird monsoon radio work in a Camaro?
  140. door lock help please.
  141. Speaker noob here, what do u reccomend for replacement speakers?
  142. Appradio with axxess aswc
  143. Keep Stock Monson System/Replace Speaker
  144. Holes in firewall?
  145. 1999 Camaro Z28 Stereo & Sound System
  146. 00 camaro power window
  147. 2nd power accy (next to e brake)
  148. Window Issue!!!! Need help fast
  149. Max amps you've drawn from stock alt?
  150. So my DRIVER's side window motor went out...
  151. Wiring diagram for a 01 camaro monsoon
  152. Changing the cutoff frequency of stock speakers (monsoon)
  153. Head unit or amp bad?
  154. 10% off EVERYTHING in our store!!!
  155. What amp should I choose
  156. Alarm: Aftermarket to stock
  157. tweeter location
  158. Switching from aftermarket HU to stock monsoon
  159. switchback led
  160. Cheap HIDs
  161. Fit of ProBox vs. Q-Logic Dual 12" Sub Boxes
  162. FYI bazooka users who hate the POS factory gain control
  163. 06 Monte Carlo - Is Rear Speaker Adapter Available?
  164. No power to power window breaker
  165. Cluster gauges and more??
  166. Double D Mods Pioneer Weekend Sale! $100.00 Rebate!
  167. audio-related question.
  168. Looking For Stock Power Antenna
  169. Customized my custom Subthump t-top box!
  170. Is there a wideband gauge that doesn't light up like a chrstams tree?
  171. NON-monsoon speaker recommendations
  172. Help with camaro speaker replacement
  173. BCM Going out?
  174. Best Monsoon Sail Panel Speaker Replacements?
  175. Turn on fogs without headlights popping up.
  176. stero loc
  177. Automatic Headlight Issue!!!
  178. no dash lights, tail lights or brake lights
  179. 99-up TA LS1 M6 and A4 Gauge Clusters the same?
  180. Replacing all the speakers with aftermarket Alpine
  181. Hollow echo sound
  182. Electric EVERYTHING having issues... headlights, misfire in rain, pulsing int/ext
  183. Thinking about re-foaming my Old School JL W6V1 10 inch... worth it?
  184. No Dash Lights or Turnover : BCM?
  185. 1999 trans am grounding issue
  186. 98 z28 high mount running light not working/ but brake light works??
  187. 2x 6.5" subs vs 1x 10" stealth box sub?
  188. Speaker Upgrade
  189. sound dead application advice raamaudio
  190. Lights wont go off!
  191. Gauges in vents!!!
  192. Subthump T-Top box
  193. installing a Pioneer x940bt need help
  194. Posible to put small portable a/c unit in a car?
  195. Swapping CD Player in Stock Head Unit (write-up with pics)
  196. Alternator help
  197. Front left turn signal is toast?
  198. Problem ground
  199. key fobs not working
  200. Problem with starting on 2000 T/A sometimes it works sometimes it doesn't
  201. Car trying to start while running.
  202. 02 camaro from japan wont progamme the remote
  203. Free air/IB woofer
  204. Guide to Neon Underglow in CA
  205. Front turn signals
  206. Nothing on my Driver side door works (03 Z06)
  207. Few questions here.
  208. Stock Cooling Fans
  209. need help on my work truck...
  210. 2002 TA Monsoon vs. 98 Z28 Monsoon, TA sucks by comparison, speakers look fine, why?
  211. Connectors
  212. Driver side window fuse?
  213. Need some aftermarket power window switches
  214. need some info
  215. Need Componant Speakers for my 98 TA
  216. bcm? fuse? circuit? please help!
  217. How to disable automatic headlights
  218. Proper grounding for ground loop isolator?
  219. Kenwood info for iPhone 5 and iOS6
  220. Replace Alarm / Keyless Remote Buttons
  221. Good iphone/ipod aux hookup for monsoon
  222. Stereo shuts off when i go over 15 with the volume
  223. Need Help with Speaker Wire Hook up.
  224. Trans Am Hatch Speaker question
  225. CD changer stuck-need help
  226. iPhone 5 Alpha Nav info for those who purchased our Alpha Nav
  227. new headunit causes sail panel subs not to work with Monsoon Amp
  228. strange VATS issue. can't clear security light. car starts.
  229. '02 CD radio - won't control cd changer?
  230. DD MODS Speaker packages
  231. am i'm wiring these kee audio CDT speakers correctly?
  232. 2 din dvd
  233. Driver side speakers not sounding properly
  234. Kee audio (CDT) speaker install quetions
  235. Different route for a stealth sub
  236. Crazy electrical problem from heat?
  237. GM peripheral iPod/iPhone
  238. Help with sound issue
  239. New system, had 2 start with the sound deadening
  240. All turn signal lamps dead at the same time, but fuse is OK?
  241. PYLE PLPW6D 6.5" 600W Dual Voice Coil 4-Ohm Car Audio Subwoofer
  242. Is it feasible to put 6X9's in the doors on a 4th gen camaro?
  243. 1 12" sub in trunk?
  244. Will resistors restore my cruise control with LED brake lights?
  245. RPM dependent buzz in Monsoon system
  246. 98 TA Speaker upgrade
  247. INSTALL GUIDE: Replacing 6.5" Monsoon Subs w/ 8" Rockford Fosgate Subs
  248. Sound like overkill?
  249. new at this..need some help
  250. Security issues
