- How to solder wires?
- One Fog Light Dead
- Well this was fun...
- need a little help..
- Problems with display on Monsoon head unit
- Pioneer DEH-P4100UB
- make your own double din bezel?
- Subwoofer Static
- what wire for raptor ?
- 95 trans am stereo blinks on and off . help
- Sub box dimensions/write up/plans?
- How do I change CD's with my 12 disc changer?
- Installing a system in my 02 Z28
- Delco CD changers. Are they all the same?
- Please help with a friends system!
- i have huge tweeters. suggestions?
- help with trailer lights please
- custom stereo for your firebird or camaro insane
- Installing a new head unit
- removing stock alarm
- Keyless remote 98
- Power UNLOCK works.. Power LOCK doesnt???
- Steering Wheel Interface Question
- Whats Wrong?!?
- Suggest a good HU
- Radio is possesed
- speakers blown again help
- LED interior questions, help.
- Trans am System Install. [Pic's]
- Installed new head unit...NOW NO SPEEDO!!!
- radio not working
- What speakers get powered by the amp in monsoon camaros?
- Have I set it up wrong? 10" sub & 500w amp...
- **Speaker Recommendations for my T/A**
- choosing the system
- cruise control indicator light?
- 95 Trans Am keyless remote programing instructions
- loose ground?
- iPhone cables for T/As
- Cheap 18 gauge speaker wire or something more expensive?
- Replaced Head Unit and no sound...please help
- Stock 99 TA stereo
- No Climate Control or Floor Console Lights?
- blinker light help..
- Electrical theory
- Fried MAF sensor?
- help on stock alarm car wont crank
- HID Conversion Kits on sale at Speed Inc.!!!
- sail speaker gone...to upgrade or not?
- radio tap in for power...
- Strange accessory electrical issue
- Question about aftermarket alarm!
- Car would not start...
- Relay
- What Subwoofer values to look at when going IB or Free-Air ??????
- Kenwood KDC MP 7028 NO POWER-- Nothing!
- 07 Yukon factory remote start
- isimple question
- Need suggestions on new front speakers
- Powering amps
- Not Enough Volts?
- Whats the biggest alternator you can have made?
- Air Bag Light
- Keyless Entry
- turn signal
- My dealership purposely damaged my car?
- Door speakers
- 12V and cig lighter issue
- headlight problems
- Factory head Units in 07 GXPs?
- Wiring A/F gauge
- Double Din - can I put 2 single Din units in?
- Radio not working?
- stereo?
- Interior lights flashing when key off?
- Fiberglass Insulation
- What Will I Need??? Double Din HU
- Fog Lights, Would this be dumb?
- Horn going off
- best 10" sub for under $100 that will work well in a stealth cubbby enclosure
- Elemental Designs Blowout sale....!
- steering wheel controls...aftermarket radio?
- Need Wiring Help ASAP
- Stereo question
- 94 z28 car beeper
- Thoughts on new receiver Eclipse CD7200 MKll
- what size screws for sail panel speakers
- aftermarket head unit?
- Cd changer question?
- HELP: No reading from O2 sensor
- Head unit no power!!!
- after doing the big 3 minus the alternator I'm experiencing voltage issues
- Monsoon Wiring Harness
- line output converter HELP!!
- Installed Underdrive pulley setup how to get higher voltage?
- Shutting Headlights Off While Car Is Running?
- Monster Tach
- 95 Z .. stock Bose system - no sound
- Flashing brakie lights??????
- will this work? fiberglass mtx enclosure to strengthen it?
- Why not just run 1 4ohm DVC Sub in the sails with the monsoon?
- where is the "exciter" wire on the alternator?
- What is the best hatch/well box?
- satellite radio antenna help
- Question about the stock headunit
- Inexpensive Firebird/Trans-Am Double DINs now for sale...
- CDT's from KEE install with pics.
- Amp help please
- Aftermarket Head Unit 60wx4 can I run the extra power to the monsoon amp?
- Stock sail panel sub question
- Monsoon System for 99 Trans Am
- What do yall think of these for replacement sail panel subs in a monsoon system?
- Viper alarm system with pager?
- Bluetooth
- the best laser detector for them damn automated cameras?
- Weird acting tail lights and turn signals
- vette wiring
- No mounting tabs on my factory radio?
- Raptor install question
- Upgraded from factory radio to Monsoon headunit
- starter help...not a camaro/firebird
- blinker/drl issue! help please
- Anyone know circuit theory better than me? (Parallel-bridging Firebird sail panel)
- Wire Cleanup???
- wiring DPDT momentary switch for pwr windows... nd help
- what wires are these on top of motor((PICS))
- Car not turning on??
- Looking to upgrade my system on a budget - Input needed
- Putting 8" Midbass in the doors with Monsoon?
- Weird electrical problem
- drivers side stealth sub box for square kicker sub
- New stereo and speaker...
- Sub with stock monsoon head unit?
- Dry rot speakers
- Yet another security light question...
- Bose CD problems. . .
- How To: Cigarette Lighter to Button Mod
- Stereo turning off and on
- Tail Light out but not Bulb?????
- Putting a 97+ dash in a 96 Z
- Replacing Tweeters in a stock monsoon camaro?????
- Monsoon Wiring Questions
- What Components?
- Midbass in rear sail panels
- i wana buy 2 sail speakers for my car
- 3rd sub placement
- Rig up IPOD connection to factory system?
- Wiring help
- Compass/Temp/Mirror 02 TA works sometimes??
- 98 Z28 Install (with pict)
- Sub specs are 300w rms @ 4 ohms..amp is 200w rms @ 4ohms/ 300w @ 2ohms
- Hooked up isimple only getting beeps
- Wiring Troubles??
- keyless entry problem
- Is my amp dead?
- Need shift light recommendations
- Steering Wheel Controls Question
- Passport 9500i cable
- Speaker replacement question
- display lights go crazy!
- need advice on a complete system!!!!
- Dual Battery kit?
- Confused as hell and need help.
- Is it possible my hatch released while connecting my battery?
- Need HVAC Schematics
- My new Audiopipe subs
- Just installed a 12 Disc cd changer getting Errr at deck
- Speaker Recommendations
- Wiring a Nav/DVD
- Double Din install
- My audio overhaul - am I missing anything?
- ground up stereo build help
- '00 T/A Ground Distribution Schematics? Tach, fuel gauge, etc. Serial Data line?
- Double Din Help (What should I get)?
- Power Cable - Radio Signal
- Pioneer P800R question
- Moving Rear panel speaker?
- In Dash Video
- Rate my setup pls.
- Hatch speaker swap question.
- Is there anyone in the NJ/PA area good with electronics?
- speaker question
- Antenea removal?
- Autotrix window fix AND DEI 530t auto up?
- Factory Alarm
- ABS inop, Air Bag, BRAKE, High voltage...
- Trip meter resets/ headlights flicker and dash lights fad
- New Battery stock head unit reads "LOC"
- way to just disable drl and not automatic lights
- which wires are sensitive to resistance?
- Aftermarket HU HELP!?
- Speaker Grilles
- running subs on my amp
- My 8 speaker "Monsoon" system is F*CKED!
- Double Din install in my Trans Am
- Replaced speakers and deleted others...
- Pioneer AVIC F700 BT
- Anyone want a touch screen JVC?
- Replacing factory amp
- Battery relocation fuse??
- Problem with an Elemental Designs woofer
- No voltage on gauge, 11.5 volts on scan tool, whats wrong?
- Big Three Cable 1/0 For Sale
- Ignition wire to alternator has no fire HELP !
- Tire air pressure sensor
- crappy alarm installs you've come across
- ?? Can I put 6.5" 3-way speakers in the hatch panels?? (01 camaro w/ monsoon)
- All my lights flicker while the car is running.
- So i got bass.....
- Stuff for sale
- HID wiring with H3 projector headlamps (camaro)
- Alpine SPR-17C
- radar detectors install ??
- power antenna stopped working?
- Keep blowing a fuse, no turn signals/back up lights
- Need help with JL system
- I need a wiring diagram from alldata... anyone?
- loc radio code
- Anyone running LJ 12woV2 ?
- Want to upgrade and tried searching.
- cUSTOM FACE PLATES/ STEREO BEZEL
- I Had a New Idea For Tweeters
- fog light and headlight problem
- Which CL-6's does Kee use for sail speakers?
- radio noise, from wide band or tach.
- Car Alarm/Remote starter
- Tweeter probelm please help!!!!
- Speaker help
- !stealth box........went ported
- optima battery mount?
- Sub volume fading in and out...
- Sound Dampening Info
- Projector Lenses?
- All in one unit + Computer
- Tweeter Pods
- Front turning signals Please help and give info
- driving lights
- LT1 Trans am Premium sound question
- My Kee Audio (CDT) Setup
- Anyone mount amps behind rear seat back?
- 99 camaro, want to add 00-02 steering wheel and airbag
- Pioneer 7100BT/Kicker/Viper Install Complete (pics)
- Stealth Fitting
- Alternator Problems
- bought some boston SX 6.5" and have a few questions
- Left Turn Signal Intermid works..
- All going in the Z28 today.. wish me luck...
- Clarion HU wont read CD's
- how to remove the door speakers?
