View Full Version : Stereo & Electronics
  1. bought a 200amp alternator and my check guages light is on
  2. stock radio wanted
  3. understanding blinker wiring
  4. Shorty Antenna
  5. no power to compressor
  6. Sail Panel Speakers
  7. Amp
  8. clear cover for "3157 led bulbs"
  9. 2 Cadence Beast 12's vs2 Kicker Comp CVR 12s
  10. radio/lights question
  11. Passenger side turning/daytime running light problem
  12. C6 navigation question.
  13. sub enclosures
  14. 1994 camaro, wiring in mid speakers HELP PLEASE.
  15. Power seat not working.
  16. Got Everything Picked Out Tell Me What You Think!!
  17. double din faceplate???????
  18. Good with fiberglass? Let's talk..
  19. 2008 GM Radio Navigation Channel steps
  20. Steering wheel stereo controls
  21. Weird Noise Coming From My "Speedo"
  22. ignition trouble
  23. 2 12" like new 900watt sony subwoofers in stealth box +1200w amp
  24. stealth box and deep bass
  25. Amp Removed - Wires Cut - Need Advice
  26. Custom Sub Box for trailblazer for sale.
  27. Custom boxes for GTAs, Irocs??????
  28. Anyone with Eclipse AVN20D?
  29. Ipod to stock monsoon in 01 Z28
  30. Charge wire
  31. Dimensions for box anyone?!
  32. Problems with amp and speaker install. Please Help
  33. 2 Fosgate P3D415
  34. New Wiring Harness
  35. How to remove monsoon head unit?? Monsoon button-light question?
  36. What you guys think?
  37. Advice Needed on Sound Deading
  38. Looking for a custom bezel
  39. Need help with speakers
  40. Amps killing HP?
  41. Doing VATS bypass need help
  42. Headlight issues - bad ground?
  43. New DD not a fbody, need some advice
  44. Alpine iDA-X100 Problems
  45. Car dying randomly when parked
  46. Post Your In-Dash DVD Players!
  47. Need help! Alarm(horn) keeps going off
  48. Sound quality of bazooka 6.5 WF641.5DV with stock radio & amp?
  49. CAPACITOR and Power Draw
  50. 93-97 T/a 10 speaker system
  51. brake light work, day times dont
  52. Rewiring headlights - where to start?
  53. Stock Stereo Controls
  54. 12 disc changer
  55. Don't use xenon factory
  56. 12" Stealth box?
  57. New system dream sheet. Opinions?
  58. 02 Formula stereo... mostly done (pics)
  59. popping and whining noises?
  60. Stock speaker replacement
  61. Question for those who have Dynamatted their entire car...
  62. Anyone need a PAC OEM-1 Sound System Interface?
  63. LED Question
  64. Help. No headlights!
  65. led flashers
  66. System setup
  67. RCA Question
  68. Does anyone make this?
  69. Kicker cvt65 (having 2nd thoughts)
  70. DOCK 'N ROLL! Anyone use the Pioneer Blackbird combo?
  71. alarm problem
  72. ipod 2 car
  73. train horn installation
  74. Iphone and Monsoon
  75. Humount faceplace: Caution with RCA cables
  76. subthump stealth box or ttop box??
  77. Been a while since I've wired subs up
  78. Anyone know if CDT CL6.25X's
  79. 2 12W6v2 's and Alpine 1000.1 amp
  80. Harness for stock monsoon amp connector
  81. Alarm Problem
  82. Anyone have trouble getting wire through the driver door grommet?
  83. Replaceing headunit
  84. Anyone with a Pioneer Avic-N1 or N2?
  85. Factory alarm and aftermarket HU?
  86. ss third brake light on Z28
  87. Radio wont turn off...
  88. Double din install under 600$
  89. qtec cutout switch question
  90. ipod to factory stereo...
  91. Double Din install 1999 camaro Z28 convert
  92. Alternator amperage Q
  93. ???can i REMOVE my DRL module and re-wire to the flasher to keep my blinkers.....
  94. What size inserts
  95. Rearview mirror w/ temp/compass/homelink? easy?
  96. Radio Dosen't remeber Time????
  97. Wiring Halo's to Foglight Switch
  98. I want to sell this! How much you guys think>
  99. How should i wire dual 2ohm comp vr's?
  100. Alpine vs. Infinity
  101. Anyone tried Kicker CompVRs
  102. keyfob questions
  103. Car Wash dumdumdum
  104. Help Me Build My Sound System
  105. Anyone use Undectectable Radar dector?
  106. Could this be my voltage regulator?
  107. Here is a Corvette DD install for you to see
  108. Car stereo stuff for sale!
  109. what happens to the tweeters after an HU upgrade?
  110. Any nice stereo receivers for sale?
  111. Factory amp ?
  112. power accessory circuit power requirements
  113. Check out this deck
  114. Need a new head unit, help please
  115. ipod touch to factory stereo
  116. Suggestions on iPhone compatible HU
  117. need help with fuel gauge
  118. What do I need for deck swap
  119. Sub Box Dimensions for 1998 camaro?
  120. Will a Kenwood Ecelon DNX8120 fit?
  121. What kind of speaker to put in rear?
  122. swapping guage cluster?????
  123. how to: replace HU display bulb and power antenna
  124. Is my Alternator dead? But how?
  125. ???window express down module ques.....
  126. radio question?...
  127. Different gauge layout
  128. Best Radar Detectors
  129. Automatic Antenna
  130. can someone anyone help me find dominick irragi alternators
  131. ???BLINKING SECURITY LIGHT vs. NON-BLINKING.....
  132. What year did the Monsoon stereo start
  133. Looking for radio that was on this site!
  134. 2002 Ws6 Map lights won't click on.
  135. Kenwood in Dash Navigation unit, will it fit?
  136. serious electric issue 98 camaro*please help*
  137. Pioneer BT 980
  138. Add Iphone support to stock HU or buy a new cheap HU?
  139. Sony head unit bleep bleep bypass?
  140. Need stock radio!
  141. ???headlight PROBLEM.....
  142. hid install pics on camaro??
  143. WTB: Pioneer AVIC D3
  144. New 12" subwoofer for sale *CHEAP* Scroll to Bottom
  145. Can this Monsoon HU control the CD changer?
  146. Monsoon stereo
  147. Autometer guage Ground and Ignition QUES???
  148. Ok, another "critique my plan"
  149. Need help with stereo problem
  150. wht this wire do
  151. How about this for a double din install??
  152. sigh... How should I power my sub?
  153. head unit in need
  154. 1998 camaro horn sounds weak
  155. Ignition Problems, car wont start
  156. keep the criticism to a minimum!
  157. Calling Ian @ KEE AUDIO
  158. custom speaker box for vert?
  159. Need an interior ground and some other help
  160. Scan Speak 29001 Flow Resistance "aperiodic"Vent?
  161. Double din bezel
  162. Switches to Fit in Dash Holes
  163. NOS Sub?
  164. light issues are radio install
  165. where to buy camaro stealth box????
  166. How Much Would you Pay???
  167. sub help
  168. Air bag components replacement
  169. Best amp for 2 12" Kicker L5 Solar baraks?
  170. Planned Car Stereo Upgrades! *Camaro GT Street*
  171. Use a WOT or TPS switch to disable relay?
  172. upgrade to stereo. advice/guidance/help appreciated.
  173. Ebay kill switch
  174. NEED HELP with FUEL GAUGE!!!
  175. need help on audio problems
  176. What are these wires?
  177. Kee Audio-CDT Speakers
  178. keeping rear speakers with a cage?
  179. lights in the hood scoops
  180. stereo problem...help please
  181. Any sponsors on here sell Car PCs?
  182. Radio turns itself up to max, my ears hurt, help
  183. Infiniti 62.9i
  184. Anyone have a pioneer deh-510ub HU or similar installed???
  185. Anyone have a good way to remove coat hangers?
  186. ???HU, amp, sail panel sub ques.....
  187. Planned Car Stereo Upgrades! *Camaro GT Street*
  188. Help with head lights!
  189. Going back to stock HU?
  190. this battery problem is driving me nuts!! help!!!
  191. some updated pictures of the install
  192. all interior lighting is dead?
  193. Speaker wiring question
  194. Non-GM stereo question
  195. getting new speakers for my firebird suggestions please
  196. To Much Voltage I Need Help
  197. could i add a louder horn to my stock alarm?
  198. Power window problem.
  199. Mid Subs
  200. Steering wheel lock or brake lock?
  201. Right side speakers not playing
  202. should i install my sub
  203. Rear Components
  204. post up pics of your radar detectors
  205. big enought amp???
  206. best setup with stock head unit
  207. Pioneer F-700BT Installation?
  208. 12 disc changer question
  209. wiring help
  210. Volt gauge erratic
  211. Slow windows fix
  212. Best Place 2 buy Subs
  213. Battery Drawl on 15A Acc Fuse
  214. interior antenna question
  215. Still having issues. Have voltage but headlights don't work.
  216. Turn Signals/Blinkers not cooperating...
  217. question about 2 monsoon rear speakers sound
  218. recommend a stereo noob a system
  219. Polk Audio DB651
  220. sidewinder alarm
  221. HUD for a SS
  222. Factory Head Unit Question?
  223. radio error???
  224. Ricer or Not
  225. Looking for Double din adapters..
  226. radio/window problem
  227. Where to buy 93-97 Camaro HID low-beam that LS1_SS used to sell?
  228. My alpine speakers dont sound right???
  229. Ipod conversions
  230. Newbie Question
  231. avic-700bt Steering wheel
  232. Great Mount for Aftermarket Headunit
  233. Replacing sail panel speakers.
  234. HID's
  235. 98 trans am problem with factory amp no sound
  236. How to change the small light in the door?
  237. CDT's dont sound good
  238. Do new speakers require new wires?
  239. Stock Pioneer 12-Disc CD Changer
  240. Monsoon radio lcd backlight
  241. Suggestions on best bang for the buck CD/GPS head unit
  242. Help with new cd player
  243. Why you don't need a capacitor
  244. Got a new surround sound-needs more bass
  245. HU replacement causing battery to drain
  246. Wiring help
  247. Pioneer CD Changer - Head unit?
  248. step by step guide for speaker install?
  249. 2002 firehawk speaker replacement
  250. Fixed antenna conversion
