View Full Version : Stereo & Electronics
  1. Pioneer DEH-7800MP & PAC SWI-PS, (free pots and pans)
  2. Problems with stereo/wiring
  3. Sub Box
  4. alpine HD tuner
  5. 12 disc changer, monsoon amp, in dash cd player
  6. Show of your Double Din stereo's
  7. Help wiht Big 3
  8. hey wallace!! help me find (a) Grommit!
  9. can i keep monsoon amp
  10. help me pick my subs!!!!!
  11. Thanks KEE - New Replacement Speakers Sounds Good
  12. Help!!!!!Black Box
  13. will this stock cd player work??
  14. Help with Speakers in 96 Bird
  15. Replacing bulb in door handles
  16. what do you guys think of this setup for my G?
  17. Installed door motors today and saw what the doors are all about
  18. Where to buy lexan
  19. Installing Amp & Sub, RCA Adapter & Turn-On Wire?
  20. Din and half and steering wheel controls black preferred
  21. door wire help... extra wires ftl
  22. Best place to ground lc-1
  23. Window wont roll down :(
  24. replacing front speakers on 95 TA
  25. Look at what i dug out from under my dash
  26. Double sized din stereo
  27. LT1 Alarm/ignition problems.. No vat chip!
  28. Replacement Speakers - Stock Monsoon (I've read the stickies!)
  29. Extremely quick question before I add the Kee sail Bazookas
  30. How To Wire Tach??? Autometer Aftermarket 5"
  31. Python 12' RCA A/V cables by Steren $9.95!!
  32. Intermittent radio power problem
  33. Power very unstable in car.
  34. What goes around comes around...
  35. back seat sub box
  36. Monsoon sound
  37. what to do with old aftermarket alarm?
  38. Bought an ISimple for my Camaro
  39. Project #9 new audio = lost my damn mind
  40. trans am headlight problem
  41. SS vs. WS6 Monsoon
  42. later model stero in a 94Z??
  43. Daytime running light/turn signal keeps going out...
  44. Question on doing aftermarket speakers..
  45. sirius FM transmitter strength
  46. UN-official Show your system pictures thread
  47. Need Help w/ 5v Source
  48. Adding more negative battery connection
  49. is my door panel inclosure to small
  50. best battery that will last
  51. ported f body boxes?
  52. Advice needed;rear speaker wire not working..
  53. KeeAudio I need you!
  54. Location of amplifier? Wiring diagram?
  55. Monstercable VS Scosche
  56. Monsoon trouble
  57. my big 3
  58. Running wires through drivers firewall.
  59. Steering controls
  60. Sound deadener question in TA
  61. Having My car "Dynamatted"
  62. Power source only when running
  63. Swipe Security problems..Help anyone??
  64. using a switch panel for garage opener
  65. Subthump stealth box and 8 gauge wire
  66. autometer speedometer
  67. annoying speaker static
  68. does anyone know how i would convert to Power windows/locks
  69. what's with head unit manufacturers lately?
  70. who makes the 12'' dual sub box with t-top holders?
  71. Speakers SS convertible CD player
  72. subthump dual 12 hatch box pic? help guys
  73. reading lamp problem
  74. Will This Work?
  75. Battery dies overnight
  76. JVC El kameleon
  77. I got 360 in gift cards for Crutchfield, but I want a DEH-P800PRS
  78. Power locks/Remote Start Unlock
  79. Need some speaker help
  80. Monsoon Deck - Non Monsoon ???
  81. did the big 3 upgrade last night...now no tcs?
  82. XM Antenna Placement
  83. Turn Signal Flasher
  84. Window motor aftermarket harness
  85. need pin out for harness!!!
  86. Thanks Kee for the CDT mids!
  87. J/w
  88. does anyone make a bracket so you can use a double din headunit/screen?
  89. Using 6 1/2'' speakers
  90. A/C Cutout switch
  91. Voltage Drop at High RPM
  92. New HU is staticy...
  93. Amp placement
  94. dash lights and tripometer resetting randomly...
  95. Detailed remote start install
  96. aux adapter?
  97. Need Help Tweaking my speakers
  98. XM Radio Users... Where Did u Mount your box?
  99. RF RFP4406 subs
  100. Which LCD remote start? ? ?
  101. ? about an LCD in a vert(had a minor thought)
  102. Problem AGAIN!!!
  103. Alpine IMPRINT hardware...Kee Audio?
  104. New box - check er out...
  105. Pioneer deck install
  106. 4awg too small for engine to chassis ground??
  107. stealth box ( passenger side)
  108. Keyless Entry Remote
  109. Navigation VSS
  110. how to wire up a cross over
  111. Just did an a4 to m6 swap, now have electrical issues
  112. Ok Why Does This Always Happen To Me!?!?!?!
  113. Help me complete my set up.
  114. Automatic Headlight Problems? Help!
  115. Question about Pass Key 3 systems???
  116. System Problem
  117. CB mountup
  118. JL CleanSweep
  119. Daytime Running Lights
  120. Key Fob Wont Work!!
  121. Factory key with computer chip help!!!???
  122. Need Bulb type for Camaro Brake Lights, got blackouts coming and need LEDs
  123. Help quick with factory.....
  124. Stock Deck, is it okay?
  125. Does this headunit change color?
  126. Pioneer/ i pod problem HELP NEEDED
  127. Calling out those with a system
  128. would like some advice on a box for a W6
  129. kenwwod excelon kdx791.
  130. Is this headunit worth it?
  131. Will a 01 Trans Am HU work in My 99 Camaro?
  132. Upgrading electrical system
  133. Is it possible to install stealth box with amp rack already installed?
  134. NEW Product Info!!! NOW Selling KENWOOD!!!
  135. Need A Factory Monsoon Radio Head Unit
  136. Lost Keys....HELP!
  137. Pics Of Sub Boxes Please!!
  138. Electrical Problem NEED HELP!!
  139. Headlight won't rise after motor replaced?
  140. Does anyone know what connector GM uses on their horn?
  141. new head unit, spare factory plug
  142. Home audio ????'s
  143. How to disable Security Light...Cluster is already out!
  144. Max size tweeter that can be fit in the Trans Am tweeter pod?
  145. Flip out HU
  146. Stock stereo display fades in & out...
  147. what to expect from my CDT's
  148. DEH-P7000BT back in stock at CF
  149. Great audio system equipment for sale!
  150. Head Unit Blue LED
  151. Help!!!
  152. Back to stock
  153. Sat Nav - Install under passenger seat
  154. My custom x50 hardwire
  155. Q-Forms Kick Panels
  156. stealth box
  157. Weird problem, speedo/accessory lights
  158. How to see Codes with a Stock Delco Deck?
  159. Alpine IVA series fitment in F-body??? want info and Pictures
  160. Okay.. Anyone put door speakers in with the stock Monsoon and loved them?
  161. Lets see some aftermarket Headunits
  162. Lets see some aftermarket Headunits
  163. Should I sell the system?
  164. Am I stuck with my 12-Disc changer?
  165. Wher to buy side enclosures
  166. FM Radio Reception?
  167. question for alpine ida-x100 owners
  168. is this an 'ok' setup?
  169. custom corvette radio bezel
  170. Anying using an iPod Touch...
  171. has this been done before?
  172. valentine one, worth the cash?
  173. Digial Designs???
  174. Zo6 projector gauges conversion?
  175. another steering wheel controls thread
  176. crossover question
  177. Radio Issues (Search Failed)
  178. 98-02 taillights conversion
  179. 2 ohm or 4?
  180. Amp install help please.
  181. 2 requests...Pics of 12" sub boxes, HU+.5 din EQ
  182. Subs acting WIERD!!! **HELP**
  183. Car wont give spark, Alarm???
  184. I need help with PAC SWI-PS
  185. Ignited switch
  186. Turn signal issue
  187. has anyone put 6x9's or 5x7's in place of the rears speakers
  188. Windows down with factory remote 2nd unlock button press
  189. New speaker rattling
  190. is this feasible on a 02 T/A with monsoon?
  191. Cheap audio stuff FS
  192. Need Help!!!!!!!!!!!!!!
  193. I have to do window motors so I want to tackle door speakers while there. Suggestions
  194. Birthday Is In 2 Weeks....give Me Some Ideas
  195. new setup question
  196. Reverse lockout circuit questions
  197. dimensions...help!
  198. New Speakers
  199. Alarm Problem
  200. Need some Audio tech guys!! Odd PROBLEM!
  201. Do I need a harness?
  202. need help installing deck
  203. Speaker Wiring Help?!
  204. Good Firebird Monsoon system door speakers
  205. Which amp is a better choice?
  206. KEE - Deals?
  207. HU cutting out at high volume....
  208. is my Monsoon System on the Fritz?
  209. Where is the blinker flasher???
  210. Radio turns on and off?
  211. Lights problem - TAIL LPS and IP DIMMER fuses good, where do I go next?
  212. Under dash wiring diagram help. (99 fbody)
  213. Driver's side power lock problem
  214. HU won't fit?
  215. Clifford Alarm removal issue
  216. What do people think of these for factory replacements?
  217. Correct me if I am wrong...
  218. Radio frequencies Europe
  219. Headlight question
  220. Possible to hook up aftermarket amp, and sub to factory headunit?
  221. Pretty sure it's a dying battery.. but... sub prob
  222. Radar Detector?
  223. Wiring two dual-voice coil subs to one amp
  224. 145A factory vette alternator help identify & alt ?'s
  225. Infinity 2ohm 6.5's?
  226. 6 volt on what is supposed to be a ground obd2 pin, cars fucked
  227. Strange Valentine 1 Issue
  228. KEE AUDIO - Replacing speakers
  229. need help choosing an amp..
  230. were do i get the stealth box??
  231. installing front speakers
  232. Deep Cycle Battery
  233. Help needed Wiring up new Fog lights
  234. So nothing left but the doors so I might as well upgrade. Got these
  235. help with componenet speaker install
  236. give amp power kills battery right away??? why??
  237. Any direct fit upgraded rearview mirrors for our cars?
  238. F/S Subthump Milhouse box
  239. Last night i finished installing my amp for front speakers
  240. emergency + or -
  241. rear view mirror wires...
  242. Wire Indiglo Gauges to the Dimmer?
  243. Security Issue Please Help!!
  244. Got the Bazooka's from Kee... Thanks! Install questions
  245. Any car audio "tuners" in Philly area?
  246. How can I disable the auto head lights?
  247. sub new speaker install
  248. 01 camaro Vert Monsoon upgrade questions
  249. Ok... so pulled out my sail panel speaker...
  250. Factory radio swapping
