View Full Version : Stereo & Electronics
  1. Monsoon System?
  2. Electrical Problem Question
  3. electrical problems
  4. Fan Switch Wires
  5. 7Kv.2 Install
  6. Enclosing Speakers?
  7. Sound deadning? Home Depot? Fenders? CONFUSED!
  8. Help/opinions with adding a SUB to my Monsoon.
  9. Can these speakers be used in rear hatch area?
  10. So I'm getting a LT1 Wagon and I'll need a good stereo.
  11. gauge cluster LED wont light up
  12. Wire up mid speakers - Monsoon
  13. Capacitor Charging Issue
  14. Subs either too quiet or pop? WTF?
  15. Electric Sweep gauges w/ sending units
  16. Non-monsoon Help
  17. Power Antenna Help.
  18. kicker kx1200.1 for cvr12s?
  19. Need Serious Help!!!!
  20. Keyless remote distance...
  21. ipod
  22. Fuse question???
  23. Dim Foglight
  24. Sound deadening
  25. system suggestions!
  26. Arc Audio Amplifiers
  27. Dome Light
  28. HELP! Bad voltage draw. Where to start diagnosing?
  29. Thinking about LEDS in my backup's
  30. 2 Issues, alarm, and rear defroster.
  31. new problem, need opinions please
  32. Sub and amp
  33. 2001 TA electrical ?????
  34. ALPINE Cva 1005 wont let me see video..how to
  35. Opinions on these for sail panel speakers
  36. Alpine SPS-17C2 or Infinity REF6022I
  37. Silverado Bose retrofit to 85 Vette?
  38. Do I need sail panel speakers?
  39. Door remote question
  40. got a crazy question for someone to answer !!
  41. Which radar detector?
  42. window and horn problems...help
  43. How to Access Firewall Grommet
  44. Tach Not Working
  45. Alarm system trouble!
  46. Subwoofer Project Wiring Help
  47. Does anybody have an In-dash navigation installed?
  48. looking for an indash...
  49. Driver side seat motor install in Trans Am?
  50. hooking sat radio up to stock head unit?
  51. What pac-oem and wires do i need?
  52. adhesive velcro-like pads
  53. wiring harness?
  54. satellite radio
  55. What CD receiver to buy
  56. Which Yellow Top?
  57. Automatic Up/Down Power Windows
  58. Focal free-air subs in a pair of SubThump side boxes?
  59. Were is the BCM?
  60. coil circuit malfunction thru codes....
  61. Monsoon turns on and off
  62. Installing a in-dash navigation
  63. which gauge would you guys use??
  64. IAT Gauge??
  65. SubThump passenger side boxes are back
  66. After a week or reading here's what I've come up with, Comments appreciated..
  67. 6x9s In the back
  68. Bluetooth headunit sound quality
  69. Programming a 93 Firebird's Keyfob
  70. JBL speakers
  71. Electrical Situation
  72. Shift light installation
  73. need to know what wire is what from the coil packs...
  74. Ignition Circuit Diagram
  75. PSP Mount
  76. custom gauge cluster
  77. Help Help Help Help Help Help Help Help Help Help Help Help Help Help
  78. Sail Panel Speakers.
  79. after market HU with monsoon amp?
  80. amp isn't waking up anymore unless unplugged
  81. If anyone needs stock Monsoon CD Player, speakers, etc...
  82. Help with CB radio?
  83. Stereo/amp setup questions
  84. -Is my HU dying??
  85. OEM Monsoon deck + aftermarket amp
  86. Check Out my One of a Kind Sound System>>Very Unique
  87. Lost my radio volume knob
  88. Lower seat sections as molds for sub boxes
  89. Upgrading front stage soon: questions
  90. Turn forward = no light on radio....turn back to acc = light on radio??
  91. New Stereo set-up in car...likes and dis-likes
  92. Lights
  93. 12" box INSTALL -- progress PICS (partial rear well box)
  94. Steering column wiring PLESE HELP
  95. Need Help Asap
  96. What is the "BEST" radar detector
  97. How To Make A New Bezel
  98. Anyone Ever Tired These??
  99. alarm installation question???
  100. Got the system in...check it out.
  101. usb cable
  102. upgrading stock non-monsoon speakers
  103. Sail panel speaker wiring question...
  104. write up: hi and low beams on same time
  105. Help with Satelite Radio antenna.
  106. Battery terminal bolt too short??
  107. subthump amp rack sucks !ing it
  108. Aftermarket Gauges in the Dash
  109. Anyone use non-sponsor.com to buy stereo stuff?
  110. Replacing speakers monsoon
  111. Need new door speakers
  112. amp
  113. TAIL TPS / Dimmer diagram
  114. steering wheel audio controls?
  115. 2 middle speakers dont work (many questions)
  116. Electrical problem.......
  117. gauge lights dont work w/ headlights ?????
  118. Superwhite Moonsoon Hu!!! Asr, Fog, Hls!!!
  119. Amp installation question, please help
  120. PLEASE HELP guages/ wiring problems !!!!!
  121. Reception!
  122. f bodys with underglow
  123. Camaro install pics
  124. Static In The L7
  125. a GOOD "WHITE" head unit... ????
  126. ASC stealthboxes
  127. anyway to test the bcm ?
  128. Best SQ 10" sub under $200?
  129. Making doors air tight + making wood frame for speakers
  130. Looking for a good amplifier
  131. Valentine 1 Wiring
  132. High Beam With Fog Light Mod??
  133. Steering wheel Volume control broken
  134. Ok Need Help Speaker System People
  135. Polyfil
  136. yes I know... another newbie audio question!!!
  137. Custom box for a camaro/trans am for sale. 18" , 2 15"s box
  138. installing ED 7Kv.2 Subwoofer
  139. Ohh the stock Cd play has gone to shit i think
  140. Easiest switching 12vdc line to splice into?
  141. Sereous remote start issue
  142. Power surge
  143. Audio Wiring in Z06
  144. Battery Terminal Heating Up
  145. Need some info,
  146. Door speaker questioooons
  147. was planing on putting on the autotrix pass side mod
  148. Security Light
  149. Kicker Comp V.S. L7
  150. bye bye monsoon now I have ?s
  151. New to the FBody world & have ?'s
  152. Front speakers dont work
  153. Neon Tube
  154. Where Is The Monsoon Amp Located? I Think Mine Is Broken?
  155. box for 4 12"s on ebay. too expensive?
  156. Will these speakers fit????
  157. Need gauge cluster wiring help
  158. mtx thunderform
  159. Sub Experts.. Have a question
  160. question???? camaro front door speaker wires
  161. 6x9's on the rear deck
  162. Anyone with whistler 1743 radar detector
  163. major electric problem
  164. how do i fix an antenna that rises half way up
  165. used sites
  166. Sneak Peek @ My System. (Double Din, Components, Subs)
  167. No Lights!!!
  168. 172 amp alternator
  169. Drag Car, keeping headlights with min. wiring
  170. System in, not enough mids. Suggestions?
  171. Trouble getting the PCM back in...
  172. power lock buzzing
  173. Lighting Modifications???
  174. JVC KD-AVX33 Install (HU swap) question
  175. installed replacement monsoon and car wont crank
  176. Gm Aux9
  177. HARADA antenna?
  178. Ohms For Subs...?
  179. sail panel speakers
  180. What amp?
  181. C5 ECU Pinouts
  182. Monsoon Amp usable w/non Monsoon Stereo?
  183. Power wire.
  184. How's this setup sound?
  185. Well, here is what I went with..
  186. New head unit
  187. steering whell controls want to use
  188. Changing mileage on cluster?
  189. Head unit upgrade ?
  190. Disable alarm
  191. Fuel pump kill switch
  192. steering wheel buttons stop working
  193. Stealing a 4th gen...how easy?
  194. 2001 Trans Am Pin Out
  195. What should I do to upgrade elec. system?
  196. Battery Relocation Question
  197. Antena Question (fixed to power)
  198. can i use stock speaker wires ?
  199. My car alarm
  200. upgradeing sail panel speakers
  201. aftermarket tach worth it?
  202. new dashboard wire harness problem
  203. Need help, can't find changer controls?
  204. pioneer premier
  205. Question about adding a sub to a Monsoon system
  206. turn signal/wipers on, turns off car
  207. Aftermarket headunit
  208. Led Gauges
  209. Who has used Dynamat (or similar)?
  210. Speaker Size?
  211. Bose system
  212. My Monsson amp experience
  213. Which PAC interface?
  214. In-dash DVD question.
  215. Monsoon not giving good bass signal to amp
  216. where to go get a pass. stealth box
  217. Cd Changer Wiring Harness Located in C5 Corvette?
  218. need help
  219. jb's box for conv!
  220. 94 Formula Wiring codes (tape deck)
  221. Help! Cd Changer wiring -Orange wire goes?
  222. aftermarket hu installed=no sound from sailpanel speakers
  223. Wiring for the Light on Autometer gauge
  224. Subs into Mids
  225. '02 WS.6 eD System
  226. hawker odyssey batteries?
  227. IS this a battery problem? need help asap?
  228. Amp tap?
  229. ASR off @ startup
  230. Cigarette Lighter Feedback?
  231. Box for a Tahoe with 3rd row seating?
  232. power help ?????
  233. Amplifier Bypass...help Please
  234. engine feedback noise
  235. What to do to get a CD changer to work in a '98
  236. Alpine sps-170a install help
  237. Noob question about picking speakers
  238. Subwoofers..
  239. car alarm time!!
  240. amp power wire
  241. Stupid question on Pioneer DEH-P880PRS
  242. Let's say I could....
  243. T2 15" ROCKFORD vs KICKER SOLO BARIC L-7 15"
  244. replacing only head unit
  245. So i got a speaker box...
  246. Please Help Build A System With What I Have.
  247. Will this be good?
  248. Is my system really using that much power???
  249. hid fog lights
  250. Amp remote with Monsoon HU?
