View Full Version : Stereo & Electronics
  1. Subwoofers behind rear seat!
  2. First system install.
  3. Sound deadning?
  4. problem with door locks
  5. starting problem....need help please
  6. electrical problem
  7. HD Radio worth it?
  8. Having problems unlocking my radio
  9. phaser II
  10. Door speaker rattle
  11. Key Fob Help...
  12. Replace TA Fog Lights with New Everything
  13. Do you get good radio reception?
  14. Which Sub, Dual 2 or Dual 4
  15. Battery?
  16. DS power mirror problem
  17. Just got my Amp Rack/Stealth box.. WHICH SUB??
  18. Infinity 62.7 crossover
  19. Using sail woofer wires to power dual voice coils on a sub independently (on Camaro)
  20. Buying and Installing Kicker Panel Subs?
  21. How did you mount your Amp???
  22. Search Search Search... Nothin' - BMW Alarm in our car?
  23. Can hear engine through speakers
  24. Amp Problem have a question
  25. What causes bad trunk rattle
  26. Does the push button give constant +12V or a pulse?
  27. need a little help
  28. I need help! Audiobahn DUB600C 200W 6" Speakers
  29. Need matching switches asap! Round rockers in DPDT, DPTT, and SPST
  30. Need A Amp?
  31. simple question about replacing speakers
  32. How to connect Ipod to Stock cd player
  33. Head Unit Not Saving Settings?
  34. Sizes of bulbs / interior
  35. Pictures of peoples kenwood HU's
  36. basic lighting question
  37. subs with stock head unit?
  38. autometer tach install 98 T/A
  39. how to take the stock cd player out
  40. Door/sail Panel Speaker Replacements?
  41. Clifford Alarm System Help!
  42. Eclipse sw6000?
  43. Anybody had the V1 and X50?
  44. new stereo setup
  45. Voltage running high??? What does your car run at??? Blowing LED gauges HELP!!!!!!!!
  46. wire through the fire wall help
  47. Key Fob Problem
  48. Camaro Fiberglass Enclosure Write Up?
  49. front speaker wires messed up
  50. burnt bulbs....
  51. BIG electical problem...maybe
  52. 96Z rear speakers compatible with 99 T/A?
  53. Need VATS disable diagram
  54. one door light is dimmer??
  55. Gtech Pro
  56. just installed speakers, little static when amp on and stereo off
  57. I Searched...aftermarket speakers and sub stock head unit question
  58. Easiest way to convert 12V to 5V
  59. need to tap into the courtesy circuit where to find ?
  60. '05 Malibu stereo question
  61. JL AUDIO Stealth boxes
  62. Doors not locking when I hit lock on key fob?
  63. in dash dvd question
  64. Dome, Map, lights on w/o key ding, not working.
  65. outside noise insulation
  66. Could it be corrosion?
  67. will the 93-97 amp rack fit 98-02?
  68. Sub Wiring Question?
  69. ?????? power window control module ???????
  70. some quick audio questions
  71. Guess what, I need a sail panel speaker
  72. Another Ipod Related Thread
  73. Good as Stock?
  74. Wiring Gurus Inside (need help kinda quickly)
  75. Need Help:Air Bag Light
  76. Want to put PC in Camaro
  77. Any Idea How I Can Get 7 Cubic Ft In The Back Of My Camaro?
  78. i've heard of the company... but
  79. swi-x install
  80. head unit price
  81. PAC SWI-X installation Q
  82. Sail panel woofers
  83. Parking Light Socket Change
  84. Help Me Price My Equipment
  85. valentine 1 concealed display
  86. Got Audio??
  87. Door Switch HELP!!!!!!!!
  88. weird intermmitent window prob
  89. Blue Valentine V1?
  90. Door Chime
  91. Totally redone
  92. shift light
  93. turn signal
  94. 8" subs added
  95. hypertech chip?
  96. ? How to hook up shift lite ?
  97. stock replacements
  98. Alittle Audio Help Please?
  99. Kicker VS Alpine
  100. MTX Subwoofer....Cutting out?
  101. what size replacement speakers
  102. Having trouble with my Stock keyless entry
  103. Amp mount install check it out.
  104. Any interest In a Subthump Single 15" Box?
  105. How Do You Port A Box?
  106. Audio Question
  107. Squealing sound from mids/highs
  108. Brand new Monsoon speakers rattle in stock system when not even screwed in?
  109. gauges not working
  110. Recommend a 5 channel amp?
  111. Monsoon Amp/Sub Install question
  112. turn signal question
  113. My new system is in
  114. Mounting Amp in the spare tire well.
  115. Anyone stuff fiberfill in their sub enclosure?
  116. Where to buy resistors
  117. Winding my own alternator
  118. New Head Unit
  119. SPeaker Grills
  120. fuel pressure gauge
  121. 92 honda system...
  122. Tell Me What You Think Of The Bezel Trim Number I Did..
  123. LEDgauges HID conv. for TAs? Anyone?
  124. PAC SWIX Trouble...
  125. Stereo from 99 TA in a 93 Formula?
  126. Any interest in Custom front speaker Mounts?
  127. is this a good deck?
  128. Stereo wiring diagrams please help!!!!!!!!
  129. 2 quick questions
  130. Wiring in Autometer Tach? Am I doing it right?
  131. Humont Wiring Q
  132. Best 10" sub for Subthump box on 400 watt MTX amp..
  133. 12" Sub Coupled With A 15" a Bad or Good Idea?
  134. Stereo Help!
  135. best system
  136. also a lil help with system...
  137. Sub Stealth Enclosure/Amp Rack?
  138. wiring diagram for 4th gen. power windows?
  139. Replace Camaro Door Panel with Firebird?
  140. speaker replacement question
  141. Replacing Monsoon Speakers
  142. My system design, finally pretty much finished
  143. just purchased!!!
  144. post pictures of your sub thump subwoofer box!!!
  145. Stereo Upgrade... Pt I
  146. How Much Cubic Feet Is In The Back of A Camaro?
  147. BEL 995 vs. ESCORT 8500 X50 vs. BEL PRO RX65
  148. Thinking about new dvd head unit
  149. volume goes up and down
  150. HUD for all? Not so far away.
  151. Question for IPod plug-in
  152. hooking up dimmer wire.
  153. Blinker socket
  154. *Alarm/Speaker question*
  155. Nav question?
  156. Which are the connections?
  157. Satellite antenna mount
  158. Window Regulator Compatibility between the LT1 and LS1
  159. Stiletto home kit in 97 Formula?
  160. Will these work???
  161. Anybody running 15" Subs
  162. T-top holder mod.
  163. Considering replacing monsoon..
  164. What do you guys usually replace the rear hatch/trunk speakers with?
  165. any idea?
  166. Lighted face plate
  167. Help
  168. gauges spiking
  169. Small 10" (and a couple of 12") sub comparison
  170. Glassin the T-top well, progress pics
  171. What Pioneer HU work the Pac SWI-PS?
  172. Amp and Sub question
  173. Need Advice!?!?! (New Speakers)
  174. Some Pics of my Amps/Subs...Almost finished!
  175. I had this weird idea..
  176. Grounding locations?
  177. How to wire mid speakers
  178. WTB JL Audio
  179. How much dynamat for a camaro
  180. Which speakers to go with for...>?
  181. looking for sub around $100, what do you think
  182. Subwoofer Opinions
  183. rewiring monsoon sound system
  184. System Pics!!!!
  185. Front Speaker Problem
  186. any reccomendations?
  187. turn signal socket problem
  188. Changing color in Head Unit
  189. door switch
  190. Please help.. problem with guages..???
  191. Recommend an amp for eD 11kv3 sub?
  192. Port tube questions
  193. passenger side subthump stealth box wanted pm me if you have one thnx
  194. installing seat heaters
  195. WHICH WAY TO GO??JL 10W3v2 OR JL 10W3V3
  196. Replacement part number questions
  197. Okay guys, who's got the tweeter pods and...
  198. Rear View Cameras. Where? What?
  199. 100 LED's to mess with
  200. JVC AVX1 Upgrading!!!!!!
  201. Bass not hitting as hard when cold?
  202. two 8"s in the sails or one 10" in stealth?
  203. Anybody using Cell Start?
  204. need help with lighters
  205. Subs Problem - Help Please!
  206. Power source
  207. radar
  208. Steering Wheel Controls
  209. BEL STi Driver?
  210. A little led board I did
  211. (searched) Little help with PAC SWI-X and my deck..
  212. Amp choices Alpine MRV-F345
  213. gps a-pillar pod
  214. Best 10 Inch Sub For A Rear Wall Enclosue Box From Subthump??
  215. any good?
  216. stock subs?
  217. Monsooon cd player
  218. in-dash navigation systems
  219. Static coming through
  220. lets see some pics of you aftermarket cd head unit
  221. Oh, shit...help
  222. who make's quality HO alt.
  223. Anyone know Wilson Adcock?
  224. head unit in gtp same as trans am??
  225. Someone Help I Need A Answer So I Can....
  226. best head unit mount?
  227. Cruise control wires question
  228. New Head Unit suggestions
  229. Door REMOTE HOW DO I REPROGRAM IT???
  230. Help please for steering wheel
  231. power antenna!?
  232. Converting over from stock cassette player to stock cd player
  233. steering wheel with radio controls
  234. Anyway I can make my car untowable???
  235. 200 amp red alt is on
  236. T mobile dash to head unit
  237. unlock stock radio
  238. Anyone interested in a stereo system
  239. Monsoon Awesomeness
  240. Stereo steering control lights don't work
  241. Mounting amp on HUMP in Hatch
  242. Odeyssey Batt. PC 680 who has one????
  243. instaling alpine iva d900
  244. Passport 8500 X50 owners come inside
  245. pic's of my sub and amp install
  246. How Do You Polyfill a Subwoofer box?
  247. factory 12 disc cd changer
  248. Need Advice...how much should I sale this for?
  249. speaker grilles shaking!!!
  250. Removing Stock System
