View Full Version : Stereo & Electronics
  1. Proposed system
  2. Factory MP3 players
  3. Crazy Gauges!
  4. kicker pods for ls1
  5. AIR BAG light on/steering wheel controls not working
  6. My Rear Seat Delete
  7. What is this thing?!
  8. MTX PRO400x5 or SONY XM5150GSX
  9. Why does my battery keep dieing?
  10. auto start
  11. Autometer installation
  12. Problem with headlights
  13. Manual override switch for EWP question
  14. Need Help Into Wiring Some Halogen Headlights///!!
  15. Battery?
  16. how many speakers in my car.....thanks .
  17. on my new car ?????
  18. 99 vette coupe speakers/amp
  19. Grrr, hardwireing my radar detector and having some problems
  20. one more effin window motor, one more
  21. Custom pieces for JL gear.
  22. amp install using stealth box
  23. Ignition to ACC= weird stuff...
  24. newbie questions about sub?
  25. sound stream..?
  26. Aftermarket stereos work with steering wheel controls?
  27. another reson why imports suck (hazard/flasher problem)
  28. Anyone use the KCA-420i with their Alpine?
  29. power seats problem
  30. WTF? My factory speakers : 4 OHM !!!
  31. Sirius S50 receiver for sale
  32. Kappa 62.7i's installed, have a question
  33. kevin check it out
  34. Monsoon HU Questions
  35. How much for this fbody fiberglass painted sub box?
  36. Will I lose sound quality with an Aftermarket Head Unit?
  37. OPTIMA: Yellow top or Red top???
  38. Dynamat install around speakers
  39. New headunit, HUmount, hooked up the xbox
  40. It's a monster - winter blues sub box
  41. Remote start problem on a m6
  42. hid life?
  43. Driver Side headlight ??? not the usual? either
  44. Sub boxes
  45. Zapco
  46. Steering wheel controls
  47. CD player cleaner??? Issue within.....
  48. stereo problem!!!!!
  49. Electric issue
  50. Stupid car
  51. S/N ratiosXplod120Pioneer94Alpine65 wtf?
  52. Car just doesn't like me
  53. High pitched ring
  54. Camaro Monsoon in a T/A
  55. dual sub setup
  56. e-brake wiring
  57. Sub boxes for the "trunk"
  58. I want to replace Monsoon H/U with Alpine...
  59. keep theftlock radio from locking?
  60. Zach's Carputer LS1 Meets Toshiba
  61. stewart warner shift light
  62. How To Relocate Climate Controls 97-02
  63. alt. power wire question
  64. Tach slow
  65. what is the biggest screen will fit in where cd player goes?
  66. will a 2 din dvd player head unit fit in stock location?
  67. headrest tvs
  68. No power to the seats
  69. Gauges in Gauge Pod
  70. Will a 93 Trans-am Radio fit 94 Camaro?
  71. Installing a Gentek mirror?
  72. flush mount headunit
  73. Remote start
  74. Whine noise and popping noise when I brake
  75. best place to hide an amp ??
  76. 12 disc Pioneer changer
  77. Stupid antenna question
  78. horn not working
  79. Rear Shelf spkr install.
  80. Using factory LED for the aftermarket alarm
  81. i need a horn like this
  82. What do you guys think is a fair price for...
  83. Power Door lock motor/Sensor
  84. door panel speakers compatability??
  85. Anti theft lock feature
  86. Monsoon HU Question
  87. !!! New keyless remote entry !!!
  88. Stock CD player ERROR
  89. Just bought a Alpine CDA-9833
  90. questions about Radio install
  91. Amber lit guages?
  92. Antenna Question?
  93. I wanna be able to use CD's again
  94. 12v Source
  95. whats the best 10" sub to fit in the back corner of fbodies
  96. Blinker Question Need Help Fast...
  97. Headlight Problem...They turn on without the ebrake being down...
  98. Why dont my steering wheel stereo controls work?
  99. Alpine 9856 or 9857
  100. HU Installation
  101. 99+ Monsoon head unit in a 98?
  102. has anybody had this on there monsoon system!
  103. Double Din DVD units
  104. Front right speaker
  105. No power?!
  106. Dash lights and others not working
  107. ok, so what do I use to mount my 1 DIN h/u
  108. Relay question for EWP's
  109. monsoon headunit display light does not work
  110. radio control steering wheel in a 98...
  111. Wiring Diagram...Please Help
  112. stupid brake lights - help!
  113. Ordering a New Alternator from Excessive Amperage but have a question
  114. A Few Questions About the Monsoon.
  115. Blown speakers
  116. Theftloc bypass doesnt work.
  117. Doulbe Din HU?
  118. Advice on new 4 chan amp
  119. are my subs blown?
  120. What is causing this issue
  121. The Monsoon System
  122. Monsoon Door speaker
  123. 1994 Camaro with Vats/Ignition problem NEED HELP
  124. speaker size
  125. Stereo wiring harness problems
  126. wiring remote start with alarm
  127. Shift light inside shifter knob?
  128. should I bi-amp my expensive components?
  129. Turn Signal Gone Wild!!!!!!!!!!
  130. for sale stock alternator. bought high output
  131. Bought an Alpine head unit...is it good?
  132. Speedo for V6 firebird
  133. High Beams Don't Work
  134. Lumbar just clicks doesnt inflate ?
  135. Need your thoughts Kicker 6.5 Comp VR
  136. Where to obtain power sources...
  137. old school RF power 800a2 amps...
  138. Stereo Noise
  139. Cheap Power Wire
  140. noob question.
  141. radio controls for streering wheel
  142. stereo question
  143. Wiring Help
  144. Fabricated pieces for 98 up
  145. ? About Raptor Shift Light
  146. Sail Panel Speakers
  147. Automatic Locks when starting car...turn this feature off?
  148. Clueless about speakers
  149. Wiring Polarity Question
  150. Looking for a new security system.
  151. got a new reciever
  152. I think I need a new BCM for my Trans-Am
  153. rear defrost
  154. are there any stereos that light up red/amber?
  155. PIE X3 Aux input problem-CD changer interference
  156. Can I put my rear taillights on a toggle switch?
  157. Signal Light Socket Change - out
  158. How much do I need?
  159. Disconnect battery if car will be sitting?
  160. fog light swtich pin out
  161. Replaced my front speakers, no soldering
  162. 15A/20A switches in 12VDC (not 125VAC)?
  163. rattle on door speaker?
  164. Need a good amp
  165. The Monsoon Isn't So Bad
  166. looking to upgrade...hows this sound?
  167. alternator/starter question
  168. 2005 Cluster Doesn't Work? HELP!!?
  169. ALternator Question. Help Needed!
  170. problem with anti theft
  171. help hooking up pioneer avic-n2
  172. Anyone here switch to power antenna on a Camaro?
  173. help! door lock problem
  174. Manual Fan Switch
  175. Few questions...
  176. new speakers installed problems help
  177. Please Help.... Amp Problems.
  178. Another monsoon Question
  179. Rear Seat! Amp Racks
  180. 12" sub box question
  181. rear amp rack design
  182. What accessories are hooked to "power accy"?
  183. Normal drain on battery in milliamps?
  184. 8" subwoofer recommendations
  185. Which amp setup?
  186. Head unit options for my vette...
  187. Pulsing lights??
  188. not the usual "express down" ?
  189. Best place to buy new JL Audio stealthbox?
  190. Speaker trouble..
  191. 2005 Sierra Denali Radio Wiring Diagram
  192. antenna wire
  193. ALPINE SPS-17C2/Suggestions...I read all stickys and FAQ's
  194. hey where the b4c cars .....
  195. Stock HU with 4 Channel Amp
  196. Electrical Problem - erratic idle speed
  197. Headunit deal
  198. CD changer same for all years?
  199. Fake Speakers!?
  200. Code E 20
  201. Factory CD changer with aftermarket deck???
  202. question about stock deck
  203. Replaced my stock speakers
  204. bad factory alarm
  205. picking out an alternater upgrade 200 or 160
  206. which one?
  207. Sub powered by stock deck?!!
  208. stereo stuff i have in the classifieds
  209. Tach and speedo reading slow????
  210. Stearing Wheel controls for aftermarket HU?
  211. brake light out need help before i get pulled over!
  212. Factory Stereo & warranty?
  213. question about amp install
  214. pioneer or kicker?
  215. Upgrade/System Advice
  216. Security Light On
  217. Where to mount my 2-Step...
  218. Brand names
  219. Remote Start Clutch Bypass
  220. Oil Temp Gauge
  221. What would you do with a Monsoonless car: Buy one or a different amp???
  222. Help with my Sony CDX-65 10 Disc Changer
  223. Factory amp location with pictures 93 t/a
  224. JL SW6 separation
  225. JL SW6 separation
  226. Anyone Put Subs or Amps in Back Seat or Have a Big System There?
  227. 98-02 F-Body Power Windows?
  228. 200 amp alternator is on its way...
  229. Dual 4 ohm wired in parallel correctly
  230. HD radio on stock monsoon HU
  231. Best GPS/DVD HU?
  232. Steering wheel controls for other functions?
  233. Replaced stock power antenna with AutoZone antenna
  234. hardwiring ipod?
  235. looking for replacement speakers
  236. Camaro Fog light switch wiring
  237. All lights dimming, can't find problem
  238. Can I replace a 4 ohm speaker with a 2 ohm speaker?
  239. Another iPOD question?
  240. Tricky monitor bypass question.
  241. How do I wire these 62.7i speakers up?
  242. Horn doesnt work, fuse is good.
  243. Need help wiring sail speaker
  244. No sound to speakers in 94 TA - HELP
  245. WTB Anti-theft Devices
  246. Need Help Quick What Ohm Speakers???
  247. 5v power source in the car?
  248. Replacing HU
  249. No tach, temp, or fuel gauge???
  250. Best 6.5 Midbass Kicker SSMB6 or Audiobahn AMD60Q
