- Changing Systems
- cyberdyne gauge problem?
- No driver's window/ No radio volume
- How to wrap plastic panels in vinyl???
- pics of my system
- powering a headunit
- monsoon CD headunit problems
- Where is a 12volt lead under my dash?
- is my new sub choice any good the infinidy prefect
- Pyle Audio Stuff
- why no sound??
- Passenger Side Window Express Down Feature
- line output converter won't work
- ipod2car charging but no music
- Power wire through firewall???
- Clean Wiring Tips
- new choice of 10" sub for effecient tight bass
- T/A firebird Monsoon sail panel speakers .. arrg!
- laser jammers
- HUD on GTO
- Pioneer AVIC Z1 coming soon
- Factory XM?
- f ed up big time
- engine compartment fuse box diagram
- Head unit help me pick. What you guys use?
- Air/fuel ratio install help!!
- Dinn for 1998 trans am
- my new choice of sub the alpine is this the best
- Only 650 cranking amps and 12.8-13.2 volts
- Stereo Swap
- Blinkers blinking slowly....
- Connectors/Wire Splices for Raptor SL?
- New wiring?
- car audio system for sale!!! LOOK HERE
- Trip reset on it's own
- Sweet... Check It Out
- Frustrating Lights / Codes ? Going off.
- Need Advice
- Speaker replacement Q...
- My car is posessed
- help
- Is it possible to DIY automatic windows?
- Alpine DVD Bypass
- Burning Mp3's to DVD -R
- How much are the Monsoon Sail Panel speakers worth?
- Pioneer Head Unit Owners
- The finishing touches. What do you think?
- good website for wiring diagrams?
- loud window motor
- Rear Blinker socket
- Stealth box
- not liking the new 10" sub now thinking 2 8" subs
- good place to ground the headunit?
- Power Door Lock Issues
- 6.5 inch Alpine SPS-13C2 in a 98 T/A, wiring help?
- Range Extender?
- Friggin monsoon speakers
- dei 530t
- What's wrong with my pioneer reciever?
- Ipod holder
- battery gauge drop
- Door Panel Speakers same in 01 Z28 and 01 T/A
- Turn signal relay/buss
- Red-Light accenting my car
- monsoon amp gettin hot
- URGENt!!! very important question
- how do i wire a DPDT switch for a cut out?
- Does Anybody needs a monsoon CD Player...I have one Extra
- Any way to use a CD head unit with the 12 Disc Changer
- My raido is locked up
- security light is ON need help
- whos got one of these?
- Odometer roll back
- My 94 Formula's Audio Setup
- Where to mound my sirius antena?
- Front door speaker replacement
- power seats quit working
- Need some help with H/U and Speaker Install
- Monsoon?
- C2 gauges too bright
- Dual DVD
- 2000 4ohm front door monsoon speakers, Anybody need them?
- speaker wiring help
- DynoMat questions
- Dash doesn't work!!!!
- Boston Acoustic Subs, Mobile Audio Amp, Alpine Head unit, Cap
- Did I fu** up my speaker??
- installing an aftermarket tach on a 99 camaro?
- Sail panel subs...who?
- Sail Pannel Speakers
- Back feed problem
- iPod Aux-Pod
- mtx amp
- Which CD-R (writable CDs) from my burner will work for stock Monsoon 12 disc?
- What do you think of this H/U?
- What Should I Ask For This System And Where To Sell?
- What Keyless Entry Fobs Work for Camaro?
- Ebay lisings/cheap subs
- wire under black tar behind rear seat
- Anybody NEED a Monsoon CD Player?
- Please help with guage question
- 6x9 speakers?
- 6x9's
- 2500 Watt Orion 12" sub & Orion Amp for sale
- Am I doing this right?
- Mounting CD Changer in Glovebox
- Head unit for Ipod?
- Monsoon system question
- Pioneer AVH-P5700DVD
- Pioneer DEH-P860MP loss of single rca channel
- Alt, wiring problems
- help the idoit out
- turn signals blink way to fast, whats the fix?
- Looking for a H.O. alternator. Which one is recommended?
- 12'' alpine for sale type R
- camaro headlights
- electrical frustration
- Stock monsoon cd changer connector question
- Best sail panels for under $150?
- Problems with Monsoon
- sub box dimentions
- Help! SS dash volt gauge won't read above 10 Volts!
- only using 1/3 of gain on amp thinking of adding more speakers
- Need to get new speakers, suggestions?
- installing used kennwood navi/dvd combo
- Kicker SSMB6's
- Wiring under carpet?
- Speaker Help, Recommendations
- Keyless entry
- Steering wheel control wiring diagram?
- New sound system, would like help (LONG READ)
- i keep killling alternators WHY??
- Good GPS anybody?
- Installed Infinity's In Sail Panel!
- Jammer finally payed itself off today
- monsoon in conv
- Pioneer D2 head unit::opinions
- Amp help???
- What Frequency Do You Cross-Over?
- Bypassing the monsoon?
- recommend
- another dumb noob? (speakers)
- silverado "like" steering colum
- X site brand speakers
- What would you do if somebody steal your car?
- New to site have a question
- turn signal out
- please help
- 98 Camaro Monsoon Speaker Questions
- T-Tops
- HOw do you....
- Is the Monsoon Amp the same in Pontiacs and Camaros?
- What kind of Amp?
- Recommend me a Sub.
- speaker whining after install
- System PIC
- Distortion/crackling- one speaker only. Ideas?
- No guages work after rearended?
- Which sub should I buy?
- Wire color question
- Help please monsoon not working correct
- Autometer gauge wiring diagram? No markings.
- Amping off of the factory monsoon
- Pioneer TS-M7PRS discontinued!
- Pin out of Monsoon AMP Harness in the rear.
- Infinity 625.7i vs Alpine SPS-170A results
- 5" tach what are these wires (pics)
- Electronic flashers s-l-o-w........
- what kind of sound is sent to backseat 6.5 speakers
- Monsoon Speaker Swaping
- Need a pre-amp for my MP3 player
- I cant believe how easy it is to break into an f-body
- modifying pontiac stereo
- Subthump Blows
- box help
- Remote starter inquiry
- firebird electrical / stereo issues
- Ram air intake neon
- Lets see some Ipods.
- Which iPod install??
- Whats wrong with my car?
- Stereo Gooroos: Amp Help
- Amp Not Working Right
- new sound system setup - help
- antenna problem
- McCord powerplate wiring/install???
- Monsoon lights out
- Line Converter/Remote Wire Hook-Up
- Cd Changer for monsoon.
- Pics of my setup
- how do you take out the door panel speaker?
- how much sq ft. is a camaro?
- The Search Button
- What year started 500 watt monsoon?
- How difficult are 2-din Nav installs?
- Installing Amp Tmrw Morning PLEASE HELP!
- Aftermarket Sub Question
- Accessory problems
- Opinions on this setup: Eclipse & JL...
- Did I blow my sub?
- have a 2 monsoon speakers blown.....
- Alpine 853, 855, 857 w/ ipod or Mp3 interface
- Push-Start Engine Switch Help
- Security light causes car to not start
- I need dash cluster wiring help
- 98 SS Monsoon How many Watts 250 or 500?
- Where are the Monsoon Tweeters Located?
- Where is the stock monsoon amp located?
- Trouble w/ Amp/Sub Wiring
- Dynamat install suggestions
- WTB: dynamat xtreme or something compairable
- Fixed The Stock Coolant Temp Gauge Today!!!
- MSD 6A installation (lt1)
- My SS Had Monsoon (I think) Help!!!
- Amp overheating . . .
- Speaker distortion
- Led Question
- radio stays on after door is open???
- ASR switch
- Where to get vacuum for vacuum gauge?
- Firewall holes?
- which amp 2 channel brigded or 1 channel for a nice sub
- Stealthbox install?
- Cut Off Switch?
- Sound quality troubles
- Speaker whistle
- Pac Swi-alp
- Damaged Sub?
- Fixing The Coolant Gauge (help)
- Subwoofer Wiring Question!!!
- Would an Alpine CDA-9856 work with my steering wheel controls?
- aux in w/o transmitter or PIE/PAC interface
- radio ticks faster as rpms rise
- Who has aftermarket deck with working steering wheel controls?
- I just don't understand...HU upgrade
- headunit?
- TV screen in console?
- security devices
- Programing a keyless entry remote on a 2000 Corvette?
- Bluetooth telephone in GTO
- Subwoofer enclosure experts come in...
- Modified Fit?
- Will these work?
- how to hook up auto meter RPM tech
- Where to find a replacement head unit?
- Pioneer DVH-P5000MP Wiring
- Tachometer wire, where to find under dash?? Can't see it...
- Newer GM Head Units in F-bodies
- 2000 and up cd players for trans am
- Speaker Grille vibrates... how to fix?
