- 2000 and up cd players for trans am
- Speaker Grille vibrates... how to fix?
- weirdest electrical issue i've ever had
- C6 Z06 audio upgrades...?
- radar detector
- help power antenna in a camaro???
- What are the best speakers to replace my stock monsoons with?
- G-Tech Pro SS
- Chevy Camero Car RAdio
- Alarm Systems
- can I do this?
- removeing monsoon and installing new system..help?
- Mounting a Portable Navigation System?
- turn signal blinks really slowly??
- Monsoon sound system
- q logic dual 12" sub box nice must see pm me if interested
- 94z RADIO WIRING PLUG QUESTION
- stock radio play mp3s?
- Headlight installation on a bird...
- Stealth Box Pictures!!!!!!!!
- Where do I run the power wire?
- Did I blow my amp?
- Stock CD Changer problems
- factory alarm
- Battery wire and terminal questions
- W7s for sale
- Hardwire my radar detector - need help
- In dash DVD HU
- question about alarm systems
- replacement key question
- Viper Issues !!!
- Line lock wiring Q?
- tach signal
- Xenon Install Guide --HELP
- '98 Camaro Cluster
- is it advised to dissconect sail panel speakers & just use sub for bass
- In-Dash DVD help...
- Dual xd7500
- Vert Subs
- difference between coaxial and component speakers?
- where do I buy these tweeter pods?
- Electric antenna won't retract
- Hardwiring Sirius to factory radio (yes i searched)
- OK I got the swi-x now what?
- 1.5" din Head Units
- Combo efficiency help
- Where to find xenon bulbs for dash?
- Your feedback on Alpine Type-S, JL Audio subs
- Help please
- Clock stays on
- windows and radio dont work
- Tach Gauge Installed (pics)
- Found an unplugged wiring harness in my car!
- SGS/Fog Light switch wiring?
- My Ipod Install
- prob with Monsoon and power windows at same time
- post pics of component installs in TAs please
- enough power for a 4channel
- Another A/F meter question. . .
- Firewall gommet
- Clarion NAX970HD
- help me with my blinkers please
- Anyone Ever Have Trouble Getting A Hold Of Subthump?
- fog lights
- Questions about the monsoon system
- Heated Seat Wiring
- guages acting screwy
- Speakers play fine when the car is off, but sound like crap when its on...
- Camaro guys: How to Mount Components in Doors?
- radio wire colors
- problem with air/fuel
- For those of you wanting to order Maptech flushmounts
- speaker install question
- bad tach?or bad connection?
- Check this out: 22 inch sub weighing in a 369lbs.
- What size are my stock speakers?
- question about my new infiniti's 6.5's
- Looking to redo Monsoon
- Customizing my sound system
- Milhouse box???
- Removing dash bulbs.
- Weird Electrical Problem with headlights on a lt1
- Problem with Raptor Shift Light
- Has to be Ipod???
- Headlight 98-02 Firebird/TransAm all the same?
- Easiest way through the firewall?
- Fog Lights
- hey
- Halogen Backup Light/Lamp?
- 12"SUBS/BOX/AMP
- Confirm my research! Do I need all this?
- Camaro Power Antenna
- Viper fan install
- new stereo noise????
- Help me install Tach gauge!!!
- What is needed to upgrade to a CS-144 type alternator?
- need help installing a sewart warner digital tach
- Need ideas for a system (C5 Coupe)
- Clifford mAtrix RSX 3.5 Question and Sail Panel Sub Question
- anyone try a 15' in your car
- Factory alarm acting up...part 2
- amp help!!
- Amp Install Write Up
- Monsoon in 94 z?
- Key Fob
- What to do for subs in sail panel?
- Satellite radio mounting
- Really odd electric problem when shutting off
- Need help locating starter wire under dash PLEASE HELP!!
- Best placement of Dynamat?
- black and red wires????
- what bulb do u need???
- Fog Lights for 2001 Camaro SS
- Pioneer Sail Speaker Replacement
- JL Stealthbox vs Subthump box Weight question
- anyone know where some of those 6.5" fosgate subs are???
- Monsoon issues
- Factory monsoon/ cd changer question
- Vibrations...
- Monsoon HU transplanted to 98 Chevy K1500?
- invisicord - radar hardwiring question.
- Splicing RCAs?
- Which head units will fit my car?
- This premier headunit any good?
- help on installing infiniti 62.7i speaker
- if lights go out in HU can u fix??
- Speaker Grills Suggestions
- Need a bit more bass
- Damplifier Pro/Frost King installed….
- Fuel Pressure Gauge???
- ABS INOP light came on after header install...
- How much does adding a stereo decrease performance?
- LED interior light write up
- Welcome to the Jungle
- opened spare tire well & have wires not connected?
- drivers side power window module?
- Better choice? 160 amp or 200 amp
- Anyone have drive+play??
- RPO for 500Watt Monsoon?
- need help installing air/fuel gauge
- factory amp????
- NEED HELP with HID system install
- Boston Acoustics?
- Post pics of stereo power wire to battery
- question about more bass
- Mono Amp/DVC Sub?
- Speaker and HU Opinions needed.....
- Navigation and In-Dash setup inquiries....
- How to install aftermaket speakers?
- Hardwire a aux imput?
- ARS/FogLamp switches hot to the touch
- TA system 56K Run Away!
- radio harness
- steering wheel button doesnt work (just one)
- Making steering wheel bottons work?
- who makes the best 6.5's?
- who likes clarion's 6.5's
- Is it possible to keep
- interior LED light mod question...
- new head unit
- Help!!! Car Won't Start!!!
- Need some help!!!
- Help with non-LS1 that wont turn over!
- e20??
- Quick question (BCM picture)
- sub box help!!!!
- XM Radio Help.
- Steering Wheel Radio Contols
- reprogram keyless entry
- Tweets in the a-pillars...not good.
- shift light question
- Headlight switch wiring help
- Factory Head Unit Problem
- Install 6X9's in rear hatch locations??
- Odometer, Radio, Alarm..not working!
- Which subwoofer Should I Choose?
- Installing Cd changer
- where to put sub w/ cd-changer
- Hooking up a amp and sub to factory Monsoon Head Unit
- power window ?
- TA Rear Seat Side Panel Speakers
- blower motor speed resistors
- Sound System??
- 4th gen Sound Quality Audiophiles come in!
- Swapping 120mph Cluster for 155mph, Possible?
- Question about possible gutted setup
- Autometer Hook Up! Help Please!
- Autometer help! PLEASE HELP!
- Heres my previous set-up.
- After Market Head Unit with stock Monsoon system
- Stereo and Windows dont work
- help me pick an amp, and a place to put my sub
- monsoon wont eject cd!!!!!!!!
- CD player says Err then spits out the cd...
- Alpine IVA-W200 ?'s
- autometer install, need help!
- Need instructions on autometer hookup
- Didn't get a keyfob with new trans am
- Anyone use LED bulbs for the running lights?
- In dash dvd ???
- Need help Asap!!!!!
- need help asap
- Amp Install?
- For those with the 10" stealth box w/woofer
- Factory Alarm LED wires
- Help with gauge cluster wiring
- need help figuring out what i wired wrong
- Factory Amp and Subs?
- Would Those Subs Fit?
- svc to dvc
- would like some help planning custom sub enclosure
- NEW Speakers??
- Best Stock Replacement Speaker
- Capacitor with Monsoon amp?
- 100hz hipass xover....18db +???
- Monsoon CD Player for 1998 TA
- System makeover complete - almost...
- Passenger side auto window
- How to (safely) wire fog lights?
- sub enclosure
- --HELP-- wiring system (passing wire from inside into door)
- blinker fuse keeps blowing
- Sail Panel Replacements
- Turn signals not working
- Monsson help
- question about cassette monsoon
- security light on, car wont start??
- Steering wheel control lights!!!
- Opinions on a new HU
- Speakers making crackling noise
- newbie to car speakers question
- Infiniti 6012's
- problem w/ cd plyr
- Headlights flickering
- Problem with JL Amp at high volume
- What Am I Doing Wrong???
- Speakers
- K40 Radar Detector
- Jvc Exad...
- sail panel speaker question
- Alpine deck cutting out...suggestions?
- Why the hell is my gauge light on?
- Exchanging T/A Monsoon HU for Another?
- Monsoon 500 watt speaker orientation and possible amp damage?
- Pics of DVD screen headunits !!
- Swapped to a supposed more pwerful amp, yeh right!
- remote CD player for 99 Silverado
- Monsoon 500 watt speaker orientation... amp damaged?
- Firebird Head Units
