- lost remote and door key
- driver turn signal not flashing??
- RIP all pcm/wires out and keep switches
- Loud Thump
- replacing drl's on Trans Am Firehawk
- Help with cigarette lighter power issue..
- Kicker 6.5 midbass
- Amp part number?
- Aftermarket Gauges
- Question: area in cabin to run wires to underneath car
- help installling aftermarket radio
- Hid problem
- Subwoofer problem
- gauge issues... no tach, fuel, or temp but others work
- Monsoon Wiring Questions
- Stereo shuts off when turned up "too high"
- What aftermarket speakers are you running?
- driver window issues
- Power to manual antenna
- anyone make their own mirror mount for radar?
- MONSOON will play cd for 10 secs and stop?
- Monsoon Amp Questions??
- Built sub box - Wondering if anyone is interested in one
- 2006 Chevy silverado 5901 Installed. Help
- blown door speaker turns down amp
- Double din HU installation for Camaro.
- CD Changer bracket okay for amplifier ground?
- Window motor replacement/fix
- Anybody ever try changing internal LED color in Autometer gauges?
- Part number for replacing window motors in 2002 Trans Am?
- Rear hatch wiring for cdt-cl-4ex
- in-cabin power distribution block
- new to me camaro aftermarket alarm?? Need advice
- HID conversion
- Will these speakers work for my t/a monsoon replacement?
- Driver's door not unlocking?
- Mystery of the Sail Speaker Wires
- dd radio
- fosgate hx2 subs
- Passenger side ground stud size???
- Kee Audio Still Open?
- stealth box!!!!!!!!!!!!!!!!
- Shift light questions.
- cut yellow wire going to radio..
- Strange window Issue(Not the Motor)
- 93 Trans Am Steering Wheel Radio Controls No Worky
- Sail Panel speakers
- Which Radar Detector: 9500ix or V1 ?
- Amp Question
- Powering headunit/nav in house?
- SGS led swap issue
- Kenwood DDX512 Sub Issues
- MTX Thunder 1501D Mono Block Amp
- 6.5" Subwoofers with Alpine KTP445 Amp
- Driver window auto-down feature, how do I bypass it?
- Stock monsoon
- Python alarm w/ viper smartstart
- Trying to install integrated bluetooth kit, why is Kenwood unit going into protect?
- Why does my VATS bypas fail every few months ?
- Stock radio Spped Control
- dynamat door panels?
- wiring everything new!
- Good Budget Sub
- Weird Turn Signal Issue
- Z28 Fog Lights??
- question about the wire from the hid ballast to the hid bulb
- Can you use Autotrix passenger window fix on driver's side?
- OEM Monsoon Sub rattling in sail panel: Common?
- Cutout wiring - how long?
- Where did you get your Alternator?
- Opinions on CDT
- Worth it to get a aftermarket amp?
- 2 ohm or 4 ohm subwoofers?
- Monsoon amp question
- 6.5 subs
- how to get connectors off stock monsoon
- viper alarm tech manuals?
- Need ideas please?? 2000 formula tach???
- Dimming dash question on my 98 Trans am
- new sq setup need help with subs/amp
- Will this 7" double din fit?
- Factory Alarm Question
- would this work?
- LED Switchback questions...
- jl audio steatlhbox
- help with a sail panel sub install
- alternator question!
- Kee Audio Mini Amp - Replacement for Monsoon Amp?
- Can I run a 10" sub off of the factory monsoon amp? Without an additional amp.
- low pressure sodium lights
- Window motor replacement - how hard and also dynamat question
- Has anyone wired an electric cutout to the power seat?
- TA running lights/turn signals not working
- monsoon amplifier wiring help
- Charge Fluctuations: Alternator?
- Speaker Clicking/Ticking
- read sticky need help
- "Burr Brown DAC"
- thoughts on jvc kw-xr610 or xr810
- Kiwi PLX
- Alpine KTP-445 Amp, What Speaker (Coaxial 6.5)?
- Need a quick answer to this.....can't wait.....
- Can i mount crossovers in the door?
- Question about my setup
- budget speaker build
- FREE SHIPPING on EVERYTHING!!!
- Rewiring battery terminal cables
- Need Instrument Cluster Diagram '99 TA
- Head unit help
- Aftermarket Traction Control On/Off
- Audio Question
- KEE Audio Firebird Ultra High End and stock radio
- amp power wire rout help
- Change LED: 96 Camaro OEM Radio
- Alarm installers
- Do I even need rear speakers?
- 530T help? I'm almost done!
- I need a new sub for my JL Stealthbox.
- Automatic seat problem
- Hooking up Firbird Speakers In camaro
- Lazy eye
- Battery Tenders/Trickle Chargers?
- delco speaker plug
- Anyone use the generic ported box for 2 12" subs?
- another dum question
- Shallow Subs?
- FM sensitivity of stock delco head unit 2002 ?
- Bass Problems
- Jl audio
- Electrical problems
- Got some Kee's Audio Stealthboxes...
- Courtesy lights in floor.
- Battery Wire Threaded Terminal
- Turn signals acting really strange :/
- Those that know a lot about Amps: Come In
- Monsoon.. Antique?
- Keep blowing Tail LPS fuse
- Monsoon Question
- My new complete 1000+ watt RMS system but need help with a big box
- Want Bass in GTO w/o subs
- tweeters in the door or dash pad?
- 99 Firebird Stereo w/screen
- 6x9 coaxial vs. 6 3/4 components?
- Battery Choice Opinions
- Problems starting. All electrical is going crazy!
- New speakers...pointers needed.
- HID Questions
- De-Pin Tool for Fuse Blocks
- LT1 Firebird Ground wire locations
- Stock speaker replacement kit
- 5 dual 10" Kicker CVR sub boxes ready to ship! $199.99
- Monitor for Double Din Opening
- HID Halo's/Fogs Power Issue
- Clarion VX401: Opinions? Warnings?
- Monsoon turning off intermittently
- Hard-Wiring Satellite Radio and V1
- Er20
- monsoon crossover and wiring questions
- Amp Rating for Relays
- Speaker Suggestions
- Double D Mods prototype driver side stealth box pic
- Replacing Stock Speakers in Grand Prix GXP.
- Help with window wiring and more!
- aftermarket head unit and subwoofer
- Rear Hatch Problem
- interior lights wont go off
- wiring for bazooka DVC
- No Sound From Speakers
- DRL Module?
- Removing back speakers
- need help wiring my cigarette lighter
- harlan shift light wont work!?!?
- Escort Passport hardwire kit
- Another HU INstall Question
- Help me pick a new head unit
- Pioneer DEH-3300UB Install Question
- Fuse Boxes Relocated
- 6le tweeter pods
- Share your iPod setup
- Double Din push to start?
- Head Unit or Monsoon Amp?
- Stealth Box Sub.
- Dual XDVDN9131 Single Din Fold out NAV $329.99!
- Odometer - Mi to Km?
- HID's... bad to flash? melts fogs?
- Black friday Firebird and Camaro Speaker Upgrade
- Whats a good, but cheap, 700-800 watt amp......
- Double D Mods Black Friday Weekend Specials Camaro & Firebird Specials
- Double D Mods Black Friday Weekend Specials C5 Audio specials
- fuel pressure gauge
- Stealth Subwoofer Enclosure for 12"
- Battery and Computer
- Non Monsoon Speaker Install
- Bazooka subs in sails, wiring?
- PIE GM9-AUX Question
- Can some one build me a custom box to fit a alpine type x?
- pac audio controler AOEM-GM24 need help
- alternator quick disconnect
- taillight & turn signal problem
- Single 12" Sub box
- General Speaker Question non Fbody
- Airbag swap
- instrument cluster needles not working
- Find ALL the grounds! LS1 F-body
- 97 trans am ignition switch
- Auto trix window fix question
- Possiblly a bad bcm?
- LED turn signal problems
- 3 amps with a dual 12 box?? (Pics please)
- rear speaker blown - opinions?
- I need help please !!!
- Slowly start losing power/gauges/lights
- dash and tail lights not working need help
- DRL & Blinker Not Working on Passenger Side
- double din for 01 camaro
- Sound cuts off
- Change turn signal light
- How far is too Far ?
- Feedback through speakers after cam install
- 97 Firebird Monsoon Amp
- ** Monsoon Sail speaker replacements
- Factory CD Changer not working
- Speakers
- Door and Sail Replacement Question
- how to connect subwoofer
- Sony CDX-M630 part
- No lights on my hvac or gauges at night
- Help with CDT front door speakers
- Gauges and radio not working
- which sailpanel speakers?
- Subwoofer not working
- Tweeter Phase Separation
- Recommend me a system
- Keyless entry not working
- wiring question
- How to remove bolt from + battery post
- Kenwood DDX PNAV418 Camaro and Firebird double din packages $599.99
- Factory Monsoon Deck + iPod?
- Will a Touchscreen/Navi/DVD unit fit?
- Car PC and monsoon system
- 2001 camaro ss guages signal, pls help for pin outs.
- How to install a Valentine One on 2002 Camaro SS
- Where can I find a factory cd player or reman? 98 Camaro SS
- Optimum setup??
- Wiring A/F gauge?
- middle speakers wire to front or rear
- Bazooka 6.5 Subs in 2000 Camaro issues
- want new HU
- ECM Constant B+ w/Kill Switch
- Non Monsoon Upgrades
