- Escort radar detector direct wire
- need help fast with new lights!!!!! look inside!!!!!
- New head unit Im going with *PIC*
- Amp Wiring Troubles :'(
- where did you camaro guys mount your tweeters from your components
- amp rack
- 6.5" speaker help
- I need a 12" stealth box
- Alpine SPS-170A 6 1/2's install help
- Convertible Sub boxes
- 2000 Alternator - 1 or 3 wire?
- adding a monitor onto my indash dvd
- Somebody tried to start my car.......
- Upgrading "BIG 3", what are they??
- installed a 6017 kenwood and nav
- Rear seat speakers
- gm9-aux install
- 12" Stealth Box?
- whats the best amp to replace stock monsoon amp for cheap
- killed battery?
- i think i fried my battery
- where can i buy replacement monsoon speakers
- mounting pics of satellite recievers
- Alternator gauge gone bad?
- Air Horn Hook Up
- Wires through the Firewall
- nice system for sale
- Big issue with Kenwood CD ( EZ 700-SR )
- what size battery does an ls1 starter need?
- VERY expensive Clarion head unit?
- xm radio
- Battery keeps draining...
- Wierd Problem.
- Radio Contols on steering wheel?
- Where does the alternator sense wire terminate
- power outlet
- any seperate relays for pass. window??
- Satellite radio (XM or Sirius) in-car hookup question...
- Sirrius wiring question/ideas
- PAC SWI-X controls for the steering wheel/help with wiring
- 96 in a 99??
- Headlights and Hazards don't work
- amp
- illuminated deck lids
- Bad Sub Sound Quality
- Radio comes on when I close my doors
- Focal Polykevlar's cutting out
- does this work?
- Pics
- Gauge Lights do not go on when headlights come on
- 6x9's on rear cargo cover, new ?
- Can I fit a ported box for a XXX in my WS6?
- is my amp toast?
- accessory power?
- Need quick help.Wiring Indiglo gauges.
- Finishing my system
- Monsoon 2001+ CD question
- Bass problems with new midrange speakers
- Alpine type R SPR-17LS individual component specs
- Quick, I Need Help Asap. Please Read!!!!
- Questions Hooking up Sub with Factory Components
- Controls on my seats
- One brake light filament not working
- jl stealth box?
- factory security has my car on lockdown!! help!
- Help with power seats??
- Help! Urgent!
- Installing strobes on C6
- Grounding Issue
- Need an amp and amp placement question.
- FOR SALE: Cerwin Vega CLSC-12 Mains..
- Just Boughta Ws6, Stereo Showing Weird Numbers!!! Help!!
- Opinions on my new system?
- help please
- Another Remote Start Thread....
- One 10" or Two 12" Subs?
- Quick alarm question...
- Anybody replace their dash security LED???
- Hid Kit
- any kit to make low beams work w/ high beams
- Anybody knows that one?
- Pics of my Set-Up
- RF, JL, or Kicker??
- Help with alarm
- car wont start' HELP
- Alarm
- Whatcha Think?
- front door speaker help
- Electric system, batter gauge and flashing lights..
- amp question for camaros
- Guys Please Help Electric Problem
- Ordered my new stereo stuff!!
- weird amp Help
- aftermaket with steering wheel controls
- FS: 12v car 5.6" LCD
- Theft Deterrent - Weird Behavior
- Driving Lights - Who has them
- Is an in-dash DVD player really worth it ? Need your feedback!
- Help me my car is possesed, the windows keep rolling down!
- dash lights quit working after cd install. not a blown fuse. help!
- Anybody have an elec diagram? (For a TA)
- hidden antenna?
- Delco 12 disc changer won't eject...
- Turn signal problems
- wtb 1600 watt amp
- Voltage drop under acceleration?
- Trunk Sleeping in 2004 GTO???
- Center console light going out?
- Can you replace cig lighter w/power outlet
- Cigarette lighter is not working?
- CD player question
- vats/resistor question
- question any help would be nice
- HID High beams?
- Wire Length Help Needed
- Tweeters in front door - too much treble?
- components or 3 ways
- Help me spend $700 on Full system!! (Part 2)
- wire problems with custom box
- Best Battery??
- Bought Alpine SPS-170A for back seat
- line output converter?
- changin radio bulbs
- question --amp mounting--
- How do I make my fog lights able to stay on with brights?
- wtb headunit
- Need advice for speakers/subs
- Subthump
- pictures of amps mounted
- Power window buttons
- sub boxes
- 6.5" to 6.75" Adapters?
- WTB:XmOr Sirus
- new Two kicker L5 10" and a kicker kx 400.1
- Pioneer DEH-P860MP AUTO TA & AUTO EQ ADJUSTMENT
- splicing into accessory outlet??
- Key Fob Programming???
- Starting to edit my audio
- 13w7 box needed
- homemade TCS module?
- In dash monitor without the sacrifice.
- Need wiring help (VSS output wire)
- Need speaker / amp opinions
- can i use a big 2 channel amp and a tri-way to do this?
- Alright I NEED a head unit that....
- Few electrical gremlins (tach problem, lights)
- Rear Turn Signal not working
- guru's please help , can i do this
- XM vs Sirius
- Sub cuts out? HELP
- Where should I soundproof for my system install?
- Tail light/brake light questnos
- hooking amp up to monsoon
- Autozone Power Antenna
- is their any way to hook up the factory changer to an aftermarket deck
- what Pontiac has rear view mirror w/ map lights and temp display in red?
- Key fob problems?
- Speaker locations? Where are they?
- keyless entry thing...?
- i need a Microvision MTV-7000BCT 7" screen thanks
- i need a Clairion VMA-7191 7" screen please help
- Using new wire, or use existing wire?
- Factory Alarm problems...Need Help
- wtb camaro door speakers any condition fast
- shift light
- Do Monsoon's REALLY suck this bad? Or do I have a defective system?
- $300-600 installed, what is the baddest alarm system out there
- Monsoon Connectors
- How to remove bezel in front of radio?
- 6.5" Speakers too Small for Sail Panel?
- how do those MTX stealth boxes sound?
- found automatic starter under dash
- Check it out!
- Turn signal/corner lense/etc questions
- Blinking Lights?
- Rattling!..
- Kenwood Peculiarity (upper end models)
- Is it possible???
- great fiberglass resorce (custom boxes)
- lighting headaches
- Diamond Audio 12" sub
- Question regarding Subthump's AMP rack and Stealth Box install!
- Orion DEQ 30 New in Box
- Looking for Factory replacement speakers 98 TA
- quick help on rear seat speakers...
- Aftermarket amps w/ stock Monsoon deck?
- Need monsoon door speaker.
- Speaker ? need help asap!
- How to make the double din Pioneer avic-d1 unit fit?
- gauges arent working
- What Kit Fits Yukon Lower Dash Opening? Help!
- Brand new kicker Solo X 12 $550
- Best speakers for 98 ss?
- How to replace PCM grommet
- head unit question! need your input!
- Alarm Neg. input
- Stereo Installation kit
- Battery Voltage Gauge Fluctuating...
- Trying to build new system,HELP!
- lock/unlock problem
- Using Stock Nav as DVD Player??
- what is the stock 95 firebird stereo?
- How much power does the stock amp have?
- gauge cluster wiring
- Completly replacing monsoon
- Dash DIED while driving
- Subthump or stealth?
- Where should I mount my amp?
- Help! - Monsoon LOC'd
- wtb: Box that fits into cd changer spot
- Rain Triggers Alarm?!
- Aftermarket HU with stock speakers? *Non-Monsoon*
- something not right.....
- Truck broken into tonight
- Security system problem
- Amp rack carpet
- How to replace sail panel speakers?
- Little more help please - HU decision
- Another lighting issue...
- LED/Fuse issue
- dB Drag Racing World Finals To Be Held in Cleveland Oct. 7-9
- keyless remote programming
- headlights problem HELP!!!!!!!!!!!!!!!!!!!!!!!!
- FS: Kenwood/Kicker stereo equip
- fuel level guage only reads 1/4 over full??? Any ideas why?
- Kenwood 815D In Dash DVD player : Impressions
- Comments and questions - I shopped today
- New install pics
- Anyone ever...?
- Kicker stuff for sale!
- Please Help Me!!
- alarm system woes
- In-dash touch screen for computer
- Question On Pop Up Lights?!?
- witch amp to hook to this sub,Alpine 1022
- How much "more" would you pay for XM/Sirius?????
- subwoofer for a convertible
- Alpine SPX-177R fronts & Type R 10" sub freq crossover recommendations
- which wire controls dome lights????
- WTB: stock monsoon door speaker.. camaro
- Aftermarket HU Faceplate Case?
- Battery keeps dying!
- Lighting Issues (DRLs)
- Something seems wrong?
- New Amp Spot.. Am I the 1st? Maybe not.. but Check it out
- How the Heck.. Dash Kit for HU
- Weird turn signal problem
- stealth box mount?
- Help w/Stereo system for my T/A!
- NAV input??? What do I need?
