- Car PC and monsoon system
- 2001 camaro ss guages signal, pls help for pin outs.
- How to install a Valentine One on 2002 Camaro SS
- Where can I find a factory cd player or reman? 98 Camaro SS
- Optimum setup??
- Wiring A/F gauge?
- middle speakers wire to front or rear
- Bazooka 6.5 Subs in 2000 Camaro issues
- want new HU
- ECM Constant B+ w/Kill Switch
- Non Monsoon Upgrades
- What kind of switch for my amp's remote wire?
- Correct Sequence for Electrical Grounds
- wiring amp to stock monsoon 98 ta
- Electrical Gremlin - Fusible Link E
- Custom LED Tail lights
- Sony CDX-M630 ?
- Full Monsoon Removal Question
- pcm, system, and body wiring soldering questions?
- Camaro Sail Panel Speaker Recommendations
- Upgrade time??
- Pheonix Gold iAMP-GM1 for you 2010 and 2011 Camaro owners!
- Budget '00 trans am stereo help
- Rain kicked my ass last weekend......
- Kill Switch Engaged
- Low Trac Light....?
- <-- needs head unit layout for 00 camaro ss monsoon head unit
- Will speakers from a '99 T/A fit an '01 Camaro?
- weird headlight?
- Steering Wheel buttons ?
- anyone have a CDT CL-4EX 4" blow? twice??
- Interior lights out, any suggestions?
- Viper 5902 Alarm Walkthrough please
- How many will want these sub boxes?????
- Several lights on out my factory Monsoon unit
- Monsoon question
- HU question for non F-Body install
- Headlight Question
- Difference between DVC and SVC subwoofers
- 96 T/A wont play burned CD's?
- 93-02 Sequential tail lights?
- PIE GM9-AUX question
- 3rd brake light and defroster not working
- sony head unit problem
- 00 pontiac firebird headlight wireing schemtiac
- replacement speakers 02 ss
- Need a Multi-channel amp, what are you guys running?
- Question for WhiteBird00
- Current headunit with RED illumination?
- Trans Am - All lights on..
- Headlight!!!
- Buy new headunit!!
- Stock Monsoon Volume Issues
- Cd Player Help
- Whats factory cd worth
- Where to put senders for new gauges?
- Foglight install?
- Custom F-Body Trunk Sub Box w/12's and amp. Still use your t-tops and have Subs!
- Bi-Amping with an Aftermarket H/U to components?
- Boss Audio CH6CK - CHAOS EXTREME (in sail panel?)
- Escort 9500ix $499.99 and FREE SHIPPING!
- v6 5 speed reverse lights not coming on
- Wiring sub in the sail panel
- Head ligths are dim on one side??
- 6LE bezel, need to move AC controls out
- JL XD700/5 amp, best price
- Hydrocarbon Double Din Camaro Bezel pic
- Front speakers need to be louder
- Increasing sub box volume
- Can a fob be installed in 2nd gen TA
- Anyone using RE Audio RE6.5C
- How many watts for a cd player with subwoofers? 400 or higher?
- [Video] KeeAudio Speaker Package
- Car starts on its own....
- Speaker and Head unit question
- TA side speakers
- calling Ian @ Kee Audio
- Remote Mount Battery Wiring Question
- Whats this window part called?
- Back to Basics... Sound Problems
- Door Speaker Question
- Adding Cruise Control?
- Camaro Speaker Replacement Problems
- 12 disc changer question
- cadillac cts brake lights
- Good Ground?
- A little help with Alpine CDe1245xm and installing ASWC
- Caddy Trunk Motor Wiring
- Tweeter Pods
- Big 3 wire connection
- Newb grounding questions
- At Witt's End with the DRL's
- Escort Passport X50 Detectable in VA, DC????
- Install LT1 Bose Subwoofer in LS1 Camaro?
- Kill switch to cigarette lighter possible?
- Hooking sub to amp
- Converting tape player to Cd player in fbody? Can it be done?
- My experience with kee audio so far.
- Pioneer AVIC-Z130BT VS. Alpine INA-W910
- Simple Question - Speaker Grille Removal
- No power :(.....Sometimes
- Power On Relay???
- Custom Sub Box Stealth style
- Sail panel speaker
- Has anyone flush-mounted tweeters where I surface mounted mine?
- Car Audio Help Needed
- Aux Adapter for Stock Stereo Question
- Sound Deadening Project in a 2002 Camaro
- Time for new Fog Lights
- A little over a grand to spend on a new stereo setup, plz help. Going for bass/rap
- Cdt com 626
- New Alpine Type R's in door....more distortion?
- PAC-SWI-RC programming
- Headlight connector pins?
- Alpine Type R in Stealth Enclosure Question
- Alternator going out?
- Question: Practical approach to bass...
- 6.5 JBL in Doors.
- Lithium Battery in a Street Car?
- Is there a 6 CD changer that plugs into factory plugs......
- What's wrong with my power seat?
- NEW Focal Integration and Performance Series Speakers!
- RE Audio mini amps now instock! (pics)
- Pyramid WX65X Sail Panel sub review
- Keyless entry & rearview mirrior lights
- door speaker crackling
- Options for sail panel speaker
- Innovative Wiring(big 3) vs stock (pics!)
- passenger rear side marker isn't working...
- So... LEDs in dash and HUMount problem?
- Rewiring a coaxial speaker for component setup
- Stealth and MMats (WOW!!)
- Rocktober Specials @ Double D Mods- Double Din Mania!
- guage cluster and light flickering when at around 6k rpms?
- Bazooka Installation
- Monsoon
- Aftermarket Keyless
- Need some help and opinions with speakers
- Engine to Chassis Ground
- Help with Convertible Rear Speakers
- Double Din in 98-02 Camaro?
- auto meter shift light?????
- Trying to find a brand of sound deadening paint.
- Odometer color change problem
- Buyheadlightbulbs.com
- 01 silverado headlights
- What battery do you have under your hood?
- MTX Thunderform sub?
- Door speakers cutting in and out?
- fuse 10a etc??
- flickering lights
- HELP! Broke a PCM pushpin connector!
- Check out these mini amps from Rockford Fosgate!
- Monsoon Speaker Upgrade
- Mirrors: Camaro vs. Firebird
- Ported Subthump Box?
- Pioneer Z130BT installed in WS6
- Will a 98-02 trans am/camaro radio work in a 93 trans am?
- Dash lights not working
- air bag/clock spring question help 98 ta
- Alarm going off during start up
- Headlights on & stereo lights go out?
- no power to fog lights
- Satellite radio
- What turns the Monsoon amp off? Constant dead battery
- Jensen VM 9224 24 hour double din hot deal only $299.99!
- Can you identify this thing
- Jvc kdr320 w/ Bluetooth and Alpine SPS-600C install
- My Z130BT install (pic heavy)
- Monsoon HU not playing CDs...
- Does anybody make a Prewired Fuse/Relay Block - 5 relays and fuses - 30amps each?
- How to wire Led switchback strips
- What does it mean when an amp has "clean power"
- I'd say these speakers were used up!
- Homedone 200mph dash
- Wiring a Kee sail panel sub to the factory harness
- factory alarm question
- Security Light no start
- Dual 10 or 12 inch sub boxes Weekend Special $59.99
- Monsoon HU will not turn on.
- No Tweeter Sound
- Kee's Ultra High End (Kinda!) & MORE: Install
- Pcm harness problem plz help!!!
- dd din brackets
- Body Control Module... Which wires are which?
- Help installing aftermarket Keyless Entry on my 1994 Trans Am
- Soundstream Stealth amps
- First step of my audio upgrade. Running power/rca and new speaker wires...
- Nice and cheap sail panel sub solution!
- Hazard and blinker lights staying On... Won't turn off..
- Kee Audio End of Summer Clearance
- Sound/Noise Insulation Idea... Pella SmartFlash
- How much would you pay for a high temp version of the DRL/turn signal socket?
- What size is battery to chassis ground wire?
- This can't be good...
- Eclipse XA5000 and DEH-P4200UB, anyone heard or own one of these?
- Custom Switches?
- 3 Double Din Jensen VM 9423 left at clearance price!
- PAC SWI-PS programming...
- Fog Lights Wiring Diagram
- Radio off, still a noise comign through speakers.
- Suggestions for new complete audio setup in 02 T/A
- What happens when you blow a speaker?
- My stereo plan...
- Has anyone changed the mileage chip from an old panel to new one?
- Trying to build sound system
- BitViper vs TuneTrapper
- Voltage meter moves alot!!!
- clicking sound in cd changer?
- 2 Kenwood DDX 418 PNAV units left! Special pricing!
- Crunch P1 5000.5 5ch
- Alarm Going off - Shock Sensor Already Removed...
- Help guys !
- Alarm keeps going off...
- bose
- car alarm goes off when washing car
- No iPod search function control with Alpine
- Custom rear-hatch sealed (2cf) single 15" enclosure needed
- rewiring wiring from oil pressure gauge to sensor
- LED woes
- JL Audio 450/4
- How much sound deadening needed for doors and sails?
- grounding issue
- 2005 GTO Aftermarket Subs?
- kee audio sub box best sub???
- Component Speakers
- Are these Focal speakers any good? Need some quick feedback..
- Speaker back feed
- problems with stereo/battery/alternator
- double din mounting question
- bulb socket
- Monsoon system question
- BCM Solder Points
- Couple of good amp grounding locations
- Just replaced a digital dash in an 87 TA..why does it show wrong mileage
- keyless entry
- Maximum safe distance of fuse from battery
- Speakers Issues
- Hatch speaker question
- Car Computer
- button start
- huge problem please help
- Alternator wiring without Stock PCM?
- Side quarter panel speaker 2002 pontiac firebird 5.7L
- Loaded Equake Sub F/S
- Metra Headunit Install Kit
- Mounting satellite radio antenna
- Old RE Audio 10" sub
- Do I need a sub with my setup? Reccommend Sub/sub box to fit.
