- Wire connector adapters for speakers
- Distribution block help
- Kenwood DNX5160 Help
- Stereo Installation HELP!
- Best way to wire my 4ohm dvc sub
- Window issue
- line out converter
- I Think Its Time.
- Camaro door speaker wiring (pics)
- How the heck do I remove these?
- radio has power, but no sound
- Parking brake light wire location
- Will this work with the monsoon system?
- Firebird Monsoon front door speaker replacements?
- Monsoon amp part number?
- Quality Budget Sound Deadening
- Steering wheels controls wont work
- Alpine SWX-1043D VS Polk SR104DVC
- Peripheral PXDX Aux Input?
- Just installed new Metra Power antenna, need proper antenna connector!!!
- 4x6 plate speakers ??
- BIG Problems
- Is this enough amp?
- Audio help
- Stock bose? Pos New System opin!
- did my cd player die
- Key wont go all the way in?
- Aux button on Monsoon just stopped working
- Hideaway enclosure??
- Where to put subs?
- Does Monsoon plug n play with non-Monsoon?
- Radio wheel control / deck questions
- swapping from fixed to power antenna
- Monsoon head unit repairs ??
- Is 4 channel 600 watts enough for 6 spkrs
- need sub and amp for stealth box
- 6.5s behind the driver and pass seats
- What window part is this?
- HID's for Camaro
- replacement Bazooka 6.5" DVC 4ohm sub in stock $89.99 shipped!
- Alpine 6.5"s?
- Audio help...
- SOLVED: Headlights cause dash lights to turn off
- A few quick AVH-4300DVD wiring questions
- night light bulbs
- Radio and windows won't work
- hard-wiring Satellite radio
- how many hours to install system
- replacing factory door speakers
- BCM issues? Surging bucking poor idle, dash lights out, keyless fob doesnt work HELP!
- Key fob sync to vehicle problem
- 01 SS Instrument cluster intermittently fails
- fans click off without control
- NEW!!! CDT Dual Voice Coil 6.5" Sub Prototypes: Check it out!!!
- Antenna Stays Down
- Car alarm remote stopped working. Why? Yes, I put a new battery in it.
- CD Player or Interior lights wont come on
- stereo cuts off randomly
- antenna
- Head unit problem
- Autometer tach install?
- Blew my Polk SR104-DVC sub Friday night
- Monsoon Subwoofer Question.
- Completely stumped.......need an exorcist!
- 2nd gen f body system ideas ??
- Quick question on theftloc
- What is your monsoon eq set to?
- Strange Alternator code..?
- LED turn signal/socket question
- Will a box fit in the space
- Got my HU. Now need speakers and sub.
- new SONAR headlights, halos won't work!
- Kee Audio system? ('99 Camaro)
- Tired of the antenna making my car look like an RC car
- antenna issues after new headunit install
- Dual coil sub connection Q
- My Firebird's Home made Pioneer's costume Hatch! pic inside !
- Ported box question
- what battery kit
- steering wheel controls wont work
- 99 cluster connector
- Quick question for HID Light owners
- Can I use two brands of sound deadener?
- Factory 12 disc problem
- Sub and amp setups for 98-02 firebird/trans ams
- Replacing monsoon deck
- The new custom install, comments appreciated!
- adding hatch speakers?
- JL Subs
- Right Turn Signal won't blink
- A nuetral C5 Corvette Double Din install pic
- Stock Monsoon Sub Problems
- Radio Controls?
- Problem with my USB feature
- Power antenna help....
- part number for fixed antenna base for those who are converting
- Monsoon Subwoofer replacement
- ZZP alternator power cable
- Need bass out of my door speakers
- can you any of you audiophiles help out...sub box for t/a, fb, ws6?
- Door panel lights
- satelite radio question
- What kind of paint can I use to touch up my amp
- polishing hu?
- Amp rack comparison
- odometer,radio, power hatch inop..help
- Backlight on monsoon deck went out
- Antenna swap
- 1987 TA turn signals not working, flasher replaced...help
- dash voltmeter
- Help!! t/a wont start :(
- Look What UPS drop off
- Alarm going off
- Proposed Monsoon system overhaul & carPC build
- Anyone using Ensolite IUO?
- For Those with In-Dash DVD Headunits
- Big 3
- Amp Suggestions and deck install
- Reversed factory radio volume control?
- Big 3 pre-made wire package website?
- Help with Monsoon sound distortion
- "q logic" bass system
- DVC coil wiring
- keeaudio
- putting stock back in
- OnStar FMV now available for install at DD MODS
- 12" Stealth enclosure?
- vin on gauge cluster?
- Monsoon problem!!!
- Capacitor or higher amperage alternator?
- Alternatives to using Pioneer CD changer with Pioneer head unit?
- covering a sub box with fabric Q
- Aftermarket amp with CDT Audio EU-61CV components
- Rattling from speaker behind driver seat
- Phone mounting bracket question.
- Lights dimming / car alarm
- how to cut a perfect circle for my 10 inch sub
- Window Problem
- check out what UPS dropped off today...
- C5 Double Din install pic of the year! One of the best to date!
- Broken Antenna
- radio dash??
- What do you think about this setup?
- Deck mount
- Alarm Question
- Security light issues!!!
- custom chime sounds
- Free set of Speakers! Who wants them!
- Distribution block.
- My stereo doesn't turn on right away sometimes. (electrical problem)
- Overheating Amps?
- alarm will not disarm...ever. HELP
- What would it take to have LED tails manufactured for the 93-2002?
- Speaker install?
- Turn signal issue
- Wierd Electric Whine
- 2002 Camaro V6 without Monsoon radio NEED HELP!
- Old School Orion Sub Specs
- Check THIS out! Custom iPhone dock
- Battery relocation blowing fuses. I need help
- Alternate Headlight Lifters?
- LF a product....
- Hooking up amp and subs
- 99 Firebird coupe wiring question
- Buying used equipment
- Deleting the factory bose stuff?
- Front speaker suggestions for this amp?
- Kenwood DDX-318 Double DIN installed-PICS***
- Luxury liner pro (second skin)
- power, ground for a pillar gauges
- removing stock cd changer
- backup camera install??
- Some questions about sound deadening doors
- Radio issues!!!
- Stereo and windows don't work for 10 seconds
- Speakers went out.
- Alt rebuild anyone
- another door speaker replacement thread....
- audiopipe TSVR6 review
- Monsoon HU volume knob
- Ordered a KD-R900 JVC H/U for $145!!!
- NEW ABS Tweeter Pods!!!
- Does anyone have the HELM INC manual for a '99 Camaro?
- Looking for white humount pics
- Pioneer TS-A1672R speakers?
- 99TA, No Right and Left adjustment on Fogs?
- remote Start help
- A better approach for Firebird Headlight Doors?
- Tweeter/Crossover mounting pics
- Monsoon LF speaker problem-sounds like it is blown
- double din in a 98 camaro
- LED Interior Kit?
- installing new sony HU
- Lost all HVAC and door panel lights??
- Suddenly no rear park lights and dash lights???
- I replaced the monsoon stuff plus I saved alot of weight
- Need help picking a new DD HU
- Stereo wired parallel?
- Window Differences
- Difference between vert and t-top monsoon amp?
- stock headunit harness hacked...
- can anyone help me?
- GM9-AUX wont work after not using
- Speakers !!!!
- Radio, blinkers and windows randomly wont work
- Ongoing gauge woahs...
- cd changer wont eject
- Continuing my sound system upgrades
- monsoon amp, how bad really??
- 451m
- Fi Q with 1000rms in a driver's side stealthbox
- SOUND dampening - Square foot question
- Stubby Antenna
- Problems with remote atart
- New sound system recommendations
- mounting amps under rear seats...?
- Hydrocarbon Camaro Double Din bezels now available!(pics)
- gages
- l5/l7 stealth box please.
- Monsoon problem
- T/A & Corvette, subwoofer questions. Experts come inside
- Need some help with a elec. problem
- looking for lighted install kit
- rebuilt alternator
- 6LE!??!! Where are the Double Dins! help!
- New speaker setup
- Newb stereo question:
- Coil for system?
- Kenwood Garmin Rebates up to $300.00 5/1-7/31
- Fog lights!
- Updating old HU install thread
- Want to find a nice looking switch for my cutous
- Stock tape deck to stock cd player swap
- installing line level converter...exactly which wires
- A few things not working..
- No more subthump????????
- alpine KTP powerpack compatible with monsoons?
- Window Motor (already searched/sticky)
- What battery charger for an AGM battery?
- audio newb, NEED HELP!!!
- audiopipe TSVR6??
- Stock radio cuts out. Keeps my windows from working lol
- why is my subwoofer doing this????
- How to connect multiple amps to factory stereo??
- Aha Radio with the new Pioneer X930 and Z130 VIDEO
- Gauge lights day time running and tail lights out!!
- Attempted to take my drl/trun sigs out but..i got stuck..need help??
- Another sound deadener product question...
- New Setup
- What H/U has all of these things?
