View Full Version : Pontiac GTO 2004-2006
- Ls2 wiring
- 6L80 GTO is happening!!
- Question before picking up a GTO
- Procharger... Magnacharger...
- Shifter
- Warm weather electrical issue
- 2005 GTO Radiator and fans question
- CSP End Of Year BLOWOUT!
- side marker lights / Fog lights
- So this happened......
- 05 gto hood
- 2004 exhaust question
- Fuel pump relay
- Am I Lazy?
- 05 goat irs
- 2005 rebuild
- 2005 M6 clutch problem
- Fuel sending unit and return line
- Does a Gto have a smaller alternator case size
- 2004 Gto brake line fitting size?
- Flow numbers Old and New
- Complete Street Performance Fall Specials
- do all GTOs have AFM/DOD
- Need help with 2004 Pontiac GTO
- 04 gto muffler delete, most economical way to reduce de cell pop
- PCM Torque Converter Control
- PCM pinouts for torque control
- Want to posted wanted ad ?
- Loose plastic steering wheel cover 2006 gto
- Home made real cold air intakes ?
- rear tires?
- Magnaflow mufflers FS???
- 1/4 mile platform - GTO?
- Supercharged Summer Special
- Pinion nut for Motive 3.90's?
- Clutch slave cylinder on 04 GTO, AGAIN
- Shifting Issues -- 2005 M6
- Removing ECU?
- 402 stroker
- Key Stuck
- 18" spare tire
- 2004 GTO exhaust question...
- Need experienced advice
- will a truck converter fit?
- Cam sensor help!
- Rear coils on 04 GTO outstanding!
- Killer GTO burnout
- 15x8 drag wheels
- 2004 GTO MAF questions
- A/c problems
- 2005 Pontiac GTO with Bobcat 455 setup.
- to build or not to build (4L60E)
- What motor
- gains with ported 243 cylinder heads
- 2005 Pontiac GTO with 16 miles on it
- chrome alternator?
- Wicked rear driver's side rub issues...
- Power problems sometimes
- Will they fit?
- 04 GTO fuel rail cover - original paint color code
- 04 GTO power steering cooler
- LS7 Clutch kit for 05 GTO
- Removing a single-peice driveshaft?
- i have multiple lights not working. shorted out drl. 2006 GTO
- Question about heads for boosted LM7
- The new guy with a question already, oil cooler lines.
- Soon to be GTO owner?
- What's the best size heads
- Corsa or magnaflow 3" comp series
- shocks/sturts and springs
- What does this wire do?
- NEW PB E.T and MPH!
- In DESPERATE need of your guys help
- Cam & Heads . Wanna buy some
- Gto overheating issue
- What did you do to your GTO today
- US OEM GTO shipping to AUS
- Help needed getting CARB Legal
- 05 GTO P0601 Code
- airbag srs fault
- Transmission cooler size for 2004 gto?
- Performance radiator, worth it?
- Power steering hose NLA ?
- T56 trans for sale outright?
- Alternator Nut
- Hinson Motorsports: Tried Numerous times Contacting them
- Best Replacement Brakes and Rotors?
- 2004 gto potential buy
- Installed Cheap eBay Grilles on my 2006 GTO
- Smallest starter for 06 GTO LS2 T56?
- 5.3l or 6.0l swap in 2004 GTO
- Do I "need" a tune?
- WTT - GTO front rts 17x8 for 17x5
- Mutant I and Mutant II
- 05 GTO Transmission ID
- Moser M9 Fabricated 9 Inch at Brute Speed
- 05 Speedometer calibration
- 4L65E help needed
- Guys need you help on my 04 GTO 60k miles
- Best bolt on parts for my 06 GTO??
- 04 identity issues?
- Poly trans mount experience
- Delete
- MAF issues and a few other things.
- TH400/TH350 with stock shifter?
- Kooks headers vs steering knukle
- Did I seriously get a lemon or what???
- Got wheels, final tire decisions
- dumb question-Exhaust
- t-56 HELP!
- Thinking about a new daily driver
- Anyone running coil overs for street use? Looking for a suspension for 04 GTO
- Set of skinnies and rears!!
- 04 GTO problems
- just bought a gto, already first issue
- OEM 05 Hood on my 04
- 04 cruise
- I feel dumb...
- Looking for a boot lid / deck lid spoiler
- What strut brace is this?
- What suspension are people running for lowering kits
- looking to possibly buy?
- Holdens vs the Tail of the Dragon
- procharged gto times
- 2004 Vauxhall GTO w/cam help me find old owner
- Possible suspension issues?
- Finding a correct fitting guage pod
- Front plate solution?
- 5.3 4L60E swap into 04 GTO
- 04 GTO High Idle After Cam Install
- 2004 gto serious problem
- My First HCI Build.. Thank you Vengeance Racing
- Trickle charger typical for everyone who does not DD their GTO?
- 05 gto 150 shot e85
- All cleaned up...
- Electrical gremlins needing some assistance
- My Best Pass in the GTO so far
- Transmission problem?
- Stumble when warm when taking off
- GTO Evaporator Core
- 1 pc DSS driveshaft.
- No start
- Converting rear to split duals
- Picked up an 04 Torrid Red
- Improving my Goat's high RPM reliablility
- 2006 gto frequency receiver
- Flashing CEL after cam
- Realistic costs for a rear end rebuild?
- Advice taken, new price is 20K
- Flexible dipstick options?
- Do headers make a big difference on a 04 GTO
- Does the '00/'02 Camaro/Corvette alternator fit the '04 GTO?
- Finally installing my cam, but a few ?'s
- Catback require tune?
- Best Cam Kit for good street Use!!!
- x275 drag radials
- Oil consumption problems at 77.5K?
- 04 gto headers
- Complete Street Moving Special
- The differential adventure begins
- Just about ready to sell my Goat...
- M6 GTO Driveline Reliability
- Sometimes wont go into gear or grinds
- spec stage 3 launch help
- help with valvetrain??
- Tiger body kit???
- Installing 2006 GTO engine and transmission along with headers
- Collision repair on 2005 GTO
- Can someone please just humor me...
- Battery? Alternator? Starter?
- LS2 (2005 GTO) Gasket Kit - Is this any good?
- O2 sensor/trans pan
- Hinson DS??
- trade in thoughts?
- 04' GTO Budget Build
- Rear shock mount
- Knock sensors
- 06 gto vs V1 looking at buying one
- subwoofer in trunk?
- Leaking Dot 4 Fluid Beneath center of Bell Housing
- trailblazer ss driveshaft in a gto
- Longtubes
- Fast 102 with aero oil pressure adapter
- 2005 ls2/4l65e into 2004 GTO
- Professional products typhoon intake and fuel rails HELP!
- bad ds carrier bearing causing wheel hop?
- 2004-2006 GTO shift boot. Trunk Monkey Parts.
- Before you buy a driveshaft
- GFroce1320 or Drivesahft Shop?
- What to do with a mostly complete wiring harness?
- Drivetrain Reliability Question
- Attention Oklahoma GTO owners.....The OK GOAT HERD is back!!!
- strut and shock time
- head selection
- Knock Sensor Tuning
- Help....O2 sensors
- Trying to decide on wheels and suspension.
- The Money Shift
- Reverse Lockout
- Looking for advice on finishing suspension work
- Heater core leaking
- CSP Beat The Heat Header Special!
- Longtubes options
- Chick GTO Drifter
- New GTO owner looking for exhaust.
- ls2 to ls1 Swap
- 04/05 Purchase Decisions: which would you?
- Overheating issue
- champoin drag wheels
- 383 stroker install
- who makes this splitter?
- Issues with Koni shock installation
- Looking to go catless this year!
- trimming the fat
- CX Racing Twin Turbo Kit, a learning opportunity?
- 06 GTO pin out.
- 04 or 05 GTO
- Fuzzy instrument cluster
- oil taking a while to ciculate no oil light
- 05 gto random missfire
- LS2 Goat
- Stock shift knob questions
- Holiday special from Livernois Motorsports
- Suspension Bushings?
- LS2 crank pulley wobble/chirp
- motor swap choices
- traded it in
- A little fun in the GTO
- 04 GTO Starter
- Is the power steering between 04 GTO and 04 5.3 Silverado the same?
- Its time M6 to TH400/350...But i need help
- lifter ticking
- 275/40/17 on a goat
- Need some help- No start, no interior power
- Throttle issues...
- bought myself an early Bday present
- The 1st GTO to go 200 MPH at The Texas Mile
- zl1 on a goat
- 2004 GTO - 05/06 Brake swap or just use Corvette pads in front?
- Cold Case Radiator
- Putting back stock mufflers
- Video of girl dropping tranny, replacing clutch slave + remote bleeder inst
- Trans Help!!!
- P0335, TCS turns off, and crank/no start or start then die.
- Stumbles under load
- swapping a t56 to 4L60e
- 2005 GTO Rear brakes dragging
- Newer guy here
- My 2004 GTO "GTO8U"
