View Full Version : Conversions & Hybrids
  1. 96 camaro lt1 to ls1 swap
  2. New to forum and engine building
  3. 1969 Nova LS3/Auto
  4. 4th Gen F-body LS1 Brakes to early GM Cars ?
  5. Which starter do I need?
  6. gas tank / fuel pump solution?
  7. Fly by Wire PCM on cable T/B Engine?
  8. 1998 s-10 5.3l 4l60e
  9. LS2 TBSS: swapable accessories?
  10. lq4 swap into 1979 camaro (twitchy steering )
  11. 1989 BMW 325i LS2 6.0 swap
  12. 2008 into a 92 Camaro, harness question......
  13. ls1 to 5.3 crysist
  14. LS1 in a mustang, i need fuel help
  15. 1964 Chevelle LS1/T56 swap
  16. LS/S197Mustang/trans selection
  17. Modify LS1 stock oilpan for 70 Chevelle
  18. 5.3 swap in a k5 blazer, Fuel delivery questions
  19. Switchable V4 Mode on a LQ4?
  20. Any Ford rangers with ls motors
  21. LS1 tach signal pull up mod using stock LT1 tach guage cluster
  22. Anyone in Los Angeles area can help me with wiring?
  23. Cleaning outside of aluminium block?
  24. alt. wiring
  25. Does anyone know where I can get this???
  26. lsx 240z people I need help
  27. Dah, hood will not close with truck intake
  28. Real World Fuel Economy. What have you gotten with your swap?
  29. fuel lines for flex
  30. 78 El Camino 6.0L build
  31. 79 z28 needs help w/few conversions
  32. School me please.
  33. How Noisey/Loud are extrenal pumps?
  34. vss for a ford t5?
  35. i need help with my lsx blazer.
  36. ls swaped into suv
  37. 1966 Mustang LSx
  38. F-body radiator measurements?
  39. New BRP Mid Length Headers for sale $450 Shipped '64 to 72 Abody
  40. Autometer Tach Reading High
  41. conversion wiring help
  42. 1975 nova ls1 5.3
  43. F body pan - available in kit form?
  44. Alternator pigtail
  45. Gauging Interest: Rick's Vaporworx Tank, A-body Suspension, CPP Big Brake Kit, etc...
  46. Ls swap into 1956 Cadillac 62 series questions
  47. Caprice LQ4 swap engine tick??
  48. LS3 Intake map sensor options??
  49. Lt1 to 5.3l, to ??? What would you do.
  50. 71 chevelle L92/tko600
  51. New to swaps
  52. hybrid swap ecu question?
  53. 67 C10 painless wiring questions?
  54. ls1 in 75 nova header questions
  55. Ideas
  56. 68 camaro LS twin turbo
  57. fuel filter fittings ???
  58. LS in a 67 nova with TCI clip which oil pan??
  59. Oil pan to crossmember clearance?
  60. PCM wiring help
  61. Coil Spring Reccomendation
  62. new issue...
  63. 72 chevelle and truck motor
  64. LS3 Swap 59 Impala - VSS problems
  65. ls motor mount in 68 camaro
  66. 5.3 swap
  67. Wiring
  68. need a little help/ideas on a conversion
  69. 1st gen camaro ls1 twin screw fitment
  70. Ls1 harness to Multec 2 injectors
  71. Bought the LH8 pan and accessories - is there..
  72. ls1 into 1972 el camino
  73. V6 to V8 Kits
  74. Difficulty Level - 3rd Gen V6/auto LS swap?
  75. PROJECT MARCEL..finallly begins! '88 RCSB LQ4/LS3 t56 swap
  76. Does any one sell headers for an ls1 in a Chevy luv truck?
  77. What to do with my 85 camaro Im loosing interest in it...
  78. Ls1 questions - 75 nova
  79. DSE clutch master cylinder advice???
  80. could somebody take a measurement for me? Crankshft bolt height on a foxbody w/LSx
  81. Need some advice. Defective LS2, need engine selection help.
  82. What master cylinder should I use?
  83. lm7 to 5 speed
  84. 34 coupe on vette suspension and drive line
  85. My Twin Turbo 1968 Chevelle Build Start to Finish- Lots of Pics!
  86. 5.3 Swap Motors
  87. first 240 swap upcoming!!!
  88. First LS Porsche boxster!!
  89. will a 05 4l60e work with 01 wiring
  90. cam swap questions on 5.3
  91. Re-work my harness
  92. 532whp & 9.670 Second 1/4! (LS1 350z)
  93. 1993 Toyota 4X4 Turbo LS1
  94. Hunting LY6/6L90 bolts?
  95. 6.0L broken starter tab
  96. F body pan for A body swap ?
  97. 66 Chevy II LS1, back at it.
  98. Over full port on the gas tank
  99. Fuel tank pressure and level sensors
  100. Change water pump ??
  101. Another ls1 fox swap.
  102. CTS-V oil pan 76-96 b body?????
  103. 455" LSX 1971 Trans Am clone project
  104. 70 Chevelle LQ4/T56 Build
  105. Tach bouncing
  106. 5.3 4l60e swap into my RUSTY '71 C-10
  107. Nissan 240 Drift Build from Turbo to LS1
  108. Coil wiring/plug wiring?
  109. High Flow Water Pumps
  110. LS turbo swap in fox body questions
  111. Junkyard NA 240SX in the 10's
  112. C6 Z06 Vs LS1 280z
  113. Motor Mounts and Headers for 64 Malibu SS
  114. CTS-V or ZL1 LSA Accessory Belt Offset / Position??
  115. LS1 Land Rover Discovery II?
  116. Sec Gen F-body Induction Ideas?
  117. Separate Neutral Safety switch required?
  118. Confirm LS1 Tech output Voltage?
  119. Engine Run Stand Rev2
  120. 240 Wagon Lm7/t56 build
  121. Truck exhaust manifolds fit B-body?
  122. Dumb Newbie Questions I'm Sure
  123. Help with gas gauge
  124. Coated header help...
  125. Best MAF sensor to use with LS3 Swap into a 98 SS
  126. F-body fans
  127. Thoughts on using a stand a lone harness in a 1995 z28
  128. Convert LM4 5.3 from DBW to DBC?
  129. Another LS240sx
  130. LT1 to LSX conversion: Wiring harness question
  131. Which cruise control module do I need?
  132. What shifter are you using with a 4l80
  133. Need Spark Plug Wires for 69 Camaro w/ LS2 & Stainless Works Headers
  134. fuel pump
  135. alternator fix?
  136. ls1 into 97 z28
  137. ls1 foxbody help?
  138. Anyone have a part number for the Cadillac CTS-V intake duct?
  139. Chevelle guys, I need some help...
  140. Tach and speedo jumping
  141. Looking for suggestions for mounting Mike Norris PCV catch can
  142. Porsche 944 with 5.3 LM4
  143. ebay headers
  144. 2nd Gen Trans Am LS1/T56 swap Questions
  145. 2002/1982 Chevy c10
  146. motor mount power angle
  147. sn95/new edge guys, throttle cable?
  148. BUILD THREAD 'Project Hard Knock' 1999 SS
  149. what length pushrods
  150. ls1 fuel filter kit?
  151. 96 mustang gt vert 5.3 swap
  152. 5.3 s10
  153. Using truck coil packs with ls1 rail
  154. Twin Turbo Chevelle Possibly For Sale? Any Interest?
  155. to complete cars need help
  156. 96 mustang swap help
  157. 1973 Kona jet boat 5.3 conversion
  158. Help with fox mustang fuel line to AN6 fitting
  159. LS2 Questions...
  160. Swap in 84 Regal
  161. 84 chevy truck lsx swap parts list
  162. 1960 Biscayne LS1 swap thread
  163. T-56 s14 help
  164. 6.0/4L80E swap in 74' Bronco
  165. Pics of 6.0 in 1963 Plymouth Valiant tube chassis
  166. Cam for 5.3L 82 CJ7?
  167. aluminum drive shaft
  168. lq4/400th 1971 c10
  169. Lq4 truck with returnless???
  170. 1960's cars/trucks with LSx swaps
  171. Trying to figure out best cam/stall options for foxbody
  172. Harness question
  173. 6.0lq4/4l80e Catera
  174. Does this spark plug look good?
  175. My 1969 Camaro Prostreet Twin Turbo Build..
  176. Thinking of swapping an 80s Conquest TSI.
  177. picking an engine
  178. LY6 Running Too Cool?
  179. What high flow fuel filter R U guys running
  180. check out my 408 carb'd ls motor in the parts section
  181. 45723 hustler mid length header third gen fbody ls swap
  182. Fuel Sender AN Fitting - Compression or Weld
  183. 2000 silverado NSS schematic
  184. The 1970 Camaro LS build begins
  185. Help Wanted: Trans issue on 4l70e
  186. 1968 Chevelle LQ4 Build
  187. Dash Harness grab?
  188. LQ4 fox body.....turbo or nitrous?
  189. Fuell cell or stock tank for g-body swap?
  190. Triple BBBs
  191. KOOKS DYNATECH slip on exhaust?
  192. LT1 to LS1 Conversion...Low Oil Light?
  193. ?s on AN flaring alum. tubing.
  194. Calling A-bodies w/Impala tank, help me solve my leak!
  195. 04 LS1 GTO Wiring in 51 Pickup
  196. 01 ZR2 Sonoma 6.0L conversion - filter/reg problems
  197. FI harness, whats idiot proof and cheap
  198. amp drawn lsx swap
  199. E38, E67, E40, ETC Factory ECM Harness connector info
  200. 67-69 Camaro LSx motor mounts, help ?
  201. On3 lsx swap turbo kits
  202. Which coil packs fit Corvette covers?
  203. 4L60E Park/Neutral safety switch HELP
  204. Which Oil filter to Use
  205. Properly connecting vacuum lines on an LS2
  206. What should I take from donor car fbody swap
  207. 1985 Monte Carlo SS 6.2l (ls3) / 4l80e swap
  208. Lq4 with ls1 accessories,please help!
  209. LS1 Swap into a 1977 Chevy "Shorty" Van
  210. need spring rates for nova
  211. 69 Camaro LSX Swap
  212. Alt. bracket help!!
  213. Ca Legal 4.8L/5.3L Swap
  214. Need help identifiying a squealing
  215. Blueprints / dimensions for LS bellhousing?
  216. Dry sump oil-tank placement.
  217. Dakota Digital wireing need help
  218. any other REAL Cadillacs out there with a ls swap?
  219. Engine RPM
  220. Another ls swapped coupe AKA Round Three
  221. Looking for a quick run down on what u need to put lq4 in 4.3 sierra
  222. 04 Envoy EXT 4X4 5.3 - not suitable for swapping?
  223. 98 s10 4.8 now 5.3/4L60E swap
  224. LS into my 1973 Oldsmobile Omega X body car
  225. Odd balancer question
  226. Automatic in 1st Gen CTS-V or LS/auto swapped CTS?
  227. 240sx 76mm 5.3L TH350 E85 "Pics & Vids"
  228. 57 Chevy and 4l80e
  229. Steam Vent...Thoughts on where to plumb it?
  230. What are you guys using? Stock computer, XFI, Holley...
  231. MSD Coils
  232. A body throttle cable
  233. Air inlet
  234. Initial start (LQ4) bad noises! video
  235. Stretching radiator core support
  236. '69 FJ40 LM7/SM420 build
  237. How many of you are still using dexcool
  238. Best Plug Wires with Headers
  239. Sanden 508 Air Compressors
  240. LS Brakes on a 71 Nova
  241. help with fuel pump wireing
  242. 84 monte SS 6.0 swap
  243. What size hood for fox body with lq4?
  244. 84 s10 ( need cam help and motor)
  245. TT 4.8 cam selection
  246. Trade Turbos?
  247. Silverado hydroboost swap ?s
  248. 3rd gen carb swap lq9 wiring ?
  249. The great psi t-shirt giveaway
  250. WARNING: eBay starter comes with one M10 x 1.5 bolt and one 3/8 x 16 SAE bolt
